YACS::casetypeParser Struct Reference
#include <switchParsers.hxx>
Inheritance diagram for YACS::casetypeParser:
Collaboration diagram for YACS::casetypeParser:
void onStart (const XML_Char *el, const XML_Char **attr)
void onEnd (const char *el, parser *child)
virtual void pre ()
virtual void id (const int &n)
virtual void inline_ (ENGINE::InlineNode *const &n)
virtual void sinline (ENGINE::ServiceInlineNode *const &n)
virtual void service (ENGINE::ServiceNode *const &n)
virtual void server (ENGINE::ServerNode *const &n)
virtual void remote (ENGINE::InlineNode *const &n)
virtual void node (ENGINE::InlineNode *const &n)
virtual void forloop (ENGINE::ForLoop *const &n)
virtual void foreach (ENGINE::ForEachLoopGen *const &n)
virtual void optimizer (ENGINE::OptimizerLoop *const &n)
virtual void while_ (ENGINE::WhileLoop *const &n)
virtual void switch_ (ENGINE::Switch *const &n)
virtual void bloc (ENGINE::Bloc *const &n)
virtual std::pair< int, ENGINE::Node * > post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
ENGINE::Node * _cnode
int _id
std::vector< int > _idStack
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static casetypeParser caseParser
static parser main_parser
Definition at line 52 of file switchParsers.hxx.
◆ bloc()
void YACS::casetypeParser::bloc ( ENGINE::Bloc *const &  n)
Definition at line 222 of file switchParsers.hxx.
223 {
224 _cnode=n;
225 std::string fullname=currentProc->names.back()+ n->getName();
226 currentProc->nodeMap[fullname]=n;
227 }
std::map< std::string, Node * > nodeMap
Definition: Proc.hxx:87
std::vector< std::string > names
Definition: Proc.hxx:93
Definition: parserBase.cxx:30
References _cnode, currentProc, gui.Appli::n, YACS::ENGINE::Proc::names, and YACS::ENGINE::Proc::nodeMap.
Referenced by onEnd().
◆ buildAttr()
void YACS::casetypeParser::buildAttr ( const XML_Char **  attr)
Reimplemented in YACS::defaultcasetypeParser.
Definition at line 113 of file switchParsers.hxx.
114 {
115 if (!attr)
116 return;
117 this->required("id",attr);
118 for (int i = 0; attr[i]; i += 2)
119 {
120 if(std::string(attr[i]) == "id")id(atoi(attr[i+1]));
121 }
122 }
virtual void id(const int &n)
References yacsorb.CORBAEngineTest::i, id(), and YACS::parser::required().
◆ foreach()
void YACS::casetypeParser::foreach ( ENGINE::ForEachLoopGen *const &  n)
Definition at line 194 of file switchParsers.hxx.
195 {
196 _cnode=n;
197 std::string fullname=currentProc->names.back()+ n->getName();
198 currentProc->nodeMap[fullname]=n;
199 fullname += ".splitter";
200 currentProc->nodeMap[fullname]=n->getChildByShortName("splitter");
201 }
◆ forloop()
void YACS::casetypeParser::forloop ( ENGINE::ForLoop *const &  n)
Definition at line 188 of file switchParsers.hxx.
189 {
190 _cnode=n;
191 std::string fullname=currentProc->names.back()+ n->getName();
192 currentProc->nodeMap[fullname]=n;
193 }
◆ id()
void YACS::casetypeParser::id ( const int &  n)
Definition at line 128 of file switchParsers.hxx.
129 {
130 DEBTRACE( "case_id: " << n )
131 _id=n;
132 //store this level id
133 _idStack.push_back(_id);
134 //store this level name
135 std::stringstream temp;
136 if (_id <0) temp << "m" << -_id << "_";
137 else temp << "p" << _id << "_";
138 std::string fullname=currentProc->names.back()+temp.str();
139 DEBTRACE( "case_fullname: " << fullname )
140 currentProc->names.push_back(fullname);
141 }
References _id, _idStack, currentProc, DEBTRACE, gui.Appli::n, and YACS::ENGINE::Proc::names.
Referenced by buildAttr().
◆ inline_()
void YACS::casetypeParser::inline_ ( ENGINE::InlineNode *const &  n)
Definition at line 146 of file switchParsers.hxx.
147 {
148 _cnode=n;
149 std::string fullname=currentProc->names.back()+ n->getName();
150 currentProc->nodeMap[fullname]=n;
151 currentProc->inlineMap[fullname]=n;
152 }
std::map< std::string, InlineNode * > inlineMap
Definition: Proc.hxx:89
References _cnode, currentProc, YACS::ENGINE::Proc::inlineMap, gui.Appli::n, YACS::ENGINE::Proc::names, and YACS::ENGINE::Proc::nodeMap.
◆ node()
◆ onEnd()
void YACS::casetypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 381 of file switchParsers.hxx.
