cataitems.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20from qt import *
21
22from . import Item
23from . import CONNECTOR
24from . import Items
27 def __init__(self,root=None):
28 Item.Item.__init__(self)
29 if root:
30 self.root=root
31 else:
32 self.root=self
33
34 def selected(self):
35 if not self.emittingemitting:
37 CONNECTOR.Emit(self.root,"selected",self)
38 self.emittingemitting=0
39
40 def panel(self,parent):
41 """Retourne un tab widget pour browser/editer la proc"""
42 tabWidget = QTabWidget( parent )
43 for name,method in self.panels:
44 tabWidget.addTab( method(self,tabWidget), name )
45 return tabWidget
46
47 box=panel
48
49 def panel1(self,parent):
50 qvbox=QVBox(parent)
51 self.text=QTextEdit(qvbox,"log")
52 self.text.setFrameShape(QTextEdit.NoFrame)
53 self.text.setTextFormat(QTextEdit.PlainText)
54 self.text.setWordWrap(QTextEdit.FixedColumnWidth)
55 #self.text.setWrapColumnOrWidth(120)
56 self.text.setReadOnly(1)
57 return qvbox
58
59 panels=[("Panel1",panel1)]
60
62 def __init__(self,service,root):
63 Item.Item.__init__(self)
64 self.root=root
65 self.service=service
66 self.labellabel=service.getName()
67
68 def isExpandable(self):
69 return True
70
71 def addNode(self,appli):
72 appli.addNode(self.service)
73
74 def getChildren(self):
75 sublist=[]
76 for port in self.service.getSetOfInputPort():
77 sublist.append(Items.ItemInPort(port,self.root))
78 for port in self.service.getSetOfOutputPort():
79 sublist.append(Items.ItemOutPort(port,self.root))
80 for port in self.service.getSetOfInputDataStreamPort():
81 sublist.append(Items.ItemInStream(port,self.root))
82 for port in self.service.getSetOfOutputDataStreamPort():
83 sublist.append(Items.ItemOutStream(port,self.root))
84 return sublist
85
86 def selected(self):
87 if not self.emittingemitting:
89 CONNECTOR.Emit(self.root,"selected",self)
90 self.emittingemitting=0
91
93 def __init__(self,typ,root,name=""):
94 Item.Item.__init__(self)
95 self.typ=typ
96 self.root=root
97 if name:
98 self.labellabel=name
99 else:
100 self.labellabel=typ.name()
101
102 def isExpandable(self):
103 return True
104
105 def getChildren(self):
106 sublist=[]
107 return sublist
108
109 def selected(self):
110 if not self.emittingemitting:
112 CONNECTOR.Emit(self.root,"selected",self)
113 self.emittingemitting=0
114
116 def __init__(self,compo,root):
117 Item.Item.__init__(self)
118 self.compo=compo
119 self.root=root
120 self.labellabel=compo.getName()
121
122 def isExpandable(self):
123 return True
124
125 def getChildren(self):
126 sublist=[]
127 for service in list(self.compo._serviceMap.values()):
128 itemservice=ItemService(service,self.root)
129 sublist.append(itemservice)
130 return sublist
131
132 def selected(self):
133 if not self.emittingemitting:
135 CONNECTOR.Emit(self.root,"selected",self)
136 self.emittingemitting=0
137
139 def __init__(self,node,root):
140 Item.Item.__init__(self)
141 self.node=node
142 self.root=root
143 self.labellabel=node.getName()
144
145 def isExpandable(self):
146 return True
147
148 def addNode(self,appli):
149 appli.addNode(self.node)
150
151 def getChildren(self):
152 sublist=[]
153 return sublist
154
155 def selected(self):
156 if not self.emittingemitting:
158 CONNECTOR.Emit(self.root,"selected",self)
159 self.emittingemitting=0
160
162 def __init__(self,node,root):
163 Item.Item.__init__(self)
164 self.node=node
165 self.root=root
166 self.labellabel=node.getName()
167
168 def addNode(self,appli):
169 appli.addNode(self.node)
170
171 def isExpandable(self):
172 return True
173
174 def getChildren(self):
175 sublist=[]
176 return sublist
177
178 def selected(self):
