YACS::ENGINE::PyFuncNode Class Reference
#include <PythonNode.hxx>
Inheritance diagram for YACS::ENGINE::PyFuncNode:
Collaboration diagram for YACS::ENGINE::PyFuncNode:
 PyFuncNode (const PyFuncNode &other, ComposedNode *father)
 PyFuncNode (const std::string &name)
virtual ~PyFuncNode ()
virtual void execute ()
virtual void load ()
virtual void loadRemote ()
virtual void loadLocal ()
virtual void executeRemote ()
virtual void executeLocal ()
void imposeResource (const std::string &resource_name, const std::string &container_name) override
bool canAcceptImposedResource () override
bool hasImposedResource () const override
std::string getContainerLog ()
PyFuncNode * cloneNode (const std::string &name)
 Create a new node of same type with a given name. More...
- Public Member Functions inherited from YACS::ENGINE::InlineFuncNode
virtual void setFname (const std::string &fname)
 Set the function name to use in node execution. More...
virtual std::string getFname ()
virtual ~InlineFuncNode ()
- Public Member Functions inherited from YACS::ENGINE::InlineNode
virtual void setScript (const std::string &script)
 Set the script (as a string) to execute. More...
virtual std::string getScript ()
virtual InlineNode * cloneNode (const std::string &name)
 Return a new InlineNode node by making a copy of this node. More...
virtual ~InlineNode ()
virtual void setExecutionMode (const std::string &mode)
virtual std::string getExecutionMode ()
virtual void setContainer (Container *container)
virtual Container * getContainer ()
bool isDeployable () const
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char SCRIPT_FOR_SERIALIZATION []
- Static Public Attributes inherited from YACS::ENGINE::InlineNode
static const char LOCAL_STR [] ="local"
static const char REMOTE_STR [] ="remote"
- Static Public Attributes inherited from YACS::ENGINE::PythonEntry
static const char SCRIPT_FOR_SIMPLE_SERIALIZATION []
Node * simpleClone (ComposedNode *father, bool editionOnly) const
void createRemoteAdaptedPyInterpretor (Engines::Container_ptr objContainer)
 returns an object, you have to deal with (UnRegister) More...
Engines::PyNodeBase_var retrieveDftRemotePyInterpretorIfAny (Engines::Container_ptr objContainer) const
 returns (if any) an object, you have to deal with (UnRegister) More...
void assignRemotePyInterpretor (Engines::PyNodeBase_var remoteInterp)
Engines::PyNodeBase_var getRemoteInterpreterHandle ()
const char * getSerializationScript () const
- Protected Member Functions inherited from YACS::ENGINE::InlineFuncNode
 InlineFuncNode (const InlineFuncNode &other, ComposedNode *father)
 InlineFuncNode (const std::string &name)
- Protected Member Functions inherited from YACS::ENGINE::InlineNode
 InlineNode (const InlineNode &other, ComposedNode *father)
 InlineNode (const std::string &name)
template<class PORT >
- Protected Member Functions inherited from YACS::ENGINE::PythonEntry
 PythonEntry ()
 ~PythonEntry ()
virtual void assignRemotePyInterpretor (Engines::PyNodeBase_var remoteInterp)=0
virtual Engines::PyNodeBase_var retrieveDftRemotePyInterpretorIfAny (Engines::Container_ptr objContainer) const =0
virtual void createRemoteAdaptedPyInterpretor (Engines::Container_ptr objContainer)=0
virtual Engines::PyNodeBase_var getRemoteInterpreterHandle ()=0
virtual const char * getSerializationScript () const =0
void commonRemoteLoad (InlineNode *reqNode)
void loadRemoteContainer (InlineNode *reqNode)
Engines::Container_var loadPythonAdapter (InlineNode *reqNode, bool &isInitializeRequested)
void loadRemoteContext (InlineNode *reqNode, Engines::Container_ptr objContainer, bool isInitializeRequested)
PyObject * _pyfunc
Engines::PyNode_var _pynode
- Protected Attributes inherited from YACS::ENGINE::InlineFuncNode
std::string _fname
- Protected Attributes inherited from YACS::ENGINE::InlineNode
std::string _script
std::string _mode
Container * _container
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
- Protected Attributes inherited from YACS::ENGINE::PythonEntry
PyObject * _context
PyObject * _pyfuncSer
PyObject * _pyfuncUnser
PyObject * _pyfuncSimpleSer
std::string _imposedResource
std::string _imposedContainer
- Static Public Member Functions inherited from YACS::ENGINE::PythonEntry
static bool IsProxy (PyObject *ob)
static bool GetDestroyStatus (PyObject *ob)
static void DoNotTouchFileIfProxy (PyObject *ob)
static void UnlinkOnDestructorIfProxy (PyObject *ob)
static void IfProxyDoSomething (PyObject *ob, const char *meth)
YACS::Colour _colour
- Static Protected Member Functions inherited from YACS::ENGINE::PythonEntry
static std::string GetContainerLog (const std::string &mode, Container *container, const Task *askingTask)
static int _total = 0
- Static Protected Attributes inherited from YACS::ENGINE::PythonEntry
static PyObject * _pyClsBigObject = nullptr
Definition at line 134 of file PythonNode.hxx.
