SalomeHPContainer.cxx
20#include "SalomeHPContainer.hxx"
21#include "SalomeHPComponent.hxx"
23#include "AutoLocker.hxx"
24
25#include <algorithm>
26#include <utility>
27
28using namespace YACS::ENGINE;
30const char SalomeHPContainer::KIND[]="HPSalome";
31
32SalomeHPContainer::SalomeHPContainer():_shutdownLevel(999)
33{
34}
35
36SalomeHPContainer::SalomeHPContainer(const SalomeHPContainer& other):_componentNames(other._componentNames),_shutdownLevel(999),_sct(other._sct),_initScript(other._initScript)
37{
38}
39
41{
43 int nbOfWorkers(getPG()->getNumberOfWorkers(this->getNumberOfCoresPerWorker()));
44 this->setSizeOfPool(nbOfWorkers);
45}
46
48{
50}
51
53{
54 return _launchModeType.size();
55}
56
58{
60}
61
62class PairVecIterator : public std::iterator<
63 std::input_iterator_tag, // iterator_category
64 std::pair<const Task *,std::size_t>, // value_type
65 long, // difference_type
66 const std::pair<const Task *,std::size_t>*, // pointer
67 std::pair<const Task *,std::size_t> > // reference
68{
69 const std::vector< const Task *> *_v0;
70 const std::vector<std::size_t> *_v1;
71 std::size_t _num;
72public:
73 explicit PairVecIterator(const std::vector< const Task * > *v0, const std::vector<std::size_t> *v1, const std::size_t num) : _v0(v0),_v1(v1),_num(num) { }
74 PairVecIterator& operator++() { _num++; return *this; }
75 bool operator==(PairVecIterator other) const { return _num == other._num; }
76 bool operator!=(PairVecIterator other) const { return !(*this == other); }
77 reference operator*() const { return std::pair<const Task *,std::size_t>((*_v0)[_num],(*_v1)[_num]); }
78};
79
80void SalomeHPContainer::allocateFor(const std::vector<const Task *>& nodes)
81{
82 std::vector<std::size_t> workerIdsAllocated(getPG()->allocateFor(nodes.size(),this->getNumberOfCoresPerWorker()));
83 std::vector<std::pair<const Task *,std::size_t>> nodesAndIds(PairVecIterator(&nodes,&workerIdsAllocated,0),PairVecIterator(&nodes,&workerIdsAllocated,nodes.size()));
85}
86
88{
89 std::size_t workerId(_launchModeType.release(node));
90 getPG()->release(workerId,this->getNumberOfCoresPerWorker());
91}
92
94{
95}
96
97std::string SalomeHPContainer::getKind() const
98{
99 return KIND;
100}
101
102std::string SalomeHPContainer::getDiscreminantStrOfThis(const Task *askingNode) const
103{
105 return tmpCont->getDiscreminantStrOfThis(askingNode);
106}
107
108bool SalomeHPContainer::isAlreadyStarted(const Task *askingNode) const
109{
111 return helper->isAlreadyStarted(askingNode);
112}
113
114void SalomeHPContainer::start(const Task *askingNode)
115{
119}
120
122{
123 if(level < _shutdownLevel)
124 return;
125 _shutdownLevel=999;
126 for(std::size_t i=0;i<_launchModeType.size();i++)
127 {
129 helper->shutdown();
130 }
131}
132
133std::string SalomeHPContainer::getPlacementId(const Task *askingNode) const
134{
135 const SalomeContainerMonoHelper *helper(nullptr);
136 {
137 std::lock_guard<std::mutex> lg(getPG()->getLocker());
138 helper=_launchModeType.getHelperOfTask(askingNode);
139 }
140 return SalomeContainerTools::GetPlacementId(helper,this,askingNode);
141}
142
143std::string SalomeHPContainer::getFullPlacementId(const Task *askingNode) const
144{
145 const SalomeContainerMonoHelper *helper(nullptr);
146 {
147 std::lock_guard<std::mutex> lg(getPG()->getLocker());
148 helper=_launchModeType.getHelperOfTask(askingNode);
149 }
150 return SalomeContainerTools::GetFullPlacementId(helper,this,askingNode);
151}
152
157{
158 incrRef();
159 return const_cast<SalomeHPContainer*>(this);
160}
161
163{
164 return new SalomeHPContainer(*this);
165}
166
167void SalomeHPContainer::setProperty(const std::string& name,const std::string& value)
168{
169 if(name==AOC_ENTRY)//no sense to set it ! It is always true ! ignore it !
