YACS::ENGINE::ServerNode Class Referenceabstract
#include <ServerNode.hxx>
Inheritance diagram for YACS::ENGINE::ServerNode:
Collaboration diagram for YACS::ENGINE::ServerNode:
 ServerNode (const std::string &name)
 ServerNode (const ServerNode &other, ComposedNode *father)
void load ()
virtual ServerNode * createNode (const std::string &name) const =0
bool isDeployable () const
 By definition of ServerNode class. More...
virtual std::string getEffectiveKindOfServer () const =0
virtual ~ServerNode ()
- Public Member Functions inherited from YACS::ENGINE::InlineFuncNode
virtual void setFname (const std::string &fname)
 Set the function name to use in node execution. More...
virtual std::string getFname ()
virtual ~InlineFuncNode ()
- Public Member Functions inherited from YACS::ENGINE::InlineNode
virtual void setScript (const std::string &script)
 Set the script (as a string) to execute. More...
virtual std::string getScript ()
virtual InlineNode * cloneNode (const std::string &name)
 Return a new InlineNode node by making a copy of this node. More...
virtual ~InlineNode ()
virtual void setExecutionMode (const std::string &mode)
virtual std::string getExecutionMode ()
virtual void setContainer (Container *container)
virtual Container * getContainer ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::InlineNode
static const char LOCAL_STR [] ="local"
static const char REMOTE_STR [] ="remote"
- Protected Member Functions inherited from YACS::ENGINE::InlineFuncNode
 InlineFuncNode (const InlineFuncNode &other, ComposedNode *father)
 InlineFuncNode (const std::string &name)
- Protected Member Functions inherited from YACS::ENGINE::InlineNode
 InlineNode (const InlineNode &other, ComposedNode *father)
 InlineNode (const std::string &name)
template<class PORT >
- Protected Attributes inherited from YACS::ENGINE::InlineFuncNode
std::string _fname
- Protected Attributes inherited from YACS::ENGINE::InlineNode
std::string _script
std::string _mode
Container * _container
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 35 of file ServerNode.hxx.
◆ ServerNode() [1/2]
ServerNode::ServerNode ( const std::string &  name)
Definition at line 26 of file ServerNode.cxx.
26 :InlineFuncNode(name)
27{
28}
InlineFuncNode(const InlineFuncNode &other, ComposedNode *father)
Definition: InlineNode.hxx:95
◆ ServerNode() [2/2]
ServerNode::ServerNode ( const ServerNode &  other,
ComposedNode *  father
Definition at line 30 of file ServerNode.cxx.
30 :InlineFuncNode(other,father)
31{
32}
◆ ~ServerNode()
ServerNode::~ServerNode ( )
Definition at line 71 of file ServerNode.cxx.
72{
73}
◆ accept()
void ServerNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::InlineFuncNode.
Definition at line 60 of file ServerNode.cxx.
61{
62 visitor->visitServerNode(this);
63}
virtual void visitServerNode(ServerNode *node)=0
References YACS::ENGINE::Visitor::visitServerNode().
◆ createNode()
virtual ServerNode * YACS::ENGINE::ServerNode::createNode ( const std::string &  name) const
pure virtual
◆ getEffectiveKindOfServer()
virtual std::string YACS::ENGINE::ServerNode::getEffectiveKindOfServer ( ) const
pure virtual
◆ isDeployable()
bool ServerNode::isDeployable ( ) const
Reimplemented from YACS::ENGINE::InlineNode.
Definition at line 66 of file ServerNode.cxx.
67{
68 return true;
69}
◆ load()
void ServerNode::load ( )
Reimplemented from YACS::ENGINE::ElementaryNode.
Reimplemented in YACS::ENGINE::DistributedPythonNode.
Definition at line 34 of file ServerNode.cxx.
35{
36 if(_container)
37 {
39 {
40 try
41 {
42 _container->start(this);
43 }
44 catch(Exception& e)
45 {
46 _errorDetails=e.what();
47 throw e;
48 }
49 }
50 }
51 else
52 {
53 std::string what("ServerNode::load : a load operation requested on ServerNode called \"");
54 what+=_name; what+="\" with no container specified.";
55 _errorDetails=what;
56 throw Exception(what);
57 }
58}
virtual void start(const Task *askingNode)=0
virtual bool isAlreadyStarted(const Task *askingNode) const =0
std::string _name
Definition: Node.hxx:89
Definition: Node.hxx:93
References YACS::ENGINE::InlineNode::_container, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_name, YACS::ENGINE::Container::isAlreadyStarted(), YACS::ENGINE::Container::start(), and YACS::Exception::what().
Referenced by YACS::ENGINE::DistributedPythonNode::load().
◆ typeName()
virtual std::string YACS::ENGINE::ServerNode::typeName ( )
Definition at line 46 of file ServerNode.hxx.
46{ return "YACS__ENGINE__ServerNode"; }
