YACS::containertypeParser Struct Reference
Class for container parser. More...
#include <containerParsers.hxx>
Inheritance diagram for YACS::containertypeParser:
Collaboration diagram for YACS::containertypeParser:
virtual void pre ()
virtual void machine_ (const machine &m)
virtual void initializescriptkey (const myfunc &f)
mycontainer post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
mycontainer _container
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static containertypeParser containerParser
static parser main_parser
Class used to parse container description
XML schema is
  <xsd:complexType name="ContainerType">
    <xsd:sequence>
      <xsd:element name="machine" type="MachineType" minOccurs="0" maxOccurs="unbounded"/>
      <xsd:element name="property" type="PropertyType" minOccurs="0" maxOccurs="unbounded"/>
    </xsd:sequence>
    <xsd:attribute name="name" type="xsd:string" use="required"/>
  </xsd:complexType>
Definition at line 66 of file containerParsers.hxx.
◆ buildAttr()
void YACS::containertypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 50 of file containerParsers.cxx.
51 {
52 if (!attr)
53 return;
54 required("name",attr);
55 for (int i = 0; attr[i]; i += 2)
56 {
57 if(std::string(attr[i]) == "name")name(attr[i+1]);
58 }
59 }
References yacsorb.CORBAEngineTest::i, name(), and YACS::parser::required().
◆ initializescriptkey()
void YACS::containertypeParser::initializescriptkey ( const myfunc &  f)
◆ machine_()
void YACS::containertypeParser::machine_ ( const machine &  m)
Definition at line 85 of file containerParsers.cxx.
86 {
87 DEBTRACE( "machine: " << m._name )
88 _container._machs.push_back(m);
89 }
References _container, mycontainer::_machs, DEBTRACE, and gui.GraphViewer::m.
Referenced by onEnd().
void YACS::containertypeParser::name ( const std::string &  name)
Definition at line 84 of file containerParsers.cxx.
std::string _name
Definition: factory.hxx:115
References _container, mycontainer::_name, and name().
Referenced by buildAttr(), and name().
◆ onEnd()
void YACS::containertypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 72 of file containerParsers.cxx.
73 {
74 std::string element(el);
75 if(element == "machine")machine_(((machinetypeParser*)child)->post());
76 if(element == "property")property(((propertytypeParser*)child)->post());
77 if(element == "initializescriptkey")initializescriptkey(((codetypeParser*)child)->post());
78 }
virtual void initializescriptkey(const myfunc &f)
virtual void machine_(const machine &m)
References initializescriptkey(), machine_(), post(), and property().
◆ onStart()
void YACS::containertypeParser::onStart ( const XML_Char *  el,
Definition at line 60 of file containerParsers.cxx.
61 {
62 std::string element(el);
64 if(element == "machine")pp=&machinetypeParser::machineParser;
65 if(element == "property")pp=&propertytypeParser::propertyParser;
66 if(element == "initializescriptkey")pp=&codetypeParser::codeParser;
68 pp->init();
69 pp->pre();
70 pp->buildAttr(attr);
71 }
static codetypeParser codeParser
Definition: codeParsers.hxx:36
static machinetypeParser machineParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), YACS::codetypeParser::codeParser, YACS::parser::init(), YACS::machinetypeParser::machineParser, YACS::parser::main_parser, YACS::parser::pre(), YACS::propertytypeParser::propertyParser, and YACS::parser::SetUserDataAndPush().
◆ post()
mycontainer YACS::containertypeParser::post ( )
Definition at line 100 of file containerParsers.cxx.
101 {
102 //mincount("machine",1);
103 return _container;
104 }
References _container.
◆ pre()
void YACS::containertypeParser::pre ( )
Definition at line 79 of file containerParsers.cxx.
80 {
81 _container._machs.clear();
82 _container._props.clear();
83 }
machines _machs
Definition: factory.hxx:116
References _container, mycontainer::_machs, and mycontainer::_props.
◆ property()
void YACS::containertypeParser::property ( const myprop &  prop)
Definition at line 90 of file containerParsers.cxx.
91 {
92 DEBTRACE( "property_set: " << prop._name << " " << prop._value );
93 _container._props[prop._name]=prop._value;
94 }
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
References _container, myprop::_name, mycontainer::_props, myprop::_value, and DEBTRACE.
◆ _container
mycontainer YACS::containertypeParser::_container
Definition at line 78 of file containerParsers.hxx.
Referenced by initializescriptkey(), machine_(), name(), post(), pre(), and property().
◆ containerParser
containertypeParser YACS::containertypeParser::containerParser
Definition at line 68 of file containerParsers.hxx.
Referenced by YACS::proctypeParser< T >::onStart().
