YACS::sinlinetypeParser< T > Struct Template Reference
Class for parsing ServiceInlineNode description. More...
#include <sinlineParsers.hxx>
Inheritance diagram for YACS::sinlinetypeParser< T >:
Collaboration diagram for YACS::sinlinetypeParser< T >:
virtual void load (const loadon &l)
virtual T post ()
- Public Member Functions inherited from YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >
virtual void pre ()
virtual void weight (const double &x)
virtual void kind (const std::string &name)
virtual void script (const myfunc &f)
virtual void function (const myfunc &f)
virtual void inport (const myinport &p)
virtual void outport (const myoutport &p)
virtual YACS::ENGINE::ServiceInlineNode * post ()
- Public Member Functions inherited from YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >
virtual void pre ()
virtual void type (const std::string &name)
YACS::ENGINE::InlineNode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Static Public Attributes
static sinlinetypeParser< T > sinlineParser
- Static Public Attributes inherited from YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >
static inlinetypeParser< YACS::ENGINE::ServiceInlineNode * > inlineParser
- Static Public Attributes inherited from YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >
static nodetypeParser< YACS::ENGINE::ServiceInlineNode * > nodeParser
static parser main_parser
- Public Attributes inherited from YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >
std::string _kind
double _weight
- Public Attributes inherited from YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >
std::string _type
std::string _state
std::string _container
YACS::ENGINE::ServiceInlineNode * _node
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
template<class T = YACS::ENGINE::ServiceInlineNode*>
struct YACS::sinlinetypeParser< T >
Definition at line 38 of file sinlineParsers.hxx.
◆ load()
virtual void YACS::sinlinetypeParser< T >::load ( const loadon &  l)
◆ onEnd()
virtual void YACS::sinlinetypeParser< T >::onEnd ( const char *  el,
parser *  child
Reimplemented from YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >.
Definition at line 43 of file sinlineParsers.hxx.
44 {
45 DEBTRACE( "sinlinetypeParser::onEnd: " << el )
46 std::string element(el);
47 if(element == "kind")this->kind(((stringtypeParser*)child)->post());
48 else if(element == "function")this->function(((functypeParser*)child)->post());
49 else if(element == "load") load(((loadtypeParser*)child)->post());
50 else if(element == "property")this->property(((propertytypeParser*)child)->post());
51 else if(element == "inport") this->inport(((inporttypeParser<myinport>*)child)->post());
52 else if(element == "outport") this->outport(((outporttypeParser<myoutport>*)child)->post());
53 }
virtual void load(const loadon &l)
References DEBTRACE, YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >::function(), YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >::inport(), YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >::kind(), YACS::sinlinetypeParser< T >::load(), YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >::outport(), YACS::sinlinetypeParser< T >::post(), and YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >::property().
◆ onStart()
template<class T >
void YACS::sinlinetypeParser< T >::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 111 of file sinlineParsers.hxx.
112 {
113 DEBTRACE( "sinlinetypeParser::onStart: " << el )
114 std::string element(el);
116 this->maxcount("kind",1,element);
117 this->maxcount("function",1,element);
118 this->maxcount("load",1,element);
119 if(element == "kind")pp=&stringtypeParser::stringParser;
120 else if(element == "function")pp=&functypeParser::funcParser;
121 else if(element == "load")pp=&loadtypeParser::loadParser;
122 else if(element == "property")pp=&propertytypeParser::propertyParser;
123 else if(element == "inport")pp=&inporttypeParser<>::inportParser;
124 else if(element == "outport")pp=&outporttypeParser<>::outportParser;
125 this->SetUserDataAndPush(pp);
126 pp->init();
127 pp->pre();
128 pp->buildAttr(attr);
129 }
static functypeParser funcParser
Definition: codeParsers.hxx:75
static inporttypeParser< T > inportParser
Definition: portParsers.hxx:50
static loadtypeParser loadParser
static outporttypeParser< T > outportParser
Definition: portParsers.hxx:71
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
Definition: dataParsers.hxx:33
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), and YACS::parser::pre().
◆ post()
virtual T YACS::sinlinetypeParser< T >::post ( )
Definition at line 60 of file sinlineParsers.hxx.
61 {
62 DEBTRACE( "sinline_post " << this->_node->getName() );
63 if(this->_state == "disabled")this->_node->exDisabledState();
64
65 if(!this->_node->getComponent())
66 throw YACS::Exception("A service inline node must have a component instance");
67
68 // If the component instance has already a container don't go further
69 if(this->_node->getComponent()->getContainer())
70 return this->_node;
71
72 // Only for anonymous component instance set a container
73 if(this->_node->getComponent()->isAnonymous())
74 {
75 if(currentProc->containerMap.count(this->_container) != 0)
76 this->_node->getComponent()->setContainer(currentProc->containerMap[this->_container]);
77 else if(this->_container == "" && currentProc->containerMap.count("DefaultContainer") != 0)
78 {
79 //a default container is defined : use it if supported
80 try
81 {
82 currentProc->containerMap["DefaultContainer"]->checkCapabilityToDealWith(this->_node->getComponent());
83 this->_node->getComponent()->setContainer(currentProc->containerMap["DefaultContainer"]);
84 }
85 catch(YACS::Exception){}
86 }
87 else
88 std::cerr << "WARNING: Unknown container " << this->_container << " ignored" << std::endl;
89 }
90
91 return this->_node;
92 }
virtual bool setContainer(Container *cont)
Definition: Node.hxx:125
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
Definition: Proc.hxx:91
virtual ComponentInstance * getComponent()
Return the associated component instance.
Definition: parserBase.cxx:30
References YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >::_container, YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >::_node, YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >::_state, YACS::ENGINE::Proc::containerMap, currentProc, DEBTRACE, YACS::ENGINE::Node::exDisabledState(), YACS::ENGINE::ServiceNode::getComponent(), YACS::ENGINE::ComponentInstance::getContainer(), YACS::ENGINE::Node::getName(), YACS::ENGINE::ComponentInstance::isAnonymous(), and YACS::ENGINE::ComponentInstance::setContainer().
Referenced by YACS::sinlinetypeParser< T >::onEnd().
◆ sinlineParser
template<class T >
sinlinetypeParser< T > YACS::sinlinetypeParser< T >::sinlineParser
Definition at line 40 of file sinlineParsers.hxx.
