containerParsers.cxx
20#include "containerParsers.hxx"
21#include "propertyParsers.hxx"
23
24//#define _DEVDEBUG_
25#include "YacsTrace.hxx"
26
27namespace YACS
28{
29 containertypeParser containertypeParser::containerParser;
30 machinetypeParser machinetypeParser::machineParser;
31 loadtypeParser loadtypeParser::loadParser;
32
34 {
35 if (!attr)
36 return;
37 required("name",attr);
38 for (int i = 0; attr[i]; i += 2)
39 {
40 if(std::string(attr[i]) == "name")name(attr[i+1]);
41 }
42 }
44 void machinetypeParser::name(const std::string& name){ _mach._name=name; }
46 {
47 return _mach;
48 }
49
51 {
52 if (!attr)
53 return;
54 required("name",attr);
55 for (int i = 0; attr[i]; i += 2)
56 {
57 if(std::string(attr[i]) == "name")name(attr[i+1]);
58 }
59 }
60 void containertypeParser::onStart(const XML_Char* el, const XML_Char** attr)
61 {
62 std::string element(el);
64 if(element == "machine")pp=&machinetypeParser::machineParser;
65 if(element == "property")pp=&propertytypeParser::propertyParser;
66 if(element == "initializescriptkey")pp=&codetypeParser::codeParser;
68 pp->init();
69 pp->pre();
70 pp->buildAttr(attr);
71 }
72 void containertypeParser::onEnd(const char *el,parser* child)
73 {
74 std::string element(el);
75 if(element == "machine")machine_(((machinetypeParser*)child)->post());
76 if(element == "property")property(((propertytypeParser*)child)->post());
77 if(element == "initializescriptkey")initializescriptkey(((codetypeParser*)child)->post());
78 }
80 {
81 _container._machs.clear();
82 _container._props.clear();
83 }
84 void containertypeParser::name(const std::string& name){ _container._name=name; }
86 {
87 DEBTRACE( "machine: " << m._name )
88 _container._machs.push_back(m);
89 }
91 {
92 DEBTRACE( "property_set: " << prop._name << " " << prop._value );
93 _container._props[prop._name]=prop._value;
94 }
96 {
98 }
99
101 {
102 //mincount("machine",1);
103 return _container;
104 }
105
107 {
108 if (!attr)
109 return;
110 required("container",attr);
111 for (int i = 0; attr[i]; i += 2)
112 {
113 if(std::string(attr[i]) == "container")container(attr[i+1]);
114 }
115 }
117 void loadtypeParser::container(const std::string& name){ _loadon._container=name; }
119 {
120 return _loadon;
121 }
122
123}
char XML_Char
Definition: parserBase.hxx:37
Class for code parser in inline nodes.
Definition: codeParsers.hxx:35
static codetypeParser codeParser
Definition: codeParsers.hxx:36
virtual void initializescriptkey(const myfunc &f)
virtual void machine_(const machine &m)
static containertypeParser containerParser
virtual void container(const std::string &name)
static loadtypeParser loadParser
Class for machine parser.
static machinetypeParser machineParser
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
Definition: parserBase.cxx:55
Definition: parserBase.cxx:195
static parser main_parser
Definition: parserBase.hxx:41
Class for property parser.
std::string _container
Definition: factory.hxx:122
std::string _name
Definition: factory.hxx:109
machines _machs
Definition: factory.hxx:116
std::map< std::string, std::string > _props
Definition: factory.hxx:117
std::string _name
Definition: factory.hxx:115
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
