YACS::ENGINE::DistributedPythonNode Class Reference
#include <DistributedPythonNode.hxx>
Inheritance diagram for YACS::ENGINE::DistributedPythonNode:
Collaboration diagram for YACS::ENGINE::DistributedPythonNode:
 DistributedPythonNode (const std::string &name)
 DistributedPythonNode (const DistributedPythonNode &other, ComposedNode *father)
 ~DistributedPythonNode ()
void execute ()
void load ()
std::string getEffectiveKindOfServer () const
 this method returns the type of container expected More...
std::string getKind () const
 this method returns the type of input/output expected More...
ServerNode * createNode (const std::string &name) const
- Public Member Functions inherited from YACS::ENGINE::ServerNode
 ServerNode (const std::string &name)
 ServerNode (const ServerNode &other, ComposedNode *father)
void load ()
virtual ServerNode * createNode (const std::string &name) const =0
bool isDeployable () const
 By definition of ServerNode class. More...
virtual std::string getEffectiveKindOfServer () const =0
virtual ~ServerNode ()
- Public Member Functions inherited from YACS::ENGINE::InlineFuncNode
virtual void setFname (const std::string &fname)
 Set the function name to use in node execution. More...
virtual std::string getFname ()
virtual ~InlineFuncNode ()
- Public Member Functions inherited from YACS::ENGINE::InlineNode
virtual void setScript (const std::string &script)
 Set the script (as a string) to execute. More...
virtual std::string getScript ()
virtual InlineNode * cloneNode (const std::string &name)
 Return a new InlineNode node by making a copy of this node. More...
virtual ~InlineNode ()
virtual void setExecutionMode (const std::string &mode)
virtual std::string getExecutionMode ()
virtual void setContainer (Container *container)
virtual Container * getContainer ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char KIND [] ="DistPython"
static const char IMPL_NAME [] ="Python"
static const char SALOME_CONTAINER_METHOD_IDL [] ="createPyNode"
- Static Public Attributes inherited from YACS::ENGINE::InlineNode
static const char LOCAL_STR [] ="local"
static const char REMOTE_STR [] ="remote"
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::InlineFuncNode
 InlineFuncNode (const InlineFuncNode &other, ComposedNode *father)
 InlineFuncNode (const std::string &name)
- Protected Member Functions inherited from YACS::ENGINE::InlineNode
 InlineNode (const InlineNode &other, ComposedNode *father)
 InlineNode (const std::string &name)
template<class PORT >
PyObject * _context
PyObject * _pyfuncSer
PyObject * _pyfuncUnser
Engines::PyNode_var _pynode
- Protected Attributes inherited from YACS::ENGINE::InlineFuncNode
std::string _fname
- Protected Attributes inherited from YACS::ENGINE::InlineNode
std::string _script
std::string _mode
Container * _container
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
void initMySelf ()
void dealException (CORBA::Exception *exc, const char *method, const char *ref)
YACS::Colour _colour
static int _total = 0
Definition at line 44 of file DistributedPythonNode.hxx.
◆ DistributedPythonNode() [1/2]
DistributedPythonNode::DistributedPythonNode ( const std::string &  name)
◆ DistributedPythonNode() [2/2]
DistributedPythonNode::DistributedPythonNode ( const DistributedPythonNode &  other,
ComposedNode *  father
Definition at line 49 of file DistributedPythonNode.cxx.
49 :ServerNode(other,father),_context(0),_pyfuncSer(0),_pyfuncUnser(0)
50{
51 initMySelf();
52}
References initMySelf().
◆ ~DistributedPythonNode()
DistributedPythonNode::~DistributedPythonNode ( )
Definition at line 54 of file DistributedPythonNode.cxx.
55{
56 AutoGIL agil;
57 Py_DECREF(_context);
58}
References _context.
◆ createNode()
ServerNode * DistributedPythonNode::createNode ( const std::string &  name) const
◆ dealException()
void DistributedPythonNode::dealException ( CORBA::Exception *  exc,
const char *  method,
const char *  ref
Definition at line 295 of file DistributedPythonNode.cxx.
