YACS::ENGINE::SalomeContainer Class Reference
#include <SalomeContainer.hxx>
Inheritance diagram for YACS::ENGINE::SalomeContainer:
Collaboration diagram for YACS::ENGINE::SalomeContainer:
 SalomeContainer ()
 SalomeContainer (const SalomeContainer &other)
 SalomeContainer (const Container &other, const SalomeContainerTools &sct, const SalomeContainerHelper *lmt, const std::vector< std::string > &componentNames, int shutdownLev)
void lock ()
 For thread safety for concurrent load operation on same Container. More...
void unLock ()
std::string getKind () const
bool isAlreadyStarted (const Task *askingNode) const
 Check if the component instance container is already started. More...
Engines::Container_ptr getContainerPtr (const Task *askingNode) const
void start (const Task *askingNode) override
 Start a salome container (true salome container not yacs one) with given ContainerParameters (_params) More...
void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name) override
bool canAcceptImposedResource () override
Container * clone () const
 WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method More...
Container * cloneAlways () const
std::string getPlacementId (const Task *askingNode) const
 Get the container placement id for a component instance. More...
std::string getFullPlacementId (const Task *askingNode) const
 Get the container full path for a component instance. More...
void checkCapabilityToDealWith (const ComponentInstance *inst) const
void setProperty (const std::string &name, const std::string &value)
std::string getProperty (const std::string &name) const
void clearProperties ()
void addComponentName (const std::string &name)
void addToResourceList (const std::string &name)
virtual CORBA::Object_ptr loadComponent (Task *inst)
 Load a component instance in this container. More...
void shutdown (int level)
std::map< std::string, std::string > getResourceProperties (const std::string &name) const
std::map< std::string, std::string > getProperties () const
- Public Member Functions inherited from YACS::ENGINE::Container
virtual std::string getKind () const =0
virtual std::string getDiscreminantStrOfThis (const Task *askingNode) const
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void start (const Task *askingNode)=0
virtual void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name)
virtual bool isUsingPythonCache ()
virtual void usePythonCache (bool v)
virtual std::string getPlacementId (const Task *askingNode) const =0
virtual std::string getFullPlacementId (const Task *askingNode) const =0
virtual void setAttachOnCloningStatus (bool val) const
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
virtual bool isAttachedOnCloning () const
virtual void lock ()=0
virtual void unLock ()=0
virtual Container * clone () const =0
virtual Container * cloneAlways () const =0
virtual bool isSupportingRTODefNbOfComp () const
virtual void checkCapabilityToDealWith (const ComponentInstance *inst) const =0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name) const =0
virtual void clearProperties ()=0
virtual void addComponentName (const std::string &name)=0
virtual std::map< std::string, std::string > getProperties () const =0
virtual std::map< std::string, std::string > getResourceProperties (const std::string &name) const =0
virtual void setProperties (const std::map< std::string, std::string > &properties)
virtual std::string getName () const
void setName (std::string name)
 WARNING ! name is used in edition to identify different containers, it is not the runtime name of the container More...
void setProc (Proc *proc)
Proc * getProc ()
virtual void shutdown (int level)=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] ="Salome"
static const char TYPE_PROPERTY_STR [] ="type"
- Static Public Attributes inherited from YACS::ENGINE::Container
static const char KIND_ENTRY [] ="container_kind"
static const char AOC_ENTRY [] ="attached_on_cloning"
static const char USE_PYCACHE_PROPERTY [] ="use_py_cache"
virtual ~SalomeContainer ()
- Protected Member Functions inherited from YACS::ENGINE::Container
 Container ()
virtual ~Container ()
 RefCounter ()
virtual ~RefCounter ()
YACS::BASES::Mutex _mutex
 thread safety in Salome ??? More...
std::vector< std::string > _componentNames
SalomeContainerHelper * _launchModeType
int _shutdownLevel
SalomeContainerTools _sct
- Protected Attributes inherited from YACS::ENGINE::Container
bool _isAttachedOnCloning
Proc * _proc
unsigned int _cnt
Friends
class SalomeComponent
Definition at line 38 of file SalomeContainer.hxx.
◆ SalomeContainer() [1/3]
SalomeContainer::SalomeContainer ( )
◆ SalomeContainer() [2/3]
SalomeContainer::SalomeContainer ( const SalomeContainer &  other)
Definition at line 62 of file SalomeContainer.cxx.
