YACS::ENGINE::InterceptorInputPort Class Reference
#include <ForEachLoop.hxx>
Inheritance diagram for YACS::ENGINE::InterceptorInputPort:
Collaboration diagram for YACS::ENGINE::InterceptorInputPort:
 InterceptorInputPort (const std::string &name, Node *node, TypeCode *type)
 InterceptorInputPort (const InterceptorInputPort &other, Node *newHelder)
void setRepr (AnySplitOutputPort *repr)
AnySplitOutputPort * _repr
Friends
class ForEachLoopGen
class SplitterNode
- Public Member Functions inherited from YACS::ENGINE::AnyInputPort
 AnyInputPort (const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
 AnyInputPort (const AnyInputPort &other, Node *newHelder)
virtual ~AnyInputPort ()
void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
void exRestoreInit ()
 Restore the saved data value to current data value. More...
Any * getValue () const
int getIntValue () const
void releaseData () override
void put (Any *data)
void * get () const
virtual bool isEmpty ()
void put (const void *data)
std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
- Protected Member Functions inherited from YACS::ENGINE::AnyInputPort
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
- Protected Attributes inherited from YACS::ENGINE::AnyInputPort
Any * _value
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 40 of file ForEachLoop.hxx.
◆ InterceptorInputPort() [1/2]
InterceptorInputPort::InterceptorInputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 59 of file ForEachLoop.cxx.
59 :AnyInputPort(name,node,type),
60 DataPort(name,node,type),Port(node),
61 _repr(0)
62{
63}
AnyInputPort(const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
Definition: DataPort.cxx:41
Port(Node *node)
Definition: Port.cxx:34
◆ InterceptorInputPort() [2/2]
InterceptorInputPort::InterceptorInputPort ( const InterceptorInputPort &  other,
Node *  newHelder
Definition at line 65 of file ForEachLoop.cxx.
65 :AnyInputPort(other,newHelder),DataPort(other,newHelder),
66 Port(other,newHelder),
67 _repr(0)
68{
69}
◆ clone()
InputPort * InterceptorInputPort::clone ( Node *  newHelder) const
privatevirtual
Reimplemented from YACS::ENGINE::AnyInputPort.
Definition at line 78 of file ForEachLoop.cxx.
79{
80 return new InterceptorInputPort(*this,newHelder);
81}
friend class InterceptorInputPort
Definition: InPort.hxx:61
References YACS::ENGINE::InPort::InterceptorInputPort.
◆ getAllRepresentants()
void InterceptorInputPort::getAllRepresentants ( std::set< InPort * > &  repr) const
privatevirtual
Reimplemented from YACS::ENGINE::InPort.
Definition at line 71 of file ForEachLoop.cxx.
72{
73 set<InPort *> ports=_repr->edSetInPort();
74 for(set<InPort *>::iterator iter=ports.begin();iter!=ports.end();iter++)
75 (*iter)->getAllRepresentants(repr);
76}
std::set< InPort * > edSetInPort() const
Definition: OutputPort.cxx:239
References _repr, and YACS::ENGINE::OutputPort::edSetInPort().
◆ setRepr()
void InterceptorInputPort::setRepr ( AnySplitOutputPort *  repr)
Definition at line 83 of file ForEachLoop.cxx.
84{
85 _repr=repr;
86}
References _repr.
Referenced by YACS::ENGINE::ForEachLoopGen::buildDelegateOf(), and YACS::ENGINE::ForEachLoopGen::ForEachLoopGen().
◆ ForEachLoopGen
friend class ForEachLoopGen
friend
Definition at line 42 of file ForEachLoop.hxx.
◆ SplitterNode
friend class SplitterNode
friend
Definition at line 43 of file ForEachLoop.hxx.
◆ _repr
AnySplitOutputPort* YACS::ENGINE::InterceptorInputPort::_repr
Definition at line 45 of file ForEachLoop.hxx.
Referenced by getAllRepresentants(), and setRepr().
