YACS::ENGINE::SalomeContainerMonoHelper Class Reference
#include <SalomeContainerHelper.hxx>
Inheritance diagram for YACS::ENGINE::SalomeContainerMonoHelper:
Collaboration diagram for YACS::ENGINE::SalomeContainerMonoHelper:
 SalomeContainerMonoHelper ()
std::string getType () const
std::string getDftLaunchMode () const
SalomeContainerMonoHelper * deepCpyOnlyStaticInfo () const
Engines::Container_var getContainer (const Task *askingNode) const
bool isAlreadyStarted (const Task *askingNode) const
void setContainer (const Task *askingNode, Engines::Container_var cont)
bool isKernelContNull () const
void shutdown ()
std::string getKernelContainerName () const
virtual std::string getType () const =0
virtual std::string getDftLaunchMode () const =0
virtual SalomeContainerHelper * deepCpyOnlyStaticInfo () const =0
virtual Engines::Container_var getContainer (const Task *askingNode) const =0
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void setContainer (const Task *askingNode, Engines::Container_var cont)=0
virtual void shutdown ()=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char TYPE_NAME [] ="mono"
static const char DFT_LAUNCH_MODE [] ="start"
 ~SalomeContainerMonoHelper ()
Engines::Container_var _trueCont
- Protected Member Functions inherited from YACS::ENGINE::SalomeContainerHelper
virtual ~SalomeContainerHelper ()
 RefCounter ()
virtual ~RefCounter ()
unsigned int _cnt
Definition at line 55 of file SalomeContainerHelper.hxx.
◆ SalomeContainerMonoHelper()
SalomeContainerMonoHelper::SalomeContainerMonoHelper ( )
Definition at line 44 of file SalomeContainerHelper.cxx.
44 :_trueCont(Engines::Container::_nil())
45{
46
47}
Referenced by deepCpyOnlyStaticInfo().
◆ ~SalomeContainerMonoHelper()
SalomeContainerMonoHelper::~SalomeContainerMonoHelper ( )
Definition at line 116 of file SalomeContainerHelper.cxx.
117{
118}
◆ deepCpyOnlyStaticInfo()
SalomeContainerMonoHelper * SalomeContainerMonoHelper::deepCpyOnlyStaticInfo ( ) const
◆ getContainer()
Engines::Container_var SalomeContainerMonoHelper::getContainer ( const Task *  askingNode) const
Implements YACS::ENGINE::SalomeContainerHelper.
Definition at line 64 of file SalomeContainerHelper.cxx.
65{
66 return _trueCont;
67}
References _trueCont.
◆ getDftLaunchMode()
std::string SalomeContainerMonoHelper::getDftLaunchMode ( ) const
Definition at line 54 of file SalomeContainerHelper.cxx.
55{
56 return std::string(DFT_LAUNCH_MODE);
57}
References DFT_LAUNCH_MODE.
◆ getKernelContainerName()
std::string SalomeContainerMonoHelper::getKernelContainerName ( ) const
Definition at line 107 of file SalomeContainerHelper.cxx.
108{
109 if(CORBA::is_nil(_trueCont))
110 return std::string("NULL");
111 CORBA::String_var containerName(_trueCont->name());
112 std::string ret(containerName);
113 return ret;
114}
◆ getType()
std::string SalomeContainerMonoHelper::getType ( ) const
Definition at line 49 of file SalomeContainerHelper.cxx.
50{
51 return TYPE_NAME;
52}
References TYPE_NAME.
◆ isAlreadyStarted()
bool SalomeContainerMonoHelper::isAlreadyStarted ( const Task *  askingNode) const
Definition at line 69 of file SalomeContainerHelper.cxx.
70{
71 if(CORBA::is_nil(_trueCont))
72 return false;
73 else
74 return true;
75}
Referenced by YACS::ENGINE::SalomeHPContainer::isAlreadyStarted().
◆ isKernelContNull()
bool SalomeContainerMonoHelper::isKernelContNull ( ) const
Definition at line 85 of file SalomeContainerHelper.cxx.
86{
87 return CORBA::is_nil(_trueCont);
88}
◆ setContainer()
void SalomeContainerMonoHelper::setContainer ( const Task *  askingNode,
Definition at line 77 of file SalomeContainerHelper.cxx.
78{
79 _trueCont=cont;
80#ifdef REFCNT
81 DEBTRACE(_trueCont->_PR_getobj()->pd_refCount );
82#endif
83}
References _trueCont, and DEBTRACE.
◆ shutdown()
void SalomeContainerMonoHelper::shutdown ( )
Definition at line 90 of file SalomeContainerHelper.cxx.
91{
92 if(CORBA::is_nil(_trueCont))
93 return ;
94 try
95 {
96 CORBA::String_var containerName=_trueCont->name();
97 INFO_MESSAGE("shutdown SALOME container: " << containerName);
98 _trueCont->Shutdown();
99 }
100 catch(...)
101 {
102 ERROR_MESSAGE("Unknown exception ignored." );
103 }
104 _trueCont=Engines::Container::_nil();
105}
Referenced by YACS::ENGINE::SalomeHPContainer::shutdown().
◆ _trueCont
Engines::Container_var YACS::ENGINE::SalomeContainerMonoHelper::_trueCont
◆ DFT_LAUNCH_MODE
const char SalomeContainerMonoHelper::DFT_LAUNCH_MODE ="start"
Definition at line 72 of file SalomeContainerHelper.hxx.
Referenced by getDftLaunchMode().
◆ TYPE_NAME
const char SalomeContainerMonoHelper::TYPE_NAME ="mono"
