YACS::outnodetypeParser< T > Struct Template Reference
Class for OutNode parser. More...
#include <outputParsers.hxx>
Inheritance diagram for YACS::outnodetypeParser< T >:
Collaboration diagram for YACS::outnodetypeParser< T >:
virtual void pre ()
virtual void kind (const std::string &kind)
virtual void ref (const std::string &ref)
virtual void create ()
virtual void parameter (myoutport &p)
virtual T post ()
- Public Member Functions inherited from YACS::nodetypeParser< ENGINE::DataNode * >
virtual void pre ()
virtual void type (const std::string &name)
virtual ENGINE::DataNode * post ()
YACS::ENGINE::InlineNode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _kind
std::string _ref
- Public Attributes inherited from YACS::nodetypeParser< ENGINE::DataNode * >
std::string _type
std::string _state
std::string _container
ENGINE::DataNode * _node
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static outnodetypeParser< T > outnodeParser
- Static Public Attributes inherited from YACS::nodetypeParser< ENGINE::DataNode * >
static nodetypeParser< ENGINE::DataNode * > nodeParser
static parser main_parser
template<class T = ENGINE::DataNode*>
struct YACS::outnodetypeParser< T >
Its XML schema is:
    <xsd:complexType name="OutNodeType">
      <xsd:attribute name="name" type="xsd:string" use="required"/>
      <xsd:attribute name="kind" type="xsd:string" />
      <xsd:attribute name="ref" type="xsd:string" />
      <xsd:element name="parameter" type="OutputDataType"/>
    </xsd:complexType>
Definition at line 114 of file outputParsers.hxx.
◆ buildAttr()
template<class T >
void YACS::outnodetypeParser< T >::buildAttr ( const XML_Char **  attr)
Reimplemented from YACS::nodetypeParser< ENGINE::DataNode * >.
Definition at line 159 of file outputParsers.hxx.
160 {
161 if (!attr)
162 return;
163 DEBTRACE("outnodetypeParser::buildAttr");
164 this->required("name",attr);
165 for (int i = 0; attr[i]; i += 2)
166 {
167 if(std::string(attr[i]) == "name")name(attr[i+1]);
168 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
169 if(std::string(attr[i]) == "ref")ref(attr[i+1]);
170 }
171 create();
172 }
virtual void kind(const std::string &kind)
virtual void ref(const std::string &ref)
References DEBTRACE, yacsorb.CORBAEngineTest::i, and gui.CONNECTOR::ref().
◆ create()
template<class T >
void YACS::outnodetypeParser< T >::create
Definition at line 199 of file outputParsers.hxx.
200{
202}
Definition: parsers.cxx:40
virtual DataNode * createOutDataNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:185
References YACS::ENGINE::Runtime::createOutDataNode(), and theRuntime.
◆ kind()
template<class T >
void YACS::outnodetypeParser< T >::kind ( const std::string &  kind)
Definition at line 188 of file outputParsers.hxx.
189{
190 _kind=kind;
191}
template<class T >
void YACS::outnodetypeParser< T >::name ( const std::string &  name)
Definition at line 183 of file outputParsers.hxx.
184{
185 _name=name;
186}
◆ onEnd()
template<class T >
void YACS::outnodetypeParser< T >::onEnd ( const char *  el,
parser *  child
Definition at line 150 of file outputParsers.hxx.
151 {
152 DEBTRACE("outnodetypeParser::onEnd");
153 std::string element(el);
154 if(element == "parameter")parameter(((outputdatatypeParser*)child)->post());
155 if(element == "property")this->property(((propertytypeParser*)child)->post());
156 }
virtual void parameter(myoutport &p)
References DEBTRACE.
◆ onStart()
template<class T >
void YACS::outnodetypeParser< T >::onStart ( const XML_Char *  el,
Definition at line 136 of file outputParsers.hxx.
137 {
138 DEBTRACE("outnodetypeParser::onStart");
139 std::string element(el);
141 if(element == "parameter")pp=&outputdatatypeParser::outputdataParser;
142 if(element == "property")pp=&propertytypeParser::propertyParser;
143 this->SetUserDataAndPush(pp);
144 pp->init();
145 pp->pre();
146 pp->buildAttr(attr);
147 }
static outputdatatypeParser outputdataParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::outputdatatypeParser::outputdataParser, YACS::parser::pre(), and YACS::propertytypeParser::propertyParser.
◆ parameter()
template<class T >
void YACS::outnodetypeParser< T >::parameter ( myoutport &  p)
Definition at line 205 of file outputParsers.hxx.
206{
207 DEBTRACE("outnodetypeParser::parameter");
208 if(currentProc->typeMap.count(p._type)==0)
209 {
210 //Check if the typecode is defined in the runtime
212 if(t==0)
213 {
214 std::string msg="Unknown Type: ";
215 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
216 this->logError(msg);
217 return;
218 }
219 else
220 {
221 currentProc->typeMap[p._type]=t;
222 t->incrRef();
223 }
224 }
225 ENGINE::InputPort *port = this->_node->edAddInputPort(p._name,currentProc->typeMap[p._type]);
226 this->_node->setData(port,p._props["ref"]);
227}
Definition: parserBase.cxx:30
virtual void setData(InputPort *port, const std::string &data)
Definition: DataNode.cxx:29
virtual InputPort * edAddInputPort(const std::string &inputPortName, TypeCode *type)
Definition: Node.hxx:125
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
Definition: TypeCode.hxx:68
Proc * p
Definition: driver.cxx:216
void logError(const std::string &reason)
Definition: parserBase.cxx:214
std::string _name
Definition: factory.hxx:80
References currentProc, DEBTRACE, YACS::ENGINE::Runtime::getTypeCode(), p, gui.Appli::t, theRuntime, and YACS::ENGINE::Proc::typeMap.
◆ post()
template<class T >
T YACS::outnodetypeParser< T >::post
Definition at line 230 of file outputParsers.hxx.
231{
232 this->_node->setRef(_ref);
233 return this->_node;
234}
virtual void setRef(const std::string &ref)
Definition: DataNode.cxx:35
◆ pre()
template<class T >
void YACS::outnodetypeParser< T >::pre
Definition at line 175 of file outputParsers.hxx.
176{
177 this->_node=0;
178 _kind="";
179 _ref="";
180}
◆ ref()
template<class T >
void YACS::outnodetypeParser< T >::ref ( const std::string &  ref)
Definition at line 193 of file outputParsers.hxx.
194{
195 _ref=ref;
196}
References gui.CONNECTOR::ref().
◆ _kind
std::string YACS::outnodetypeParser< T >::_kind
Definition at line 128 of file outputParsers.hxx.
◆ _name
std::string YACS::outnodetypeParser< T >::_name
Definition at line 127 of file outputParsers.hxx.
◆ _ref
std::string YACS::outnodetypeParser< T >::_ref
Definition at line 129 of file outputParsers.hxx.
◆ outnodeParser
template<class T >
outnodetypeParser< T > YACS::outnodetypeParser< T >::outnodeParser
Definition at line 116 of file outputParsers.hxx.
