YACS::ENGINE::SalomeHPContainer Class Reference
#include <SalomeHPContainer.hxx>
Inheritance diagram for YACS::ENGINE::SalomeHPContainer:
Collaboration diagram for YACS::ENGINE::SalomeHPContainer:
 SalomeHPContainer ()
 SalomeHPContainer (const SalomeHPContainer &other)
void assignPG (const PlayGround *pg) override
void setSizeOfPool (int sz)
int getSizeOfPool () const
std::size_t getNumberOfFreePlace () const
void allocateFor (const std::vector< const Task * > &nodes)
void release (const Task *node) override
void lock ()
 For thread safety for concurrent load operation on same Container. More...
void unLock ()
std::string getKind () const
std::string getDiscreminantStrOfThis (const Task *askingNode) const
bool isAlreadyStarted (const Task *askingNode) const
void start (const Task *askingNode)
void shutdown (int level)
std::string getPlacementId (const Task *askingNode) const
std::string getFullPlacementId (const Task *askingNode) const
Container * clone () const
Container * cloneAlways () const
void setProperty (const std::string &name, const std::string &value)
std::string getProperty (const std::string &name) const
void clearProperties ()
void addComponentName (const std::string &name)
std::map< std::string, std::string > getProperties () const
std::map< std::string, std::string > getResourceProperties (const std::string &name) const
void checkCapabilityToDealWith (const ComponentInstance *inst) const
std::vector< std::string > getKernelContainerNames () const
int getNumberOfCoresPerWorker () const
std::size_t locateTask (const Task *askingNode) const
const SalomeContainerTools & getContainerInfo () const
std::vector< std::string > getComponentNames () const
int getShutdownLev () const
SalomeContainerMonoHelper * getHelperOfTask (const Task *node)
const SalomeContainerMonoHelper * getHelperOfTask (const Task *node) const
- Public Member Functions inherited from YACS::ENGINE::HomogeneousPoolContainer
void attachOnCloning () const
void dettachOnCloning () const
bool isAttachedOnCloning () const
void setAttachOnCloningStatus (bool val) const
virtual void assignPG (const PlayGround *pg)
std::mutex & getLocker () const
virtual void setSizeOfPool (int sz)=0
virtual int getSizeOfPool () const =0
virtual std::size_t getNumberOfFreePlace () const =0
virtual void allocateFor (const std::vector< const Task * > &nodes)=0
virtual void release (const Task *node)=0
virtual int getNumberOfCoresPerWorker () const =0
- Public Member Functions inherited from YACS::ENGINE::Container
virtual std::string getKind () const =0
virtual std::string getDiscreminantStrOfThis (const Task *askingNode) const
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void start (const Task *askingNode)=0
virtual void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name)
virtual bool isUsingPythonCache ()
virtual void usePythonCache (bool v)
virtual std::string getPlacementId (const Task *askingNode) const =0
virtual std::string getFullPlacementId (const Task *askingNode) const =0
virtual void setAttachOnCloningStatus (bool val) const
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
virtual bool isAttachedOnCloning () const
virtual void lock ()=0
virtual void unLock ()=0
virtual Container * clone () const =0
 WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method More...
virtual Container * cloneAlways () const =0
virtual bool isSupportingRTODefNbOfComp () const
virtual void checkCapabilityToDealWith (const ComponentInstance *inst) const =0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name) const =0
virtual void clearProperties ()=0
virtual void addComponentName (const std::string &name)=0
virtual std::map< std::string, std::string > getProperties () const =0
virtual std::map< std::string, std::string > getResourceProperties (const std::string &name) const =0
virtual void setProperties (const std::map< std::string, std::string > &properties)
virtual std::string getName () const
void setName (std::string name)
 WARNING ! name is used in edition to identify different containers, it is not the runtime name of the container More...