◆ PyFuncNode() [1/2]
PyFuncNode::PyFuncNode ( const PyFuncNode &  other,
ComposedNode *  father
Definition at line 1096 of file PythonNode.cxx.
1096 :InlineFuncNode(other,father),_pyfunc(0)
1097{
1099 {
1100 AutoGIL agil;
1101 _context=PyDict_New();
1102 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1103 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
1104 {
1105 stringstream msg;
1106 msg << "Not possible to set builtins" << __FILE__ << ":" << __LINE__;
1107 _errorDetails=msg.str();
1108 throw Exception(msg.str());
1109 }
1110 }
1111}
InlineFuncNode(const InlineFuncNode &other, ComposedNode *father)
Definition: InlineNode.hxx:95
Definition: Node.hxx:97
Definition: Node.hxx:93
static const char IMPL_NAME[]
Definition: PythonNode.hxx:123
References YACS::ENGINE::PythonEntry::_context, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_implementation, DEBTRACE, YACS::ENGINE::getSALOMERuntime(), and YACS::ENGINE::PythonNode::IMPL_NAME.
Referenced by cloneNode(), and simpleClone().
◆ PyFuncNode() [2/2]
PyFuncNode::PyFuncNode ( const std::string &  name)
Definition at line 1113 of file PythonNode.cxx.
1113 : InlineFuncNode(name),_pyfunc(0)
1114{
1115
1117 DEBTRACE( "PyFuncNode::PyFuncNode " << name );
1118 {
1119 AutoGIL agil;
1120 _context=PyDict_New();
1121 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1122 if( PyDict_SetItemString( _context, "__builtins__", getSALOMERuntime()->getBuiltins() ))
1123 {
1124 stringstream msg;
1125 msg << "Not possible to set builtins" << __FILE__ << ":" << __LINE__;
1126 _errorDetails=msg.str();
1127 throw Exception(msg.str());
1128 }
1129 }
1130}
◆ ~PyFuncNode()
PyFuncNode::~PyFuncNode ( )
Definition at line 1132 of file PythonNode.cxx.
1133{
1134 if(!CORBA::is_nil(_pynode))
1135 {
1136 _pynode->UnRegister();
1137 }
1138}
Definition: PythonNode.hxx:168
References _pynode.
◆ assignRemotePyInterpretor()
void PyFuncNode::assignRemotePyInterpretor ( Engines::PyNodeBase_var  remoteInterp)
Implements YACS::ENGINE::PythonEntry.
Definition at line 1596 of file PythonNode.cxx.
1597{
1598 if(!CORBA::is_nil(_pynode))
1599 {
1600 Engines::PyNode_var tmpp(Engines::PyNode::_narrow(remoteInterp));
1601 if(_pynode->_is_equivalent(tmpp))
1602 return ;
1603 }
1604 if(!CORBA::is_nil(_pynode))
1605 _pynode->UnRegister();
1606 _pynode=Engines::PyNode::_narrow(remoteInterp);
1607}
References _pynode.
◆ canAcceptImposedResource()
bool PyFuncNode::canAcceptImposedResource ( )
overridevirtual
Reimplemented from YACS::ENGINE::Task.
Definition at line 1662 of file PythonNode.cxx.
1663{
1664 return _container != nullptr && _container->canAcceptImposedResource();
1665}
virtual bool canAcceptImposedResource()
Definition: Container.cxx:59
References YACS::ENGINE::InlineNode::_container, and YACS::ENGINE::Container::canAcceptImposedResource().
◆ checkBasicConsistency()
void PyFuncNode::checkBasicConsistency ( ) const
Reimplemented from YACS::ENGINE::InlineFuncNode.
Definition at line 1154 of file PythonNode.cxx.
