YACS::ENGINE::RuntimeSALOME Class Reference
#include <RuntimeSALOME.hxx>
Inheritance diagram for YACS::ENGINE::RuntimeSALOME:
Collaboration diagram for YACS::ENGINE::RuntimeSALOME:
enum  {
  IsPyExt = 1 , UsePython = 2 , UseCorba = 4 , UseXml = 8 ,
  UseCpp = 16 , UseSalome = 32
std::unique_ptr< SALOME_NamingService_Container_Abstract > getNS ()
virtual std::string getVersion () const
virtual void init (long flags, int argc, char *argv[])
 CORBA and Python initialization. More...
virtual void fini (bool isFinalizingPython=true)
PyObject * launchSubProcess (const std::vector< std::string > &cmds)
virtual std::vector< std::pair< std::string, int > > getCatalogOfComputeNodes () const
virtual InputPort * createInputPort (const std::string &name, const std::string &impl, Node *node, TypeCode *type)
virtual OutputPort * createOutputPort (const std::string &name, const std::string &impl, Node *node, TypeCode *type)
virtual InputDataStreamPort * createInputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual OutputDataStreamPort * createOutputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual DataNode * createInDataNode (const std::string &kind, const std::string &name)
virtual DataNode * createOutDataNode (const std::string &kind, const std::string &name)
virtual InlineFuncNode * createFuncNode (const std::string &kind, const std::string &name)
virtual InlineNode * createScriptNode (const std::string &kind, const std::string &name)
virtual ServiceNode * createRefNode (const std::string &kind, const std::string &name)
virtual ServiceNode * createCompoNode (const std::string &kind, const std::string &name)
virtual ServiceInlineNode * createSInlineNode (const std::string &kind, const std::string &name)
virtual ComponentInstance * createComponentInstance (const std::string &name, const std::string &kind="")
virtual Container * createContainer (const std::string &kind="")
virtual WhileLoop * createWhileLoop (const std::string &name)
virtual ForLoop * createForLoop (const std::string &name)
virtual OptimizerLoop * createOptimizerLoop (const std::string &name, const std::string &algLib, const std::string &factoryName, bool algInitOnFile, const std::string &kind="", Proc *procForTypes=NULL)
virtual Bloc * createBloc (const std::string &name)
virtual Proc * createProc (const std::string &name)
virtual TypeCode * createInterfaceTc (const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
virtual TypeCode * createSequenceTc (const std::string &id, const std::string &name, TypeCode *content)
virtual TypeCodeStruct * createStructTc (const std::string &id, const std::string &name)
virtual InputPort * adapt (InputPort *source, const std::string &impl, TypeCode *type, bool init=false)
 Main adapter function : adapt an InputPort to be able to connect it to an OutputPort with a possible different implementation. More...
virtual InputPort * adapt (InPropertyPort *source, const std::string &impl, TypeCode *type, bool init=false)
 Adapter function for InPropertyPort. More...
virtual InputPort * adaptNeutral (InputPort *source, const std::string &impl, TypeCode *type, bool init)
 Adapt a Neutral input port to connect it to an output port with a given implementation. More...
virtual InputPort * adapt (InputCorbaPort *source, const std::string &impl, TypeCode *type, bool init)
 Adapt a CORBA input port to an output which implementation and type are given by impl and type. More...
virtual InputPort * adaptCorbaToCorba (InputCorbaPort *source, TypeCode *type)
 Adapt a CORBA input port to a CORBA output port. More...
virtual InputPort * adaptCorbaToNeutral (InputCorbaPort *source, TypeCode *type)
 Adapt a CORBA input port to a neutral data. More...
virtual InputPort * adaptCorbaToPython (InputCorbaPort *source, TypeCode *type)
 Adapt a CORBA input port to a Python output port. More...
virtual InputPort * adaptCorbaToCpp (InputCorbaPort *source, TypeCode *type)
 Adapt a CORBA input port to a C++ output port. More...
virtual InputPort * adaptCorbaToXml (InputCorbaPort *source, TypeCode *type)
 Adapt a CORBA input port to connect it to a XML output port. More...
virtual InputPort * adapt (InputPyPort *source, const std::string &impl, TypeCode *type, bool init)
 Adapt a Python input port to an output port with a given implementation. More...
virtual InputPort * adaptPythonToCorba (InputPyPort *source, TypeCode *type)
 Adapt a Python input port to a Corba output port. More...
virtual InputPort * adaptPythonToNeutral (InputPyPort *source, TypeCode *type)
 Adapt a Python input port to a Neutral data port. More...
virtual InputPort * adaptPythonToPython (InputPyPort *source, TypeCode *type, bool init)
 Adapt a Python input port to a Python output port. More...