void setProc (Proc *proc)
Proc * getProc ()
virtual void shutdown (int level)=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] ="HPSalome"
- Static Public Attributes inherited from YACS::ENGINE::HomogeneousPoolContainer
static const char SIZE_OF_POOL_KEY [] ="SizeOfPool"
static const char INITIALIZE_SCRIPT_KEY [] ="InitializeScriptKey"
- Static Public Attributes inherited from YACS::ENGINE::Container
static const char KIND_ENTRY [] ="container_kind"
static const char AOC_ENTRY [] ="attached_on_cloning"
static const char USE_PYCACHE_PROPERTY [] ="use_py_cache"
 ~SalomeHPContainer ()
- Protected Member Functions inherited from YACS::ENGINE::HomogeneousPoolContainer
 HomogeneousPoolContainer ()
virtual ~HomogeneousPoolContainer ()
const PlayGround * getPG () const
- Protected Member Functions inherited from YACS::ENGINE::Container
 Container ()
virtual ~Container ()
 RefCounter ()
virtual ~RefCounter ()
std::mutex _lock
int _shutdownLevel
SalomeContainerTools _sct
std::vector< std::string > _componentNames
SalomeHPContainerVectOfHelper _launchModeType
std::string _initScript
- Protected Attributes inherited from YACS::ENGINE::Container
bool _isAttachedOnCloning
Proc * _proc
unsigned int _cnt
Definition at line 44 of file SalomeHPContainer.hxx.
◆ SalomeHPContainer() [1/2]
SalomeHPContainer::SalomeHPContainer ( )
Definition at line 32 of file SalomeHPContainer.cxx.
Referenced by cloneAlways().
◆ SalomeHPContainer() [2/2]
SalomeHPContainer::SalomeHPContainer ( const SalomeHPContainer &  other)
Definition at line 36 of file SalomeHPContainer.cxx.
◆ ~SalomeHPContainer()
SalomeHPContainer::~SalomeHPContainer ( )
Definition at line 93 of file SalomeHPContainer.cxx.
94{
95}
◆ addComponentName()
void SalomeHPContainer::addComponentName ( const std::string &  name)
Implements YACS::ENGINE::Container.
Definition at line 211 of file SalomeHPContainer.cxx.
212{
213 _componentNames.push_back(name);
214}
References _componentNames.
◆ allocateFor()
void SalomeHPContainer::allocateFor ( const std::vector< const Task * > &  nodes)
Implements YACS::ENGINE::HomogeneousPoolContainer.
Definition at line 80 of file SalomeHPContainer.cxx.
81{
82 std::vector<std::size_t> workerIdsAllocated(getPG()->allocateFor(nodes.size(),this->getNumberOfCoresPerWorker()));
83 std::vector<std::pair<const Task *,std::size_t>> nodesAndIds(PairVecIterator(&nodes,&workerIdsAllocated,0),PairVecIterator(&nodes,&workerIdsAllocated,nodes.size()));
85}
void allocateForCrude(const std::vector< std::pair< const Task *, std::size_t > > &nodes)
void allocateFor(const std::vector< const Task * > &nodes)
References _launchModeType, allocateFor(), YACS::ENGINE::SalomeHPContainerVectOfHelper::allocateForCrude(), and YACS::ENGINE::HomogeneousPoolContainer::getPG().
Referenced by allocateFor().
◆ assignPG()
void SalomeHPContainer::assignPG ( const PlayGround *  pg)
overridevirtual
◆ checkCapabilityToDealWith()
void SalomeHPContainer::checkCapabilityToDealWith ( const ComponentInstance *  inst) const
Definition at line 231 of file SalomeHPContainer.cxx.
232{
234 throw Exception("SalomeHPContainer::checkCapabilityToDealWith : SalomeContainer is not able to deal with this type of ComponentInstance.");
235}
Return the component kind.
References YACS::ENGINE::ComponentInstance::getKind(), and YACS::ENGINE::SalomeHPComponent::KIND.
