YACS::ENGINE::SalomeComponent Class Reference
Class for Salome component instance. More...
#include <SalomeComponent.hxx>
Inheritance diagram for YACS::ENGINE::SalomeComponent:
Collaboration diagram for YACS::ENGINE::SalomeComponent:
 SalomeComponent (const std::string &name)
 SalomeComponent constructor. More...
 SalomeComponent (const SalomeComponent &other)
 SalomeComponent copy constructor. More...
virtual ~SalomeComponent ()
virtual void load (Task *askingNode)
 Load the component. More...
virtual void unload (Task *askingNode)
 Unload the component. More...
virtual bool isLoaded (Task *askingNode) const
 Is the component instance already loaded ? More...
virtual bool setContainer (Container *cont)
virtual ServiceNode * createNode (const std::string &name)
 Create a ServiceNode with this component instance and no input or output port. More...
virtual ComponentInstance * clone () const
 Clone the component instance. More...
virtual ComponentInstance * cloneAlways () const
virtual std::string getFileRepr () const
 For dump in file. More...
virtual CORBA::Object_ptr getCompoPtr ()
virtual std::string getKind () const
 Return the component kind. More...
virtual std::string getKindForNode () const
- Public Member Functions inherited from YACS::ENGINE::ComponentInstance
 ComponentInstance (const std::string &name)
 ComponentInstance (const ComponentInstance &other)
const std::string & getCompoName () const
const std::string & getInstanceName () const
virtual void setAnonymous (bool anon)
virtual bool isAnonymous ()
int getNumId () const
Container * getContainer () const
virtual void load (Task *askingNode)=0
 Load the component instance. More...
virtual void unload (Task *askingNode)=0
 Unload the component instance. More...
virtual bool isLoaded (Task *askingNode) const =0
 Indicate if the component instance is loaded (true) or not. More...
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
bool isAttachedOnCloning () const
virtual ServiceNode * createNode (const std::string &name)=0
virtual ComponentInstance * clone () const =0
virtual ComponentInstance * cloneAlways () const =0
- Public Member Functions inherited from YACS::ENGINE::PropertyInterface
virtual ~PropertyInterface ()
 Get a property value given its name. More...
std::map< std::string, std::string > getProperties () const
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] ="Salome"
- Static Public Attributes inherited from YACS::ENGINE::ComponentInstance
static const char KIND [] =""
CORBA::Object_var _objComponent
- Protected Attributes inherited from YACS::ENGINE::ComponentInstance
std::string _compoName
 WARNING : _compoName identify only the component type. More...
std::string _instanceName
 WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each other. More...
int _numId
Container * _container
bool _isAttachedOnCloning
bool _anonymous
- Protected Attributes inherited from YACS::ENGINE::PropertyInterface
unsigned int _cnt
- Protected Member Functions inherited from YACS::ENGINE::ComponentInstance
virtual ~ComponentInstance ()
 RefCounter ()
virtual ~RefCounter ()
- Static Protected Attributes inherited from YACS::ENGINE::ComponentInstance
static const char NULL_FILE_REPR [] ="No repr specified for ComponentInstance"
static int _total = 0
Definition at line 35 of file SalomeComponent.hxx.
◆ SalomeComponent() [1/2]
SalomeComponent::SalomeComponent ( const std::string &  name)
Definition at line 45 of file SalomeComponent.cxx.
45 : ComponentInstance(name)
46{
47 _objComponent=CORBA::Object::_nil();
48}
ComponentInstance(const std::string &name)
References _objComponent.
Referenced by clone(), and cloneAlways().
◆ SalomeComponent() [2/2]
SalomeComponent::SalomeComponent ( const SalomeComponent &  other)
Definition at line 51 of file SalomeComponent.cxx.
51 :ComponentInstance(other)
52{
53 _objComponent=CORBA::Object::_nil();
54}
◆ ~SalomeComponent()
SalomeComponent::~SalomeComponent ( )
Definition at line 56 of file SalomeComponent.cxx.
57{
58}
◆ clone()
ComponentInstance * SalomeComponent::clone ( ) const
Implements YACS::ENGINE::ComponentInstance.
Definition at line 130 of file SalomeComponent.cxx.
131{
133 {
134 incrRef();
135 return (ComponentInstance*) (this);
136 }
137 else
138 return new SalomeComponent(*this);
139}
SalomeComponent(const std::string &name)
References YACS::ENGINE::ComponentInstance::_isAttachedOnCloning, YACS::ENGINE::RefCounter::incrRef(), and SalomeComponent().
◆ cloneAlways()
ComponentInstance * SalomeComponent::cloneAlways ( ) const
Definition at line 141 of file SalomeComponent.cxx.
142{
143 return new SalomeComponent(*this);
144}
References SalomeComponent().
