YACS::dynparalooptypeParser< T > Struct Template Reference
#include <loopParsers.hxx>
Inheritance diagram for YACS::dynparalooptypeParser< T >:
Collaboration diagram for YACS::dynparalooptypeParser< T >:
virtual void initnode (PseudoComposedNode *const &n)
virtual void finalizenode (PseudoComposedNode *const &n)
- Public Member Functions inherited from YACS::looptypeParser< ENGINE::DynParaLoop * >
virtual void pre ()
virtual void inline_ (ENGINE::InlineNode *const &n)
virtual void sinline (ENGINE::ServiceInlineNode *const &n)
virtual void service (ENGINE::ServiceNode *const &n)
virtual void server (ENGINE::ServerNode *const &n)
virtual void remote (ENGINE::InlineNode *const &n)
virtual void node (ENGINE::InlineNode *const &n)
virtual void forloop (ENGINE::ForLoop *const &b)
virtual void foreach (ENGINE::ForEachLoopGen *const &b)
virtual void optimizer (ENGINE::OptimizerLoop *const &b)
virtual void while_ (ENGINE::WhileLoop *const &b)
virtual void switch_ (ENGINE::Switch *const &b)
virtual void bloc (ENGINE::Bloc *const &b)
virtual void datalink (const mylink &l)
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
- Public Attributes inherited from YACS::looptypeParser< ENGINE::DynParaLoop * >
std::string _state
ENGINE::DynParaLoop * _cnode
std::vector< ENGINE::DynParaLoop * > _cnodes
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
static parser main_parser
template<class T = ENGINE::DynParaLoop*>
struct YACS::dynparalooptypeParser< T >
Definition at line 441 of file loopParsers.hxx.
◆ finalizenode()
virtual void YACS::dynparalooptypeParser< T >::finalizenode ( PseudoComposedNode *const &  n)
Definition at line 479 of file loopParsers.hxx.
480 {
481 DEBTRACE( "dynparaloop_finalizenode: " << n->getNode()->getName() )
482 this->_cnode->edSetFinalizeNode(n->getNode());
483 delete n;
484 }
References YACS::looptypeParser< ENGINE::DynParaLoop * >::_cnode, DEBTRACE, YACS::ENGINE::DynParaLoop::edSetFinalizeNode(), YACS::PseudoComposedNode::getNode(), and gui.Appli::n.
Referenced by YACS::dynparalooptypeParser< T >::onEnd().
◆ initnode()
virtual void YACS::dynparalooptypeParser< T >::initnode ( PseudoComposedNode *const &  n)
Definition at line 472 of file loopParsers.hxx.
473 {
474 DEBTRACE( "dynparaloop_initnode: " << n->getNode()->getName() )
475 this->_cnode->edSetInitNode(n->getNode());
476 delete n;
477 }
References YACS::looptypeParser< ENGINE::DynParaLoop * >::_cnode, DEBTRACE, YACS::ENGINE::DynParaLoop::edSetInitNode(), YACS::PseudoComposedNode::getNode(), and gui.Appli::n.
◆ onEnd()
virtual void YACS::dynparalooptypeParser< T >::onEnd ( const char *  el,
parser *  child
Reimplemented from YACS::looptypeParser< ENGINE::DynParaLoop * >.
Definition at line 463 of file loopParsers.hxx.
464 {
465 DEBTRACE( "dynparalooptypeParser::onEnd: " << el )
466 std::string element(el);
467 if (element == "initnode") initnode(((pseudocomposednodetypeParser<>*)child)->post());
468 else if (element == "finalizenode") finalizenode(((pseudocomposednodetypeParser<>*)child)->post());
469 else this->looptypeParser<T>::onEnd(el, child);
470 }
virtual void finalizenode(PseudoComposedNode *const &n)
virtual void initnode(PseudoComposedNode *const &n)
References DEBTRACE, YACS::dynparalooptypeParser< T >::finalizenode(), YACS::dynparalooptypeParser< T >::initnode(), YACS::looptypeParser< T >::onEnd(), and YACS::parser::post().
◆ onStart()
virtual void YACS::dynparalooptypeParser< T >::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 443 of file loopParsers.hxx.
444 {
445 DEBTRACE( "dynparalooptypeParser::onStart: " << el )
446 std::string element(el);
447 this->maxcount("initnode",1,element);
448 this->maxcount("finalizenode",1,element);
449 if (element == "initnode" || element == "finalizenode")
450 {
452 this->SetUserDataAndPush(pp);
453 pp->init();
454 pp->pre();
455 pp->buildAttr(attr);
456 }
457 else
458 {
459 this->looptypeParser<T>::onStart(el, attr);
460 }
461 }
Definition: parserBase.cxx:55
static pseudocomposednodetypeParser< T > pseudocomposednodeParser
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::maxcount(), YACS::looptypeParser< T >::onStart(), YACS::parser::pre(), and YACS::parser::SetUserDataAndPush().
