YACS::nodetypeParser< T > Struct Template Reference
Class for node parser. More...
#include <nodeParsers.hxx>
Inheritance diagram for YACS::nodetypeParser< T >:
Collaboration diagram for YACS::nodetypeParser< T >:
virtual void pre ()
virtual void type (const std::string &name)
virtual T post ()
YACS::ENGINE::InlineNode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _type
std::string _state
std::string _container
T _node
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static nodetypeParser< T > nodeParser
static parser main_parser
template<class T = YACS::ENGINE::InlineNode*>
struct YACS::nodetypeParser< T >
This class is a base class for other parsers
Definition at line 53 of file nodeParsers.hxx.
◆ buildAttr()
virtual void YACS::nodetypeParser< T >::buildAttr ( const XML_Char **  attr)
Reimplemented in YACS::inlinetypeParser< T >, YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServerNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::outnodetypeParser< T >, and YACS::presettypeParser< T >.
Definition at line 72 of file nodeParsers.hxx.
73 {
74 if (!attr)
75 return;
76 required("name",attr);
77 required("type",attr);
78 for (int i = 0; attr[i]; i += 2)
79 {
80 if(std::string(attr[i]) == "name")name(attr[i+1]);
81 if(std::string(attr[i]) == "state")state(attr[i+1]);
82 if(std::string(attr[i]) == "type")type(attr[i+1]);
83 }
84 }
virtual void state(const std::string &name)
Definition: nodeParsers.hxx:95
Definition: nodeParsers.hxx:90
virtual void type(const std::string &name)
Definition: nodeParsers.hxx:99
References yacsorb.CORBAEngineTest::i, YACS::nodetypeParser< T >::name(), YACS::parser::required(), YACS::nodetypeParser< T >::state(), and YACS::nodetypeParser< T >::type().
virtual void YACS::nodetypeParser< T >::name ( const std::string &  name)
◆ onEnd()
◆ onStart()
◆ post() [1/2]
◆ post() [2/2]
Definition at line 130 of file nodeParsers.hxx.
131{
132 std::string fullname = currentProc->names.back()+_type;
133 if(currentProc->inlineMap.count(_type) != 0)
134 {
135 //InlineNode type with absolute name found
137 _node=n->cloneNode(_name);
138 }
139 else if(currentProc->inlineMap.count(fullname) != 0)
140 {
141 //InlineNode type with relative name found
143 _node=n->cloneNode(_name);
144 }
145 else
146 {
147 throw YACS::Exception("Unknown InlineNode type");
148 }
149 if(_state == "disabled")_node->exDisabledState();
150 DEBTRACE( "node_post " << _node->getName() )
151 return _node;
152}
Definition: InlineNode.hxx:44
std::map< std::string, InlineNode * > inlineMap
Definition: Proc.hxx:89
std::vector< std::string > names
Definition: Proc.hxx:93
Definition: parserBase.cxx:30
References currentProc, DEBTRACE, YACS::ENGINE::Proc::inlineMap, gui.Appli::n, and YACS::ENGINE::Proc::names.
◆ pre()
◆ property()
template<class T >
void YACS::nodetypeParser< T >::property ( const myprop &  prop)
Definition at line 116 of file nodeParsers.hxx.
117{
118 if(this->_node==0)
119 throw YACS::Exception("Node must be completely defined before setting its properties");
120 _node->setProperty(prop._name,prop._value);
121}
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
References myprop::_name, and myprop::_value.
◆ state()
virtual void YACS::nodetypeParser< T >::state ( const std::string &  name)
◆ type()
virtual void YACS::nodetypeParser< T >::type ( const std::string &  name)
Definition at line 99 of file nodeParsers.hxx.
100 {
101 DEBTRACE( "node_type " << name )
102 _type=name;
103 }
References YACS::nodetypeParser< T >::_type, DEBTRACE, and YACS::nodetypeParser< T >::name().
Referenced by YACS::nodetypeParser< T >::buildAttr().
◆ _container
std::string YACS::nodetypeParser< T >::_container
Definition at line 109 of file nodeParsers.hxx.
Referenced by YACS::nodetypeParser< T >::pre().
◆ _name
std::string YACS::nodetypeParser< T >::_name
Definition at line 107 of file nodeParsers.hxx.
Referenced by YACS::nodetypeParser< T >::name().
◆ _node
T YACS::nodetypeParser< T >::_node
Definition at line 110 of file nodeParsers.hxx.
◆ _state
std::string YACS::nodetypeParser< T >::_state
Definition at line 108 of file nodeParsers.hxx.
Referenced by YACS::nodetypeParser< T >::state().
◆ _type
std::string YACS::nodetypeParser< T >::_type
Definition at line 106 of file nodeParsers.hxx.
Referenced by YACS::nodetypeParser< T >::type().
◆ nodeParser
template<class T >
nodetypeParser< T > YACS::nodetypeParser< T >::nodeParser
Definition at line 55 of file nodeParsers.hxx.
