YACS::ENGINE::XmlNode Class Reference
#include <XMLNode.hxx>
Inheritance diagram for YACS::ENGINE::XmlNode:
Collaboration diagram for YACS::ENGINE::XmlNode:
 XmlNode (const XmlNode &other, ComposedNode *father)
 XmlNode (const std::string &name)
virtual void execute ()
virtual void load ()
 DISTRIBUTION NOT YET implemented for XMLNode. More...
virtual void setRef (const std::string &ref)
 Associate a new component instance to this service node. More...
virtual void setScript (const std::string &script)
virtual std::string getScript () const
virtual ServiceNode * createNode (const std::string &name)
virtual std::string getKind () const
 Return the service node kind. More...
- Public Member Functions inherited from YACS::ENGINE::ServiceNode
 Load the component associated to the node. More...
virtual bool isDeployable () const
 By definition of ServiceNode class. More...
virtual void setComponent (ComponentInstance *compo)
 Associate an existing component instance to this service node AND check the consistency regarding the deployment from root node point of view. More...
virtual ComponentInstance * getComponent ()
 Return the associated component instance. More...
virtual const ComponentInstance * getComponent () const
virtual Container * getContainer ()
 Return the associated container. More...
virtual std::string getRef ()
virtual void setMethod (const std::string &method)
virtual std::string getMethod ()
virtual ServiceNode * createNode (const std::string &name)=0
virtual ~ServiceNode ()
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
Static Public Attributes
static const char IMPL_NAME [] ="XML"
static const char KIND [] ="xmlsh"
- Static Public Attributes inherited from YACS::ENGINE::ServiceNode
static const char KIND [] =""
Node * simpleClone (ComposedNode *father, bool editionOnly) const
- Protected Member Functions inherited from YACS::ENGINE::ServiceNode
 ServiceNode (const std::string &name)
 ServiceNode (const ServiceNode &other, ComposedNode *father)
template<class PORT >
std::string _script
- Protected Attributes inherited from YACS::ENGINE::ServiceNode
ComponentInstance * _component
std::string _method
std::string _ref
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
YACS::Colour _colour
static int _total = 0
Definition at line 29 of file XMLNode.hxx.
◆ XmlNode() [1/2]
XmlNode::XmlNode ( const XmlNode &  other,
ComposedNode *  father
Definition at line 54 of file XMLNode.cxx.
55 : _script(other._script), ServiceNode(other, father)
56{
58 _ref = other._ref;
59}
Definition: Node.hxx:97
ServiceNode(const std::string &name)
Definition: ServiceNode.cxx:55
static const char IMPL_NAME[]
Definition: XMLNode.hxx:46
std::string _script
Definition: XMLNode.hxx:49
References YACS::ENGINE::Node::_implementation, YACS::ENGINE::ServiceNode::_ref, and IMPL_NAME.
Referenced by simpleClone().
◆ XmlNode() [2/2]
XmlNode::XmlNode ( const std::string &  name)
Definition at line 61 of file XMLNode.cxx.
62 : ServiceNode(name)
63{
65}
References YACS::ENGINE::Node::_implementation, and IMPL_NAME.
◆ createNode()
virtual ServiceNode * YACS::ENGINE::XmlNode::createNode ( const std::string &  name)
Implements YACS::ENGINE::ServiceNode.
Definition at line 42 of file XMLNode.hxx.
43 { throw Exception("not implemented"); }
◆ execute()
void XmlNode::execute ( )
Implements YACS::ENGINE::Task.
Definition at line 93 of file XMLNode.cxx.
