YACS::optimizerlooptypeParser< T > Struct Template Reference
#include <loopParsers.hxx>
Inheritance diagram for YACS::optimizerlooptypeParser< T >:
Collaboration diagram for YACS::optimizerlooptypeParser< T >:
virtual void pre ()
virtual void lib (const std::string &name)
virtual void entry (const std::string &name)
virtual void nbranch (const int &n)
virtual void weight (const double &x)
virtual void kind (const std::string &name)
virtual void postAttr ()
virtual T post ()
- Public Member Functions inherited from YACS::dynparalooptypeParser< ENGINE::OptimizerLoop * >
virtual void initnode (PseudoComposedNode *const &n)
virtual void finalizenode (PseudoComposedNode *const &n)
- Public Member Functions inherited from YACS::looptypeParser< ENGINE::OptimizerLoop * >
virtual void pre ()
virtual void inline_ (ENGINE::InlineNode *const &n)
virtual void sinline (ENGINE::ServiceInlineNode *const &n)
virtual void service (ENGINE::ServiceNode *const &n)
virtual void server (ENGINE::ServerNode *const &n)
virtual void remote (ENGINE::InlineNode *const &n)
virtual void node (ENGINE::InlineNode *const &n)
virtual void forloop (ENGINE::ForLoop *const &b)
virtual void foreach (ENGINE::ForEachLoopGen *const &b)
virtual void optimizer (ENGINE::OptimizerLoop *const &b)
virtual void while_ (ENGINE::WhileLoop *const &b)
virtual void switch_ (ENGINE::Switch *const &b)
virtual void bloc (ENGINE::Bloc *const &b)
virtual void datalink (const mylink &l)
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
int _nbranch
double _weight
std::string _fullname
std::string _entry
std::string _kind
std::string _lib
- Public Attributes inherited from YACS::looptypeParser< ENGINE::OptimizerLoop * >
std::string _state
ENGINE::OptimizerLoop * _cnode
std::vector< ENGINE::OptimizerLoop * > _cnodes
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static optimizerlooptypeParser< T > optimizerloopParser
static parser main_parser
template<class T = ENGINE::OptimizerLoop*>
struct YACS::optimizerlooptypeParser< T >
Definition at line 602 of file loopParsers.hxx.
◆ buildAttr()
virtual void YACS::optimizerlooptypeParser< T >::buildAttr ( const XML_Char **  attr)
Reimplemented from YACS::looptypeParser< ENGINE::OptimizerLoop * >.
Definition at line 606 of file loopParsers.hxx.
607 {
608 if (!attr)
609 return;
610 this->required("name",attr);
611 this->required("lib",attr);
612 this->required("entry",attr);
613 for (int i = 0; attr[i]; i += 2)
614 {
615 if(std::string(attr[i]) == "name")name(attr[i+1]);
616 if(std::string(attr[i]) == "state")this->state(attr[i+1]);
617 if(std::string(attr[i]) == "nbranch")nbranch(atoi(attr[i+1]));
618 if(std::string(attr[i]) == "loopWeight")weight(atof(attr[i+1]));
619 if(std::string(attr[i]) == "lib")lib(attr[i+1]);
620 if(std::string(attr[i]) == "entry")entry(attr[i+1]);
621 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
622 }
623 postAttr();
624 }
virtual void state(const std::string &name)
virtual void weight(const double &x)
virtual void lib(const std::string &name)
virtual void entry(const std::string &name)
virtual void nbranch(const int &n)
References YACS::optimizerlooptypeParser< T >::entry(), yacsorb.CORBAEngineTest::i, YACS::optimizerlooptypeParser< T >::kind(), YACS::optimizerlooptypeParser< T >::lib(), YACS::optimizerlooptypeParser< T >::name(), YACS::optimizerlooptypeParser< T >::nbranch(), YACS::optimizerlooptypeParser< T >::postAttr(), YACS::parser::required(), YACS::looptypeParser< ENGINE::OptimizerLoop * >::state(), and YACS::optimizerlooptypeParser< T >::weight().