◆ clearProperties()
void SalomeHPContainer::clearProperties ( )
◆ clone()
Container * SalomeHPContainer::clone ( ) const
It is not a bug here ! clone for homogeneous container is not supposed to be copied !
Definition at line 156 of file SalomeHPContainer.cxx.
157{
158 incrRef();
159 return const_cast<SalomeHPContainer*>(this);
160}
References YACS::ENGINE::RefCounter::incrRef().
◆ cloneAlways()
Container * SalomeHPContainer::cloneAlways ( ) const
Definition at line 162 of file SalomeHPContainer.cxx.
163{
164 return new SalomeHPContainer(*this);
165}
References SalomeHPContainer().
◆ getComponentNames()
std::vector< std::string > YACS::ENGINE::SalomeHPContainer::getComponentNames ( ) const
Definition at line 83 of file SalomeHPContainer.hxx.
83{ return _componentNames; }
Referenced by YACS::ENGINE::SalomeContainerTmpForHP::BuildFrom().
◆ getContainerInfo()
const SalomeContainerTools & YACS::ENGINE::SalomeHPContainer::getContainerInfo ( ) const
Definition at line 82 of file SalomeHPContainer.hxx.
82{ return _sct; }
◆ getDiscreminantStrOfThis()
std::string SalomeHPContainer::getDiscreminantStrOfThis ( const Task *  askingNode) const
Reimplemented from YACS::ENGINE::Container.
Definition at line 102 of file SalomeHPContainer.cxx.
103{
105 return tmpCont->getDiscreminantStrOfThis(askingNode);
106}
static SalomeContainerTmpForHP * BuildFrom(const SalomeHPContainer *cont, const Task *askingNode)
References YACS::ENGINE::SalomeContainerTmpForHP::BuildFrom().
◆ getFullPlacementId()
std::string SalomeHPContainer::getFullPlacementId ( const Task *  askingNode) const
Definition at line 143 of file SalomeHPContainer.cxx.
144{
145 const SalomeContainerMonoHelper *helper(nullptr);
146 {
147 std::lock_guard<std::mutex> lg(getPG()->getLocker());
148 helper=_launchModeType.getHelperOfTask(askingNode);
149 }
150 return SalomeContainerTools::GetFullPlacementId(helper,this,askingNode);
151}
static std::string GetFullPlacementId(const SalomeContainerHelper *launchModeType, const Container *cont, const Task *askingNode)
const SalomeContainerMonoHelper * getHelperOfTask(const Task *node) const
References _launchModeType, YACS::ENGINE::SalomeContainerToolsBase::GetFullPlacementId(), YACS::ENGINE::SalomeHPContainerVectOfHelper::getHelperOfTask(), YACS::ENGINE::HomogeneousPoolContainer::getLocker(), and YACS::ENGINE::HomogeneousPoolContainer::getPG().
◆ getHelperOfTask() [1/2]
SalomeContainerMonoHelper * YACS::ENGINE::SalomeHPContainer::getHelperOfTask ( const Task *  node)
Definition at line 85 of file SalomeHPContainer.hxx.
85{ return _launchModeType.getHelperOfTask(node); }
◆ getHelperOfTask() [2/2]
const SalomeContainerMonoHelper * YACS::ENGINE::SalomeHPContainer::getHelperOfTask ( const Task *  node) const
Definition at line 86 of file SalomeHPContainer.hxx.
86{ return _launchModeType.getHelperOfTask(node); }
◆ getKernelContainerNames()
std::vector< std::string > SalomeHPContainer::getKernelContainerNames ( ) const
Definition at line 237 of file SalomeHPContainer.cxx.
238{
240}
std::vector< std::string > getKernelContainerNames(const SalomeHPContainer *cont) const
References _launchModeType, and YACS::ENGINE::SalomeHPContainerVectOfHelper::getKernelContainerNames().
