ComponentInstance.hxx
20#ifndef __COMPONENTINSTANCE_HXX__
21#define __COMPONENTINSTANCE_HXX__
24#include "RefCounter.hxx"
25#include "PropertyInterface.hxx"
26
27#include <list>
28#include <string>
30namespace YACS
31{
32 namespace ENGINE
33 {
34 class Task;
35 class ServiceNode;
36 class Container;
37
39 {
40 protected:
41 virtual ~ComponentInstance();
42 public:
43 ComponentInstance(const std::string& name);
45 const std::string& getCompoName() const { return _compoName; }
46 const std::string& getInstanceName() const { return _instanceName; }
47 void setName(const std::string& name) { _instanceName = name; };
48 virtual void setAnonymous(bool anon) { _anonymous = anon; };
49 virtual bool isAnonymous() { return _anonymous; };
50 int getNumId() const { return _numId; }
51 virtual bool setContainer(Container *cont);
52 Container *getContainer() const { return _container; }
54 virtual void load(Task *askingNode) = 0;
56 virtual void unload(Task *askingNode) = 0;
58 virtual bool isLoaded(Task *askingNode) const = 0;
59 virtual void attachOnCloning() const;
60 virtual void dettachOnCloning() const;
61 bool isAttachedOnCloning() const;
62 virtual std::string getFileRepr() const;
63 virtual ServiceNode* createNode(const std::string& name)=0;
64 virtual ComponentInstance *clone() const = 0;
65 virtual ComponentInstance *cloneAlways() const = 0;
66 virtual std::string getKind() const;
67 virtual std::string getKindForNode() const;
68 static const char KIND[];
69 virtual void shutdown(int level);
70 protected:
72 std::string _compoName;
74 std::string _instanceName;
75 int _numId;
78 protected:
79 static const char NULL_FILE_REPR[];
80 static int _total;
82 };
83 }
84}
85
86#endif
#define YACSLIBENGINE_EXPORT
virtual ComponentInstance * cloneAlways() const =0
const std::string & getInstanceName() const
virtual bool isLoaded(Task *askingNode) const =0
Indicate if the component instance is loaded (true) or not.
WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each othe...
virtual ServiceNode * createNode(const std::string &name)=0
virtual void unload(Task *askingNode)=0
Unload the component instance.
WARNING : _compoName identify only the component type.
virtual ComponentInstance * clone() const =0
virtual void load(Task *askingNode)=0
Load the component instance.
Class for adding property interface to another class.