382{
383 DEBTRACE( "casetypeParser::onEnd: " << el )
384 std::string element(el);
385 if(element == "property")property(((propertytypeParser*)child)->post());
386 else if(element == "inline")inline_(((inlinetypeParser<>*)child)->post());
387 else if(element == "sinline")sinline(((sinlinetypeParser<>*)child)->post());
388 else if(element == "service")service(((servicetypeParser<>*)child)->post());
389 else if(element == "server")server(((servertypeParser<>*)child)->post());
390 else if(element == "remote")remote(((remotetypeParser<>*)child)->post());
391 else if(element == "node")node(((nodetypeParser<>*)child)->post());
392 else if(element == "forloop")forloop(((forlooptypeParser<>*)child)->post());
393 else if(element == "foreach")foreach(((foreachlooptypeParser<ENGINE::ForEachLoop *>*)child)->post());
394 else if(element == "foreachdyn")foreach(((foreachlooptypeParser<ENGINE::ForEachLoopDyn *>*)child)->post());
395 else if(element == "optimizer")optimizer(((optimizerlooptypeParser<>*)child)->post());
396 else if(element == "while")while_(((whilelooptypeParser<>*)child)->post());
397 else if(element == "switch")switch_(((switchtypeParser*)child)->post());
398 else if(element == "bloc")bloc(((bloctypeParser<>*)child)->post());
399}
virtual std::pair< int, ENGINE::Node * > post()
virtual void remote(ENGINE::InlineNode *const &n)
virtual void bloc(ENGINE::Bloc *const &n)
virtual void optimizer(ENGINE::OptimizerLoop *const &n)
virtual void service(ENGINE::ServiceNode *const &n)
virtual void forloop(ENGINE::ForLoop *const &n)
virtual void switch_(ENGINE::Switch *const &n)
virtual void inline_(ENGINE::InlineNode *const &n)
virtual void while_(ENGINE::WhileLoop *const &n)
virtual void server(ENGINE::ServerNode *const &n)
virtual void node(ENGINE::InlineNode *const &n)
virtual void sinline(ENGINE::ServiceInlineNode *const &n)
References bloc(), DEBTRACE, forloop(), inline_(), node(), optimizer(), post(), property(), remote(), server(), service(), sinline(), switch_(), and while_().
◆ onStart()
void YACS::casetypeParser::onStart ( const XML_Char *  el,
Definition at line 343 of file switchParsers.hxx.
344{
345 DEBTRACE( "casetypeParser::onStart: " << el )
346 std::string element(el);
347 this->maxcount("inline",1,element);
348 this->maxcount("sinline",1,element);
349 this->maxcount("service",1,element);
350 this->maxcount("server",1,element);
351 this->maxcount("remote",1,element);
352 this->maxcount("node",1,element);
353 this->maxcount("forloop",1,element);
354 this->maxcount("foreach",1,element);
355 this->maxcount("optimizer",1,element);
356 this->maxcount("while",1,element);
357 this->maxcount("switch",1,element);
358 this->maxcount("bloc",1,element);
359 this->maxchoice(switch_t3,1,element);
361 if(element == "property")pp=&propertytypeParser::propertyParser;
362 else if(element == "inline")pp=&inlinetypeParser<>::inlineParser;
363 else if(element == "sinline")pp=&sinlinetypeParser<>::sinlineParser;
364 else if(element == "service")pp=&servicetypeParser<>::serviceParser;
365 else if(element == "server")pp=&servertypeParser<>::serverParser;
366 else if(element == "remote")pp=&remotetypeParser<>::remoteParser;
367 else if(element == "node")pp=&nodetypeParser<>::nodeParser;
368 else if(element == "forloop")pp=&forlooptypeParser<>::forloopParser;
371 else if(element == "optimizer")pp=&optimizerlooptypeParser<>::optimizerloopParser;
372 else if(element == "while")pp=&whilelooptypeParser<>::whileloopParser;
373 else if(element == "switch")pp=&switchtypeParser::switchParser;
374 else if(element == "bloc")pp=&bloctypeParser<>::blocParser;
376 pp->init();
377 pp->pre();
378 pp->buildAttr(attr);
379}
static std::string switch_t3[]
static bloctypeParser< T > blocParser
Definition: blocParsers.hxx:62
static foreachlooptypeParser< T > foreachloopParser
static forlooptypeParser< T > forloopParser
static inlinetypeParser< T > inlineParser
static nodetypeParser< T > nodeParser
Definition: nodeParsers.hxx:55
static optimizerlooptypeParser< T > optimizerloopParser
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
virtual void maxchoice(std::string *names, int max, std::string &el)
Definition: parserBase.cxx:145
static remotetypeParser< T > remoteParser
static servertypeParser< T > serverParser
static servicetypeParser< T > serviceParser
static sinlinetypeParser< T > sinlineParser
static switchtypeParser switchParser
static whilelooptypeParser< T > whileloopParser
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::maxchoice(), YACS::parser::maxcount(), YACS::parser::pre(), YACS::propertytypeParser::propertyParser, YACS::parser::SetUserDataAndPush(), and YACS::switchtypeParser::switchParser.
