YACS::remotetypeParser< T > Struct Template Reference
#include <remoteParsers.hxx>
Inheritance diagram for YACS::remotetypeParser< T >:
Collaboration diagram for YACS::remotetypeParser< T >:
virtual void load (const loadon &l)
void function (const myfunc &f)
void script (const myfunc &f)
virtual T post ()
- Public Member Functions inherited from YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >
virtual void pre ()
virtual void weight (const double &x)
virtual void kind (const std::string &name)
virtual void script (const myfunc &f)
virtual void function (const myfunc &f)
virtual void inport (const myinport &p)
virtual void outport (const myoutport &p)
virtual YACS::ENGINE::InlineNode * post ()
- Public Member Functions inherited from YACS::nodetypeParser< YACS::ENGINE::InlineNode * >
virtual void pre ()
virtual void type (const std::string &name)
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Static Public Attributes
static remotetypeParser< T > remoteParser
- Static Public Attributes inherited from YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >
static inlinetypeParser< YACS::ENGINE::InlineNode * > inlineParser
- Static Public Attributes inherited from YACS::nodetypeParser< YACS::ENGINE::InlineNode * >
static nodetypeParser< YACS::ENGINE::InlineNode * > nodeParser
static parser main_parser
- Public Attributes inherited from YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >
std::string _kind
double _weight
- Public Attributes inherited from YACS::nodetypeParser< YACS::ENGINE::InlineNode * >
std::string _type
std::string _state
std::string _container
YACS::ENGINE::InlineNode * _node
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
template<class T = YACS::ENGINE::InlineNode*>
struct YACS::remotetypeParser< T >
Definition at line 32 of file remoteParsers.hxx.
◆ function()
void YACS::remotetypeParser< T >::function ( const myfunc &  f)
Reimplemented from YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >.
Definition at line 56 of file remoteParsers.hxx.
57 {
58 DEBTRACE( "remote_function: " << f._code )
59 YACS::ENGINE::InlineFuncNode *fnode;
60 fnode=theRuntime->createFuncNode(this->_kind,this->_name);
61 fnode->setScript(f._code);
62 fnode->setFname(f._name);
63 fnode->setExecutionMode("remote");
64 if (this->_weight>0)fnode->setWeight(this->_weight);
65 this->_node=fnode;
66 }
Definition: parsers.cxx:40
References YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >::_kind, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >::_name, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >::_node, YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >::_weight, YACS::ENGINE::Runtime::createFuncNode(), DEBTRACE, gui.CONNECTOR::f(), YACS::ENGINE::InlineNode::setExecutionMode(), YACS::ENGINE::InlineFuncNode::setFname(), YACS::ENGINE::InlineNode::setScript(), YACS::ENGINE::ElementaryNode::setWeight(), and theRuntime.
Referenced by YACS::remotetypeParser< T >::onEnd().
◆ load()
virtual void YACS::remotetypeParser< T >::load ( const loadon &  l)
◆ onEnd()
virtual void YACS::remotetypeParser< T >::onEnd ( const char *  el,
parser *  child
Definition at line 37 of file remoteParsers.hxx.
38 {
39 DEBTRACE( "remotetypeParser::onEnd: " << el )
40 std::string element(el);
41 if(element == "kind")this->kind(((stringtypeParser*)child)->post()); // inherited
42 else if(element == "function")this->function(((functypeParser*)child)->post());
43 else if(element == "script")this->script(((codetypeParser*)child)->post());
44 else if(element == "load") this->load(((loadtypeParser*)child)->post());
45 else if(element == "property")this->property(((propertytypeParser*)child)->post());
46 else if(element == "inport") this->inport(((inporttypeParser<myinport>*)child)->post());
47 else if(element == "outport") this->outport(((outporttypeParser<myoutport>*)child)->post());
48 }
void function(const myfunc &f)
virtual void load(const loadon &l)
void script(const myfunc &f)
References DEBTRACE, YACS::remotetypeParser< T >::function(), YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >::inport(), YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >::kind(), YACS::remotetypeParser< T >::load(), YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >::outport(), YACS::remotetypeParser< T >::post(), YACS::nodetypeParser< YACS::ENGINE::InlineNode * >::property(), and YACS::remotetypeParser< T >::script().