◆ getKind()
std::string SalomeHPContainer::getKind ( ) const
Definition at line 97 of file SalomeHPContainer.cxx.
98{
99 return KIND;
100}
References KIND.
◆ getNumberOfCoresPerWorker()
int SalomeHPContainer::getNumberOfCoresPerWorker ( ) const
◆ getNumberOfFreePlace()
std::size_t SalomeHPContainer::getNumberOfFreePlace ( ) const
◆ getPlacementId()
std::string SalomeHPContainer::getPlacementId ( const Task *  askingNode) const
Definition at line 133 of file SalomeHPContainer.cxx.
134{
135 const SalomeContainerMonoHelper *helper(nullptr);
136 {
137 std::lock_guard<std::mutex> lg(getPG()->getLocker());
138 helper=_launchModeType.getHelperOfTask(askingNode);
139 }
140 return SalomeContainerTools::GetPlacementId(helper,this,askingNode);
141}
static std::string GetPlacementId(const SalomeContainerHelper *launchModeType, const Container *cont, const Task *askingNode)
References _launchModeType, YACS::ENGINE::SalomeHPContainerVectOfHelper::getHelperOfTask(), YACS::ENGINE::HomogeneousPoolContainer::getLocker(), YACS::ENGINE::HomogeneousPoolContainer::getPG(), and YACS::ENGINE::SalomeContainerToolsBase::GetPlacementId().
◆ getProperties()
std::map< std::string, std::string > SalomeHPContainer::getProperties ( ) const
Definition at line 216 of file SalomeHPContainer.cxx.
217{
218 std::map<std::string,std::string> ret(_sct.getProperties());
219 std::ostringstream oss; oss << getSizeOfPool();
220 ret[SIZE_OF_POOL_KEY]=oss.str();
221 if(!_initScript.empty())
223 return ret;
224}
const std::map< std::string, std::string > & getProperties() const override
References _initScript, _sct, YACS::ENGINE::SalomeContainerTools::getProperties(), getSizeOfPool(), YACS::ENGINE::HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY, and YACS::ENGINE::HomogeneousPoolContainer::SIZE_OF_POOL_KEY.
◆ getProperty()
std::string SalomeHPContainer::getProperty ( const std::string &  name) const
Definition at line 186 of file SalomeHPContainer.cxx.
187{
188 if(name==AOC_ENTRY)
189 {
190 return std::string("1");
191 }
192 else if(name==SIZE_OF_POOL_KEY)
193 {
194 std::ostringstream oss; oss << getSizeOfPool();
195 return oss.str();
196 }
197 else if(name==INITIALIZE_SCRIPT_KEY)
198 {
199 return _initScript;
200 }
201 else
202 return _sct.getProperty(name);
203}
static const char AOC_ENTRY[]
Definition: Container.hxx:88
std::string getProperty(const std::string &name) const override
References _initScript, _sct, YACS::ENGINE::Container::AOC_ENTRY, YACS::ENGINE::SalomeContainerTools::getProperty(), getSizeOfPool(), YACS::ENGINE::HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY, and YACS::ENGINE::HomogeneousPoolContainer::SIZE_OF_POOL_KEY.
◆ getResourceProperties()
std::map< std::string, std::string > SalomeHPContainer::getResourceProperties ( const std::string &  name) const
Definition at line 226 of file SalomeHPContainer.cxx.
227{
228 return _sct.getResourceProperties(name);
229}
std::map< std::string, std::string > getResourceProperties(const std::string &name) const override
References _sct, and YACS::ENGINE::SalomeContainerTools::getResourceProperties().
◆ getShutdownLev()
int YACS::ENGINE::SalomeHPContainer::getShutdownLev ( ) const
Definition at line 84 of file SalomeHPContainer.hxx.