94{
95 DEBTRACE("execute");
96 char dir[]="yacsXXXXXX";
97 // add a lock around mkdtemp (seems not thread safe)
98 {
100#ifdef WIN32
101#ifdef UNICODE
102wchar_t mdir[512 + 1];
103#else
104 char mdir[512 + 1];
105#endif
106 GetTempPath(MAX_PATH+1, mdir);
107 CreateDirectory(mdir, NULL);
108#else
109 char* mdir=mkdtemp(dir);
110#endif
111 if(mdir==NULL)
112 {
113 perror("mkdtemp failed");
114 std::cerr << "Problem in mkdtemp " << dir << " " << mdir << std::endl;
115 throw Exception("Execution problem in mkdtemp");
116 }
117 }
118 std::string sdir(dir);
119 std::string input=sdir+"/input";
120 std::ofstream f(input.c_str());
121 f<<"<methodCall> <methodName>" << _method << "</methodName> <params>"<<std::endl;
122 DEBTRACE("---------------XmlNode::inputs---------------");
123 list<InputPort *>::iterator iter;
124 for(iter = _setOfInputPort.begin(); iter != _setOfInputPort.end(); iter++)
125 {
126 InputXmlPort *p=(InputXmlPort *)*iter;
127 DEBTRACE("port name: " << p->getName());
128 DEBTRACE("port kind: " << p->edGetType()->kind());
129 const char* ob=p->getXml();
130 DEBTRACE("Xml: " << ob );
131 f<<"<param>" << ob << "</param>"<<std::endl;
132 }
133 f<<"</params>"<<std::endl;
134 f<<"</methodCall>"<<std::endl;
135 f.close();
136 DEBTRACE("--------------XmlNode::calculation---------------" << _ref );
137 std::string call=sdir+"/run.sh";
138 std::ofstream run(call.c_str());
139 run << "#!/bin/sh" << std::endl;
140 run << "cd " << sdir << std::endl;
141 if(_ref[0]=='/' || _ref[0]=='~')
142 run << _ref << "> stdout 2>&1 " << std::endl;
143 else
144 run << "../"<<_ref << "> stdout 2>&1 " << std::endl;
145 //run << "cat stdout" << std::endl;
146 run.close();
147 chmod(call.c_str(),00777);
148
149 std::string call2="/bin/sh "+call;
150 int ret=system(call2.c_str());
151 if(ret)
152 {
153 std::cerr << "Problem: " << ret << std::endl;
154 DEBTRACE("Problem: " << ret);
155 throw Exception("Execution problem");
156 }
157 std::string output=sdir+"/output";
158 xmlDocPtr doc;
159 doc = xmlReadFile(output.c_str(), NULL, 0);
160 if (doc == NULL)
161 {
162 DEBTRACE("Failed to parse " << output);
163 throw Exception("Execution problem");
164 }
165 xmlNodePtr cur;
166 cur = xmlDocGetRootElement(doc);
167 if (cur == NULL)
168 {
169 DEBTRACE("empty document " );
170 xmlFreeDoc(doc);
171 throw Exception("Execution problem");
172 }
173 if (xmlStrcmp(cur->name, (const xmlChar *) "methodResponse"))
174 {
175 DEBTRACE("document of the wrong type, root node != methodResponse");
176 xmlFreeDoc(doc);
177 throw Exception("Execution problem");
178 }
179 cur = cur->xmlChildrenNode;
180 xmlBufferPtr buf=xmlBufferCreate();
181 list<OutputPort *>::iterator iter2;
182 iter2 = _setOfOutputPort.begin();
184 p=(OutputXmlPort *)*iter2;
185 int nres=0;
186
187 while (cur != NULL)
188 {
189 if ((!xmlStrcmp(cur->name, (const xmlChar *)"fault")))
190 {
191 DEBTRACE("exception in shell" );
192 xmlFreeDoc(doc);
193 throw Exception("Execution problem");
194 }
195 if ((!xmlStrcmp(cur->name, (const xmlChar *)"params")))
196 {
197 xmlNodePtr cur0 = cur->xmlChildrenNode;
198 while (cur0 != NULL)
199 {
200 if ((!xmlStrcmp(cur0->name, (const xmlChar *)"param")))