296{
297 if( exc )
298 {
299 GURU_YACSTRACE( "An exception was thrown!" );
300 GURU_YACSTRACE( "The raised exception is of Type:" << exc->_name() );
301
302 CORBA::SystemException* sysexc;
303 sysexc=CORBA::SystemException::_downcast(exc);
304 if(sysexc != NULL)
305 {
306 // It's a SystemException
307 GURU_YACSTRACE( "minor code: " << sysexc->minor() );
308 GURU_YACSTRACE( "completion code: " << sysexc->completed() );
309 std::string text="Execution problem: ";
310 std::string excname=sysexc->_name();
311 if(excname == "BAD_OPERATION")
312 {
313 text=text+"bad operation detected";
314 }
315 else if(excname == "MARSHAL" && sysexc->minor() == omni::MARSHAL_PassEndOfMessage)
316 {
317 text=text+"probably an error in arguments of service '" + method + "' from component '" +ref+ "'";
318 }
319 else if(excname == "COMM_FAILURE" && sysexc->minor() == omni::COMM_FAILURE_UnMarshalResults)
320 {
321 text=text+"probably an error in output arguments of service '" + method + "' from component '" +ref+ "'";
322 }
323 else if(excname == "COMM_FAILURE" && sysexc->minor() == omni::COMM_FAILURE_UnMarshalArguments)
324 {
325 text=text+"probably an error in input arguments of service '" + method + "' from component '" +ref+ "'";
326 }
327 else if(excname == "COMM_FAILURE" && sysexc->minor() == omni::COMM_FAILURE_WaitingForReply)
328 {
329 text=text+"probably an error in input arguments of service '" + method + "' from component '" +ref+ "'";
330 }
331 else
332 {
333 GURU_YACSTRACE(sysexc->NP_minorString() );
334 text=text+"System Exception "+ excname;
335 }
336 _errorDetails=text;
337 throw Exception(text);
338 }
339
340 // Not a System Exception
341 CORBA::UnknownUserException* userexc;
342 userexc=CORBA::UnknownUserException::_downcast(exc);
343 if(userexc != NULL)
344 {
345 CORBA::Any anyExcept = userexc->exception();
346
347 const SALOME::SALOME_Exception* salexc;
348 if(anyExcept >>= salexc)
349 {
350 GURU_YACSTRACE("SALOME_Exception: "<< salexc->details.sourceFile);
351 GURU_YACSTRACE("SALOME_Exception: "<<salexc->details.lineNumber);
352 _errorDetails=salexc->details.text;
353 throw Exception("Execution problem: Salome Exception occurred" + getErrorDetails() );
354 }
355 std::string msg="Execution problem: User Exception occurred";
356 _errorDetails=msg;
357 throw Exception(msg);
358 }
359 std::string msg="Execution problem";
360 _errorDetails=msg;
361 throw Exception(msg);
362 }
363}
#define GURU_YACSTRACE(msg)
Definition: YacsTrace.hxx:55
virtual std::string getErrorDetails()
Give a description of error when node status is ERROR.
Definition: Node.hxx:93
Definition: CONNECTOR.py:120
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::ElementaryNode::getErrorDetails(), GURU_YACSTRACE, and gui.CONNECTOR::ref().
◆ execute()
void DistributedPythonNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 161 of file DistributedPythonNode.cxx.