1155{
1156 DEBTRACE("checkBasicConsistency");
1158 {
1159 AutoGIL agil;
1160 PyObject* res;
1161 res=Py_CompileString(_script.c_str(),getName().c_str(),Py_file_input);
1162 if(res == NULL)
1163 {
1164 std::string error="";
1165 PyObject* new_stderr = newPyStdOut(error);
1166 PySys_SetObject((char*)"stderr", new_stderr);
1167 PyErr_Print();
1168 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1169 Py_DECREF(new_stderr);
1170 throw Exception(error);
1171 }
1172 else
1173 Py_XDECREF(res);
1174 }
1175}
Definition: InlineNode.cxx:75
Definition: Node.hxx:125
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
References YACS::ENGINE::InlineNode::_script, YACS::ENGINE::InlineFuncNode::checkBasicConsistency(), DEBTRACE, YACS::ENGINE::Node::getName(), and YACS::ENGINE::newPyStdOut().
◆ cloneNode()
PyFuncNode * PyFuncNode::cloneNode ( const std::string &  name)
Reimplemented from YACS::ENGINE::InlineNode.
Definition at line 1615 of file PythonNode.cxx.
1616{
1617 PyFuncNode* n=new PyFuncNode(name);
1618 n->setScript(_script);
1619 n->setFname(_fname);
1620 list<InputPort *>::iterator iter;
1621 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
1622 {
1623 InputPyPort *p=(InputPyPort *)*iter;
1624 n->edAddInputPort(p->getName(),p->edGetType());
1625 }
1626 list<OutputPort *>::iterator iter2;
1627 for(iter2 = _setOfOutputPort.begin(); iter2 != _setOfOutputPort.end(); iter2++)
1628 {
1629 OutputPyPort *p=(OutputPyPort *)*iter2;
1630 n->edAddOutputPort(p->getName(),p->edGetType());
1631 }
1632 return n;
1633}
std::string getName() const
Class for Python Ports.
Definition: PythonPorts.hxx:74
PyFuncNode(const PyFuncNode &other, ComposedNode *father)
Proc * p
Definition: driver.cxx:216
References YACS::ENGINE::InlineFuncNode::_fname, YACS::ENGINE::InlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, YACS::ENGINE::ComposedNode::getName(), gui.Appli::n, p, and PyFuncNode().
◆ createRemoteAdaptedPyInterpretor()
void PyFuncNode::createRemoteAdaptedPyInterpretor ( Engines::Container_ptr  objContainer)
Definition at line 1579 of file PythonNode.cxx.
1580{
1581 if(!CORBA::is_nil(_pynode))
1582 _pynode->UnRegister();
1583 _pynode=objContainer->createPyNode(getName().c_str(),getScript().c_str());
1584}
virtual std::string getScript()
Definition: InlineNode.hxx:51
References _pynode, YACS::ENGINE::Node::getName(), and YACS::ENGINE::InlineNode::getScript().
◆ execute()
void PyFuncNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 1263 of file PythonNode.cxx.
1264{
1266 executeRemote();
1267 else
1268 executeLocal();
1269}
virtual void executeRemote()
virtual void executeLocal()
static const char REMOTE_NAME[]
Definition: PythonNode.hxx:125
References YACS::ENGINE::InlineNode::_mode, executeLocal(), executeRemote(), and YACS::ENGINE::PythonNode::REMOTE_NAME.
◆ executeLocal()
void PyFuncNode::executeLocal ( )
Definition at line 1458 of file PythonNode.cxx.
