YACS::ENGINE::SeqAnyInputPort Class Reference
#include <ForEachLoop.hxx>
Inheritance diagram for YACS::ENGINE::SeqAnyInputPort:
Collaboration diagram for YACS::ENGINE::SeqAnyInputPort:
unsigned getNumberOfElements () const
virtual std::string dump ()
- Public Member Functions inherited from YACS::ENGINE::AnyInputPort
 AnyInputPort (const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
 AnyInputPort (const AnyInputPort &other, Node *newHelder)
virtual ~AnyInputPort ()
void exSaveInit ()
 Save the current data value for further reinitialization of the port. More...
void exRestoreInit ()
 Restore the saved data value to current data value. More...
Any * getValue () const
int getIntValue () const
void releaseData () override
void put (Any *data)
void * get () const
virtual bool isEmpty ()
void put (const void *data)
std::string dump ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual void releaseData ()=0
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
 SeqAnyInputPort (const std::string &name, Node *node, TypeCodeSeq *type)
 SeqAnyInputPort (const SeqAnyInputPort &other, Node *newHelder)
Any * getValueAtRank (int i) const
Friends
class ForEachLoopGen
class SplitterNode
- Protected Member Functions inherited from YACS::ENGINE::AnyInputPort
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
- Protected Attributes inherited from YACS::ENGINE::AnyInputPort
Any * _value
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 75 of file ForEachLoop.hxx.
◆ SeqAnyInputPort() [1/2]
SeqAnyInputPort::SeqAnyInputPort ( const std::string &  name,
Node *  node,
TypeCodeSeq *  type
Definition at line 147 of file ForEachLoop.cxx.
147 :AnyInputPort(name,node,type),DataPort(name,node,type),Port(node)
148{
149 _type->decrRef();
150}
AnyInputPort(const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
Definition: DataPort.cxx:41
Port(Node *node)
Definition: Port.cxx:34
References YACS::ENGINE::DataPort::_type, and YACS::ENGINE::RefCounter::decrRef().
Referenced by clone().
◆ SeqAnyInputPort() [2/2]
SeqAnyInputPort::SeqAnyInputPort ( const SeqAnyInputPort &  other,
Node *  newHelder
Definition at line 152 of file ForEachLoop.cxx.
152 :AnyInputPort(other,newHelder),DataPort(other,newHelder),Port(other,newHelder)
153{
154}
◆ clone()
InputPort * SeqAnyInputPort::clone ( Node *  newHelder) const
privatevirtual
Reimplemented from YACS::ENGINE::AnyInputPort.
Definition at line 156 of file ForEachLoop.cxx.
157{
158 return new SeqAnyInputPort(*this,newHelder);
159}
SeqAnyInputPort(const std::string &name, Node *node, TypeCodeSeq *type)
References SeqAnyInputPort().
◆ dump()
std::string SeqAnyInputPort::dump ( )
Definition at line 176 of file ForEachLoop.cxx.
177{
178 stringstream xmldump;
179 int nbElem = getNumberOfElements();
180 xmldump << "<value><array><data>" << endl;
181 for (int i = 0; i < nbElem; i++)
182 {
183 Any *val = getValueAtRank(i);
184 switch (((YACS::ENGINE::TypeCodeSeq *)edGetType())->contentType()->kind())
185 {
186 case Double:
187 xmldump << "<value><double>" << setprecision(16) << val->getDoubleValue() << "</double></value>" << endl;
188 break;
189 case Int:
190 xmldump << "<value><int>" << val->getIntValue() << "</int></value>" << endl;
191 break;
192 case Bool:
193 xmldump << "<value><boolean>" << val->getBoolValue() << "</boolean></value>" << endl;
194 break;
195 case String:
196 xmldump << "<value><string>" << val->getStringValue() << "</string></value>" << endl;
197 break;
198 case Objref:
199 xmldump << "<value><objref>" << ToBase64(val->getStringValue()) << "</objref></value>" << endl;
200 break;
201 default:
202 xmldump << "<value><error> NO_SERIALISATION_AVAILABLE </error></value>" << endl;
203 break;
204 }
205 }
206 xmldump << "</data></array></value>" << endl;
207 return xmldump.str();
208}
Definition: Any.hxx:79
virtual std::string getStringValue() const =0
virtual int getIntValue() const =0
virtual double getDoubleValue() const =0
virtual bool getBoolValue() const =0
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Any * getValueAtRank(int i) const
unsigned getNumberOfElements() const
Class for sequence objects.
Definition: TypeCode.hxx:160
YACSLIBENGINE_EXPORT std::string ToBase64(const std::string &bytes)
Definition: Any.cxx:85
References YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::Any::getBoolValue(), YACS::ENGINE::Any::getDoubleValue(), YACS::ENGINE::Any::getIntValue(), getNumberOfElements(), YACS::ENGINE::Any::getStringValue(), getValueAtRank(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::Int, YACS::ENGINE::Objref, YACS::ENGINE::String, and YACS::ENGINE::ToBase64().
◆ getNumberOfElements()
unsigned SeqAnyInputPort::getNumberOfElements ( ) const
Definition at line 161 of file ForEachLoop.cxx.
162{
163 const SequenceAny * valCsted=(const SequenceAny *) _value;
164 if (valCsted) return valCsted->size();
165 return 0;
166}
unsigned int size() const
Definition: Any.hxx:209
References YACS::ENGINE::AnyInputPort::_value, and YACS::ENGINE::SequenceAny::size().
Referenced by dump(), and YACS::ENGINE::SplitterNode::getNumberOfElements().
◆ getValueAtRank()
Any * SeqAnyInputPort::getValueAtRank ( int  i) const
Definition at line 168 of file ForEachLoop.cxx.
169{
170 const SequenceAny * valCsted=(const SequenceAny *) _value;
171 AnyPtr ret=(*valCsted)[i];
172 ret->incrRef();
173 return ret;
174}
: Allow to manage memory of instances of T. The only constraint on T is to have method incrRef and De...
Definition: SharedPtr.hxx:30
References YACS::ENGINE::AnyInputPort::_value, and yacsorb.CORBAEngineTest::i.
Referenced by dump(), and YACS::ENGINE::SplitterNode::putSplittedValueOnRankTo().
◆ ForEachLoopGen
friend class ForEachLoopGen
friend
Definition at line 77 of file ForEachLoop.hxx.
◆ SplitterNode
friend class SplitterNode
friend
Definition at line 78 of file ForEachLoop.hxx.