◆ optimizer()
void YACS::casetypeParser::optimizer ( ENGINE::OptimizerLoop *const &  n)
Definition at line 202 of file switchParsers.hxx.
203 {
204 _cnode=n;
205 std::string fullname=currentProc->names.back()+ n->getName();
206 currentProc->nodeMap[fullname]=n;
207 //fullname += ".splitter";
208 //currentProc->nodeMap[fullname]=n->getChildByShortName("splitter");
209 }
◆ post()
std::pair< int, ENGINE::Node * > YACS::casetypeParser::post ( )
Definition at line 228 of file switchParsers.hxx.
229 {
230 DEBTRACE( "case_post" )
232 //get back this level id
233 _id=_idStack.back();
234 _idStack.pop_back();
235 //pop back this level name
236 currentProc->names.pop_back();
237 return std::pair<int,ENGINE::Node*>(_id,_cnode);
238 }
virtual void minchoice(std::string *names, int min)
Definition: parserBase.cxx:162
References _cnode, _id, _idStack, currentProc, DEBTRACE, YACS::parser::minchoice(), YACS::ENGINE::Proc::names, and YACS::switch_t3.
◆ pre()
void YACS::casetypeParser::pre ( )
Definition at line 123 of file switchParsers.hxx.
124 {
125 _cnode=0;
126 _id=0;
127 }
References _cnode, and _id.
◆ property()
void YACS::casetypeParser::property ( const myprop &  prop)
Definition at line 142 of file switchParsers.hxx.
143 {
144 DEBTRACE( "property_set: " << prop._name << prop._value )
145 }
std::string _name
Definition: factory.hxx:96
std::string _value
Definition: factory.hxx:97
References myprop::_name, myprop::_value, and DEBTRACE.
◆ remote()
void YACS::casetypeParser::remote ( ENGINE::InlineNode *const &  n)
Definition at line 174 of file switchParsers.hxx.
175 {
176 _cnode=n;
177 std::string fullname=currentProc->names.back()+ n->getName();
178 currentProc->nodeMap[fullname]=n;
179 currentProc->inlineMap[fullname]=n;
180 }
◆ server()
void YACS::casetypeParser::server ( ENGINE::ServerNode *const &  n)
Definition at line 167 of file switchParsers.hxx.
168 {
169 _cnode=n;
170 std::string fullname=currentProc->names.back()+ n->getName();
171 currentProc->nodeMap[fullname]=n;
172 currentProc->inlineMap[fullname]=n;
173 }
◆ service()
void YACS::casetypeParser::service ( ENGINE::ServiceNode *const &  n)
Definition at line 160 of file switchParsers.hxx.
161 {
162 _cnode=n;
163 std::string fullname=currentProc->names.back()+ n->getName();
164 currentProc->nodeMap[fullname]=n;
165 currentProc->serviceMap[fullname]=n;
166 }
std::map< std::string, ServiceNode * > serviceMap
Definition: Proc.hxx:88
References _cnode, currentProc, gui.Appli::n, YACS::ENGINE::Proc::names, YACS::ENGINE::Proc::nodeMap, and YACS::ENGINE::Proc::serviceMap.
Referenced by gui.cataitems.ItemService::addNode(), gui.cataitems.ItemService::getChildren(), and onEnd().
◆ sinline()
void YACS::casetypeParser::sinline ( ENGINE::ServiceInlineNode *const &  n)
Definition at line 153 of file switchParsers.hxx.
154 {
155 _cnode=n;
156 std::string fullname=currentProc->names.back()+ n->getName();
157 currentProc->nodeMap[fullname]=n;
158 currentProc->serviceMap[fullname]=n;
159 }
◆ switch_()
void YACS::casetypeParser::switch_ ( ENGINE::Switch *const &  n)
Definition at line 216 of file switchParsers.hxx.
217 {
218 _cnode=n;
219 std::string fullname=currentProc->names.back()+ n->getName();
220 currentProc->nodeMap[fullname]=n;
221 }
◆ while_()
void YACS::casetypeParser::while_ ( ENGINE::WhileLoop *const &  n)
Definition at line 210 of file switchParsers.hxx.
211 {
212 _cnode=n;
213 std::string fullname=currentProc->names.back()+ n->getName();
214 currentProc->nodeMap[fullname]=n;
215 }
◆ _cnode
◆ _id
int YACS::casetypeParser::_id
Definition at line 75 of file switchParsers.hxx.
Referenced by id(), post(), pre(), and YACS::defaultcasetypeParser::pre().
◆ _idStack
std::vector<int> YACS::casetypeParser::_idStack
Definition at line 76 of file switchParsers.hxx.
Referenced by id(), post(), and YACS::defaultcasetypeParser::pre().
◆ caseParser
casetypeParser YACS::casetypeParser::caseParser
Definition at line 54 of file switchParsers.hxx.
Referenced by YACS::switchtypeParser::onStart().
