SalomePythonComponent.cxx
20#include <Python.h>
22#include "SalomeComponent.hxx"
23#include "SalomePythonNode.hxx"
24#include "Exception.hxx"
25#include "Container.hxx"
26
27#include <sstream>
28
29using namespace YACS::ENGINE;
30
31const char SalomePythonComponent::KIND[]="SalomePy";
32
33unsigned SalomePythonComponent::_cntForReprS = 0;
34
35SalomePythonComponent::SalomePythonComponent(const std::string &name):ComponentInstance(name),_cntForRepr(_cntForReprS++)
36{
37}
38
40{
41}
42
44{
45}
46
48{
49 if(_container)
50 {
51 _container->start(askingNode);
52 return;
53 }
54 //This component has no specified container : use default container policy
55 //given by getStringValueToExportInInterp()
56 //throw Exception("SalomePythonComponent::load : no container specified !!! To be implemented in executor to allocate default a Container in case of presenceOfDefaultContainer.");
57}
58
60{
61}
62
64{
65 if(!_container)
66 return false;
67 else
68 return _container->isAlreadyStarted(askingNode);
69}
70
72{
73 //This is not a bug !!!! SalomeComponent NOT SalomePythonComponent. This is for Container assignation.
75}
76
78{
80 {
81 incrRef();
82 return (ComponentInstance*) (this);
83 }
84 else
85 return new SalomePythonComponent(*this);
86}
87
89{
90 return new SalomePythonComponent(*this);
91}
92
94{
95 ServiceNode* node=new SalomePythonNode(name);
96 node->setComponent(this);
97 return node;
98}
99
101{
102 std::ostringstream stream;
103 stream << "<ref>" << "SalomePythonComponent #" << _cntForRepr << "</ref>";
104 return stream.str();
105}
106
108{
109 if(!_container)
110 return "localhost/FactoryServer";
111 else
112 return _container->getPlacementId(askingNode);
113}
virtual void start(const Task *askingNode)=0
virtual bool isAlreadyStarted(const Task *askingNode) const =0
virtual std::string getPlacementId(const Task *askingNode) const =0
virtual std::string getFileRepr() const
For dump in file.
virtual ServiceNode * createNode(const std::string &name)
virtual ComponentInstance * clone() const
virtual void load(Task *askingNode)
Load the component instance.
virtual bool isLoaded(Task *askingNode) const
Indicate if the component instance is loaded (true) or not.
std::string getStringValueToExportInInterp(const Task *askingNode) const
The specific method that justified SalomePythonComponent class.
virtual void unload(Task *askingNode)
Unload the component instance.
Return the component kind.
virtual ComponentInstance * cloneAlways() const
virtual void setComponent(ComponentInstance *compo)
Associate an existing component instance to this service node AND check the consistency regarding the...
