YACS::inporttypeParser< T > Struct Template Reference
Class for Inport parser. More...
#include <portParsers.hxx>
Inheritance diagram for YACS::inporttypeParser< T >:
Collaboration diagram for YACS::inporttypeParser< T >:
virtual void pre ()
virtual void type (const std::string &type)
virtual T & post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Static Public Attributes
static inporttypeParser< T > inportParser
static parser main_parser
T _port
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
template<class T = myinport>
struct YACS::inporttypeParser< T >
This class is a base class for other inport parsers
XML schema:
  <xsd:complexType name="InPortType">
    <xsd:sequence>
      <xsd:element name="property" type="PropertyType" minOccurs="0"/>
    </xsd:sequence>
    <xsd:attribute name="name" type="xsd:string" use="required"/>
    <xsd:attribute name="type" type="xsd:string" use="required"/>
  </xsd:complexType>
Definition at line 48 of file portParsers.hxx.
◆ buildAttr()
template<class T >
void YACS::inporttypeParser< T >::buildAttr ( const XML_Char **  attr)
Definition at line 95 of file portParsers.hxx.
96 {
97 if (!attr)
98 return;
99 required("name",attr);
100 required("type",attr);
101 for (int i = 0; attr[i]; i += 2)
102 {
103 if(std::string(attr[i]) == "name")name(attr[i+1]);
104 if(std::string(attr[i]) == "type")type(attr[i+1]);
105 }
106 }
virtual void type(const std::string &type)
References yacsorb.CORBAEngineTest::i.
template<class T >
void YACS::inporttypeParser< T >::name ( const std::string &  name)
Definition at line 115 of file portParsers.hxx.
116 {
117 _port._name=name;
118 }
◆ onEnd()
template<class T >
void YACS::inporttypeParser< T >::onEnd ( const char *  el,
parser *  child
Definition at line 89 of file portParsers.hxx.
90 {
91 std::string element(el);
92 if(element == "property")property(((propertytypeParser*)child)->post());
93 }
◆ onStart()
template<class T >
void YACS::inporttypeParser< T >::onStart ( const XML_Char *  el,
Definition at line 78 of file portParsers.hxx.
79 {
80 std::string element(el);
82 if(element == "property")pp=&propertytypeParser::propertyParser;
83 this->SetUserDataAndPush(pp);
84 pp->init();
85 pp->pre();
86 pp->buildAttr(attr);
87 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::parser::main_parser, YACS::parser::pre(), and YACS::propertytypeParser::propertyParser.
◆ post()
template<class T >
T & YACS::inporttypeParser< T >::post
Definition at line 131 of file portParsers.hxx.
132 {
133 return _port;
134 }
◆ pre()
template<class T >
void YACS::inporttypeParser< T >::pre
Definition at line 108 of file portParsers.hxx.
109 {
110 _port._name="";
111 _port._type="";
112 _port.clear();
113 }
◆ property()
template<class T >
void YACS::inporttypeParser< T >::property ( const myprop &  prop)
Definition at line 125 of file portParsers.hxx.
126 {
127 DEBTRACE( "property_set: " << prop._name << prop._value )
128 _port.setProperty(prop._name,prop._value);
129 }
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
References myprop::_name, myprop::_value, and DEBTRACE.
◆ type()
template<class T >
void YACS::inporttypeParser< T >::type ( const std::string &  type)
Definition at line 120 of file portParsers.hxx.
121 {
122 _port._type=type;
123 }
◆ _port
T YACS::inporttypeParser< T >::_port
Definition at line 60 of file portParsers.hxx.
◆ inportParser
template<class T >
inporttypeParser< T > YACS::inporttypeParser< T >::inportParser
Definition at line 50 of file portParsers.hxx.