84{ return _shutdownLevel; }
◆ getSizeOfPool()
int SalomeHPContainer::getSizeOfPool ( ) const
◆ isAlreadyStarted()
bool SalomeHPContainer::isAlreadyStarted ( const Task *  askingNode) const
Definition at line 108 of file SalomeHPContainer.cxx.
109{
111 return helper->isAlreadyStarted(askingNode);
112}
const SalomeContainerMonoHelper * getHelperOfTaskThreadSafe(const SalomeHPContainer *cont, const Task *node) const
References _launchModeType, YACS::ENGINE::SalomeHPContainerVectOfHelper::getHelperOfTaskThreadSafe(), and YACS::ENGINE::SalomeContainerMonoHelper::isAlreadyStarted().
◆ locateTask()
std::size_t YACS::ENGINE::SalomeHPContainer::locateTask ( const Task *  askingNode) const
Definition at line 81 of file SalomeHPContainer.hxx.
81{ return _launchModeType.locateTask(askingNode); }
std::size_t locateTask(const Task *node) const
◆ lock()
void YACS::ENGINE::SalomeHPContainer::lock ( )
Definition at line 57 of file SalomeHPContainer.hxx.
57{ _lock.lock(); }
◆ release()
void SalomeHPContainer::release ( const Task *  node)
overridevirtual
◆ setProperty()
void SalomeHPContainer::setProperty ( const std::string &  name,
const std::string &  value
Definition at line 167 of file SalomeHPContainer.cxx.
168{
169 if(name==AOC_ENTRY)//no sense to set it ! It is always true ! ignore it !
170 return ;
171 else if(name==SIZE_OF_POOL_KEY)
172 {
173 std::istringstream iss(value);
174 int val(0);
175 iss >> val;
176 setSizeOfPool(val);
177 }
178 else if(name==INITIALIZE_SCRIPT_KEY)
179 {
180 _initScript=value;
181 }
182 else
183 _sct.setProperty(name,value);
184}
void setProperty(const std::string &name, const std::string &value) override
References _initScript, _sct, YACS::ENGINE::Container::AOC_ENTRY, YACS::ENGINE::HomogeneousPoolContainer::INITIALIZE_SCRIPT_KEY, YACS::ENGINE::SalomeContainerTools::setProperty(), setSizeOfPool(), and YACS::ENGINE::HomogeneousPoolContainer::SIZE_OF_POOL_KEY.
◆ setSizeOfPool()
void SalomeHPContainer::setSizeOfPool ( int  sz)
◆ shutdown()
void SalomeHPContainer::shutdown ( int  level)
◆ start()
void SalomeHPContainer::start ( const Task *  askingNode)
◆ unLock()
void YACS::ENGINE::SalomeHPContainer::unLock ( )
Definition at line 59 of file SalomeHPContainer.hxx.
59{ _lock.unlock(); }
◆ _componentNames
std::vector<std::string> YACS::ENGINE::SalomeHPContainer::_componentNames
Definition at line 98 of file SalomeHPContainer.hxx.
Referenced by addComponentName(), and start().
◆ _initScript
std::string YACS::ENGINE::SalomeHPContainer::_initScript
Definition at line 101 of file SalomeHPContainer.hxx.
Referenced by clearProperties(), getProperties(), getProperty(), and setProperty().
◆ _launchModeType
◆ _lock
std::mutex YACS::ENGINE::SalomeHPContainer::_lock
Definition at line 95 of file SalomeHPContainer.hxx.
◆ _sct
SalomeContainerTools YACS::ENGINE::SalomeHPContainer::_sct
◆ _shutdownLevel
int YACS::ENGINE::SalomeHPContainer::_shutdownLevel
Definition at line 96 of file SalomeHPContainer.hxx.
Referenced by shutdown(), and start().
◆ KIND
const char SalomeHPContainer::KIND ="HPSalome"
Definition at line 89 of file SalomeHPContainer.hxx.
Referenced by YACS::ENGINE::RuntimeSALOME::createContainer(), and getKind().
