YACS::ENGINE::SalomeContainerMultiHelper Class Reference
#include <SalomeContainerHelper.hxx>
Inheritance diagram for YACS::ENGINE::SalomeContainerMultiHelper:
Collaboration diagram for YACS::ENGINE::SalomeContainerMultiHelper:
std::string getType () const
std::string getDftLaunchMode () const
SalomeContainerMultiHelper * deepCpyOnlyStaticInfo () const
Engines::Container_var getContainer (const Task *askingNode) const
bool isAlreadyStarted (const Task *askingNode) const
void setContainer (const Task *askingNode, Engines::Container_var cont)
void shutdown ()
virtual std::string getType () const =0
virtual std::string getDftLaunchMode () const =0
virtual SalomeContainerHelper * deepCpyOnlyStaticInfo () const =0
virtual Engines::Container_var getContainer (const Task *askingNode) const =0
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void setContainer (const Task *askingNode, Engines::Container_var cont)=0
virtual void shutdown ()=0
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char TYPE_NAME [] ="multi"
static const char DFT_LAUNCH_MODE [] ="getorstart"
 ~SalomeContainerMultiHelper ()
std::map< const ComponentInstance *, Engines::Container_var > _containersForComponents
std::map< const Task *, Engines::Container_var > _containersForTasks
std::mutex _data_mutex
- Protected Member Functions inherited from YACS::ENGINE::SalomeContainerHelper
virtual ~SalomeContainerHelper ()
 RefCounter ()
virtual ~RefCounter ()
unsigned int _cnt
Definition at line 77 of file SalomeContainerHelper.hxx.
◆ ~SalomeContainerMultiHelper()
SalomeContainerMultiHelper::~SalomeContainerMultiHelper ( )
Definition at line 239 of file SalomeContainerHelper.cxx.
240{
241}
◆ deepCpyOnlyStaticInfo()
SalomeContainerMultiHelper * SalomeContainerMultiHelper::deepCpyOnlyStaticInfo ( ) const
◆ getContainer()
Engines::Container_var SalomeContainerMultiHelper::getContainer ( const Task *  askingNode) const
Implements YACS::ENGINE::SalomeContainerHelper.
Definition at line 135 of file SalomeContainerHelper.cxx.
136{
137 std::unique_lock<std::mutex> lock(_data_mutex);
138 const ComponentInstance *inst(askingNode?askingNode->getComponent():0);
139 if(inst == nullptr && askingNode != nullptr && askingNode->hasImposedResource())
140 {
141 std::map<const Task *,Engines::Container_var>::const_iterator it(_containersForTasks.find(askingNode));
142 if(it!=_containersForTasks.end())
143 return (*it).second;
144 else
145 return Engines::Container::_nil();
146 }
147 else
148 {
149 std::map<const ComponentInstance *,Engines::Container_var>::const_iterator it(_containersForComponents.find(inst));
150 if(it!=_containersForComponents.end())
151 return (*it).second;
152 else
153 return Engines::Container::_nil();
154 }
155}
virtual bool hasImposedResource() const
Definition: Task.hxx:58
virtual ComponentInstance * getComponent()=0
References _containersForComponents, _containersForTasks, _data_mutex, YACS::ENGINE::Task::getComponent(), and YACS::ENGINE::Task::hasImposedResource().
◆ getDftLaunchMode()
std::string SalomeContainerMultiHelper::getDftLaunchMode ( ) const
Definition at line 125 of file SalomeContainerHelper.cxx.
126{
127 return std::string(DFT_LAUNCH_MODE);
128}
References DFT_LAUNCH_MODE.
◆ getType()
std::string SalomeContainerMultiHelper::getType ( ) const
Definition at line 120 of file SalomeContainerHelper.cxx.
121{
122 return TYPE_NAME;
123}
References TYPE_NAME.
◆ isAlreadyStarted()
bool SalomeContainerMultiHelper::isAlreadyStarted ( const Task *  askingNode) const
Definition at line 157 of file SalomeContainerHelper.cxx.