66 _sct(other._sct)
67{
68}
virtual SalomeContainerHelper * deepCpyOnlyStaticInfo() const =0
◆ SalomeContainer() [3/3]
SalomeContainer::SalomeContainer ( const Container &  other,
const SalomeContainerTools &  sct,
const SalomeContainerHelper *  lmt,
const std::vector< std::string > &  componentNames,
int  shutdownLev
Definition at line 70 of file SalomeContainer.cxx.
71 :Container(other),_componentNames(componentNames),
72 _launchModeType(const_cast<SalomeContainerHelper *>(lmt)),_shutdownLevel(shutdownLev),_sct(sct)
73{
74 if(lmt)
75 lmt->incrRef();
76}
References YACS::ENGINE::RefCounter::incrRef().
◆ ~SalomeContainer()
SalomeContainer::~SalomeContainer ( )
Definition at line 78 of file SalomeContainer.cxx.
79{
81}
References _launchModeType, and YACS::ENGINE::RefCounter::decrRef().
◆ addComponentName()
void SalomeContainer::addComponentName ( const std::string &  name)
Implements YACS::ENGINE::Container.
Definition at line 165 of file SalomeContainer.cxx.
166{
167 _componentNames.push_back(name);
168}
References _componentNames.
◆ addToResourceList()
void SalomeContainer::addToResourceList ( const std::string &  name)
Definition at line 170 of file SalomeContainer.cxx.
171{
173}
void addToResourceList(const std::string &name) override
References _sct, and YACS::ENGINE::SalomeContainerTools::addToResourceList().
◆ canAcceptImposedResource()
bool SalomeContainer::canAcceptImposedResource ( )
overridevirtual
◆ checkCapabilityToDealWith()
void SalomeContainer::checkCapabilityToDealWith ( const ComponentInstance *  inst) const
Definition at line 114 of file SalomeContainer.cxx.
115{
116 if(inst->getKind()!=SalomeComponent::KIND)
117 throw Exception("SalomeContainer::checkCapabilityToDealWith : SalomeContainer is not able to deal with this type of ComponentInstance.");
118}
Return the component kind.
References YACS::ENGINE::ComponentInstance::getKind(), and YACS::ENGINE::SalomeComponent::KIND.
◆ clearProperties()
void SalomeContainer::clearProperties ( )
◆ clone()
Container * SalomeContainer::clone ( ) const
Definition at line 98 of file SalomeContainer.cxx.
99{
101 {
102 incrRef();
103 return (Container*) (this);
104 }
105 else
106 return new SalomeContainer(*this);
107}
References YACS::ENGINE::Container::_isAttachedOnCloning, YACS::ENGINE::RefCounter::incrRef(), and SalomeContainer().
◆ cloneAlways()
Container * SalomeContainer::cloneAlways ( ) const
Definition at line 109 of file SalomeContainer.cxx.
110{
111 return new SalomeContainer(*this);
112}
References SalomeContainer().
◆ getContainerPtr()
Engines::Container_ptr SalomeContainer::getContainerPtr ( const Task *  askingNode) const
Definition at line 214 of file SalomeContainer.cxx.
215{
216 return Engines::Container::_duplicate(_launchModeType->getContainer(askingNode));
217}
virtual Engines::Container_var getContainer(const Task *askingNode) const =0
References _launchModeType, and YACS::ENGINE::SalomeContainerHelper::getContainer().
Referenced by YACS::ENGINE::PythonEntry::GetContainerLog(), GetContainerObj(), and YACS::ENGINE::DistributedPythonNode::load().
◆ getFullPlacementId()
std::string SalomeContainer::getFullPlacementId ( const Task *  askingNode) const
instthe component instance
the full placement id
Definition at line 199 of file SalomeContainer.cxx.
200{
202}
static std::string GetFullPlacementId(const SalomeContainerHelper *launchModeType, const Container *cont, const Task *askingNode)
References _launchModeType, and YACS::ENGINE::SalomeContainerToolsBase::GetFullPlacementId().
◆ getKind()
std::string SalomeContainer::getKind ( ) const
Definition at line 93 of file SalomeContainer.cxx.
94{
95 return KIND;
96}
References KIND.