1459{
1460 DEBTRACE( "++++++++++++++ PyFuncNode::execute: " << getName() << " ++++++++++++++++++++" );
1461
1462 int pos=0;
1463 PyObject* ob;
1464 if(!_pyfunc)throw Exception("PyFuncNode badly loaded");
1465 {
1466 AutoGIL agil;
1467 DEBTRACE( "---------------PyFuncNode::inputs---------------" );
1468 PyObject* args = PyTuple_New(getNumberOfInputPorts()) ;
1469 list<InputPort *>::iterator iter2;
1470 for(iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++)
1471 {
1472 InputPyPort *p=(InputPyPort *)*iter2;
1473 DEBTRACE( "port name: " << p->getName() );
1474 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1475 ob=p->getPyObj();
1476#ifdef _DEVDEBUG_
1477 PyObject_Print(ob,stderr,Py_PRINT_RAW);
1478 cerr << endl;
1479#endif
1480 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1481 Py_INCREF(ob);
1482 PyTuple_SetItem(args,pos,ob);
1483 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1484 pos++;
1485 }
1486 DEBTRACE( "---------------End PyFuncNode::inputs---------------" );
1487
1488 DEBTRACE( "----------------PyFuncNode::calculation---------------" );
1489#ifdef _DEVDEBUG_
1490 PyObject_Print(_pyfunc,stderr,Py_PRINT_RAW);
1491 cerr << endl;
1492 PyObject_Print(args,stderr,Py_PRINT_RAW);
1493 cerr << endl;
1494#endif
1495 DEBTRACE( "_pyfunc refcnt: " << _pyfunc->ob_refcnt );
1496 PyObject* result = PyObject_CallObject( _pyfunc , args ) ;
1497 DEBTRACE( "_pyfunc refcnt: " << _pyfunc->ob_refcnt );
1498 Py_DECREF(args);
1499 fflush(stdout);
1500 fflush(stderr);
1501 if(result == NULL)
1502 {
1503 _errorDetails="";
1504 PyObject* new_stderr = newPyStdOut(_errorDetails);
1505 PySys_SetObject((char*)"stderr", new_stderr);
1506 std::ostringstream stream;
1507 stream << "/tmp/PythonNode_";
1508 stream << getpid();
1509 ofstream errorfile(stream.str().c_str());
1510 if (errorfile.is_open())
1511 {
1512 errorfile << _script;
1513 errorfile.close();
1514 }
1515 PyErr_Print();
1516 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1517 Py_DECREF(new_stderr);
1518 throw Exception("Error during execution");
1519 }
1520 DEBTRACE( "----------------End PyFuncNode::calculation---------------" );
1521
1522 DEBTRACE( "-----------------PyFuncNode::outputs-----------------" );
1523 int nres=1;
1524 if(result == Py_None)
1525 nres=0;
1526 else if(PyTuple_Check(result))
1527 nres=PyTuple_Size(result);
1528
1529 if(getNumberOfOutputPorts() != nres)
1530 {
1531 std::string msg="Number of output arguments : Mismatch between definition and execution";
1532 Py_DECREF(result);
1533 _errorDetails=msg;
1534 throw Exception(msg);
1535 }
1536
1537 pos=0;
1538#ifdef _DEVDEBUG_
1539 PyObject_Print(result,stderr,Py_PRINT_RAW);
1540 cerr << endl;
1541#endif
1542 list<OutputPort *>::iterator iter;
1543 try
1544 {
1545 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
1546 {
1547 OutputPyPort *p=(OutputPyPort *)*iter;
1548 DEBTRACE( "port name: " << p->getName() );
1549 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1550 DEBTRACE( "port pos : " << pos );
1551 if(PyTuple_Check(result))ob=PyTuple_GetItem(result,pos) ;
1552 else ob=result;
1553 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1554#ifdef _DEVDEBUG_
1555 PyObject_Print(ob,stderr,Py_PRINT_RAW);
1556 cerr << endl;
1557#endif
1558 p->put(ob);
1559 pos++;
1560 }
1561 }
1562 catch(ConversionException& ex)
1563 {
1564 Py_DECREF(result);
1565 _errorDetails=ex.what();
1566 throw;
1567 }
1568 DEBTRACE( "-----------------End PyFuncNode::outputs-----------------" );
1569 Py_DECREF(result);
1570 }
1571 DEBTRACE( "++++++++++++++ End PyFuncNode::execute: " << getName() << " ++++++++++++++++++++" );
1572}
References YACS::ENGINE::Node::_errorDetails, _pyfunc, YACS::ENGINE::InlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, driver_internal::args, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ElementaryNode::getNumberOfInputPorts(), YACS::ENGINE::ElementaryNode::getNumberOfOutputPorts(), YACS::ENGINE::newPyStdOut(), and p.
Referenced by execute().
◆ executeRemote()
void PyFuncNode::executeRemote ( )
Definition at line 1271 of file PythonNode.cxx.
