YACS::machinetypeParser Struct Reference
Class for machine parser. More...
#include <containerParsers.hxx>
Inheritance diagram for YACS::machinetypeParser:
Collaboration diagram for YACS::machinetypeParser:
virtual void pre ()
machine post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
machine _mach
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static machinetypeParser machineParser
static parser main_parser
Class used to parse computer adress on which container must be started
XML schema is
  <xsd:complexType name="MachineType">
    <xsd:attribute name="name" type="xsd:string" use="required"/>
  </xsd:complexType>
Definition at line 41 of file containerParsers.hxx.
◆ buildAttr()
void YACS::machinetypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 33 of file containerParsers.cxx.
34 {
35 if (!attr)
36 return;
37 required("name",attr);
38 for (int i = 0; attr[i]; i += 2)
39 {
40 if(std::string(attr[i]) == "name")name(attr[i+1]);
41 }
42 }
References yacsorb.CORBAEngineTest::i, name(), and YACS::parser::required().
void YACS::machinetypeParser::name ( const std::string &  name)
Definition at line 44 of file containerParsers.cxx.
44{ _mach._name=name; }
std::string _name
Definition: factory.hxx:109
References _mach, machine::_name, and name().
Referenced by buildAttr(), and name().
◆ post()
machine YACS::machinetypeParser::post ( )
Definition at line 45 of file containerParsers.cxx.
46 {
47 return _mach;
48 }
References _mach.
◆ pre()
void YACS::machinetypeParser::pre ( )
Definition at line 43 of file containerParsers.cxx.
43{_mach._name="";}
References _mach, and machine::_name.
◆ _mach
machine YACS::machinetypeParser::_mach
Definition at line 48 of file containerParsers.hxx.
Referenced by name(), post(), and pre().
◆ machineParser
machinetypeParser YACS::machinetypeParser::machineParser
Definition at line 43 of file containerParsers.hxx.
Referenced by YACS::containertypeParser::onStart().