◆ onStart()
template<class T >
void YACS::remotetypeParser< T >::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 105 of file remoteParsers.hxx.
106{
107 DEBTRACE( "remotetypeParser::onStart: " << el )
108 std::string element(el);
110 this->maxcount("kind",1,element);
111 this->maxcount("function",1,element);
112 this->maxcount("script",1,element);
113 this->maxcount("load",1,element);
114 this->maxchoice(t1,1,element);
115
116 if(element == "kind")pp=&stringtypeParser::stringParser;
117 else if(element == "load")pp=&loadtypeParser::loadParser;
118 else if(element == "function")pp=&functypeParser::funcParser;
119 else if(element == "script")pp=&codetypeParser::codeParser;
120 else if(element == "property")pp=&propertytypeParser::propertyParser;
121 else if(element == "inport")pp=&inporttypeParser<>::inportParser;
122 else if(element == "outport")pp=&outporttypeParser<>::outportParser;
123
124 this->SetUserDataAndPush(pp);
125 pp->init();
126 pp->pre();
127 pp->buildAttr(attr);
128}
static std::string t1[]
static codetypeParser codeParser
Definition: codeParsers.hxx:36
static functypeParser funcParser
Definition: codeParsers.hxx:75
static inporttypeParser< T > inportParser
Definition: portParsers.hxx:50
static loadtypeParser loadParser
static outporttypeParser< T > outportParser
Definition: portParsers.hxx:71
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
virtual void maxchoice(std::string *names, int max, std::string &el)
Definition: parserBase.cxx:145
Definition: dataParsers.hxx:33
References YACS::parser::buildAttr(), YACS::codetypeParser::codeParser, DEBTRACE, YACS::functypeParser::funcParser, YACS::parser::init(), YACS::loadtypeParser::loadParser, YACS::parser::main_parser, YACS::parser::pre(), YACS::propertytypeParser::propertyParser, YACS::stringtypeParser::stringParser, and YACS::t1.
◆ post()
virtual T YACS::remotetypeParser< T >::post ( )
Definition at line 79 of file remoteParsers.hxx.
80 {
81 DEBTRACE( "remote_post " << this->_node->getName() )
82 if(this->_state == "disabled")this->_node->exDisabledState();
83
84 //set the container
85 if(currentProc->containerMap.count(this->_container) != 0)
86 {
87 // a container with name (this->_container) exists. Use it
88 this->_node->setContainer(currentProc->containerMap[this->_container]);
89 }
90 else if(this->_container == "" && currentProc->containerMap.count("DefaultContainer") != 0)
91 {
92 // a container with name (this->_container) does not exist
93 //a default container is defined : use it
94 this->_node->setContainer(currentProc->containerMap["DefaultContainer"]);
95 }
96 else
97 std::cerr << "WARNING: Unknown container and no DefaultContainer " << this->_container << " will be ignored" << std::endl;
98
99 return this->_node;
100 }
virtual void setContainer(Container *container)
Definition: InlineNode.cxx:105
Definition: Node.hxx:125
Definition: Proc.hxx:91
Definition: parserBase.cxx:30
References YACS::nodetypeParser< YACS::ENGINE::InlineNode * >::_container, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >::_node, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >::_state, YACS::ENGINE::Proc::containerMap, DEBTRACE, YACS::ENGINE::Node::exDisabledState(), YACS::ENGINE::Node::getName(), and YACS::ENGINE::InlineNode::setContainer().
◆ script()
void YACS::remotetypeParser< T >::script ( const myfunc &  f)
◆ remoteParser
template<class T >
remotetypeParser< T > YACS::remotetypeParser< T >::remoteParser
Definition at line 34 of file remoteParsers.hxx.