158{
159 std::unique_lock<std::mutex> lock(_data_mutex);
160 const ComponentInstance *inst(askingNode?askingNode->getComponent():0);
161 if(inst == nullptr && askingNode != nullptr && askingNode->hasImposedResource())
162 {
163 return _containersForTasks.count(askingNode) > 0;
164 }
165 else
166 {
167 if(_containersForComponents.count(inst)==0)
168 return false;
169 else
170 return true;
171 }
172}
◆ setContainer()
void SalomeContainerMultiHelper::setContainer ( const Task *  askingNode,
Definition at line 174 of file SalomeContainerHelper.cxx.
175{
176 std::unique_lock<std::mutex> lock(_data_mutex);
177 const ComponentInstance *inst(askingNode?askingNode->getComponent():0);
178 if(inst == nullptr && askingNode != nullptr && askingNode->hasImposedResource())
179 {
180 _containersForTasks[askingNode] = cont;
181 }
182 else
183 {
184 _containersForComponents[inst]=cont;
185#ifdef REFCNT
186 std::map<const ComponentInstance *, Engines::Container_var >::const_iterator it;
187 for(it = _containersForComponents.begin(); it != _containersForComponents.end(); ++it)
188 {
189 DEBTRACE(it->second->_PR_getobj()->pd_refCount );
190 }
191#endif
192 }
193}
References _containersForComponents, _containersForTasks, _data_mutex, DEBTRACE, YACS::ENGINE::Task::getComponent(), and YACS::ENGINE::Task::hasImposedResource().
◆ shutdown()
void SalomeContainerMultiHelper::shutdown ( )
Definition at line 195 of file SalomeContainerHelper.cxx.
196{
197 std::unique_lock<std::mutex> lock(_data_mutex);
198 for(std::map<const Task *, Engines::Container_var >::const_iterator it = _containersForTasks.begin();
199 it != _containersForTasks.end(); ++it)
200 {
201 try
202 {
203 CORBA::String_var containerName=it->second->name();
204 INFO_MESSAGE("shutdown SALOME container: " << containerName);
205 it->second->Shutdown();
206 }
207 catch(CORBA::Exception&)
208 {
209 ERROR_MESSAGE("Unexpected CORBA failure detected." );
210 }
211 catch(...)
212 {
213 ERROR_MESSAGE("Unknown exception ignored." );
214 }
215 }
216 _containersForTasks.clear();
217
218 for(std::map<const ComponentInstance *, Engines::Container_var >::const_iterator it = _containersForComponents.begin(); it != _containersForComponents.end(); ++it)
219 {
220 try
221 {
222 CORBA::String_var containerName=it->second->name();
223 INFO_MESSAGE("shutdown SALOME container: " << containerName);
224 it->second->Shutdown();
225 std::cerr << "shutdown SALOME container: " << containerName << std::endl;
226 }
227 catch(CORBA::Exception&)
228 {
229 ERROR_MESSAGE("Unexpected CORBA failure detected." );
230 }
231 catch(...)
232 {
233 ERROR_MESSAGE("Unknown exception ignored." );
234 }
235 }
237}
References _containersForComponents, _containersForTasks, and _data_mutex.
◆ _containersForComponents
std::map<const ComponentInstance *,Engines::Container_var> YACS::ENGINE::SalomeContainerMultiHelper::_containersForComponents
Definition at line 93 of file SalomeContainerHelper.hxx.
Referenced by getContainer(), isAlreadyStarted(), setContainer(), and shutdown().
◆ _containersForTasks
std::map<const Task *,Engines::Container_var> YACS::ENGINE::SalomeContainerMultiHelper::_containersForTasks
Definition at line 94 of file SalomeContainerHelper.hxx.
◆ _data_mutex
std::mutex YACS::ENGINE::SalomeContainerMultiHelper::_data_mutex
mutableprivate
Definition at line 95 of file SalomeContainerHelper.hxx.
◆ DFT_LAUNCH_MODE
const char SalomeContainerMultiHelper::DFT_LAUNCH_MODE ="getorstart"
Definition at line 91 of file SalomeContainerHelper.hxx.
Referenced by getDftLaunchMode().
◆ TYPE_NAME
const char SalomeContainerMultiHelper::TYPE_NAME ="multi"