1272{
1273 DEBTRACE( "++++++++++++++ PyFuncNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
1274 if(!_pyfuncSer)
1275 throw Exception("DistributedPythonNode badly loaded");
1276 //
1277 if(dynamic_cast<HomogeneousPoolContainer *>(getContainer()))
1278 {
1279 bool dummy;
1280 loadPythonAdapter(this,dummy);
1281 _pynode->executeAnotherPieceOfCode(getScript().c_str());
1282 }
1283 //
1284 Engines::pickledArgs_var serializationInputCorba(new Engines::pickledArgs);;
1285 {
1286#if PY_VERSION_HEX < 0x03070000
1287 std::unique_lock<std::mutex> lock(data_mutex);
1288#endif
1289 AutoGIL agil;
1290 PyObject *ob(0);
1291 //===========================================================================
1292 // Get inputs in input ports, build a Python tuple and pickle it
1293 //===========================================================================
1294 PyObject *args(PyTuple_New(getNumberOfInputPorts()));
1295 int pos(0);
1296 for(std::list<InputPort *>::iterator iter2 = _setOfInputPort.begin(); iter2 != _setOfInputPort.end(); iter2++,pos++)
1297 {
1298 InputPyPort *p=(InputPyPort *)*iter2;
1299 ob=p->getPyObj();
1300 Py_INCREF(ob);
1301 PyTuple_SetItem(args,pos,ob);
1302 }
1303#ifdef _DEVDEBUG_
1304 PyObject_Print(args,stderr,Py_PRINT_RAW);
1305 std::cerr << endl;
1306#endif
1307 PyObject *serializationInput=PyObject_CallObject(_pyfuncSer,args);
1308 Py_DECREF(args);
1309 //The pickled string may contain NULL characters so use PyString_AsStringAndSize
1310 char *serializationInputC(0);
1311 Py_ssize_t len;
1312 if (PyBytes_AsStringAndSize(serializationInput, &serializationInputC, &len))
1313 throw Exception("DistributedPythonNode problem in python pickle");
1314
1315 serializationInputCorba->length(len);
1316 for(int i=0; i < len ; i++)
1317 serializationInputCorba[i]=serializationInputC[i];
1318 Py_DECREF(serializationInput);
1319 }
1320
1321 //===========================================================================
1322 // Execute in remote Python node
1323 //===========================================================================
1324 DEBTRACE( "-----------------starting remote python invocation-----------------" );
1325 Engines::pickledArgs_var resultCorba;
1326 try
1327 {
1328 resultCorba=_pynode->execute(getFname().c_str(),serializationInputCorba);
1329 }
1330 catch( const SALOME::SALOME_Exception& ex )
1331 {
1332 std::string msg="Exception on remote python invocation";
1333 msg += '\n';
1334 msg += ex.details.text.in();
1335 _errorDetails=msg;
1336 throw Exception(msg);
1337 }
1338 catch(CORBA::COMM_FAILURE& ex)
1339 {
1340 std::ostringstream msg;
1341 msg << "Exception on remote python invocation." << std::endl ;
1342 msg << "Caught system exception COMM_FAILURE -- unable to contact the "
1343 << "object." << std::endl;
1344 _errorDetails=msg.str();
1345 throw Exception(msg.str());
1346 }
1347 catch(CORBA::SystemException& ex)
1348 {
1349 std::ostringstream msg;
1350 msg << "Exception on remote python invocation." << std::endl ;
1351 msg << "Caught a CORBA::SystemException." ;
1352 CORBA::Any tmp;
1353 tmp <<= ex;
1354 CORBA::TypeCode_var tc = tmp.type();
1355 const char *p = tc->name();
1356 if ( *p != '\0' )
1357 msg <<p;
1358 else
1359 msg << tc->id();
1360 msg << std::endl;
1361 _errorDetails=msg.str();
1362 throw Exception(msg.str());
1363 }
1364 catch(CORBA::Exception& ex)
1365 {
1366 std::ostringstream msg;
1367 msg << "Exception on remote python invocation." << std::endl ;
1368 msg << "Caught CORBA::Exception. " ;
1369 CORBA::Any tmp;
1370 tmp <<= ex;
1371 CORBA::TypeCode_var tc = tmp.type();
1372 const char *p = tc->name();
1373 if ( *p != '\0' )
1374 msg <<p;
1375 else
1376 msg << tc->id();
1377 msg << std::endl;
1378 _errorDetails=msg.str();
1379 throw Exception(msg.str());
1380 }
1381 catch(omniORB::fatalException& fe)
1382 {
1383 std::ostringstream msg;
1384 msg << "Exception on remote python invocation." << std::endl ;
1385 msg << "Caught omniORB::fatalException:" << std::endl;
1386 msg << " file: " << fe.file() << std::endl;
1387 msg << " line: " << fe.line() << std::endl;
