componentinstanceParsers.cxx
21#include "containerParsers.hxx"
22#include "dataParsers.hxx"
23#include "propertyParsers.hxx"
24
25//#define _DEVDEBUG_
26#include "YacsTrace.hxx"
27
28namespace YACS
29{
31
33 {
34 if (!attr)
35 return;
36 required("name",attr);
37 for (int i = 0; attr[i]; i += 2)
38 {
39 if(std::string(attr[i]) == "name")name(attr[i+1]);
40 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
41 }
42 }
44 {
45 std::string element(el);
47 this->maxcount("component",1,element);
48 this->maxcount("load",1,element);
49 if(element == "property")pp=&propertytypeParser::propertyParser;
50 else if(element == "component")pp=&stringtypeParser::stringParser;
51 else if(element == "load")pp=&loadtypeParser::loadParser;
53 pp->init();
54 pp->pre();
55 pp->buildAttr(attr);
56 }
57 void componentinstancetypeParser::onEnd(const char *el,parser* child)
58 {
59 std::string element(el);
60 if(element == "property")property(((propertytypeParser*)child)->post());
61 else if(element == "component") component(((stringtypeParser*)child)->post());
62 else if(element == "load") load(((loadtypeParser*)child)->post());
63 }
64
66 {
68 }
69
70 void componentinstancetypeParser::name(const std::string& name)
72
73 void componentinstancetypeParser::kind(const std::string& kind)
75
77 {
78 DEBTRACE("property_set: "<<prop._name<<" "<<prop._value);
80 }
81
82 void componentinstancetypeParser::component (const std::string& name)
83 {
84 DEBTRACE( "component_set: " << name )
86 }
87
89 {
90 DEBTRACE( "load: " )
92 }
93
95 {
96 this->mincount("component",1);
97 return _componentinstance;
98 }
99}
char XML_Char
Definition: parserBase.hxx:37
virtual void kind(const std::string &kind)
static componentinstancetypeParser componentinstanceParser
virtual void component(const std::string &name)
Class for loading parser.
static loadtypeParser loadParser
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
Definition: parserBase.cxx:55
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
Definition: parserBase.cxx:195
static parser main_parser
Definition: parserBase.hxx:41
Class for property parser.
Class for string parser.
Definition: dataParsers.hxx:32
Definition: dataParsers.hxx:33
std::string _kind
Definition: factory.hxx:128
std::map< std::string, std::string > _props
Definition: factory.hxx:131
std::string _name
Definition: factory.hxx:127
std::string _component
Definition: factory.hxx:129
std::string _container
Definition: factory.hxx:130
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
