YACS::ENGINE::ForEachLoop Class Reference
Loop node for parametric calculation. More...
#include <ForEachLoop.hxx>
Inheritance diagram for YACS::ENGINE::ForEachLoop:
Collaboration diagram for YACS::ENGINE::ForEachLoop:
 ForEachLoop (const std::string &name, TypeCode *typeOfDataSplitted)
 ForEachLoop (const ForEachLoop &other, ComposedNode *father, bool editionOnly)
 ~ForEachLoop ()
- Public Member Functions inherited from YACS::ENGINE::ForEachLoopGen
 ForEachLoopGen (const std::string &name, TypeCode *typeOfDataSplitted, std::unique_ptr< NbBranchesAbstract > &&branchManager)
 ForEachLoopGen (const ForEachLoopGen &other, ComposedNode *father, bool editionOnly)
 ~ForEachLoopGen ()
void init (bool start=true)
void exUpdateState ()
void exUpdateProgress ()
void checkNoCyclePassingThrough (Node *node)
void selectRunnableTasks (std::vector< Task * > &tasks)
unsigned getExecCurrentId () const
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
InputPort * edGetSeqOfSamplesPort ()
 Get an input port given its name. More...
OutPort * getOutPort (const std::string &name) const
 Get an output port given its name. More...
Node * getChildByShortName (const std::string &name) const
void writeDot (std::ostream &os) const
 Dump the node state to a stream. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getProgress () const
int getCurrentIndex () const
int getNbOfElementsToBeProcessed () const
ForEachLoopPassedData * getProcessedData () const
void setProcessedData (ForEachLoopPassedData *processedData)
std::vector< unsigned int > getPassedResults (Executor *execut, std::vector< SequenceAny * > &outputs, std::vector< std::string > &nameOfOutputs) const
void assignPassedResults (const std::vector< unsigned int > &passedIds, const std::vector< SequenceAny * > &passedOutputs, const std::vector< std::string > &nameOfOutputs)
const TypeCode * getOutputPortType (const std::string &portName) const
void cleanDynGraph () override
- Public Member Functions inherited from YACS::ENGINE::DynParaLoop
Node * edRemoveNode ()
Node * edRemoveInitNode ()
Node * edRemoveFinalizeNode ()
Node * edSetNode (Node *DISOWNnode)
Node * edSetInitNode (Node *DISOWNnode)
Node * edSetFinalizeNode (Node *DISOWNnode)
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add control link if necessary. More...
InputPort * edGetNbOfBranchesPort ()
unsigned getNumberOfEltsConsumed () const
int getBranchIDOfNode (Node *node) const
OutputPort * edGetSamplePort ()
bool isPlacementPredictableB4Run () const
 For the moment false is returned : impovement about it coming soon. More...
void edRemoveChild (Node *node)
 Remove a child node. More...
bool isLoop () const override
virtual bool edAddChild (Node *DISOWNnode)
std::list< Node * > edGetDirectDescendants () const
unsigned getNumberOfBranchesCreatedDyn () const
Node * getChildByNameExec (const std::string &name, unsigned id) const
std::vector< Node * > getNodes () const
ComplexWeight * getWeight ()
void setWeight (double loopWeight)
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
Node * getInitNode ()
Node * getExecNode ()
Node * getFinalizeNode ()
virtual void cleanDynGraph ()
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
- Protected Member Functions inherited from YACS::ENGINE::ForEachLoopGen
void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
YACS::Event updateStateOnFinishedEventFrom (Node *node)
 Method used to notify the node that a child node has finished. More...
YACS::Event updateStateForInitNodeOnFinishedEventFrom (Node *node, unsigned int id)
YACS::Event updateStateForWorkNodeOnFinishedEventFrom (Node *node, unsigned int id, bool isNormalFinish)
YACS::Event updateStateForFinalizeNodeOnFinishedEventFrom (Node *node, unsigned int id)
YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void pushAllSequenceValues ()
void createOutputOutOfScopeInterceptors (int branchNb)
void prepareSequenceValues (int sizeOfSamples)
OutPort * getDynOutPortByAbsName (int branchNb, const std::string &name)
void storeOutValsInSeqForOutOfScopeUse (int rank, int branchNb)
- Protected Member Functions inherited from YACS::ENGINE::DynParaLoop
 DynParaLoop (const std::string &name, TypeCode *typeOfDataSplitted, std::unique_ptr< NbBranchesAbstract > &&branchManager)
virtual ~DynParaLoop ()
 DynParaLoop (const DynParaLoop &other, ComposedNode *father, bool editionOnly)
void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
void prepareInputsFromOutOfScope (int branchNb)
void putValueOnBranch (Any *val, unsigned branchId, bool first)
TypeOfNode getIdentityOfNotifyerNode (const Node *node, unsigned &id)
InputPort * getDynInputPortByAbsName (int branchNb, const std::string &name, bool initNodeAdmitted)
virtual void forwardExecStateToOriginalBody (Node *execNode)
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
std::vector< Node * > cloneAndPlaceNodesCoherently (const std::vector< Node * > &origNodes)
 Clone nodes and make their placement consistent with the placement of the original ones. More...