1388 msg << " mesg: " << fe.errmsg() << std::endl;
1389 _errorDetails=msg.str();
1390 throw Exception(msg.str());
1391 }
1392 DEBTRACE( "-----------------end of remote python invocation-----------------" );
1393 //===========================================================================
1394 // Get results, unpickle and put them in output ports
1395 //===========================================================================
1396 char *resultCorbaC=new char[resultCorba->length()+1];
1397 resultCorbaC[resultCorba->length()]='\0';
1398 for(int i=0;i<resultCorba->length();i++)
1399 resultCorbaC[i]=resultCorba[i];
1400
1401 {
1402#if PY_VERSION_HEX < 0x03070000
1403 std::unique_lock<std::mutex> lock(data_mutex);
1404#endif
1405 AutoGIL agil;
1406
1407 PyObject *resultPython(PyBytes_FromStringAndSize(resultCorbaC,resultCorba->length()));
1408 delete [] resultCorbaC;
1409 PyObject *args(PyTuple_New(1)),*ob(0);
1410 PyTuple_SetItem(args,0,resultPython);
1411 PyObject *finalResult=PyObject_CallObject(_pyfuncUnser,args);
1412 Py_DECREF(args);
1413
1414 DEBTRACE( "-----------------PythonNode::outputs-----------------" );
1415 int nres=1;
1416 if(finalResult == Py_None)
1417 nres=0;
1418 else if(PyTuple_Check(finalResult))
1419 nres=PyTuple_Size(finalResult);
1420
1421 if(getNumberOfOutputPorts() != nres)
1422 {
1423 std::string msg="Number of output arguments : Mismatch between definition and execution";
1424 Py_DECREF(finalResult);
1425 _errorDetails=msg;
1426 throw Exception(msg);
1427 }
1428
1429 try
1430 {
1431 int pos(0);
1432 for(std::list<OutputPort *>::iterator iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++, pos++)
1433 {
1434 OutputPyPort *p=(OutputPyPort *)*iter;
1435 DEBTRACE( "port name: " << p->getName() );
1436 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1437 DEBTRACE( "port pos : " << pos );
1438 if(PyTuple_Check(finalResult))
1439 ob=PyTuple_GetItem(finalResult,pos) ;
1440 else
1441 ob=finalResult;
1442 DEBTRACE( "ob refcnt: " << ob->ob_refcnt );
1443 p->put(ob);
1444 }
1445 Py_DECREF(finalResult);
1446 }
1447 catch(ConversionException& ex)
1448 {
1449 Py_DECREF(finalResult);
1450 _errorDetails=ex.what();
1451 throw;
1452 }
1453 }
1454
1455 DEBTRACE( "++++++++++++++ ENDOF PyFuncNode::executeRemote: " << getName() << " ++++++++++++++++++++" );
1456}
int Py_ssize_t
Definition: PythonNode.cxx:45
static std::mutex data_mutex
Definition: PythonNode.cxx:90
virtual std::string getFname()
Definition: InlineNode.hxx:101
virtual Container * getContainer()
Definition: InlineNode.cxx:100
Engines::Container_var loadPythonAdapter(InlineNode *reqNode, bool &isInitializeRequested)
Definition: PythonNode.cxx:165
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::PythonEntry::_pyfuncSer, YACS::ENGINE::PythonEntry::_pyfuncUnser, _pynode, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, driver_internal::args, data_mutex, DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::InlineNode::getContainer(), YACS::ENGINE::InlineFuncNode::getFname(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ElementaryNode::getNumberOfInputPorts(), YACS::ENGINE::ElementaryNode::getNumberOfOutputPorts(), YACS::ENGINE::InlineNode::getScript(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::PythonEntry::loadPythonAdapter(), and p.
◆ getContainerLog()
std::string PyFuncNode::getContainerLog ( )
returns a string that contains the name of the container log file if it exists
Do nothing here. To subclass
Reimplemented from YACS::ENGINE::Node.
Definition at line 1635 of file PythonNode.cxx.
1636{
1638}
static std::string GetContainerLog(const std::string &mode, Container *container, const Task *askingTask)
Definition: PythonNode.cxx:283
References YACS::ENGINE::InlineNode::_container, YACS::ENGINE::InlineNode::_mode, and YACS::ENGINE::PythonEntry::GetContainerLog().
◆ getRemoteInterpreterHandle()
Engines::PyNodeBase_var PyFuncNode::getRemoteInterpreterHandle ( )
Definition at line 1609 of file PythonNode.cxx.
1610{
1611 return Engines::PyNodeBase::_narrow(_pynode);
1612}
References _pynode.
