YACS::loadtypeParser Struct Reference
Class for loading parser. More...
#include <containerParsers.hxx>
Inheritance diagram for YACS::loadtypeParser:
Collaboration diagram for YACS::loadtypeParser:
virtual void pre ()
virtual void container (const std::string &name)
loadon post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
loadon _loadon
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static loadtypeParser loadParser
static parser main_parser
Class used to parse service node loading information
XML schema is
  <xsd:complexType name="LoadType">
    <xsd:attribute name="container" type="xsd:string" use="required"/>
  </xsd:complexType>
Definition at line 92 of file containerParsers.hxx.
◆ buildAttr()
void YACS::loadtypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 106 of file containerParsers.cxx.
107 {
108 if (!attr)
109 return;
110 required("container",attr);
111 for (int i = 0; attr[i]; i += 2)
112 {
113 if(std::string(attr[i]) == "container")container(attr[i+1]);
114 }
115 }
virtual void container(const std::string &name)
References container(), yacsorb.CORBAEngineTest::i, and YACS::parser::required().
◆ container()
void YACS::loadtypeParser::container ( const std::string &  name)
Definition at line 117 of file containerParsers.cxx.
117{ _loadon._container=name; }
std::string _container
Definition: factory.hxx:122
References loadon::_container, and _loadon.
Referenced by buildAttr().
◆ post()
loadon YACS::loadtypeParser::post ( )
Definition at line 118 of file containerParsers.cxx.
119 {
120 return _loadon;
121 }
References _loadon.
◆ pre()
void YACS::loadtypeParser::pre ( )
Definition at line 116 of file containerParsers.cxx.
◆ _loadon
loadon YACS::loadtypeParser::_loadon
Definition at line 99 of file containerParsers.hxx.
Referenced by container(), post(), and pre().
◆ loadParser