Node * checkConsistencyAndSetNode (Node *&nodeToReplace, Node *DISOWNnode)
 This method is used to factorize methods edSetNode, edSetInitNode and edSetFinalizeNode. More...
Node * removeNode (Node *&nodeToRemove)
 This method is used to factorize methods edRemoveNode, edRemoveInitNode and edRemoveFinalizeNode. More...
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const std::string &name)
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
- Static Public Member Functions inherited from YACS::ENGINE::ForEachLoopGen
static int getFEDeltaBetween (OutPort *start, InPort *end)
static void InterceptorizeNameOfPort (std::string &portName)
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ForEachLoopGen
static const char NAME_OF_SPLITTERNODE [] ="splitter"
static const char INTERCEPTOR_STR [] ="_interceptor"
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Protected Types inherited from YACS::ENGINE::DynParaLoop
enum  TypeOfNode { INIT_NODE = 5 , WORK_NODE = 6 , FINALIZE_NODE = 7 }
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
- Protected Attributes inherited from YACS::ENGINE::ForEachLoopGen
int _currentIndex
SplitterNode _splitterNode
FakeNodeForForEachLoop * _nodeForSpecialCases
std::vector< AnySplitOutputPort * > _outGoingPorts
std::vector< InterceptorInputPort * > _intecptrsForOutGoingPorts
 ports linked to node outside the current scope More...
unsigned _execCurrentId
 ports created for TypeCodes correctness More...
std::vector< SequenceAny * > _execVals
std::vector< std::vector< AnyInputPort * > > _execOutGoingPorts
ForEachLoopPassedData * _passedData
- Protected Attributes inherited from YACS::ENGINE::DynParaLoop
Node * _node
Node * _initNode
Node * _finalizeNode
unsigned _nbOfEltConsumed
std::vector< int > _execIds
std::unique_ptr< NbBranchesAbstract > _nbOfBranches
AnyOutputPort _splittedPort
std::vector< Node * > _execNodes
std::vector< Node * > _execInitNodes
std::vector< Node * > _execFinalizeNodes
int _initializingCounter
int _unfinishedCounter
int _failedCounter
ComplexWeight _weight
double _loopWeight
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
- Static Protected Attributes inherited from YACS::ENGINE::ForEachLoopGen
static const int NOT_RUNNING_BRANCH_ID =-1
- Static Protected Attributes inherited from YACS::ENGINE::DynParaLoop
static const char NAME_OF_SPLITTED_SEQ_OUT [] = "evalSamples"
static const char OLD_NAME_OF_SPLITTED_SEQ_OUT [] = "SmplPrt"
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
Definition at line 235 of file ForEachLoop.hxx.
◆ ForEachLoop() [1/2]
YACS::ENGINE::ForEachLoop::ForEachLoop ( const std::string &  name,
TypeCode *  typeOfDataSplitted
Definition at line 238 of file ForEachLoop.hxx.
238:ForEachLoopGen(name,typeOfDataSplitted,std::unique_ptr<NbBranchesAbstract>(new NbBranches(this))) { }
ForEachLoopGen(const std::string &name, TypeCode *typeOfDataSplitted, std::unique_ptr< NbBranchesAbstract > &&branchManager)
◆ ForEachLoop() [2/2]
YACS::ENGINE::ForEachLoop::ForEachLoop ( const ForEachLoop &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 239 of file ForEachLoop.hxx.
239:ForEachLoopGen(other,father,editionOnly) { }
◆ ~ForEachLoop()
YACS::ENGINE::ForEachLoop::~ForEachLoop ( )
Definition at line 240 of file ForEachLoop.hxx.
240{ }
◆ accept()
void ForEachLoop::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::DynParaLoop.
Definition at line 1288 of file ForEachLoop.cxx.
1289{
1290 visitor->visitForEachLoop(this);
1291}
virtual void visitForEachLoop(ForEachLoop *node)=0
References YACS::ENGINE::Visitor::visitForEachLoop().
◆ simpleClone()
Node * ForEachLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly = true
Definition at line 1283 of file ForEachLoop.cxx.
1284{
1285 return new ForEachLoop(*this,father,editionOnly);
1286}
friend class ForEachLoop
Definition: Node.hxx:78
References YACS::ENGINE::Node::ForEachLoop.