◆ getPlacementId()
std::string SalomeContainer::getPlacementId ( const Task *  askingNode) const
the placement id
Definition at line 189 of file SalomeContainer.cxx.
190{
192}
static std::string GetPlacementId(const SalomeContainerHelper *launchModeType, const Container *cont, const Task *askingNode)
References _launchModeType, and YACS::ENGINE::SalomeContainerToolsBase::GetPlacementId().
◆ getProperties()
std::map< std::string, std::string > SalomeContainer::getProperties ( ) const
Definition at line 268 of file SalomeContainer.cxx.
269{
270 return _sct.getProperties();
271}
const std::map< std::string, std::string > & getProperties() const override
References _sct, and YACS::ENGINE::SalomeContainerTools::getProperties().
◆ getProperty()
std::string SalomeContainer::getProperty ( const std::string &  name) const
Definition at line 147 of file SalomeContainer.cxx.
148{
149 if (name == TYPE_PROPERTY_STR)
150 return _launchModeType->getType();
151 if (name==AOC_ENTRY)
152 {
153 int reti(_isAttachedOnCloning);
154 std::ostringstream oss; oss << reti;
155 return oss.str();
156 }
157 return _sct.getProperty(name);
158}
static const char AOC_ENTRY[]
Definition: Container.hxx:88
std::string getProperty(const std::string &name) const override
static const char TYPE_PROPERTY_STR[]
References YACS::ENGINE::Container::_isAttachedOnCloning, _launchModeType, _sct, YACS::ENGINE::Container::AOC_ENTRY, YACS::ENGINE::SalomeContainerTools::getProperty(), YACS::ENGINE::SalomeContainerHelper::getType(), and TYPE_PROPERTY_STR.
◆ getResourceProperties()
std::map< std::string, std::string > SalomeContainer::getResourceProperties ( const std::string &  name) const
Definition at line 263 of file SalomeContainer.cxx.
264{
265 return _sct.getResourceProperties(name);
266}
std::map< std::string, std::string > getResourceProperties(const std::string &name) const override
References _sct, and YACS::ENGINE::SalomeContainerTools::getResourceProperties().
◆ isAlreadyStarted()
bool SalomeContainer::isAlreadyStarted ( const Task *  askingNode) const
true, if the container is already started, else false
Definition at line 209 of file SalomeContainer.cxx.
210{
211 return _launchModeType->isAlreadyStarted(askingNode);
212}
virtual bool isAlreadyStarted(const Task *askingNode) const =0
References _launchModeType, and YACS::ENGINE::SalomeContainerHelper::isAlreadyStarted().
Referenced by YACS::ENGINE::SalomeContainerTmpForHP::loadComponent().
◆ loadComponent()
CORBA::Object_ptr SalomeContainer::loadComponent ( Task *  askingNode)
instthe component instance to load
Reimplemented in YACS::ENGINE::SalomeContainerTmpForHP.
Definition at line 179 of file SalomeContainer.cxx.
180{
182}
static CORBA::Object_ptr LoadComponent(SalomeContainerHelper *launchModeType, Container *cont, Task *askingNode)
References _launchModeType, and YACS::ENGINE::SalomeContainerToolsBase::LoadComponent().
Referenced by YACS::ENGINE::SalomeComponent::load().
◆ lock()
void SalomeContainer::lock ( )
Definition at line 83 of file SalomeContainer.cxx.
84{
85 _mutex.lock();
86}
References _mutex.
◆ setProperty()
void SalomeContainer::setProperty ( const std::string &  name,
const std::string &  value
Definition at line 120 of file SalomeContainer.cxx.
121{
122 if (name == AOC_ENTRY)
123 {
124 std::istringstream iss(value);
125 int val;
126 iss >> val;
127 setAttachOnCloningStatus((bool)val);
128 }
129 else if (name == TYPE_PROPERTY_STR)
130 {
132 {
135 }
137 {
140 }
141 else
142 throw Exception("SalomeContainer::setProperty : type value is not correct (mono or multi): " + value);
143 }
144 _sct.setProperty(name,value);
145}
virtual void setAttachOnCloningStatus(bool val) const
Definition: Container.cxx:68
void setProperty(const std::string &name, const std::string &value) override
References _launchModeType, _sct, YACS::ENGINE::Container::AOC_ENTRY, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::Container::setAttachOnCloningStatus(), YACS::ENGINE::SalomeContainerTools::setProperty(), YACS::ENGINE::SalomeContainerMonoHelper::TYPE_NAME, YACS::ENGINE::SalomeContainerMultiHelper::TYPE_NAME, and TYPE_PROPERTY_STR.
