YACS::componentinstancetypeParser Struct Reference
Class for componentinstance parser. More...
#include <componentinstanceParsers.hxx>
Inheritance diagram for YACS::componentinstancetypeParser:
Collaboration diagram for YACS::componentinstancetypeParser:
virtual void pre ()
virtual void kind (const std::string &kind)
virtual void component (const std::string &name)
virtual void load (const loadon &l)
mycomponentinstance post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
mycomponentinstance _componentinstance
std::string _container
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static componentinstancetypeParser componentinstanceParser
static parser main_parser
Class used to parse ComponentInstance description
XML schema is
  <xsd:complexType name="ComponentInstanceType">
    <xsd:sequence>
      <xsd:element name="component" type="xsd:string"/>
      <xsd:element name="property" type="PropertyType" minOccurs="0" maxOccurs="unbounded"/>
    </xsd:sequence>
    <xsd:attribute name="name" type="xsd:string" use="required"/>
    <xsd:attribute name="kind" type="xsd:string"/>
  </xsd:complexType>
Definition at line 45 of file componentinstanceParsers.hxx.
◆ buildAttr()
void YACS::componentinstancetypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 32 of file componentinstanceParsers.cxx.
33 {
34 if (!attr)
35 return;
36 required("name",attr);
37 for (int i = 0; attr[i]; i += 2)
38 {
39 if(std::string(attr[i]) == "name")name(attr[i+1]);
40 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
41 }
42 }
virtual void kind(const std::string &kind)
References yacsorb.CORBAEngineTest::i, kind(), name(), and YACS::parser::required().
◆ component()
void YACS::componentinstancetypeParser::component ( const std::string &  name)
Definition at line 82 of file componentinstanceParsers.cxx.
83 {
84 DEBTRACE( "component_set: " << name )
86 }
std::string _component
Definition: factory.hxx:129
References mycomponentinstance::_component, _componentinstance, DEBTRACE, and name().
Referenced by onEnd().
◆ kind()
void YACS::componentinstancetypeParser::kind ( const std::string &  kind)
Definition at line 73 of file componentinstanceParsers.cxx.
References _componentinstance, mycomponentinstance::_kind, and kind().
Referenced by buildAttr(), and kind().
◆ load()
void YACS::componentinstancetypeParser::load ( const loadon &  l)
void YACS::componentinstancetypeParser::name ( const std::string &  name)
◆ onEnd()
void YACS::componentinstancetypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 57 of file componentinstanceParsers.cxx.
58 {
59 std::string element(el);
60 if(element == "property")property(((propertytypeParser*)child)->post());
61 else if(element == "component") component(((stringtypeParser*)child)->post());
62 else if(element == "load") load(((loadtypeParser*)child)->post());
63 }
virtual void component(const std::string &name)
References component(), load(), post(), and property().
◆ onStart()
void YACS::componentinstancetypeParser::onStart ( const XML_Char *  el,
Definition at line 43 of file componentinstanceParsers.cxx.
44 {
45 std::string element(el);
47 this->maxcount("component",1,element);
48 this->maxcount("load",1,element);
49 if(element == "property")pp=&propertytypeParser::propertyParser;
50 else if(element == "component")pp=&stringtypeParser::stringParser;
51 else if(element == "load")pp=&loadtypeParser::loadParser;
53 pp->init();
54 pp->pre();
55 pp->buildAttr(attr);
56 }
static loadtypeParser loadParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
Definition: dataParsers.hxx:33
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::loadtypeParser::loadParser, YACS::parser::main_parser, YACS::parser::maxcount(), YACS::parser::pre(), YACS::propertytypeParser::propertyParser, YACS::parser::SetUserDataAndPush(), and YACS::stringtypeParser::stringParser.
◆ post()
mycomponentinstance YACS::componentinstancetypeParser::post ( )
Definition at line 94 of file componentinstanceParsers.cxx.
95 {
96 this->mincount("component",1);
97 return _componentinstance;
98 }
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
References _componentinstance, and YACS::parser::mincount().
◆ pre()
void YACS::componentinstancetypeParser::pre ( )
Definition at line 65 of file componentinstanceParsers.cxx.
66 {
68 }
std::map< std::string, std::string > _props
Definition: factory.hxx:131
References _componentinstance, and mycomponentinstance::_props.
◆ property()
void YACS::componentinstancetypeParser::property ( const myprop &  prop)
Definition at line 76 of file componentinstanceParsers.cxx.
77 {
78 DEBTRACE("property_set: "<<prop._name<<" "<<prop._value);
80 }
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
References _componentinstance, myprop::_name, mycomponentinstance::_props, myprop::_value, and DEBTRACE.
◆ _componentinstance
mycomponentinstance YACS::componentinstancetypeParser::_componentinstance
Definition at line 58 of file componentinstanceParsers.hxx.
Referenced by component(), kind(), load(), name(), post(), pre(), and property().
◆ _container
std::string YACS::componentinstancetypeParser::_container
Definition at line 59 of file componentinstanceParsers.hxx.
◆ componentinstanceParser
componentinstancetypeParser YACS::componentinstancetypeParser::componentinstanceParser
Definition at line 47 of file componentinstanceParsers.hxx.
Referenced by YACS::proctypeParser< T >::onStart().