◆ entry()
virtual void YACS::optimizerlooptypeParser< T >::entry ( const std::string &  name)
◆ kind()
virtual void YACS::optimizerlooptypeParser< T >::kind ( const std::string &  name)
◆ lib()
virtual void YACS::optimizerlooptypeParser< T >::lib ( const std::string &  name)
◆ nbranch()
virtual void YACS::optimizerlooptypeParser< T >::nbranch ( const int &  n)
Definition at line 645 of file loopParsers.hxx.
646 {
647 DEBTRACE("optimizer_nbranch: " << n )
648 _nbranch=n;
649 }
References YACS::optimizerlooptypeParser< T >::_nbranch, DEBTRACE, and gui.Appli::n.
Referenced by YACS::optimizerlooptypeParser< T >::buildAttr().
◆ post()
virtual T YACS::optimizerlooptypeParser< T >::post ( )
Definition at line 668 of file loopParsers.hxx.
669 {
670 DEBTRACE("optimizer_post" << this->_cnode->getName())
671 T b=this->_cnode;
672 this->_cnodes.pop_back();
673 currentProc->names.pop_back();
674 this->_cnode=this->_cnodes.empty() ? 0 : this->_cnodes.back();
675 return b;
676 }
std::string getName() const
Definition: loopParsers.hxx:72
References YACS::looptypeParser< ENGINE::OptimizerLoop * >::_cnode, YACS::looptypeParser< ENGINE::OptimizerLoop * >::_cnodes, gui.CONNECTOR::b, currentProc, DEBTRACE, YACS::ENGINE::ComposedNode::getName(), and YACS::ENGINE::Proc::names.
◆ postAttr()
virtual void YACS::optimizerlooptypeParser< T >::postAttr ( )
Definition at line 659 of file loopParsers.hxx.
660 {
662 //set number of branches
664 if(_weight > 0)this->_cnode->setWeight(_weight);
665 this->_cnodes.push_back(this->_cnode);
666 currentProc->names.push_back(_fullname + '.');
667 }
Definition: parsers.cxx:40
InputPort * edGetNbOfBranchesPort()
Definition: DynParaLoop.hxx:83
void setWeight(double loopWeight)
void edInit(T value)
Definition: InputPort.hxx:129
virtual OptimizerLoop * createOptimizerLoop(const std::string &name, const std::string &algLib, const std::string &factoryName, bool algInitOnFile, const std::string &kind="", Proc *procForTypes=NULL)
Definition: Runtime.cxx:263
References YACS::looptypeParser< ENGINE::OptimizerLoop * >::_cnode, YACS::looptypeParser< ENGINE::OptimizerLoop * >::_cnodes, YACS::optimizerlooptypeParser< T >::_entry, YACS::optimizerlooptypeParser< T >::_fullname, YACS::optimizerlooptypeParser< T >::_kind, YACS::optimizerlooptypeParser< T >::_lib, YACS::optimizerlooptypeParser< T >::_name, YACS::optimizerlooptypeParser< T >::_nbranch, YACS::optimizerlooptypeParser< T >::_weight, YACS::ENGINE::Runtime::createOptimizerLoop(), currentProc, YACS::ENGINE::DynParaLoop::edGetNbOfBranchesPort(), YACS::ENGINE::InputPort::edInit(), YACS::ENGINE::Proc::names, YACS::ENGINE::DynParaLoop::setWeight(), and theRuntime.
◆ pre()
virtual void YACS::optimizerlooptypeParser< T >::pre ( )
◆ weight()
virtual void YACS::optimizerlooptypeParser< T >::weight ( const double &  x)
Definition at line 650 of file loopParsers.hxx.
651 {
652 DEBTRACE("foreach_weight: " << x )
653 _weight=x;
654 }
References YACS::optimizerlooptypeParser< T >::_weight, and DEBTRACE.
◆ _entry
std::string YACS::optimizerlooptypeParser< T >::_entry
◆ _fullname
std::string YACS::optimizerlooptypeParser< T >::_fullname
◆ _kind
std::string YACS::optimizerlooptypeParser< T >::_kind
◆ _lib
std::string YACS::optimizerlooptypeParser< T >::_lib
◆ _name
std::string YACS::optimizerlooptypeParser< T >::_name
◆ _nbranch
◆ _weight
◆ optimizerloopParser
template<class T >
optimizerlooptypeParser< T > YACS::optimizerlooptypeParser< T >::optimizerloopParser
Definition at line 604 of file loopParsers.hxx.