◆ shutdown()
void SalomeContainer::shutdown ( int  level)
Definition at line 252 of file SalomeContainer.cxx.
253{
254 DEBTRACE("SalomeContainer::shutdown: " << _name << "," << level << "," << _shutdownLevel);
255 if(level < _shutdownLevel)
256 return;
257
258 _shutdownLevel=999;
259 //shutdown the SALOME containers
261}
References _launchModeType, YACS::ENGINE::Container::_name, _shutdownLevel, DEBTRACE, and YACS::ENGINE::SalomeContainerHelper::shutdown().
◆ start() [1/2]
void SalomeContainer::start ( const Task *  askingNode)
overridevirtual
Definition at line 223 of file SalomeContainer.cxx.
224{
226}
static void Start(const std::vector< std::string > &compoNames, SalomeContainerHelper *schelp, SalomeContainerToolsBase &sct, int &shutdownLevel, const Container *cont, const Task *askingNode)
References _componentNames, _launchModeType, _sct, _shutdownLevel, and YACS::ENGINE::SalomeContainerToolsBase::Start().
Referenced by YACS::ENGINE::SalomeContainerTmpForHP::loadComponent(), and start().
◆ start() [2/2]
void SalomeContainer::start ( const Task *  askingNode,
const std::string &  resource_name,
const std::string &  container_name
overridevirtual
Reimplemented from YACS::ENGINE::Container.
Definition at line 228 of file SalomeContainer.cxx.
231{
233 && askingNode != nullptr
234 && askingNode->hasImposedResource())
235 {
236 SalomeContainerTools tempSct = _sct;
237 tempSct.setProperty("name", resource_name);
238 tempSct.setProperty("container_name", container_name);
239 // components are not supported yet on this kind of start
240 std::vector<std::string> noComponentNames;
241 SalomeContainerTools::Start(noComponentNames,_launchModeType,tempSct,_shutdownLevel,this,askingNode);
242 }
243 else
244 start(askingNode);
245}
void start(const Task *askingNode) override
Start a salome container (true salome container not yacs one) with given ContainerParameters (_params...
bool canAcceptImposedResource() override
virtual bool hasImposedResource() const
Definition: Task.hxx:58
References _launchModeType, _sct, _shutdownLevel, canAcceptImposedResource(), YACS::ENGINE::Task::hasImposedResource(), YACS::ENGINE::SalomeContainerTools::setProperty(), YACS::ENGINE::SalomeContainerToolsBase::Start(), and start().
◆ unLock()
void SalomeContainer::unLock ( )
Definition at line 88 of file SalomeContainer.cxx.
89{
90 _mutex.unLock();
91}
References _mutex.
◆ SalomeComponent
friend class SalomeComponent
friend
Definition at line 40 of file SalomeContainer.hxx.
◆ _componentNames
std::vector<std::string> YACS::ENGINE::SalomeContainer::_componentNames
Definition at line 83 of file SalomeContainer.hxx.
Referenced by addComponentName(), and start().
◆ _launchModeType
◆ _mutex
YACS::BASES::Mutex YACS::ENGINE::SalomeContainer::_mutex
Definition at line 82 of file SalomeContainer.hxx.
Referenced by lock(), and unLock().
◆ _sct
SalomeContainerTools YACS::ENGINE::SalomeContainer::_sct
◆ _shutdownLevel
int YACS::ENGINE::SalomeContainer::_shutdownLevel
Definition at line 85 of file SalomeContainer.hxx.
Referenced by shutdown(), and start().
◆ KIND
const char SalomeContainer::KIND ="Salome"
Definition at line 74 of file SalomeContainer.hxx.
Referenced by YACS::ENGINE::RuntimeSALOME::createContainer(), and getKind().
◆ TYPE_PROPERTY_STR
const char SalomeContainer::TYPE_PROPERTY_STR ="type"
Definition at line 75 of file SalomeContainer.hxx.
Referenced by getProperty(), and setProperty().
