serviceParsers.hxx
20#ifndef _SERVICEPARSERS_HXX_
21#define _SERVICEPARSERS_HXX_
23#include "parserBase.hxx"
24#include "containerParsers.hxx"
25#include "dataParsers.hxx"
26#include "portParsers.hxx"
27#include "codeParsers.hxx"
28#include "propertyParsers.hxx"
30#include "Proc.hxx"
31#include "TypeCode.hxx"
32#include "InlineNode.hxx"
33#include "ServiceNode.hxx"
34#include "Exception.hxx"
35#include "Runtime.hxx"
36#include "Container.hxx"
37#include "ComponentInstance.hxx"
40#include "ComponentInstance.hxx"
41#include "factory.hxx"
42
45
46namespace YACS
47{
48
49static std::string t2[]={"ref","node","component","componentinstance",""};
50
51template <class T=YACS::ENGINE::ServiceNode*>
53{
55
56 virtual void onStart(const XML_Char* el, const XML_Char** attr);
57 virtual void onEnd(const char *el,parser* child)
58 {
59 DEBTRACE( "servicetypeParser::onEnd: " << el )
60 std::string element(el);
61 if(element == "kind")this->kind(((stringtypeParser*)child)->post());
62 else if(element == "ref") ref(((stringtypeParser*)child)->post());
63 else if(element == "component") component(((stringtypeParser*)child)->post());
64 else if(element == "componentinstance") componentinstance(((stringtypeParser*)child)->post());
65 else if(element == "node") node(((stringtypeParser*)child)->post());
66 else if(element == "method") method(((stringtypeParser*)child)->post());
67 else if(element == "load") load(((loadtypeParser*)child)->post());
68 else if(element == "property")this->property(((propertytypeParser*)child)->post());
69 else if(element == "inport") this->inport(((inporttypeParser<myinport>*)child)->post());
70 else if(element == "outport") this->outport(((outporttypeParser<myoutport>*)child)->post());
71 else if(element == "instream") instream(((inporttypeParser<myinport>*)child)->post());
72 else if(element == "outstream") outstream(((outporttypeParser<myoutport>*)child)->post());
73 }
74 virtual void ref (const std::string& name)
75 {
76 DEBTRACE( "service_ref: " << name )
77 this->_node=theRuntime->createRefNode(this->_kind,this->_name);
78 this->_node->setRef(name);
79 }
80
81 virtual void componentinstance (const std::string& name)
82 {
83 DEBTRACE( "componentinstance: " << name )
85 throw YACS::Exception("Unknown ComponentInstance: "+name);
86 this->_node=theRuntime->createCompoNode(this->_kind,this->_name);
88 this->_node->setComponent(inst);
89 }
90
91 virtual void component (const std::string& name)
92 {
93 DEBTRACE( "service_component: " << name )
94 this->_node=theRuntime->createCompoNode(this->_kind,this->_name);
96 this->_node->setComponent(inst);
97 inst->decrRef();
98 }
99 virtual void node (const std::string& name)
100 {
101 DEBTRACE( "service_node: " << name )
102 std::string fullname = currentProc->names.back()+name;
103 if(currentProc->serviceMap.count(name) != 0)
104 {
105 //ServiceNode with absolute name found
107 this->_node =n->createNode(this->_name);
108 }
109 else if(currentProc->serviceMap.count(fullname) != 0)
110 {
111 //ServiceNode with relative name found
112 //TODO: must be a short name (possible only in the same context)
114 this->_node =n->createNode(this->_name);
115 }
116 else
117 {
118 throw YACS::Exception("Unknown ServiceNode");
119 }
120 }
121
122 virtual void method (const std::string& name)
123 {
124 DEBTRACE( "service_method: " << name )
125 if(this->_node==0)
126 throw YACS::Exception("ServiceNode must be completely defined before defining its method");
127 if(name == "")
128 {
129 this->logError("a service name must be a non empty string");
130 return;
131 }
132 this->_node->setMethod(name);
133 }
134
135 virtual void load (const loadon& l)
136 {
137 DEBTRACE( "service_load: " << l._container);
138 this->_container=l._container;
139 }
140
141 virtual void instream (const myinport& p)
142 {
143 DEBTRACE( "service_instream" )
144 DEBTRACE( p._type )
145 DEBTRACE( p._name )
146 if(this->_node==0)
147 throw YACS::Exception("ServiceNode must be completely defined before defining its ports");
148
149 if(currentProc->typeMap.count(p._type)==0)
150 {
152 if(t==0)
153 {
154 std::string msg="Unknown InStreamPort Type: ";
155 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
156 throw YACS::Exception(msg);
157 }
158 else
159 {
160 currentProc->typeMap[p._type]=t;
161 t->incrRef();
162 }
163 }
166 // Set all properties for this port
167 std::map<std::string, std::string>::const_iterator pt;
168 for(pt=p._props.begin();pt!=p._props.end();pt++)
169 port->setProperty((*pt).first,(*pt).second);
170 }
171 virtual void outstream (const myoutport& p)
172 {
173 DEBTRACE( "service_outstream" )
174 DEBTRACE( p._type )
175 DEBTRACE( p._name )
176 if(this->_node==0)
177 throw YACS::Exception("ServiceNode must be completely defined before defining its ports");
178
179 if(currentProc->typeMap.count(p._type)==0)
180 {
182 if(t==0)
183 {
184 std::string msg="Unknown OutStreamPort Type: ";
185 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
186 throw YACS::Exception(msg);
187 }
188 else
189 {
190 currentProc->typeMap[p._type]=t;
191 t->incrRef();
192 }
193 }
196 // Set all properties for this port
197 std::map<std::string, std::string>::const_iterator pt;
198 for(pt=p._props.begin();pt!=p._props.end();pt++)
199 port->setProperty((*pt).first,(*pt).second);
200 }
201 virtual T post()
202 {
203 DEBTRACE( "service_post " << this->_node->getName() )
204 this->mincount("method",1);
205 if(this->_state == "disabled")this->_node->exDisabledState();
206
207 // If the service node has no component instance don't go further return the node