◆ getSerializationScript()
const char * YACS::ENGINE::PyFuncNode::getSerializationScript ( ) const
inlineprotectedvirtual
Definition at line 143 of file PythonNode.hxx.
143{ return SCRIPT_FOR_SERIALIZATION; }
static const char SCRIPT_FOR_SERIALIZATION[]
Definition: PythonNode.hxx:165
◆ hasImposedResource()
bool PyFuncNode::hasImposedResource ( ) const
overridevirtual
Reimplemented from YACS::ENGINE::PythonEntry.
Definition at line 1667 of file PythonNode.cxx.
1668{
1670}
virtual bool hasImposedResource() const
Definition: PythonNode.cxx:326
References YACS::ENGINE::PythonEntry::hasImposedResource().
◆ imposeResource()
void PyFuncNode::imposeResource ( const std::string &  resource_name,
const std::string &  container_name
overridevirtual
Definition at line 1652 of file PythonNode.cxx.
1654{
1655 if(!resource_name.empty() && !container_name.empty())
1656 {
1657 _imposedResource = resource_name;
1658 _imposedContainer = container_name;
1659 }
1660}
Definition: PythonNode.hxx:69
Definition: PythonNode.hxx:70
References YACS::ENGINE::PythonEntry::_imposedContainer, and YACS::ENGINE::PythonEntry::_imposedResource.
◆ init()
void PyFuncNode::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 1140 of file PythonNode.cxx.
1141{
1143 if(_state == YACS::DISABLED)
1144 {
1145 exDisabledState(); // to refresh propagation of DISABLED state
1146 return ;
1147 }
1148 if(start) //complete initialization
1150 else if(_state > YACS::LOADED)// WARNING FuncNode has internal vars (CEA usecase) ! Partial initialization (inside a loop). Exclusivity of funcNode.
1152}
void initCommonPartWithoutStateManagement(bool start)
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
Definition: Node.hxx:91
@ LOADED
Definition: define.hxx:39
@ READY
Definition: define.hxx:37
@ DISABLED
Definition: define.hxx:50
@ TORECONNECT
Definition: define.hxx:48
References YACS::ENGINE::Node::_state, YACS::DISABLED, YACS::ENGINE::Node::exDisabledState(), YACS::ENGINE::ElementaryNode::initCommonPartWithoutStateManagement(), YACS::LOADED, YACS::READY, YACS::ENGINE::Node::setState(), and YACS::TORECONNECT.
◆ load()
void PyFuncNode::load ( )
Definition at line 1177 of file PythonNode.cxx.
1178{
1179 DEBTRACE( "---------------PyfuncNode::load function---------------" );
1181 loadRemote();
1182 else
1183 loadLocal();
1184}
virtual void loadLocal()
virtual void loadRemote()
References YACS::ENGINE::InlineNode::_mode, DEBTRACE, loadLocal(), loadRemote(), and YACS::ENGINE::PythonNode::REMOTE_NAME.
◆ loadLocal()
void PyFuncNode::loadLocal ( )
Definition at line 1191 of file PythonNode.cxx.
1192{
1193 DEBTRACE( "---------------PyFuncNode::load function " << getName() << " ---------------" );
1194 DEBTRACE( _script );
1195
1196#ifdef _DEVDEBUG_
1197 list<OutputPort *>::iterator iter;
1198 for(iter = _setOfOutputPort.begin(); iter != _setOfOutputPort.end(); iter++)
1199 {
1200 OutputPyPort *p=(OutputPyPort *)*iter;
1201 DEBTRACE( "port name: " << p->getName() );
1202 DEBTRACE( "port kind: " << p->edGetType()->kind() );
1203 }
1204#endif
1205
1206 {
1207 AutoGIL agil;
1208 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1209
1210 std::ostringstream stream;
1211 stream << "/tmp/PythonNode_";
1212 stream << getpid();
1213
1214 PyObject* code=Py_CompileString(_script.c_str(), stream.str().c_str(), Py_file_input);
1215 if(code == NULL)
1216 {
1217 _errorDetails="";
1218 PyObject* new_stderr = newPyStdOut(_errorDetails);
1219 PySys_SetObject((char*)"stderr", new_stderr);
1220 PyErr_Print();
1221 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1222 Py_DECREF(new_stderr);
1223 throw Exception("Error during execution");
1224 }
1225 PyObject *res = PyEval_EvalCode( code, _context, _context);