◆ createNode()
ServiceNode * SalomeComponent::createNode ( const std::string &  name)
a new SalomeNode node
Definition at line 122 of file SalomeComponent.cxx.
123{
124 SalomeNode* node=new SalomeNode(name);
125 node->setComponent(this);
126 return node;
127}
Class for Salome component Service Node.
Definition: CORBANode.hxx:68
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
References YACS::ENGINE::ServiceNode::setComponent().
◆ getCompoPtr()
virtual CORBA::Object_ptr YACS::ENGINE::SalomeComponent::getCompoPtr ( )
Definition at line 49 of file SalomeComponent.hxx.
49{return CORBA::Object::_duplicate(_objComponent);}
◆ getFileRepr()
std::string SalomeComponent::getFileRepr ( ) const
For dump in file.
Reimplemented from YACS::ENGINE::ComponentInstance.
Definition at line 146 of file SalomeComponent.cxx.
147{
148 ostringstream stream;
149 stream << "<component>" << getCompoName() << "</component>";
150 return stream.str();
151}
References YACS::ENGINE::ComponentInstance::getCompoName().
◆ getKind()
std::string SalomeComponent::getKind ( ) const
A runtime can provide several implementations of a component instance. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode is they have the same kind.
Definition at line 60 of file SalomeComponent.cxx.
61{
62 return KIND;
63}
References KIND.
◆ getKindForNode()
std::string SalomeComponent::getKindForNode ( ) const
Definition at line 65 of file SalomeComponent.cxx.
66{
67 return KIND;
68}
References KIND.
◆ isLoaded()
bool SalomeComponent::isLoaded ( Task *  askingNode) const
Definition at line 78 of file SalomeComponent.cxx.
79{
80 if(CORBA::is_nil(_objComponent))
81 return false;
82 else
83 return true;
84}
◆ load()
void SalomeComponent::load ( Task *  askingNode)
Load the component.
Definition at line 88 of file SalomeComponent.cxx.
89{
90 if(_container)
91 {
92 SalomeContainer *salomeContainer(dynamic_cast<SalomeContainer *>(_container));
93 if(salomeContainer)
94 {
95 _objComponent=salomeContainer->loadComponent(askingNode);
96 return ;
97 }
98 throw Exception("Unrecognized type of Container ! Only Salome are supported by the Salome components !");
99 }
100 //throw Exception("SalomeComponent::load : no container specified !!! To be implemented in executor to allocate default a Container in case of presenceOfDefaultContainer.");
101 //This component has no specified container : use default container policy
103 SALOME_LifeCycleCORBA LCC(&ns);
104 Engines::ContainerParameters params;
105 LCC.preSet(params);
106 params.resource_params.name = "localhost";
107 params.container_name ="FactoryServer";
108 _objComponent=LCC.LoadComponent(params,_compoName.c_str());
109}
References YACS::ENGINE::ComponentInstance::_compoName, YACS::ENGINE::ComponentInstance::_container, _objComponent, YACS::ENGINE::getSALOMERuntime(), and YACS::ENGINE::SalomeContainer::loadComponent().
◆ setContainer()
bool SalomeComponent::setContainer ( Container *  cont)
Definition at line 153 of file SalomeComponent.cxx.
154{
155 if(!dynamic_cast<SalomeContainer *>(cont))
156 throw Exception("SalomeComponent::setContainer : a Salome component must be attached to a Salome container !");
158 {
159 if(_container)
161 return true;
162 }
163 else
164 return false;
165}
virtual bool setContainer(Container *cont)
virtual void addComponentName(const std::string &name)=0
References YACS::ENGINE::ComponentInstance::_compoName, YACS::ENGINE::ComponentInstance::_container, YACS::ENGINE::Container::addComponentName(), and YACS::ENGINE::ComponentInstance::setContainer().
◆ shutdown()
void SalomeComponent::shutdown ( int  level)
Definition at line 167 of file SalomeComponent.cxx.
168{
169 DEBTRACE("SalomeComponent::shutdown " << level);
170 if(_container)
171 _container->shutdown(level);
172}
virtual void shutdown(int level)=0
References YACS::ENGINE::ComponentInstance::_container, DEBTRACE, and YACS::ENGINE::Container::shutdown().
◆ unload()
void SalomeComponent::unload ( Task *  askingNode)
Definition at line 71 of file SalomeComponent.cxx.
72{
73 //Not implemented
74 std::cerr << "SalomeComponent::unload : not implemented " << std::endl;
75}
◆ _objComponent
CORBA::Object_var YACS::ENGINE::SalomeComponent::_objComponent
Definition at line 56 of file SalomeComponent.hxx.
Referenced by isLoaded(), load(), and SalomeComponent().
◆ KIND
