YACS::forlooptypeParser< T > Struct Template Reference
#include <loopParsers.hxx>
Inheritance diagram for YACS::forlooptypeParser< T >:
Collaboration diagram for YACS::forlooptypeParser< T >:
virtual void nsteps (const int &n)
virtual T post ()
- Public Member Functions inherited from YACS::looptypeParser< ENGINE::ForLoop * >
virtual void pre ()
virtual void inline_ (ENGINE::InlineNode *const &n)
virtual void sinline (ENGINE::ServiceInlineNode *const &n)
virtual void service (ENGINE::ServiceNode *const &n)
virtual void server (ENGINE::ServerNode *const &n)
virtual void remote (ENGINE::InlineNode *const &n)
virtual void node (ENGINE::InlineNode *const &n)
virtual void forloop (ENGINE::ForLoop *const &b)
virtual void foreach (ENGINE::ForEachLoopGen *const &b)
virtual void optimizer (ENGINE::OptimizerLoop *const &b)
virtual void while_ (ENGINE::WhileLoop *const &b)
virtual void switch_ (ENGINE::Switch *const &b)
virtual void bloc (ENGINE::Bloc *const &b)
virtual void datalink (const mylink &l)
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
int _nsteps
- Public Attributes inherited from YACS::looptypeParser< ENGINE::ForLoop * >
std::string _state
ENGINE::ForLoop * _cnode
std::vector< ENGINE::ForLoop * > _cnodes
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static forlooptypeParser< T > forloopParser
static parser main_parser
template<class T = ENGINE::ForLoop*>
struct YACS::forlooptypeParser< T >
Definition at line 326 of file loopParsers.hxx.
◆ buildAttr()
template<class T >
void YACS::forlooptypeParser< T >::buildAttr ( const XML_Char **  attr)
Reimplemented from YACS::looptypeParser< ENGINE::ForLoop * >.
Definition at line 339 of file loopParsers.hxx.
340 {
341 if (!attr)
342 return;
343 this->required("name",attr);
344 for (int i = 0; attr[i]; i += 2)
345 {
346 if(std::string(attr[i]) == "name")name(attr[i+1]);
347 if(std::string(attr[i]) == "state")this->state(attr[i+1]);
348 if(std::string(attr[i]) == "nsteps")nsteps(atoi(attr[i+1]));
349 }
350 }
virtual void nsteps(const int &n)
virtual void state(const std::string &name)
References yacsorb.CORBAEngineTest::i, and yacsorb.CORBAEngineTest::state.
template<class T >
void YACS::forlooptypeParser< T >::name ( const std::string &  name)
Definition at line 353 of file loopParsers.hxx.
354 {
355 DEBTRACE( "forloop_name: " << name );
356 std::string fullname=currentProc->names.back()+name;
358 currentProc->nodeMap[fullname]=this->_cnode;
359 this->_cnodes.push_back(this->_cnode);
360 currentProc->names.push_back(fullname+'.');
361 _nsteps=0;
362 }
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
std::map< std::string, Node * > nodeMap
Definition: Proc.hxx:87
std::vector< std::string > names
Definition: Proc.hxx:93
virtual ForLoop * createForLoop(const std::string &name)
Definition: Runtime.cxx:246
Definition: loopParsers.hxx:72
References YACS::ENGINE::Runtime::createForLoop(), currentProc, DEBTRACE, YACS::ENGINE::Proc::names, YACS::ENGINE::Proc::nodeMap, and theRuntime.
◆ nsteps()
template<class T >
void YACS::forlooptypeParser< T >::nsteps ( const int &  n)
Definition at line 365 of file loopParsers.hxx.
366 {
367 DEBTRACE( "forloop_nsteps: " << n )
368 if(!this->_cnode)
369 throw Exception("Node name must be defined before nsteps");
370 ENGINE::InputPort *iNbTimes=this->_cnode->edGetNbOfTimesInputPort();
371 iNbTimes->edInit(n);
372 }
InputPort * edGetNbOfTimesInputPort()
Definition: ForLoop.hxx:45
void edInit(T value)
Definition: InputPort.hxx:129
References DEBTRACE, YACS::ENGINE::InputPort::edInit(), and gui.Appli::n.
◆ post()
template<class T >
T YACS::forlooptypeParser< T >::post
Definition at line 375 of file loopParsers.hxx.
376 {
377 DEBTRACE( "forloop_post" )
378 T b=this->_cnode;
379 this->_cnodes.pop_back();
380 currentProc->names.pop_back();
381 this->_cnode=this->_cnodes.empty() ? 0 : this->_cnodes.back();
382 return b;
383 }
References gui.CONNECTOR::b, currentProc, DEBTRACE, and YACS::ENGINE::Proc::names.
◆ _nsteps
int YACS::forlooptypeParser< T >::_nsteps
Definition at line 333 of file loopParsers.hxx.
◆ forloopParser
template<class T >
forlooptypeParser< T > YACS::forlooptypeParser< T >::forloopParser
Definition at line 328 of file loopParsers.hxx.
