YACS::propertytypeParser Struct Reference
Class for property parser. More...
#include <propertyParsers.hxx>
Inheritance diagram for YACS::propertytypeParser:
Collaboration diagram for YACS::propertytypeParser:
virtual void value (const std::string &name)
myprop post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
myprop _prop
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static propertytypeParser propertyParser
static parser main_parser
Class used to parse a property. A property is a pair of name(string), value(string)
XML schema is
  <xsd:complexType name="PropertyType">
    <xsd:attribute name="name" type="xsd:string" use="required"/>
    <xsd:attribute name="value" type="xsd:string" use="required"/>
  </xsd:complexType>
Definition at line 43 of file propertyParsers.hxx.
◆ buildAttr()
void YACS::propertytypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 27 of file propertyParsers.cxx.
28 {
29 if (!attr)
30 return;
31 required("name",attr);
32 required("value",attr);
33 for (int i = 0; attr[i]; i += 2)
34 {
35 if(std::string(attr[i]) == "name")name(attr[i+1]);
36 if(std::string(attr[i]) == "value")value(attr[i+1]);
37 }
38 }
virtual void value(const std::string &name)
References yacsorb.CORBAEngineTest::i, name(), YACS::parser::required(), and value().
void YACS::propertytypeParser::name ( const std::string &  name)
Definition at line 39 of file propertyParsers.cxx.
39{ _prop._name=name; }
std::string _name
Definition: factory.hxx:96
References myprop::_name, _prop, and name().
Referenced by buildAttr(), name(), and value().
◆ post()
myprop YACS::propertytypeParser::post ( )
Definition at line 41 of file propertyParsers.cxx.
41{return _prop;}
References _prop.
◆ value()
void YACS::propertytypeParser::value ( const std::string &  name)
◆ _prop
myprop YACS::propertytypeParser::_prop
Definition at line 50 of file propertyParsers.hxx.
Referenced by name(), post(), and value().
◆ propertyParser