1226 Py_DECREF(code);
1227 Py_XDECREF(res);
1228
1229 DEBTRACE( "_context refcnt: " << _context->ob_refcnt );
1230 if(PyErr_Occurred ())
1231 {
1232 _errorDetails="";
1233 PyObject* new_stderr = newPyStdOut(_errorDetails);
1234 PySys_SetObject((char*)"stderr", new_stderr);
1235 ofstream errorfile(stream.str().c_str());
1236 if (errorfile.is_open())
1237 {
1238 errorfile << _script;
1239 errorfile.close();
1240 }
1241 PyErr_Print();
1242 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1243 Py_DECREF(new_stderr);
1244 throw Exception("Error during execution");
1245 return;
1246 }
1247 _pyfunc=PyDict_GetItemString(_context,_fname.c_str());
1248 DEBTRACE( "_pyfunc refcnt: " << _pyfunc->ob_refcnt );
1249 if(_pyfunc == NULL)
1250 {
1251 _errorDetails="";
1252 PyObject* new_stderr = newPyStdOut(_errorDetails);
1253 PySys_SetObject((char*)"stderr", new_stderr);
1254 PyErr_Print();
1255 PySys_SetObject((char*)"stderr", PySys_GetObject((char*)"__stderr__"));
1256 Py_DECREF(new_stderr);
1257 throw Exception("Error during execution");
1258 }
1259 DEBTRACE( "---------------End PyFuncNode::load function---------------" );
1260 }
1261}
References YACS::ENGINE::PythonEntry::_context, YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::InlineFuncNode::_fname, _pyfunc, YACS::ENGINE::InlineNode::_script, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::newPyStdOut(), and p.
Referenced by load().
◆ loadRemote()
void PyFuncNode::loadRemote ( )
Definition at line 1186 of file PythonNode.cxx.
1187{
1188 commonRemoteLoad(this);
1189}
void commonRemoteLoad(InlineNode *reqNode)
Definition: PythonNode.cxx:318
References YACS::ENGINE::PythonEntry::commonRemoteLoad().
◆ retrieveDftRemotePyInterpretorIfAny()
Engines::PyNodeBase_var PyFuncNode::retrieveDftRemotePyInterpretorIfAny ( Engines::Container_ptr  objContainer) const
Definition at line 1586 of file PythonNode.cxx.
1587{
1588 Engines::PyNode_var ret(objContainer->getDefaultPyNode(getName().c_str()));
1589 if(!CORBA::is_nil(ret))
1590 {
1591 ret->Register();
1592 }
1593 return Engines::PyNodeBase::_narrow(ret);
1594}
References YACS::ENGINE::Node::getName().
◆ shutdown()
void PyFuncNode::shutdown ( int  level)
Stop all pending activities of the node.
This method should be called when a Proc is finished and must be deleted from the YACS server
Definition at line 1640 of file PythonNode.cxx.
1641{
1642 DEBTRACE("PyFuncNode::shutdown " << level);
1643 if(_mode=="local")return;
1644 if(_container)
1645 {
1646 if(!CORBA::is_nil(_pynode)) _pynode->UnRegister();
1647 _pynode=Engines::PyNode::_nil();
1648 _container->shutdown(level);
1649 }
1650}
virtual void shutdown(int level)=0
References YACS::ENGINE::InlineNode::_container, YACS::ENGINE::InlineNode::_mode, _pynode, DEBTRACE, and YACS::ENGINE::Container::shutdown().
◆ simpleClone()
Node * PyFuncNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 1574 of file PythonNode.cxx.
1575{
1576 return new PyFuncNode(*this,father);
1577}
References PyFuncNode().
◆ typeName()
virtual std::string YACS::ENGINE::PyFuncNode::typeName ( )
Definition at line 163 of file PythonNode.hxx.
163{ return "YACS__ENGINE__PyFuncNode"; }
◆ _pyfunc
PyObject* YACS::ENGINE::PyFuncNode::_pyfunc
Definition at line 167 of file PythonNode.hxx.
Referenced by executeLocal(), and loadLocal().
◆ _pynode
Engines::PyNode_var YACS::ENGINE::PyFuncNode::_pynode
◆ SCRIPT_FOR_SERIALIZATION
const char PyFuncNode::SCRIPT_FOR_SERIALIZATION
Initial value:
="import pickle\n"
"def pickleForDistPyth2009(*args,**kws):\n"
" return pickle.dumps((args,kws),-1)\n"
"\n"
"def unPickleForDistPyth2009(st):\n"
" args=pickle.loads(st)\n"
" return args\n"
Definition at line 165 of file PythonNode.hxx.