162{
163 GURU_YACSTRACE("+++++++++++++++++ DistributedPythonNode::execute: " << getName() << " " << getFname() << " +++++++++++++++++" );
165 PyObject* ob;
166 if(!_pyfuncSer)
167 throw Exception("DistributedPythonNode badly loaded");
168 Engines::pickledArgs *serializationInputCorba(0);
169 PyObject *args(0);
170 {
171 AutoGIL agil;
172
173 GURU_YACSTRACE( "---------------DistributedPythonNode::inputs---------------" );
174 args = PyTuple_New(getNumberOfInputPorts()) ;
175 int pos=0;
176 for(list<InputPort *>::iterator iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++,pos++)
177 {
178 InputPyPort *p=(InputPyPort *)*iter2;
179 ob=p->getPyObj();
180 Py_INCREF(ob);
181 PyTuple_SetItem(args,pos,ob);
182 }
183 PyObject *serializationInput=PyObject_CallObject(_pyfuncSer,args);
184 Py_ssize_t len = PyBytes_Size(serializationInput);
185 char* serializationInputC = PyBytes_AsString(serializationInput);
186 //int ret = PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len);
187 serializationInputCorba=new Engines::pickledArgs;
188 serializationInputCorba->length(len+1);
189 for(int i=0;i<len+1;i++)
190 (*serializationInputCorba)[i]=serializationInputC[i];
191 Py_DECREF(serializationInput);
192 }
193 //serializationInputCorba[serializationInputC.length()]='\0';
194 DEBUG_YACSTRACE( "-----------------DistributedPythonNode starting remote python invocation-----------------" );
195 Engines::pickledArgs *resultCorba;
196 try
197 {
198 resultCorba=_pynode->execute(getFname().c_str(),*serializationInputCorba);
199 }
200 catch(...)
201 {
202 std::string msg="Exception on remote python invocation";
203 _errorDetails=msg;
204 throw Exception(msg);
205 }
206 DEBUG_YACSTRACE( "-----------------DistributedPythonNode end of remote python invocation-----------------" );
207 //
208 delete serializationInputCorba;
209 char *resultCorbaC=new char[resultCorba->length()+1];
210 resultCorbaC[resultCorba->length()]='\0';
211 for(int i=0;i<resultCorba->length();i++)
212 resultCorbaC[i]=(*resultCorba)[i];
213 int lenResCorba=resultCorba->length();
214 delete resultCorba;
215 {
216 AutoGIL agil;
217 args = PyTuple_New(1);
218 //PyObject* resultPython=PyBytes_FromString(resultCorbaC);
219 PyObject* resultPython=PyBytes_FromStringAndSize(resultCorbaC,lenResCorba);
220 delete [] resultCorbaC;
221 PyTuple_SetItem(args,0,resultPython);
222 PyObject *finalResult=PyObject_CallObject(_pyfuncUnser,args);
223 GURU_YACSTRACE( "-----------------DistributedPythonNode::outputs-----------------" );
224 if(finalResult == NULL)
225 {
226 std::stringstream msg;
227 msg << "Conversion with pickle of output ports failed !";
228 msg << " : " << __FILE__ << ":" << __LINE__;
229 _errorDetails=msg.str();
230 throw YACS::ENGINE::ConversionException(msg.str());
231 }
232 int nres=1;
233 if(finalResult == Py_None)
234 nres=0;
235 else if(PyTuple_Check(finalResult))
236 nres=PyTuple_Size(finalResult);
237
238 if(getNumberOfOutputPorts() != nres)
239 {
240 std::string msg="Number of output arguments : Mismatch between definition and execution";
241 Py_DECREF(finalResult);
242 _errorDetails=msg;
243 throw Exception(msg);
244 }
245 try
246 {
247 int pos(0);
248 for(list<OutputPort *>::iterator iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++, pos++)
249 {
250 OutputPyPort *p=(OutputPyPort *)*iter;
251 GURU_YACSTRACE( "port name: " << p->getName() );
252 GURU_YACSTRACE( "port kind: " << p->typeName() );
253 GURU_YACSTRACE( "port pos : " << pos );
254 if(PyTuple_Check(finalResult))ob=PyTuple_GetItem(finalResult,pos) ;
255 else ob=finalResult;
256 GURU_YACSTRACE( "ob refcnt: " << ob->ob_refcnt );
257 p->put(ob);
258 }
259 }
260 catch(ConversionException& ex)
261 {
262 Py_DECREF(finalResult);
263 _errorDetails=ex.what();
264 throw;
265 }
266 }
267 GURU_YACSTRACE( "++++++++++++++ End DistributedPythonNode::execute: " << getName() << " ++++++++++++++++++++" );
268}
int Py_ssize_t
Definition: PythonNode.cxx:45
#define DEBUG_YACSTRACE(msg)
Definition: YacsTrace.hxx:53
std::string getName() const
virtual std::string getFname()
Definition: InlineNode.hxx:101
Class for Python Ports.
