YACS::foreachlooptypeParser< T > Struct Template Reference
#include <loopParsers.hxx>
Inheritance diagram for YACS::foreachlooptypeParser< T >:
Collaboration diagram for YACS::foreachlooptypeParser< T >:
virtual void pre ()
virtual void nbranch (const int &n)
virtual void weight (const double &x)
virtual void datatype (const std::string &type)
virtual void postAttr ()
virtual T post ()
- Public Member Functions inherited from YACS::dynparalooptypeParser< T >
virtual void initnode (PseudoComposedNode *const &n)
virtual void finalizenode (PseudoComposedNode *const &n)
- Public Member Functions inherited from YACS::looptypeParser< T >
virtual void pre ()
virtual void inline_ (ENGINE::InlineNode *const &n)
virtual void sinline (ENGINE::ServiceInlineNode *const &n)
virtual void service (ENGINE::ServiceNode *const &n)
virtual void server (ENGINE::ServerNode *const &n)
virtual void remote (ENGINE::InlineNode *const &n)
virtual void node (ENGINE::InlineNode *const &n)
virtual void forloop (ENGINE::ForLoop *const &b)
virtual void foreach (ENGINE::ForEachLoopGen *const &b)
virtual void optimizer (ENGINE::OptimizerLoop *const &b)
virtual void while_ (ENGINE::WhileLoop *const &b)
virtual void switch_ (ENGINE::Switch *const &b)
virtual void bloc (ENGINE::Bloc *const &b)
virtual void datalink (const mylink &l)
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
int _nbranch
double _weight
std::string _fullname
std::string _datatype
- Public Attributes inherited from YACS::looptypeParser< T >
std::string _state
T _cnode
std::vector< T > _cnodes
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static foreachlooptypeParser< T > foreachloopParser
static parser main_parser
template<class T>
struct YACS::foreachlooptypeParser< T >
Definition at line 506 of file loopParsers.hxx.
◆ buildAttr()
template<class T >
virtual void YACS::foreachlooptypeParser< T >::buildAttr ( const XML_Char **  attr)
Reimplemented from YACS::looptypeParser< T >.
Definition at line 510 of file loopParsers.hxx.
511 {
512 if (!attr)
513 return;
514 this->required("name",attr);
515 this->required("type",attr);
516 for (int i = 0; attr[i]; i += 2)
517 {
518 if(std::string(attr[i]) == "name")name(attr[i+1]);
519 if(std::string(attr[i]) == "state")this->state(attr[i+1]);
520 if(std::string(attr[i]) == "nbranch")nbranch(atoi(attr[i+1]));
521 if(std::string(attr[i]) == "loopWeight")weight(atof(attr[i+1]));
522 if(std::string(attr[i]) == "type")datatype(attr[i+1]);
523 }
524 postAttr();
525 }
virtual void nbranch(const int &n)
virtual void weight(const double &x)
virtual void datatype(const std::string &type)
virtual void state(const std::string &name)
References YACS::foreachlooptypeParser< T >::datatype(), yacsorb.CORBAEngineTest::i, YACS::foreachlooptypeParser< T >::name(), YACS::foreachlooptypeParser< T >::nbranch(), YACS::foreachlooptypeParser< T >::postAttr(), YACS::parser::required(), YACS::looptypeParser< T >::state(), and YACS::foreachlooptypeParser< T >::weight().
◆ datatype()
template<class T >
virtual void YACS::foreachlooptypeParser< T >::datatype ( const std::string &  type)
Definition at line 548 of file loopParsers.hxx.
549 {
550 DEBTRACE("foreach_datatype: "<< type)
551 _datatype=type;
552 }
References YACS::foreachlooptypeParser< T >::_datatype, and DEBTRACE.
Referenced by YACS::foreachlooptypeParser< T >::buildAttr().
template<class T >
virtual void YACS::foreachlooptypeParser< T >::name ( const std::string &  name)
◆ nbranch()
template<class T >
virtual void YACS::foreachlooptypeParser< T >::nbranch ( const int &  n)
Definition at line 538 of file loopParsers.hxx.
539 {
540 DEBTRACE("foreach_nbranch: " << n )
541 _nbranch=n;
542 }
References YACS::foreachlooptypeParser< T >::_nbranch, DEBTRACE, and gui.Appli::n.
◆ post()
template<class T >
virtual T YACS::foreachlooptypeParser< T >::post ( )
Definition at line 578 of file loopParsers.hxx.
579 {
580 DEBTRACE("foreach_post" << this->_cnode->getName())
581 T b=this->_cnode;
582 this->_cnodes.pop_back();
583 currentProc->names.pop_back();
584 this->_cnode=this->_cnodes.empty() ? 0 : this->_cnodes.back();
585 return b;
586 }
Definition: loopParsers.hxx:72
References YACS::looptypeParser< T >::_cnode, YACS::looptypeParser< T >::_cnodes, gui.CONNECTOR::b, currentProc, DEBTRACE, and YACS::ENGINE::Proc::names.
◆ postAttr()
template<class T >
virtual void YACS::foreachlooptypeParser< T >::postAttr ( )
Definition at line 553 of file loopParsers.hxx.
554 {
555 if(currentProc->typeMap.count(_datatype)==0)
556 {
557 //Check if the typecode is defined in the runtime
559 if(t==0)
560 {
561 std::stringstream msg;
562 msg << "Type "<< _datatype <<" does not exist"<<" ("<<__FILE__<<":"<<__LINE__<< ")";
563 throw Exception(msg.str());
564 }
565 else
566 {
568 t->incrRef();
569 }
570 }
571 this->_cnode=buildFrom<T>(theRuntime,_name,currentProc->typeMap[_datatype]);
572 //set number of branches
573 if(_nbranch > 0)this->_cnode->edGetNbOfBranchesPort()->edInit(_nbranch);
574 if(_weight > 0)this->_cnode->setWeight(_weight);
575 this->_cnodes.push_back(this->_cnode);
576 currentProc->names.push_back(_fullname + '.');
577 }
Definition: parsers.cxx:40
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
Definition: TypeCode.hxx:68
References YACS::looptypeParser< T >::_cnode, YACS::looptypeParser< T >::_cnodes, YACS::foreachlooptypeParser< T >::_datatype, YACS::foreachlooptypeParser< T >::_fullname, YACS::foreachlooptypeParser< T >::_name, YACS::foreachlooptypeParser< T >::_nbranch, YACS::foreachlooptypeParser< T >::_weight, currentProc, YACS::ENGINE::Runtime::getTypeCode(), YACS::ENGINE::Proc::names, gui.Appli::t, theRuntime, and YACS::ENGINE::Proc::typeMap.
◆ pre()
template<class T >
virtual void YACS::foreachlooptypeParser< T >::pre ( )
◆ weight()
template<class T >
virtual void YACS::foreachlooptypeParser< T >::weight ( const double &  x)
Definition at line 543 of file loopParsers.hxx.
544 {
545 DEBTRACE("foreach_weight: " << x )
546 _weight=x;
547 }
References YACS::foreachlooptypeParser< T >::_weight, and DEBTRACE.
◆ _datatype
template<class T >
std::string YACS::foreachlooptypeParser< T >::_datatype
◆ _fullname
template<class T >
std::string YACS::foreachlooptypeParser< T >::_fullname
◆ _name
template<class T >
std::string YACS::foreachlooptypeParser< T >::_name
◆ _nbranch
◆ _weight
◆ foreachloopParser
template<class T >
foreachlooptypeParser< T > YACS::foreachlooptypeParser< T >::foreachloopParser
Definition at line 508 of file loopParsers.hxx.