201 {
202 xmlNodePtr cur1 = cur0->xmlChildrenNode;
203 while (cur1 != NULL)
204 {
205 if ((!xmlStrcmp(cur1->name, (const xmlChar *)"value")))
206 {
207 xmlNodePtr cur2=cur1->xmlChildrenNode;
208 while (cur2 != NULL)
209 {
210 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"int")))
211 {
212 //got an int
214 {
215 //mismatch
216 xmlBufferFree(buf);
217 xmlFreeDoc(doc);
218 throw Exception("Execution problem:mismatch in output numbers");
219 }
220 xmlBufferEmpty(buf);
221 xmlNodeDump(buf,doc,cur1,0,0);
222 DEBTRACE(xmlBufferContent(buf));
223 p->put(xmlBufferContent(buf));
224 }
225 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"double")))
226 {
227 //got an double
229 {
230 //mismatch
231 xmlBufferFree(buf);
232 xmlFreeDoc(doc);
233 throw Exception("Execution problem:mismatch in output numbers");
234 }
235 xmlBufferEmpty(buf);
236 xmlNodeDump(buf,doc,cur1,0,0);
237 DEBTRACE(xmlBufferContent(buf));
238 p->put(xmlBufferContent(buf));
239 }
240 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"string")))
241 {
242 //got an string
244 {
245 //mismatch
246 xmlBufferFree(buf);
247 xmlFreeDoc(doc);
248 throw Exception("Execution problem:mismatch in output port numbers");
249 }
250 xmlBufferEmpty(buf);
251 xmlNodeDump(buf,doc,cur1,0,0);
252 DEBTRACE(xmlBufferContent(buf));
253 p->put(xmlBufferContent(buf));
254 }
255 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"boolean")))
256 {
257 //got an boolean
259 {
260 //mismatch
261 xmlBufferFree(buf);
262 xmlFreeDoc(doc);
263 throw Exception("Execution problem:mismatch in output port numbers");
264 }
265 xmlBufferEmpty(buf);
266 xmlNodeDump(buf,doc,cur1,0,0);
267 DEBTRACE(xmlBufferContent(buf));
268 p->put(xmlBufferContent(buf));
269 }
270 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"objref")))
271 {
272 //got an objref
274 {
275 //mismatch
276 xmlBufferFree(buf);
277 xmlFreeDoc(doc);
278 throw Exception("Execution problem:mismatch in output port numbers");
279 }
280 xmlBufferEmpty(buf);
281 xmlNodeDump(buf,doc,cur1,0,0);
282 DEBTRACE(xmlBufferContent(buf));
283 p->put(xmlBufferContent(buf));
284 }
285 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"struct")))
286 {
287 //got an struct
289 {
290 //mismatch
291 xmlBufferFree(buf);
292 xmlFreeDoc(doc);
293 throw Exception("Execution problem:mismatch in output port numbers");
294 }
295 xmlBufferEmpty(buf);
296 xmlNodeDump(buf,doc,cur1,0,0);
297 DEBTRACE(xmlBufferContent(buf));
298 p->put(xmlBufferContent(buf));
299 }
300 if ((!xmlStrcmp(cur2->name, (const xmlChar *)"array")))
301 {
302 //got a tuple of results or only one result (but a list)
304 {
305 //It's a one result list
306 xmlBufferEmpty(buf);
307 xmlNodeDump(buf,doc,cur1,0,0);
308 DEBTRACE(xmlBufferContent(buf));
309 p->put(xmlBufferContent(buf));
310 }
311 else
312 {
313 //It's a list of results
314 xmlNodePtr cur3=cur2->xmlChildrenNode;
315 while (cur3 != NULL)
316 {
317 if ((!xmlStrcmp(cur3->name, (const xmlChar *)"data")))
318 {
319 xmlNodePtr cur4=cur3->xmlChildrenNode;
320 while (cur4 != NULL)
321 {
322 if ((!xmlStrcmp(cur4->name, (const xmlChar *)"value")))
323 {
324 nres++;