Definition: PythonPorts.hxx:74
Definition: Node.hxx:125
virtual std::string typeName()
Definition: Proc.hxx:84
Proc * p
Definition: driver.cxx:216
References YACS::ENGINE::Node::_errorDetails, _pyfuncSer, _pyfuncUnser, _pynode, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, driver_internal::args, DEBUG_YACSTRACE, testCppPluginInvokation::ex, YACS::ENGINE::InlineFuncNode::getFname(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ElementaryNode::getNumberOfInputPorts(), YACS::ENGINE::ElementaryNode::getNumberOfOutputPorts(), GURU_YACSTRACE, yacsorb.CORBAEngineTest::i, p, and YACS::ENGINE::Proc::typeName().
◆ getEffectiveKindOfServer()
std::string DistributedPythonNode::getEffectiveKindOfServer ( ) const
Implements YACS::ENGINE::ServerNode.
Definition at line 270 of file DistributedPythonNode.cxx.
271{
272 return "Salome";
273}
◆ getKind()
std::string DistributedPythonNode::getKind ( ) const
not a bug : this is to use classical python port translators.
Definition at line 275 of file DistributedPythonNode.cxx.
276{
278 return PythonNode::KIND;
279}
static const char KIND[]
Definition: PythonNode.hxx:122
References YACS::ENGINE::PythonNode::KIND.
◆ initMySelf()
void DistributedPythonNode::initMySelf ( )
Definition at line 288 of file DistributedPythonNode.cxx.
289{
291 AutoGIL agil;
292 _context=PyDict_New();
293}
Definition: Node.hxx:97
References _context, YACS::ENGINE::Node::_implementation, and IMPL_NAME.
Referenced by DistributedPythonNode().
◆ load()
void DistributedPythonNode::load ( )
Reimplemented from YACS::ENGINE::ServerNode.
Definition at line 60 of file DistributedPythonNode.cxx.
61{
62 bool isContAlreadyStarted(false);
63 if(_container)
64 isContAlreadyStarted=_container->isAlreadyStarted(this);
66 {
67 AutoGIL agil;
68 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
69 {
70 stringstream msg;
71 msg << "Impossible to set builtins" << __FILE__ << ":" << __LINE__;
72 _errorDetails=msg.str();
73 throw Exception(msg.str());
74 }
75 const char picklizeScript[]="import pickle\ndef pickleForDistPyth2009(*args,**kws):\n return pickle.dumps((args,kws),-1)\n\ndef unPickleForDistPyth2009(st):\n args=pickle.loads(st)\n return args\n";
76 PyObject *res=PyRun_String(picklizeScript,Py_file_input,_context,_context);
77 if(res == NULL)
78 {
80 PyObject* new_stderr = newPyStdOut(_errorDetails);
81 PySys_SetObject((char*)"stderr", new_stderr);
82 PyErr_Print();
83 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
84 Py_DECREF(new_stderr);
85 throw Exception("Error during execution");
86 return;
87 }
88 Py_DECREF(res);
89 _pyfuncSer=PyDict_GetItemString(_context,"pickleForDistPyth2009");
90 _pyfuncUnser=PyDict_GetItemString(_context,"unPickleForDistPyth2009");
91 if(_pyfuncSer == NULL)
92 {
94 PyObject* new_stderr = newPyStdOut(_errorDetails);
95 PySys_SetObject((char*)"stderr", new_stderr);
96 PyErr_Print();
97 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
98 Py_DECREF(new_stderr);
99 throw Exception("Error during execution");
100 }
101 if(_pyfuncUnser == NULL)
102 {
103 _errorDetails="";
104 PyObject* new_stderr = newPyStdOut(_errorDetails);
105 PySys_SetObject((char*)"stderr", new_stderr);
106 PyErr_Print();
107 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
108 Py_DECREF(new_stderr);
109 throw Exception("Error during execution");
110 }
111
112 Engines::Container_var objContainer=Engines::Container::_nil();
113 if(!_container)
114 throw Exception("No container specified !");
115 SalomeContainer *containerCast0(dynamic_cast<SalomeContainer *>(_container));
