YACS::ENGINE::FakeNodeForForEachLoop Class Reference
#include <ForEachLoop.hxx>
Inheritance diagram for YACS::ENGINE::FakeNodeForForEachLoop:
Collaboration diagram for YACS::ENGINE::FakeNodeForForEachLoop:
 FakeNodeForForEachLoop (ForEachLoopGen *loop, bool normalFinish)
 FakeNodeForForEachLoop (const FakeNodeForForEachLoop &other)
Node * simpleClone (ComposedNode *father, bool editionOnly) const
void exForwardFailed ()
void exForwardFinished ()
void execute ()
void aborted ()
void finished ()
ForEachLoopGen * _loop
bool _normalFinish
Static Private Attributes
static const char NAME [] ="thisIsAFakeNode"
Friends
class ForEachLoopGen
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
YACS::Colour _colour
template<class PORT >
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 107 of file ForEachLoop.hxx.
◆ FakeNodeForForEachLoop() [1/2]
FakeNodeForForEachLoop::FakeNodeForForEachLoop ( ForEachLoopGen *  loop,
bool  normalFinish
Definition at line 260 of file ForEachLoop.cxx.
261 _loop(loop),
262 _normalFinish(normalFinish)
263{
266}
Definition: Node.hxx:90
friend class ElementaryNode
Definition: Node.hxx:80
ComposedNode * getFather() const
Definition: Node.hxx:127
Definition: Node.hxx:91
@ TOACTIVATE
Definition: define.hxx:40
References YACS::ENGINE::Node::_father, _loop, YACS::ENGINE::Node::_state, YACS::ENGINE::Node::getFather(), and YACS::TOACTIVATE.
Referenced by simpleClone().
◆ FakeNodeForForEachLoop() [2/2]
FakeNodeForForEachLoop::FakeNodeForForEachLoop ( const FakeNodeForForEachLoop &  other)
Definition at line 268 of file ForEachLoop.cxx.
268 :ElementaryNode(other),_loop(0),
269 _normalFinish(false)
270{
271}
◆ aborted()
void FakeNodeForForEachLoop::aborted ( )
privatevirtual
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 296 of file ForEachLoop.cxx.
297{
299}
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
@ ERROR
Definition: define.hxx:52
References _loop, YACS::ERROR, and YACS::ENGINE::Node::setState().
◆ execute()
void FakeNodeForForEachLoop::execute ( )
privatevirtual
Implements YACS::ENGINE::Task.
Definition at line 288 of file ForEachLoop.cxx.
289{
290 if(!_normalFinish)
291 throw Exception("");//only to trigger ABORT on Executor
292 else
294}
References _loop, _normalFinish, and YACS::ENGINE::ForEachLoopGen::pushAllSequenceValues().
◆ exForwardFailed()
void FakeNodeForForEachLoop::exForwardFailed ( )
privatevirtual
Called typically by Bloc to notify failure on potentially next nodes on the same scope of 'this'
Reimplemented from YACS::ENGINE::Node.
Definition at line 278 of file ForEachLoop.cxx.
279{
281}
virtual void exForwardFailed()
Definition: Node.cxx:378
References _loop, and YACS::ENGINE::Node::exForwardFailed().
◆ exForwardFinished()
void FakeNodeForForEachLoop::exForwardFinished ( )
privatevirtual
Called typically by Bloc to activate potentially next nodes on the same scope of 'this'
Definition at line 283 of file ForEachLoop.cxx.
284{
286}
virtual void exForwardFinished()
Definition: Node.cxx:386
References _loop, and YACS::ENGINE::Node::exForwardFinished().
◆ finished()
void FakeNodeForForEachLoop::finished ( )
privatevirtual
Definition at line 301 of file ForEachLoop.cxx.
302{
304}
@ DONE
Definition: define.hxx:43
References _loop, YACS::DONE, and YACS::ENGINE::Node::setState().
◆ simpleClone()
Node * FakeNodeForForEachLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly
privatevirtual
Definition at line 273 of file ForEachLoop.cxx.
274{
275 return new FakeNodeForForEachLoop(*this);
276}
FakeNodeForForEachLoop(ForEachLoopGen *loop, bool normalFinish)
References FakeNodeForForEachLoop().
◆ ForEachLoopGen
friend class ForEachLoopGen
friend
Definition at line 109 of file ForEachLoop.hxx.
◆ _loop
ForEachLoopGen* YACS::ENGINE::FakeNodeForForEachLoop::_loop
◆ _normalFinish
bool YACS::ENGINE::FakeNodeForForEachLoop::_normalFinish
Definition at line 112 of file ForEachLoop.hxx.
Referenced by execute().
◆ NAME
const char FakeNodeForForEachLoop::NAME ="thisIsAFakeNode"
staticprivate
Definition at line 123 of file ForEachLoop.hxx.
