YACS::switchtypeParser Struct Reference
#include <switchParsers.hxx>
Inheritance diagram for YACS::switchtypeParser:
Collaboration diagram for YACS::switchtypeParser:
void onStart (const XML_Char *el, const XML_Char **attr)
void onEnd (const char *el, parser *child)
virtual void pre ()
virtual void case_ (const std::pair< int, ENGINE::Node * > &p)
virtual void default_ (const std::pair< int, ENGINE::Node * > &p)
virtual void state (const std::string &state)
virtual void select (const int &s)
virtual ENGINE::Switch * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::vector< ENGINE::Switch * > _cnodes
std::string _state
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static switchtypeParser switchParser
static parser main_parser
Definition at line 86 of file switchParsers.hxx.
◆ buildAttr()
void YACS::switchtypeParser::buildAttr ( const XML_Char **  attr)
Definition at line 261 of file switchParsers.hxx.
262 {
263 if (!attr)
264 return;
265 this->required("name",attr);
266 for (int i = 0; attr[i]; i += 2)
267 {
268 if(std::string(attr[i]) == "name")name(attr[i+1]);
269 if(std::string(attr[i]) == "state")state(attr[i+1]);
270 if(std::string(attr[i]) == "select")select(atoi(attr[i+1]));
271 }
272 }
virtual void state(const std::string &state)
virtual void select(const int &s)
References yacsorb.CORBAEngineTest::i, name(), YACS::parser::required(), select(), and state().
◆ case_()
void YACS::switchtypeParser::case_ ( const std::pair< int, ENGINE::Node * > &  p)
Definition at line 274 of file switchParsers.hxx.
275 {
276 ENGINE::Switch* s=_cnodes.back();
277 s->edSetNode(p.first,p.second);
278 }
Proc * p
Definition: driver.cxx:216
References _cnodes, YACS::ENGINE::Switch::edSetNode(), and p.
Referenced by onEnd().
◆ default_()
void YACS::switchtypeParser::default_ ( const std::pair< int, ENGINE::Node * > &  p)
Definition at line 279 of file switchParsers.hxx.
280 {
281 ENGINE::Switch* s=_cnodes.back();
282 s->edSetDefaultNode(p.second);
283 }
References _cnodes, YACS::ENGINE::Switch::edSetDefaultNode(), and p.
void YACS::switchtypeParser::name ( const std::string &  name)
Definition at line 284 of file switchParsers.hxx.
285 {
286 ENGINE::Switch* s;
287 std::string fullname=currentProc->names.back()+name;
288 DEBTRACE( "switch_fullname: " << fullname )
290 _cnodes.push_back(s);
291 currentProc->names.push_back(fullname+'.');
292 }
std::vector< std::string > names
Definition: Proc.hxx:93
virtual Switch * createSwitch(const std::string &name)
Definition: Runtime.cxx:236
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
References _cnodes, YACS::ENGINE::Runtime::createSwitch(), currentProc, DEBTRACE, name(), YACS::ENGINE::Proc::names, and theRuntime.
Referenced by buildAttr(), and name().
◆ onEnd()
void YACS::switchtypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 335 of file switchParsers.hxx.
336{
337 DEBTRACE( "switchtypeParser::onEnd: " << el )
338 std::string element(el);
339 if(element == "case")case_(((casetypeParser*)child)->post());
340 else if(element == "default")default_(((defaultcasetypeParser*)child)->post());
341}
virtual ENGINE::Switch * post()
virtual void default_(const std::pair< int, ENGINE::Node * > &p)
virtual void case_(const std::pair< int, ENGINE::Node * > &p)
References case_(), DEBTRACE, default_(), and post().
◆ onStart()
void YACS::switchtypeParser::onStart ( const XML_Char *  el,
Definition at line 321 of file switchParsers.hxx.
322{
323 DEBTRACE( "switchtypeParser::onStart: " << el )
324 std::string element(el);
325 this->maxcount("default",1,element);
327 if(element == "case")pp=&casetypeParser::caseParser;
328 else if(element == "default")pp=&defaultcasetypeParser::defaultcaseParser;
330 pp->init();
331 pp->pre();
332 pp->buildAttr(attr);
333}
static casetypeParser caseParser
static defaultcasetypeParser defaultcaseParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
References YACS::parser::buildAttr(), YACS::casetypeParser::caseParser, DEBTRACE, YACS::defaultcasetypeParser::defaultcaseParser, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::maxcount(), YACS::parser::pre(), and YACS::parser::SetUserDataAndPush().
◆ post()
ENGINE::Switch * YACS::switchtypeParser::post ( )
Definition at line 311 of file switchParsers.hxx.
312 {
313 DEBTRACE( "switch_post: " )
314 ENGINE::Switch* sw=_cnodes.back();
315 //pop back current level name and node
316 _cnodes.pop_back();
317 currentProc->names.pop_back();
318 return sw;
319 }
References _cnodes, currentProc, DEBTRACE, and YACS::ENGINE::Proc::names.
◆ pre()
void YACS::switchtypeParser::pre ( )
Definition at line 273 of file switchParsers.hxx.
273{_state="";}
References _state.
◆ select()
void YACS::switchtypeParser::select ( const int &  s)
Definition at line 304 of file switchParsers.hxx.
305 {
306 //select is an attribute
307 ENGINE::Switch* sw=_cnodes.back();
308 ENGINE::InputPort *p=sw->edGetConditionPort();
309 p->edInit(s);
310 }
References _cnodes, YACS::ENGINE::Switch::edGetConditionPort(), and p.
Referenced by buildAttr().
◆ state()
void YACS::switchtypeParser::state ( const std::string &  state)
Definition at line 293 of file switchParsers.hxx.
294 {
295 //state is an attribute (no order). It can be defined before name
296 //To be improved
297 ENGINE::Switch* s=_cnodes.back();
298 if(_state == "disabled")
299 {
300 DEBTRACE( "Switch disabled: " << s->getName())
301 s->exDisabledState();
302 }
303 }
References _cnodes, _state, DEBTRACE, YACS::ENGINE::Node::exDisabledState(), and YACS::ENGINE::ComposedNode::getName().
◆ _cnodes
std::vector<ENGINE::Switch *> YACS::switchtypeParser::_cnodes
Definition at line 100 of file switchParsers.hxx.
Referenced by case_(), default_(), name(), post(), select(), and state().
◆ _state
std::string YACS::switchtypeParser::_state
Definition at line 101 of file switchParsers.hxx.
Referenced by pre(), and state().
◆ switchParser
switchtypeParser YACS::switchtypeParser::switchParser