170 return ;
171 else if(name==SIZE_OF_POOL_KEY)
172 {
173 std::istringstream iss(value);
174 int val(0);
175 iss >> val;
176 setSizeOfPool(val);
177 }
178 else if(name==INITIALIZE_SCRIPT_KEY)
179 {
180 _initScript=value;
181 }
182 else
183 _sct.setProperty(name,value);
184}
185
186std::string SalomeHPContainer::getProperty(const std::string& name) const
187{
188 if(name==AOC_ENTRY)
189 {
190 return std::string("1");
191 }
192 else if(name==SIZE_OF_POOL_KEY)
193 {
194 std::ostringstream oss; oss << getSizeOfPool();
195 return oss.str();
196 }
197 else if(name==INITIALIZE_SCRIPT_KEY)
198 {
199 return _initScript;
200 }
201 else
202 return _sct.getProperty(name);
203}
204
206{
207 _initScript.clear();
209}
210
211void SalomeHPContainer::addComponentName(const std::string& name)
212{
213 _componentNames.push_back(name);
214}
215
216std::map<std::string,std::string> SalomeHPContainer::getProperties() const
217{
218 std::map<std::string,std::string> ret(_sct.getProperties());
219 std::ostringstream oss; oss << getSizeOfPool();
220 ret[SIZE_OF_POOL_KEY]=oss.str();
221 if(!_initScript.empty())
223 return ret;
224}
225
226std::map<std::string,std::string> SalomeHPContainer::getResourceProperties(const std::string& name) const
227{
228 return _sct.getResourceProperties(name);
229}
230
232{
234 throw Exception("SalomeHPContainer::checkCapabilityToDealWith : SalomeContainer is not able to deal with this type of ComponentInstance.");
235}
236
237std::vector<std::string> SalomeHPContainer::getKernelContainerNames() const
238{
240}
241
243{
245}
const std::vector< std::size_t > * _v1
const std::vector< const Task * > * _v0
PairVecIterator(const std::vector< const Task * > *v0, const std::vector< std::size_t > *v1, const std::size_t num)
PairVecIterator & operator++()
Return the component kind.
static const char AOC_ENTRY[]
Definition: Container.hxx:88
virtual void assignPG(const PlayGround *pg)
void release(std::size_t workerId, int nbCoresPerCont) const
Definition: PlayGround.cxx:210
std::size_t getNumberOfFreePlace(int nbCoresPerCont) const
Definition: PlayGround.cxx:184
bool isAlreadyStarted(const Task *askingNode) const
static SalomeContainerTmpForHP * BuildFrom(const SalomeHPContainer *cont, const Task *askingNode)
static std::string GetPlacementId(const SalomeContainerHelper *launchModeType, const Container *cont, const Task *askingNode)
static void Start(const std::vector< std::string > &compoNames, SalomeContainerHelper *schelp, SalomeContainerToolsBase &sct, int &shutdownLevel, const Container *cont, const Task *askingNode)
static std::string GetFullPlacementId(const SalomeContainerHelper *launchModeType, const Container *cont, const Task *askingNode)
std::map< std::string, std::string > getResourceProperties(const std::string &name) const override
std::string getProperty(const std::string &name) const override
const std::map< std::string, std::string > & getProperties() const override
void setProperty(const std::string &name, const std::string &value) override
const SalomeContainerMonoHelper * at(std::size_t pos) const
const SalomeContainerMonoHelper * getHelperOfTaskThreadSafe(const SalomeHPContainer *cont, const Task *node) const
std::vector< std::string > getKernelContainerNames(const SalomeHPContainer *cont) const
void allocateForCrude(const std::vector< std::pair< const Task *, std::size_t > > &nodes)
const SalomeContainerMonoHelper * getHelperOfTask(const Task *node) const
void checkCapabilityToDealWith(const ComponentInstance *inst) const
std::string getPlacementId(const Task *askingNode) const
std::vector< std::string > getKernelContainerNames() const
void allocateFor(const std::vector< const Task * > &nodes)
std::vector< std::string > _componentNames
std::map< std::string, std::string > getProperties() const
void release(const Task *node) override
void start(const Task *askingNode)
void assignPG(const PlayGround *pg) override
std::string getDiscreminantStrOfThis(const Task *askingNode) const
SalomeHPContainerVectOfHelper _launchModeType
std::string getFullPlacementId(const Task *askingNode) const
std::size_t getNumberOfFreePlace() const
void addComponentName(const std::string &name)