325 if(nres > getNumberOfOutputPorts())
326 {
327 //mismatch
328 xmlBufferFree(buf);
329 xmlFreeDoc(doc);
330 throw Exception("Execution problem:mismatch in output port numbers");
331 }
332 xmlBufferEmpty(buf);
333 xmlNodeDump(buf,doc,cur4,0,0);
334 DEBTRACE(xmlBufferContent(buf));
335 p=(OutputXmlPort *)*iter2;
336 p->put(xmlBufferContent(buf));
337 iter2++;
338 }
339 cur4 = cur4->next;
340 } // end while value
341 break;
342 }
343 cur3 = cur3->next;
344 } // end while data
345 }
346 break;
347 }
348 cur2 = cur2->next;
349 } // end while array
350 break;
351 }
352 cur1 = cur1->next;
353 } // end while value
354 }
355 cur0 = cur0->next;
356 }// end while param
357 }
358 cur = cur->next;
359 }
360 xmlBufferFree(buf);
361 xmlFreeDoc(doc);
362}
static YACS::BASES::Mutex MUTEX
Definition: XMLNode.cxx:52
std::string getName() const
Class for XML Input Ports.
Definition: XMLPorts.hxx:38
Class for XML Output Ports.
Definition: XMLPorts.hxx:68
Proc * p
Definition: driver.cxx:216
static char doc[]
Definition: driver.cxx:63
void * run(void *obj)
Definition: yacs_clt.cxx:54
References YACS::ENGINE::ServiceNode::_method, YACS::ENGINE::ServiceNode::_ref, YACS::ENGINE::ElementaryNode::_setOfInputPort, YACS::ENGINE::ElementaryNode::_setOfOutputPort, DEBTRACE, doc, gui.CONNECTOR::f(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::ElementaryNode::getNumberOfOutputPorts(), MUTEX, p, and run().
◆ getKind()
std::string XmlNode::getKind ( ) const
A runtime can provide several implementations of a service node. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode with the same kind.
Reimplemented from YACS::ENGINE::ServiceNode.
Definition at line 88 of file XMLNode.cxx.
89{
90 return KIND;
91}
static const char KIND[]
Definition: XMLNode.hxx:47
References KIND.
◆ getScript()
std::string XmlNode::getScript ( ) const
Definition at line 83 of file XMLNode.cxx.
84{
85 return _script;
86}
References _script.
◆ load()
virtual void YACS::ENGINE::XmlNode::load ( )
Definition at line 38 of file XMLNode.hxx.
38{ }
◆ setRef()
void XmlNode::setRef ( const std::string &  ref)
A new component instance with type name ref is created (from runtime factory createComponentInstance) and associated to the node.
Definition at line 72 of file XMLNode.cxx.
73{
74 //No component instance here
75 _ref=ref;
76}
Definition: CONNECTOR.py:120
References YACS::ENGINE::ServiceNode::_ref, and gui.CONNECTOR::ref().
◆ setScript()
void XmlNode::setScript ( const std::string &  script)
Definition at line 78 of file XMLNode.cxx.
79{
80 _script=script;
81}
References _script.
◆ simpleClone()
Node * XmlNode::simpleClone ( ComposedNode *  father,
bool  editionOnly
Definition at line 67 of file XMLNode.cxx.
68{
69 return new XmlNode(*this,father);
70}
XmlNode(const XmlNode &other, ComposedNode *father)
Definition: XMLNode.cxx:54
References XmlNode().
◆ _script
std::string YACS::ENGINE::XmlNode::_script
Definition at line 49 of file XMLNode.hxx.
Referenced by getScript(), and setScript().
◆ IMPL_NAME
◆ KIND
const char XmlNode::KIND ="xmlsh"
Definition at line 47 of file XMLNode.hxx.
Referenced by YACS::ENGINE::RuntimeSALOME::createRefNode(), and getKind().
