YACS::ENGINE::ServiceInlineNode Class Reference
#include <ServiceInlineNode.hxx>
Inheritance diagram for YACS::ENGINE::ServiceInlineNode:
Collaboration diagram for YACS::ENGINE::ServiceInlineNode:
void setScript (const std::string &script)
std::string getScript () const
- Public Member Functions inherited from YACS::ENGINE::ServiceNode
virtual void load ()
 Load the component associated to the node. More...
virtual bool isDeployable () const
 By definition of ServiceNode class. More...
virtual void setComponent (ComponentInstance *compo)
 Associate an existing component instance to this service node AND check the consistency regarding the deployment from root node point of view. More...
virtual ComponentInstance * getComponent ()
 Return the associated component instance. More...
virtual const ComponentInstance * getComponent () const
virtual Container * getContainer ()
 Return the associated container. More...
virtual void setRef (const std::string &ref)
 Associate a new component instance to this service node. More...
virtual std::string getRef ()
virtual void setMethod (const std::string &method)
virtual std::string getMethod ()
virtual ServiceNode * createNode (const std::string &name)=0
virtual ~ServiceNode ()
virtual std::string getKind () const
 Return the service node kind. More...
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
 ServiceInlineNode (const std::string &name)
 ServiceInlineNode (const ServiceInlineNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ServiceNode
 ServiceNode (const std::string &name)
 ServiceNode (const ServiceNode &other, ComposedNode *father)
template<class PORT >
std::string _script
- Protected Attributes inherited from YACS::ENGINE::ServiceNode
ComponentInstance * _component
std::string _method
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ServiceNode
static const char KIND [] =""
static int _total = 0
Definition at line 33 of file ServiceInlineNode.hxx.
◆ ServiceInlineNode() [1/2]
ServiceInlineNode::ServiceInlineNode ( const std::string &  name)
Definition at line 25 of file ServiceInlineNode.cxx.
25 :ServiceNode(name)
26{
27}
ServiceNode(const std::string &name)
Definition: ServiceNode.cxx:55
◆ ServiceInlineNode() [2/2]
ServiceInlineNode::ServiceInlineNode ( const ServiceInlineNode &  other,
ComposedNode *  father
Definition at line 29 of file ServiceInlineNode.cxx.
29 :ServiceNode(other,father),_script(other._script)
30{
31}
◆ accept()
void ServiceInlineNode::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ServiceNode.
Definition at line 43 of file ServiceInlineNode.cxx.
44{
45 visitor->visitServiceInlineNode(this);
46}
virtual void visitServiceInlineNode(ServiceInlineNode *node)=0
References YACS::ENGINE::Visitor::visitServiceInlineNode().
◆ getScript()
std::string ServiceInlineNode::getScript ( ) const
Definition at line 38 of file ServiceInlineNode.cxx.
39{
40 return _script;
41}
References _script.
Referenced by YACS::ENGINE::VisitorSaveSchema::visitServiceInlineNode().
◆ setScript()
void ServiceInlineNode::setScript ( const std::string &  script)
Definition at line 33 of file ServiceInlineNode.cxx.
34{
35 _script=script;
36}
References _script.
Referenced by YACS::inlinetypeParser< T >::function().
◆ typeName()
virtual std::string YACS::ENGINE::ServiceInlineNode::typeName ( )
Definition at line 42 of file ServiceInlineNode.hxx.
42{return "YACS__ENGINE__ServiceInlineNode";}
◆ _script
std::string YACS::ENGINE::ServiceInlineNode::_script
