20#ifndef _NODEPARSERS_HXX_
21#define _NODEPARSERS_HXX_
52template <
class T=YACS::ENGINE::InlineNode*>
59 DEBTRACE(
"nodetypeParser::onStart: " << el )
60 std::string element(el);
69 DEBTRACE(
"nodetypeParser::onEnd: " << el )
70 std::string element(el);
78 for (
int i = 0; attr[
i];
i += 2)
80 if(std::string(attr[
i]) ==
"name")
name(attr[
i+1]);
81 if(std::string(attr[
i]) ==
"state")
state(attr[
i+1]);
82 if(std::string(attr[
i]) ==
"type")
type(attr[
i+1]);
119 throw YACS::Exception(
"Node must be completely defined before setting its properties");
137 _node=
n->cloneNode(_name);
143 _node=
149 if(_state ==
"disabled")_node->exDisabledState();
150 DEBTRACE(
"node_post " << _node->getName() )
std::map< std::string, InlineNode * > inlineMap
std::vector< std::string > names
virtual void state(const std::string &name)
static nodetypeParser< T > nodeParser
virtual void type(const std::string &name)
static parser main_parser
