YACS::ENGINE::AnySplitOutputPort Class Reference
#include <ForEachLoop.hxx>
Inheritance diagram for YACS::ENGINE::AnySplitOutputPort:
Collaboration diagram for YACS::ENGINE::AnySplitOutputPort:
bool decrRef ()
void incrRef () const
 AnySplitOutputPort (const std::string &name, Node *node, TypeCode *type)
 AnySplitOutputPort (const AnySplitOutputPort &other, Node *newHelder)
bool addInPort (InPort *inPort)
void getAllRepresented (std::set< OutPort * > &represented) const
int removeInPort (InPort *inPort, bool forward)
void addRepr (OutPort *repr, InterceptorInputPort *intercptr)
OutPort * getRepr () const
OutputPort * clone (Node *newHelder) const
OutPort * _repr
InterceptorInputPort * _intercptr
unsigned int _cnt
Friends
class ForEachLoopGen
class SplitterNode
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual std::string dump ()
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 54 of file ForEachLoop.hxx.
◆ AnySplitOutputPort() [1/2]
AnySplitOutputPort::AnySplitOutputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 98 of file ForEachLoop.cxx.
98 :OutputPort(name,node,type),
99 DataPort(name,node,type),Port(node),
100 _repr(0),_intercptr(0),_cnt(1)
101{
102}
Definition: ForEachLoop.hxx:60
Definition: DataPort.cxx:41
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ AnySplitOutputPort() [2/2]
AnySplitOutputPort::AnySplitOutputPort ( const AnySplitOutputPort &  other,
Node *  newHelder
Definition at line 104 of file ForEachLoop.cxx.
104 :OutputPort(other,newHelder),
105 DataPort(other,newHelder),
106 Port(other,newHelder),
107 _repr(0),_intercptr(0),_cnt(1)
108{
109}
◆ addInPort()
bool AnySplitOutputPort::addInPort ( InPort *  inPort)
privatevirtual
Implements YACS::ENGINE::OutPort.
Definition at line 111 of file ForEachLoop.cxx.
112{
113 bool ret=OutputPort::addInPort(inPort);
114 if(_repr)
116 return ret;
117}
virtual bool addInPort(InPort *inPort)=0
Definition: OutputPort.cxx:205
References _intercptr, _repr, YACS::ENGINE::OutputPort::addInPort(), and YACS::ENGINE::OutPort::addInPort().
◆ addRepr()
void AnySplitOutputPort::addRepr ( OutPort *  repr,
InterceptorInputPort *  intercptr
Definition at line 136 of file ForEachLoop.cxx.
137{
138 _repr=repr;
139 _intercptr=intercptr;
140}
References _intercptr, and _repr.
Referenced by YACS::ENGINE::ForEachLoopGen::buildDelegateOf(), and YACS::ENGINE::ForEachLoopGen::ForEachLoopGen().
◆ clone()
OutputPort * AnySplitOutputPort::clone ( Node *  newHelder) const
privatevirtual
Implements YACS::ENGINE::OutputPort.
Definition at line 142 of file ForEachLoop.cxx.
143{
144 return new AnySplitOutputPort(*this,newHelder);
145}
AnySplitOutputPort(const std::string &name, Node *node, TypeCode *type)
Definition: ForEachLoop.cxx:98
References AnySplitOutputPort().
◆ decrRef()
bool AnySplitOutputPort::decrRef ( )
Definition at line 88 of file ForEachLoop.cxx.
89{
90 return (--_cnt==0);
91}
References _cnt.
◆ getAllRepresented()
void AnySplitOutputPort::getAllRepresented ( std::set< OutPort * > &  represented) const
privatevirtual
Reimplemented from YACS::ENGINE::OutPort.
Definition at line 119 of file ForEachLoop.cxx.
120{
121 if(!_repr)
122 OutPort::getAllRepresented(represented);
123 else
124 _repr->getAllRepresented(represented);
125}
virtual void getAllRepresented(std::set< OutPort * > &represented) const
Definition: OutPort.cxx:45
References _repr, and YACS::ENGINE::OutPort::getAllRepresented().
◆ getRepr()
OutPort * YACS::ENGINE::AnySplitOutputPort::getRepr ( ) const
inlineprivate
Definition at line 71 of file ForEachLoop.hxx.
71{ return _repr; }
References _repr.
◆ incrRef()
void AnySplitOutputPort::incrRef ( ) const
Definition at line 93 of file ForEachLoop.cxx.
94{
95 _cnt++;
96}
References _cnt.
◆ removeInPort()
int AnySplitOutputPort::removeInPort ( InPort *  inPort,
bool  forward
privatevirtual
Definition at line 127 of file ForEachLoop.cxx.
128{
129 bool ret=OutputPort::removeInPort(inPort,forward);
130 if(_repr)
131 if(_setOfInputPort.empty())
132 _repr->removeInPort(_intercptr,forward);
133 return ret;
134}
virtual int removeInPort(InPort *inPort, bool forward)=0
Definition: OutputPort.cxx:228
Definition: OutputPort.hxx:77
References _intercptr, _repr, YACS::ENGINE::OutputPort::_setOfInputPort, YACS::ENGINE::OutputPort::removeInPort(), and YACS::ENGINE::OutPort::removeInPort().
◆ ForEachLoopGen
friend class ForEachLoopGen
friend
Definition at line 56 of file ForEachLoop.hxx.
◆ SplitterNode
friend class SplitterNode
friend
Definition at line 57 of file ForEachLoop.hxx.
◆ _cnt
unsigned int YACS::ENGINE::AnySplitOutputPort::_cnt
mutableprivate
Definition at line 61 of file ForEachLoop.hxx.
Referenced by decrRef(), and incrRef().
◆ _intercptr
InterceptorInputPort* YACS::ENGINE::AnySplitOutputPort::_intercptr
Definition at line 60 of file ForEachLoop.hxx.
Referenced by addInPort(), addRepr(), and removeInPort().
◆ _repr
OutPort* YACS::ENGINE::AnySplitOutputPort::_repr
Definition at line 59 of file ForEachLoop.hxx.
Referenced by addInPort(), addRepr(), getAllRepresented(), getRepr(), and removeInPort().
