20#ifndef _SWITCHPARSERS_HXX_
21#define _SWITCHPARSERS_HXX_
59 virtual void id (
const int&
n);
73 virtual std::pair<int,ENGINE::Node*>
post();
93 virtual void case_ (
const std::pair<int,ENGINE::Node*>&
p);
94 virtual void default_ (
p);
95 virtual void name (
const std::string&
name);
97 virtual void select (
const int& s);
111 static std::string
switch_t3[]={
"inline",
"sinline",
"service",
"server",
"remote",
"node",
"forloop",
"foreach",
"optimizer",
"while",
"switch",
"bloc",
118 for (
int i = 0; attr[
i];
i += 2)
120 if(std::string(attr[
i]) ==
"id")
id(atoi(attr[
i+1]));
135 std::stringstream temp;
136 if (
_id <0) temp <<
"m" << -
_id <<
"_";
137 else temp <<
"p" <<
_id <<
"_";
139 DEBTRACE(
"case_fullname: " << fullname )
199 fullname +=
".splitter";
237 return std::pair<int,ENGINE::Node*>(
_id,
_cnode);
244 for (
int i = 0; attr[
i];
i += 2)
257 DEBTRACE(
266 for (
int i = 0; attr[
i];
i += 2)
268 if(std::string(attr[
i]) ==
"name")
name(attr[
i+1]);
269 if(std::string(attr[
i]) ==
"state")
state(attr[
i+1]);
270 if(std::string(attr[
i]) ==
"select")
select(atoi(attr[
i+1]));
288 DEBTRACE(
"switch_fullname: " << fullname )
323 DEBTRACE(
"switchtypeParser::onStart: " << el )
324 std::string element(el);
325 this->
maxcount(
"default",1,element);
337 DEBTRACE(
"switchtypeParser::onEnd: " << el )
338 std::string element(el);
345 DEBTRACE(
"casetypeParser::onStart: " << el )
346 std::string element(el);
348 this->
maxcount(
"sinline",1,element);
349 this->
maxcount(
"service",1,element);
353 this->
maxcount(
"forloop",1,element);
354 this->
maxcount(
"foreach",1,element);
355 this->
maxcount(
"optimizer",1,element);
383 DEBTRACE(
"casetypeParser::onEnd: " << el )
384 std::string element(el);
std::string getName() const
Base class for all nodes.
virtual void exDisabledState()
Notify this node that it has been disabled.
std::map< std::string, InlineNode * > inlineMap
std::map< std::string, ServiceNode * > serviceMap
std::map< std::string, Node * > nodeMap
std::vector< std::string > names
virtual Switch * createSwitch(const std::string &name)
InputPort * edGetConditionPort()
Node * edSetDefaultNode(Node *DISOWNnode)
Node * edSetNode(int caseId, Node *DISOWNnode)
static std::string switch_t3[]
virtual std::pair< int, ENGINE::Node * > post()
virtual void remote(ENGINE::InlineNode *const &n)
void onStart(const XML_Char *el, const XML_Char **attr)
virtual void foreach(ENGINE::ForEachLoopGen *const &n)
virtual void bloc(ENGINE::Bloc *const &n)
std::vector< int > _idStack
virtual void optimizer(ENGINE::OptimizerLoop *const &n)
virtual void service(ENGINE::ServiceNode *const &n)
virtual void forloop(ENGINE::ForLoop *const &n)
virtual void switch_(ENGINE::Switch *const &n)
void onEnd(const char *el, parser *child)
virtual void inline_(ENGINE::InlineNode *const &n)
virtual void while_(ENGINE::WhileLoop *const &n)
static casetypeParser caseParser
virtual void id(const int &n)
virtual void server(ENGINE::ServerNode *const &n)
virtual void node(ENGINE::InlineNode *const &n)
virtual void sinline(ENGINE::ServiceInlineNode *const &n)
static defaultcasetypeParser defaultcaseParser
virtual void minchoice(std::string *names, int min)
static parser main_parser
virtual void maxchoice(std::string *names, int max, std::string &el)
Class for property parser.
Class for parsing ServiceInlineNode description.
virtual ENGINE::Switch * post()
virtual void default_(const std::pair< int, ENGINE::Node * > &p)
virtual void state(const std::string &state)
virtual void case_(const std::pair< int, ENGINE::Node * > &p)
virtual void select(const int &s)
static switchtypeParser switchParser
std::vector< ENGINE::Switch * > _cnodes