116 SalomeHPContainer *containerCast1(dynamic_cast<SalomeHPContainer *>(_container));
117 if(containerCast0)
118 objContainer=containerCast0->getContainerPtr(this);
119 else if(containerCast1)
120 {
122 objContainer=tmpCont->getContainerPtr(this);
123 }
124 else
125 throw Exception("Unrecognized type of container ! Salome one is expected !");
126 if(CORBA::is_nil(objContainer))
127 throw Exception("Container corba pointer is NULL !");
128
129 try
130 {
131 if(containerCast0 || !isContAlreadyStarted)
132 {
133 _pynode = objContainer->createPyNode(getName().c_str(),getScript().c_str());
134 }
135 else
136 {
137 Engines::PyNode_var dftPyScript(objContainer->getDefaultPyNode(getName().c_str()));
138 if(CORBA::is_nil(dftPyScript))
139 _pynode = objContainer->createPyNode(getName().c_str(),getScript().c_str());
140 else
141 _pynode = dftPyScript;
142 }
143 }
144 catch( const SALOME::SALOME_Exception& ex )
145 {
146 std::string msg="Exception on remote python node creation ";
147 msg += '\n';
148 msg += ex.details.text.in();
149 _errorDetails=msg;
150 throw Exception(msg);
151 }
152
153 if(CORBA::is_nil(_pynode))
154 throw Exception("In DistributedPythonNode the ref in NULL ! ");
155
156
157 DEBUG_YACSTRACE( "---------------End PyfuncSerNode::load function---------------" );
158 }
159}
virtual bool isAlreadyStarted(const Task *askingNode) const =0
virtual std::string getScript()
Definition: InlineNode.hxx:51
static SalomeContainerTmpForHP * BuildFrom(const SalomeHPContainer *cont, const Task *askingNode)
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
References YACS::ENGINE::InlineNode::_container, _context, YACS::ENGINE::Node::_errorDetails, _pyfuncSer, _pyfuncUnser, _pynode, YACS::ENGINE::SalomeContainerTmpForHP::BuildFrom(), DEBUG_YACSTRACE, testCppPluginInvokation::ex, YACS::ENGINE::SalomeContainer::getContainerPtr(), YACS::ENGINE::Node::getName(), YACS::ENGINE::getSALOMERuntime(), YACS::ENGINE::InlineNode::getScript(), YACS::ENGINE::Container::isAlreadyStarted(), YACS::ENGINE::ServerNode::load(), and YACS::ENGINE::newPyStdOut().
◆ simpleClone()
Node * DistributedPythonNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 39 of file DistributedPythonNode.cxx.
40{
41 return new DistributedPythonNode(*this,father);
42}
References DistributedPythonNode().
◆ typeName()
virtual std::string YACS::ENGINE::DistributedPythonNode::typeName ( )
Definition at line 59 of file DistributedPythonNode.hxx.
59{return "YACS__ENGINE__DistributedPythonNode";}
◆ _context
PyObject* YACS::ENGINE::DistributedPythonNode::_context
Definition at line 68 of file DistributedPythonNode.hxx.
Referenced by initMySelf(), load(), and ~DistributedPythonNode().
◆ _pyfuncSer
PyObject* YACS::ENGINE::DistributedPythonNode::_pyfuncSer
Definition at line 69 of file DistributedPythonNode.hxx.
Referenced by execute(), and load().
◆ _pyfuncUnser
PyObject* YACS::ENGINE::DistributedPythonNode::_pyfuncUnser
Definition at line 70 of file DistributedPythonNode.hxx.
◆ _pynode
Engines::PyNode_var YACS::ENGINE::DistributedPythonNode::_pynode
Definition at line 71 of file DistributedPythonNode.hxx.
◆ IMPL_NAME
const char DistributedPythonNode::IMPL_NAME ="Python"
Definition at line 65 of file DistributedPythonNode.hxx.
Referenced by initMySelf().
◆ KIND
const char DistributedPythonNode::KIND ="DistPython"
◆ SALOME_CONTAINER_METHOD_IDL
const char DistributedPythonNode::SALOME_CONTAINER_METHOD_IDL ="createPyNode"
Definition at line 66 of file DistributedPythonNode.hxx.