208 if(!this->_node->getComponent())
209 return this->_node;
210
211 // when container is not defined by <load container="xxx"/> but indirectly by <node>xxx</node>
212 // this->_container is not set, and there is no need to setContainer
213 // so stop here and return the node
214 if(this->_node->getComponent()->getContainer())
215 return this->_node;
216
217 //If the component instance is anonymous set the container
218 // with the load directive or with the DefaultContainer
219 if(this->_node->getComponent()->isAnonymous())
220 {
221 if(currentProc->containerMap.count(this->_container) != 0)
222 this->_node->getComponent()->setContainer(currentProc->containerMap[this->_container]);
223 else if(this->_container == "" && currentProc->containerMap.count("DefaultContainer") != 0)
224 {
225 //a default container is defined : use it if supported
226 try
227 {
228 currentProc->containerMap["DefaultContainer"]->checkCapabilityToDealWith(this->_node->getComponent());
229 this->_node->getComponent()->setContainer(currentProc->containerMap["DefaultContainer"]);
230 }
231 catch(YACS::Exception)
232 {}
233 }
234 else
235 std::cerr << "WARNING: Unknown container " << this->_container << " ignored" << std::endl;
236 }
237 return this->_node;
238 }
239};
240
241template <class T> servicetypeParser<T> servicetypeParser<T>::serviceParser;
242
243template <class T>
245 {
246 DEBTRACE( "servicetypeParser::onStart: " << el )
247 std::string element(el);
249 this->maxcount("kind",1,element);
250 this->maxcount("ref",1,element);
251 this->maxcount("node",1,element);
252 this->maxcount("component",1,element);
253 this->maxcount("componentinstance",1,element);
254 this->maxcount("method",1,element);
255 this->maxcount("load",1,element);
256 this->maxchoice(t2,1,element);
257 if(element == "kind")pp=&stringtypeParser::stringParser;
258 else if(element == "ref")pp=&stringtypeParser::stringParser;
259 else if(element == "component")pp=&stringtypeParser::stringParser;
260 else if(element == "componentinstance")pp=&stringtypeParser::stringParser;
261 else if(element == "node")pp=&stringtypeParser::stringParser;
262 else if(element == "method")pp=&stringtypeParser::stringParser;
263 else if(element == "load")pp=&loadtypeParser::loadParser;
264 else if(element == "property")pp=&propertytypeParser::propertyParser;
265 else if(element == "inport")pp=&inporttypeParser<>::inportParser;
266 else if(element == "outport")pp=&outporttypeParser<>::outportParser;
267 else if(element == "instream")pp=&inporttypeParser<>::inportParser;
268 else if(element == "outstream")pp=&outporttypeParser<>::outportParser;
269 this->SetUserDataAndPush(pp);
270 pp->init();
271 pp->pre();
272 pp->buildAttr(attr);
273 }
274
275} // end of namespace YACS
276
277#endif
virtual bool setContainer(Container *cont)
virtual void setProperty(const std::string &name, const std::string &value)
Set a new value for a property of the port.
virtual OutputDataStreamPort * edAddOutputDataStreamPort(const std::string &outputPortDSName, TypeCode *type)
virtual InputDataStreamPort * edAddInputDataStreamPort(const std::string &inputPortDSName, TypeCode *type)
Definition: Node.hxx:125
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
Definition: Proc.hxx:44
std::map< std::string, ServiceNode * > serviceMap
Definition: Proc.hxx:88
Definition: Proc.hxx:90
std::vector< std::string > names
Definition: Proc.hxx:93
Definition: Proc.hxx:91
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
virtual ComponentInstance * createComponentInstance(const std::string &componame, const std::string &name="", const std::string &kind="")
Create a new ComponentInstance and add it into componentInstanceMap.
Definition: Proc.cxx:599
virtual ServiceNode * createRefNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:200
Definition: Runtime.cxx:333
virtual ServiceNode * createCompoNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:205
Return the service node kind.
Definition: ServiceNode.cxx:50
virtual void setRef(const std::string &ref)
Associate a new component instance to this service node.
virtual void setMethod(const std::string &method)
Definition: ServiceNode.hxx:50
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
virtual ServiceNode * createNode(const std::string &name)=0
virtual ComponentInstance * getComponent()
Return the associated component instance.
Definition: TypeCode.hxx:68
Proc * p
Definition: driver.cxx:216
char XML_Char
Definition: parserBase.hxx:37
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
Class for Inport parser.
Definition: portParsers.hxx:49
Class for loading parser.
static loadtypeParser loadParser
Definition: nodeParsers.hxx:90
Class for Outport parser.
Definition: portParsers.hxx:70
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
Definition: parserBase.cxx:195
static parser main_parser
Definition: parserBase.hxx:41
void logError(const std::string &reason)
Definition: parserBase.cxx:214
Class for property parser.
virtual void ref(const std::string &name)
virtual void load(const loadon &l)
virtual void instream(const myinport &p)
virtual void method(const std::string &name)
virtual void componentinstance(const std::string &name)
virtual void node(const std::string &name)
virtual void component(const std::string &name)
static servicetypeParser< T > serviceParser
virtual void outstream(const myoutport &p)
Class for string parser.
Definition: dataParsers.hxx:32
Definition: dataParsers.hxx:33
std::string _container
Definition: factory.hxx:122
std::string _name
Definition: factory.hxx:80