179 if not self.emittingemitting:
181 CONNECTOR.Emit(self.root,"selected",self)
182 self.emittingemitting=0
183
185 """Item for types folder"""
186 def __init__(self,typeMap,root):
187 Item.Item.__init__(self)
188 self.typeMap=typeMap
189 self.labellabel="Types"
190 self.root=root
191
192 def getIconName(self):
193 return "folder"
194
195 def isExpandable(self):
196 return True
197
198 def getChildren(self):
199 sublist=[]
200 for name,typ in list(self.typeMap.items()):
201 itemtype=ItemType(typ,self.root,name)
202 sublist.append(itemtype)
203 return sublist
204
206 """Item for components folder"""
207 def __init__(self,compoMap,root):
208 Item.Item.__init__(self)
209 self.compoMap=compoMap
210 self.labellabel="Components"
211 self.root=root
212
213 def getIconName(self):
214 return "folder"
215
216 def isExpandable(self):
217 return True
218
219 def getChildren(self):
220 sublist=[]
221 for compo in list(self.compoMap.values()):
222 itemcompo=ItemCompo(compo,self.root)
223 sublist.append(itemcompo)
224 return sublist
225
227 """Item for nodes folder"""
228 def __init__(self,nodesMap,root):
229 Item.Item.__init__(self)
230 self.nodesMap=nodesMap
231 self.labellabel="Nodes"
232 self.root=root
233
234 def getIconName(self):
235 return "folder"
236
237 def isExpandable(self):
238 return True
239
240 def getChildren(self):
241 sublist=[]
242 for node in list(self.nodesMap.values()):
243 itemnode=ItemNode(node,self.root)
244 sublist.append(itemnode)
245 return sublist
246
248 """Item for composed nodes folder"""
249 def __init__(self,composedMap,root):
250 Item.Item.__init__(self)
251 self.composedMap=composedMap
252 self.labellabel="ComposedNodes"
253 self.root=root
254
255 def getIconName(self):
256 return "folder"
257
258 def isExpandable(self):
259 return True
260
261 def getChildren(self):
262 sublist=[]
263 for node in list(self.composedMap.values()):
264 itemnode=ItemComposedNode(node,self.root)
265 sublist.append(itemnode)
266 return sublist
267
268class Cata(Obj):
269 def __init__(self,cata):
270 Obj.__init__(self)
271 self.cata=cata
272 self.labellabel=cata.getName()
273
274 def isExpandable(self):
275 return True
276
277 def getChildren(self):
278 sublist=[]
279 sublist.append(TypesItem(self.cata._typeMap,self))
280 sublist.append(NodesItem(self.cata._nodeMap,self))
281 sublist.append(ComposedNodesItem(self.cata._composednodeMap,self))
282 sublist.append(ComponentsItem(self.cata._componentMap,self))
283 return sublist
284
285 def dblselected(self):
286 if not self.emittingemittingemitting:
288 CONNECTOR.Emit(self,"dblselected",self)
290
Definition: cataitems.py:285
Definition: cataitems.py:277
Definition: cataitems.py:274
def __init__(self, cata)
Definition: cataitems.py:269
def __init__(self, compoMap, root)
Definition: cataitems.py:207
def __init__(self, composedMap, root)
Definition: cataitems.py:249
def __init__(self, compo, root)
Definition: cataitems.py:116
def __init__(self, node, root)
Definition: cataitems.py:162
def addNode(self, appli)
Definition: cataitems.py:168
Definition: cataitems.py:145
Definition: cataitems.py:139
Definition: cataitems.py:148
Definition: cataitems.py:71
def __init__(self, service, root)
Definition: cataitems.py:62
def __init__(self, typ, root, name="")
Definition: cataitems.py:93
Definition: cataitems.py:102
def __init__(self, nodesMap, root)
Definition: cataitems.py:228
def panel(self, parent)
Definition: cataitems.py:40
def __init__(self, root=None)
def selected(self)
Definition: cataitems.py:34
def panel1(self, parent)
Definition: cataitems.py:49
def __init__(self, typeMap, root)
Definition: cataitems.py:186
