YACS::ENGINE::SplitterNode Class Reference
#include <ForEachLoop.hxx>
Inheritance diagram for YACS::ENGINE::SplitterNode:
Collaboration diagram for YACS::ENGINE::SplitterNode:
 SplitterNode (const std::string &name, TypeCode *typeOfData, ForEachLoopGen *father)
 SplitterNode (const SplitterNode &other, ForEachLoopGen *father)
Node * simpleClone (ComposedNode *father, bool editionOnly) const
unsigned getNumberOfElements () const
void execute ()
void init (bool start=true)
void putSplittedValueOnRankTo (int rankInSeq, int branch, bool first)
SeqAnyInputPort _dataPortToDispatch
Static Private Attributes
static const char NAME_OF_SEQUENCE_INPUT [] ="SmplsCollection"
Friends
class ForEachLoopGen
virtual ~ElementaryNode ()
void exUpdateState ()
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
YACS::Colour _colour
template<class PORT >
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 89 of file ForEachLoop.hxx.
◆ SplitterNode() [1/2]
SplitterNode::SplitterNode ( const std::string &  name,
TypeCode *  typeOfData,
ForEachLoopGen *  father
Definition at line 210 of file ForEachLoop.cxx.
211 :ElementaryNode(name),
213 this,(TypeCodeSeq *)TypeCode::sequenceTc("","",typeOfData))
214{
215 _father=father;
216}
Definition: Node.hxx:90
friend class ElementaryNode
Definition: Node.hxx:80
static const char NAME_OF_SEQUENCE_INPUT[]
Definition: ForEachLoop.hxx:93
Class for sequence objects.
Definition: TypeCode.hxx:160
static TypeCode * sequenceTc(const char *id, const char *name, TypeCode *content)
static factory of sequence type given an id, a name and a content type
Definition: TypeCode.cxx:254
References YACS::ENGINE::Node::_father.
Referenced by simpleClone().
◆ SplitterNode() [2/2]
SplitterNode::SplitterNode ( const SplitterNode &  other,
Definition at line 218 of file ForEachLoop.cxx.
218 :ElementaryNode(other,father),
220{
221}
◆ execute()
void SplitterNode::execute ( )
privatevirtual
Implements YACS::ENGINE::Task.
Definition at line 241 of file ForEachLoop.cxx.
242{
243 //Nothing : should never been called elsewhere big problem...
244}
◆ getInputPort()
InputPort * SplitterNode::getInputPort ( const std::string &  name) const
privatevirtual
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 223 of file ForEachLoop.cxx.
224{
225 if(name==NAME_OF_SEQUENCE_INPUT)
227 else
228 return ElementaryNode::getInputPort(name);
229}
InputPort * getInputPort(const std::string &name) const
Base class for Input Ports.
Definition: InputPort.hxx:44
References _dataPortToDispatch, YACS::ENGINE::ElementaryNode::getInputPort(), and NAME_OF_SEQUENCE_INPUT.
◆ getNumberOfElements()
◆ init()
void SplitterNode::init ( bool  start = true)
privatevirtual
initialisation of all input and output ports and gates, for execution
Definition at line 246 of file ForEachLoop.cxx.
247{
250}
void init(bool start=true)
virtual void exInit(bool start)
Definition: InputPort.cxx:63
References _dataPortToDispatch, YACS::ENGINE::InputPort::exInit(), and YACS::ENGINE::ElementaryNode::init().
Referenced by YACS::ENGINE::ForEachLoopGen::init().
◆ putSplittedValueOnRankTo()
void SplitterNode::putSplittedValueOnRankTo ( int  rankInSeq,
int  branch,
bool  first
Definition at line 252 of file ForEachLoop.cxx.
253{
254 Any *valueToDispatch=_dataPortToDispatch.getValueAtRank(rankInSeq);
255 ForEachLoopGen *fatherTyped=(ForEachLoopGen *)_father;
256 fatherTyped->putValueOnBranch(valueToDispatch,branch,first);
257 valueToDispatch->decrRef();
258}
Definition: Any.hxx:79
void putValueOnBranch(Any *val, unsigned branchId, bool first)
Any * getValueAtRank(int i) const
References _dataPortToDispatch, YACS::ENGINE::Node::_father, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::SeqAnyInputPort::getValueAtRank(), and YACS::ENGINE::DynParaLoop::putValueOnBranch().
Referenced by YACS::ENGINE::ForEachLoopGen::exUpdateState(), and YACS::ENGINE::ForEachLoopGen::updateStateForWorkNodeOnFinishedEventFrom().
◆ simpleClone()
Node * SplitterNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
privatevirtual
Definition at line 231 of file ForEachLoop.cxx.
232{
233 return new SplitterNode(*this,(ForEachLoopGen *)father);
234}
SplitterNode(const std::string &name, TypeCode *typeOfData, ForEachLoopGen *father)
References SplitterNode().
◆ ForEachLoopGen
friend class ForEachLoopGen
friend
Definition at line 91 of file ForEachLoop.hxx.
◆ _dataPortToDispatch
◆ NAME_OF_SEQUENCE_INPUT
const char SplitterNode::NAME_OF_SEQUENCE_INPUT ="SmplsCollection"
staticprivate
Definition at line 93 of file ForEachLoop.hxx.
Referenced by getInputPort(), and YACS::ENGINE::ForEachLoopGen::getInputPort().
