YACS::ENGINE::InlineFuncNode Class Reference
Class for calculation node (function) inlined (and executed) in the schema. More...
#include <InlineNode.hxx>
Inheritance diagram for YACS::ENGINE::InlineFuncNode:
Collaboration diagram for YACS::ENGINE::InlineFuncNode:
virtual void setFname (const std::string &fname)
 Set the function name to use in node execution. More...
virtual std::string getFname ()
virtual ~InlineFuncNode ()
- Public Member Functions inherited from YACS::ENGINE::InlineNode
virtual void setScript (const std::string &script)
 Set the script (as a string) to execute. More...
virtual std::string getScript ()
virtual InlineNode * cloneNode (const std::string &name)
 Return a new InlineNode node by making a copy of this node. More...
virtual ~InlineNode ()
virtual void setExecutionMode (const std::string &mode)
virtual std::string getExecutionMode ()
virtual void setContainer (Container *container)
virtual Container * getContainer ()
bool isDeployable () const
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
 InlineFuncNode (const InlineFuncNode &other, ComposedNode *father)
 InlineFuncNode (const std::string &name)
- Protected Member Functions inherited from YACS::ENGINE::InlineNode
 InlineNode (const InlineNode &other, ComposedNode *father)
 InlineNode (const std::string &name)
template<class PORT >
std::string _fname
- Protected Attributes inherited from YACS::ENGINE::InlineNode
std::string _script
std::string _mode
Container * _container
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::InlineNode
static const char LOCAL_STR [] ="local"
static const char REMOTE_STR [] ="remote"
static int _total = 0
This node is like a function. It can have a state. The first time the node is executed, the string _script is executed in a clean context followed by the execution of the function _fname. Next times, the function _fname is executed within the preserved context.
See also
ServiceNode
ElementaryNode
Definition at line 92 of file InlineNode.hxx.
◆ InlineFuncNode() [1/2]
YACS::ENGINE::InlineFuncNode::InlineFuncNode ( const InlineFuncNode &  other,
ComposedNode *  father
inlineprotected
Definition at line 95 of file InlineNode.hxx.
96 :InlineNode(other,father),_fname(other._fname) { }
InlineNode(const InlineNode &other, ComposedNode *father)
Definition: InlineNode.hxx:46
◆ InlineFuncNode() [2/2]
YACS::ENGINE::InlineFuncNode::InlineFuncNode ( const std::string &  name)
inlineprotected
Definition at line 97 of file InlineNode.hxx.
97:InlineNode(name) { }
◆ ~InlineFuncNode()
InlineFuncNode::~InlineFuncNode ( )
Definition at line 57 of file InlineNode.cxx.
58{
59}
◆ accept()
void InlineFuncNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::InlineNode.
Reimplemented in YACS::ENGINE::ServerNode.
Definition at line 61 of file InlineNode.cxx.
62{
63 visitor->visitInlineFuncNode(this);
64}
virtual void visitInlineFuncNode(InlineFuncNode *node)=0
References YACS::ENGINE::Visitor::visitInlineFuncNode().
◆ checkBasicConsistency()
void InlineFuncNode::checkBasicConsistency ( ) const
Reimplemented from YACS::ENGINE::ElementaryNode.
Reimplemented in YACS::ENGINE::PyFuncNode.
Definition at line 75 of file InlineNode.cxx.
76{
78 if(_fname.empty() )
79 {
80 string mess = "Function name is not defined";
81 throw Exception(mess);
82 }
83}
References _fname, and YACS::ENGINE::ElementaryNode::checkBasicConsistency().
Referenced by YACS::ENGINE::PyFuncNode::checkBasicConsistency().
◆ getFname()
◆ setFname()
void InlineFuncNode::setFname ( const std::string &  fname)
fnamename of the function contained in the script to execute
Definition at line 69 of file InlineNode.cxx.
70{
71 _fname=fname;
72 modified();
73}
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
References _fname, and YACS::ENGINE::Node::modified().
Referenced by YACS::inlinetypeParser< T >::function(), YACS::remotetypeParser< T >::function(), and YACS::servertypeParser< T >::method().
◆ typeName()
virtual std::string YACS::ENGINE::InlineFuncNode::typeName ( )
Reimplemented in YACS::ENGINE::ServerNode, YACS::ENGINE::DistributedPythonNode, and YACS::ENGINE::PyFuncNode.
Definition at line 104 of file InlineNode.hxx.
104{ return "YACS__ENGINE__InlineFuncNode"; }
◆ _fname
std::string YACS::ENGINE::InlineFuncNode::_fname
