yacs_clt.cxx
20#include <Python.h>
21#include <yacs.hh>
22#include "RuntimeSALOME.hxx"
23#include "Proc.hxx"
24#include "parsers.hxx"
26#include <vector>
27#include <string>
28#include <iostream>
29#include <pthread.h>
30
32
33class Obs_i : public POA_YACS_ORB::Observer,
34 public PortableServer::RefCountServantBase
35{
36public:
37 inline Obs_i(YACS_ORB::Proc_ptr proc) {_server_proc=proc;}
38 virtual ~Obs_i() {}
39 void notifyObserver(CORBA::Long numid, const char* event);
40protected:
41 YACS_ORB::Proc_ptr _server_proc;
42};
43
44void Obs_i::notifyObserver(CORBA::Long numid, const char* event)
45{
46 std::cerr << "Obs_i::notifyObserver " << numid << event << std::endl;
47 std::cerr << "Obs_i::notifyObserver:state= " << _server_proc->getState(numid) << std::endl;
48 std::cerr << "Obs_i::notifyObserver:XMLstate= " << _server_proc->getXMLState(numid) << std::endl;
49}
50
51YACS_ORB::YACS_Gen_var yacsref;
52YACS_ORB::Proc_ptr server_proc;
53
54void * run(void *obj)
55{
56 yacsref->Run(server_proc);
57}
58
59int main(int argc, char** argv)
60{
63
64 try
65 {
66 CORBA::ORB_var orb = CORBA::ORB_init(argc, argv);
67 CORBA::Object_var obj = orb->string_to_object("corbaname:rir:#test.my_context/Yacs.Object");
68 yacsref = YACS_ORB::YACS_Gen::_narrow(obj);
69 if( CORBA::is_nil(yacsref) )
70 {
71 std::cerr << "Can't narrow reference to type yacs (or it was nil)." << std::endl;
72 return 1;
73 }
74
75 //Activate POA
76 CORBA::Object_var poa = orb->resolve_initial_references("RootPOA");
77 PortableServer::POA_var root_poa = PortableServer::POA::_narrow(poa);
78 PortableServer::POAManager_var poa_man = root_poa->the_POAManager();
79 poa_man->activate();
80
81 char* xmlFile="/local/chris/SALOME2/SUPERV/YACS/BR_CC/YACS_SRC/src/yacsloader/samples/aschema.xml";
82 //Load XML file in client
83 YACS::ENGINE::Proc* local_proc=loader->load(xmlFile);
84 //Load xml file in server
85 server_proc = yacsref->Load(xmlFile);
86 //Create an observer for server_proc
87 Obs_i* obs=new Obs_i(server_proc);
88 YACS_ORB::Observer_ptr obs_ptr = obs->_this();
89 //Get ids and names
90 YACS_ORB::stringArray_var names;
91 YACS_ORB::longArray_var ids;
92 server_proc->getIds(ids.out(),names.out());
93 //Register it
94 int len=ids->length();
95 int numid;
96 for(int i=0;i<len;i++)
97 {
98 numid=ids[i];
99 yacsref->addObserver(obs_ptr,numid,"status");
100 }
101 //Execute Proc in thread ??
102 pthread_t th;
103 //pthread_create(&th,NULL,run,0);
104 yacsref->Run(server_proc);
105
106 //orb->run();
107 orb->destroy();
108 }
109 catch(CORBA::COMM_FAILURE& ex) {
110 std::cerr << "Caught system exception COMM_FAILURE -- unable to contact the "
111 << "object." << std::endl;
112 }
113 catch(CORBA::SystemException&) {
114 std::cerr << "Caught a CORBA::SystemException." << std::endl;
115 }
116 catch(CORBA::Exception&) {
117 std::cerr << "Caught CORBA::Exception." << std::endl;
118 }
119 catch(omniORB::fatalException& fe) {
120 std::cerr << "Caught omniORB::fatalException:" << std::endl;
121 std::cerr << " file: " << fe.file() << std::endl;
122 std::cerr << " line: " << fe.line() << std::endl;
123 std::cerr << " mesg: " << fe.errmsg() << std::endl;
124 }
125 catch(...) {
126 std::cerr << "Caught unknown exception." << std::endl;
127 }
128 return 0;
129}
Definition: yacs_clt.cxx:41
virtual ~Obs_i()
Definition: yacs_clt.cxx:38
void notifyObserver(CORBA::Long numid, const char *event)
Definition: yacs_clt.cxx:44
Definition: yacs_clt.cxx:37
Definition: Proc.hxx:44
static void setRuntime(long flags=UsePython+UseCorba+UseXml+UseCpp+UseSalome, int argc=0, char *argv[]=NULL)
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
Definition: yacs_clt.cxx:51
Definition: yacs_clt.cxx:59
Definition: yacs_clt.cxx:52
Definition: yacs_clt.cxx:54
YACS::YACSLoader::YACSLoader * loader
Definition: yacs_clt.cxx:31
