45Runtime* Runtime::_singleton = 0;
51TypeCode* Runtime::_tc_stringpair = 0;
57const char Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME[]=
"Neutral";
63 if ( ! Runtime::_singleton )
64 throw Exception(
"Runtime is not yet initialized");
65 return Runtime::_singleton;
110 char* valenv=getenv(
"YACS_TRACELEVEL");
113 std::istringstream iss(valenv);
120 char *maxThreadStr = getenv(
"YACS_MAX_THREADS");
121 if (maxThreadStr != NULL)
123 int maxThreads = atoi(maxThreadStr);
124 DEBTRACE(
"maxThreads = " << maxThreads);
129 char *threadStackSizeStr = getenv(
"YACS_THREADS_STACK_SIZE");
130 if (threadStackSizeStr != NULL)
132 size_t threadStackSize = strtoul(threadStackSizeStr, NULL, 0);
133 DEBTRACE(
"threadStackSize = " << threadStackSize);
163 std::list<TypeCodeObjref *> ltc)
169 const std::string& name,
182 throw Exception(
"InDataNode factory not implemented");
187 throw Exception(
"OutDataNode factory not implemented");
192 throw Exception(
"FuncNode factory not implemented");
197 throw Exception(
"ScriptNode factory not implemented");
202 throw Exception(
"RefNode factory not implemented");
207 throw Exception(
"CompoNode factory not implemented");
212 throw Exception(
"SInlineNode factory not implemented");
216 const std::string& kind)
218 throw Exception(
"ComponentInstance factory not implemented");
223 throw Exception(
"Container factory not implemented");
228 return new Proc(name);
233 return new Bloc(name);
264 const std::string& kind,
Proc * procForTypes)
266 return new OptimizerLoop(name,algLib,factoryName,algInitOnFile,
true, procForTypes);
289 throw Exception(
"This type of catalog loader does not exist: " + sourceKind);
295 proto->
load(cata,path);
337 for(std::vector<Catalog *>::const_iterator it=
_catalogs.begin();it !=
_catalogs.end();it++)
339 if ((*it)->_typeMap.count(name) != 0)
340 return (*it)->_typeMap[name];
357 throw Exception(
"convertNeutral is not implemented by your runtime");
371 throw Exception(
"convertNeutralAsString is not implemented by your runtime");
class for YACS catalog loader.
virtual void load(Catalog *cata, const std::string &path)
std::map< std::string, TypeCode * > _typeMap
InputPort * edGetNbOfBranchesPort()
static size_t _threadStackSize
Loop node for parametric calculation.
Base class for all nodes.
static unsigned int _totalCnt
Catalog * getBuiltinCatalog()
Get the catalog of base nodes (elementary and composed)
virtual ServiceNode * createRefNode(const std::string &kind, const std::string &name)
virtual OptimizerLoop * createOptimizerLoop(const std::string &name, const std::string &algLib, const std::string &factoryName, bool algInitOnFile, const std::string &kind="", Proc *procForTypes=NULL)
static YACS::ENGINE::TypeCode * _tc_double
virtual InlineFuncNode * createFuncNode(const std::string &kind, const std::string &name)
virtual std::string convertNeutralAsString(TypeCode *type, Any *data)
Convert a YACS::ENGINE::Any object to a string to be used in GUI for example.
virtual Switch * createSwitch(const std::string &name)
virtual void addCatalog(Catalog *catalog)
Add a catalog of types and nodes to the runtime.
virtual InputDataStreamPort * createInputDataStreamPort(const std::string &name, Node *node, TypeCode *type)
static YACS::ENGINE::TypeCode * _tc_bool
virtual ForLoop * createForLoop(const std::string &name)
virtual ServiceInlineNode * createSInlineNode(const std::string &kind, const std::string &name)
virtual InlineNode * createScriptNode(const std::string &kind, const std::string &name)
Catalog * _builtinCatalog
virtual DataNode * createOutDataNode(const std::string &kind, const std::string &name)
virtual Container * createContainer(const std::string &kind="")
virtual TypeCode * createInterfaceTc(const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
virtual ForEachLoop * createForEachLoop(const std::string &name, TypeCode *type)
virtual Bloc * createBloc(const std::string &name)
virtual Catalog * loadCatalog(const std::string &sourceKind, const std::string &path)
Load a catalog of calculation to use as factory.
virtual TypeCode * createSequenceTc(const std::string &id, const std::string &name, TypeCode *content)
virtual OutputDataStreamPort * createOutputDataStreamPort(const std::string &name, Node *node, TypeCode *type)
virtual void setCatalogLoaderFactory(const std::string &name, CatalogLoader *factory)
Add a catalog loader factory to the map _catalogLoaderFactoryMap under the name name.
virtual DataNode * createInDataNode(const std::string &kind, const std::string &name)
virtual Proc * createProc(const std::string &name)
virtual ForEachLoopDyn * createForEachLoopDyn(const std::string &name, TypeCode *type)
static YACS::ENGINE::TypeCode * _tc_file
virtual ServiceNode * createCompoNode(const std::string &kind, const std::string &name)
std::vector< Catalog * > _catalogs
static Runtime * _singleton
virtual TypeCodeStruct * createStructTc(const std::string &id, const std::string &name)
static YACS::ENGINE::TypeCode * _tc_propvec
virtual void removeRuntime()
std::map< std::string, CatalogLoader * > _catalogLoaderFactoryMap
virtual ComponentInstance * createComponentInstance(const std::string &name, const std::string &kind="")
static YACS::ENGINE::TypeCode * _tc_int
static YACS::ENGINE::TypeCode * _tc_stringpair
virtual WhileLoop * createWhileLoop(const std::string &name)
virtual void * convertNeutral(TypeCode *type, Any *data)
Convert a YACS::ENGINE::Any object to an external object with type type.
Class for reference objects.
Class for sequence objects.
virtual void addMember(const std::string &name, TypeCode *tc)
The only non const method.
static TypeCode * interfaceTc(const char *id, const char *name)
static factory of object reference type given an id and a name
static TypeCode * sequenceTc(const char *id, const char *name, TypeCode *content)
static factory of sequence type given an id, a name and a content type
static TypeCode * structTc(const char *id, const char *name)
static factory of struct type given an id and a name