virtual InputPort * adaptPythonToXml (InputPyPort *source, TypeCode *type)
 Adapt a Python input port to a Xml output port. More...
virtual InputPort * adaptPythonToCpp (InputPyPort *source, TypeCode *type)
 Adapt a Python input port to a C++ output port. More...
virtual InputPort * adapt (InputCppPort *source, const std::string &impl, TypeCode *type, bool init)
 Adapt a C++ input port to connect it to an output port with a given implementation. More...
virtual InputPort * adaptCppToCorba (InputCppPort *source, TypeCode *type)
 Adapt a C++ input port to connect it to a CORBA output port. More...
virtual InputPort * adaptCppToNeutral (InputCppPort *source, TypeCode *type)
 Adapt a C++ input port to a Neutral output port. More...
virtual InputPort * adaptCppToPython (InputCppPort *source, TypeCode *type)
 Adapt a C++ input port to a Python output port. More...
virtual InputPort * adaptCppToXml (InputCppPort *source, TypeCode *type)
virtual InputPort * adaptCppToCpp (InputCppPort *source, TypeCode *type)
 Adapt a C++ input port to a C++ output port. More...
virtual InputPort * adapt (InputXmlPort *source, const std::string &impl, TypeCode *type, bool init)
 Adapt an Xml input port to an output port which implementation is given by impl. More...
virtual InputPort * adaptXmlToCorba (InputXmlPort *source, TypeCode *type)
 Adapt a XML input port to connect it to a CORBA output port. More...
virtual InputPort * adaptXmlToPython (InputXmlPort *inport, TypeCode *type)
 Adapt a XML input port to a Python output port. More...
virtual InputPort * adaptXmlToCpp (InputXmlPort *inport, TypeCode *type)
 Adapt a XML input port to a C++ output port. More...
virtual InputPort * adaptXmlToNeutral (InputXmlPort *inport, TypeCode *type)
 Adapt a XML input port to a Neutral output port. More...
virtual InputPort * adaptXmlToXml (InputXmlPort *inport, TypeCode *type, bool init)
 Adapt a XML input port to a Xml output port. More...
virtual InputPort * adaptNeutralToXml (InputPort *inport, TypeCode *type)
 Adapt a Neutral input port to a Xml output port. More...
virtual InputPort * adaptNeutralToPython (InputPort *inport, TypeCode *type)
 Adapt a Neutral input port to a Python output port. More...
virtual InputPort * adaptNeutralToCorba (InputPort *inport, TypeCode *type)
 Adapt a Neutral input port to a Corba output port. More...
virtual InputPort * adaptNeutralToCpp (InputPort *inport, TypeCode *type)
 Adapt a Neutral input port to a C++ output port. More...
virtual void * convertNeutral (TypeCode *type, Any *data)
 Convert a YACS::ENGINE::Any object to an external object with type type. More...
virtual std::string convertNeutralAsString (TypeCode *type, Any *data)
 Convert a YACS::ENGINE::Any object to a string to be used in GUI for example. More...
virtual std::string convertPyObjectToString (PyObject *ob)
virtual PyObject * convertStringToPyObject (const std::string &s)
virtual ~RuntimeSALOME ()
void loadModulCatalog ()
CORBA::ORB_ptr getOrb () const
CORBA::Object_var getFromNS (const char *entry) const
PyObject * getPyOrb () const
PyObject * getBuiltins () const
DynamicAny::DynAnyFactory_ptr getDynFactory () const
omniORBpyAPI * getApi ()
PyObject * get_omnipy ()
ConnectionManager & getConnectionManager ()
- Public Member Functions inherited from YACS::ENGINE::Runtime
virtual void init ()
virtual void fini ()
virtual std::vector< std::pair< std::string, int > > getCatalogOfComputeNodes () const =0
virtual Catalog * loadCatalog (const std::string &sourceKind, const std::string &path)
 Load a catalog of calculation to use as factory. More...
virtual ForEachLoop * createForEachLoop (const std::string &name, TypeCode *type)
virtual ForEachLoopDyn * createForEachLoopDyn (const std::string &name, TypeCode *type)
virtual Switch * createSwitch (const std::string &name)
virtual InputPort * createInputPort (const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
virtual OutputPort * createOutputPort (const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
virtual InputPort * adapt (InputPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
virtual InputPort * adapt (InPropertyPort *source, const std::string &impl, TypeCode *type, bool init=false)=0
virtual void removeRuntime ()
virtual ~Runtime ()
virtual void setCatalogLoaderFactory (const std::string &name, CatalogLoader *factory)
 Add a catalog loader factory to the map _catalogLoaderFactoryMap under the name name. More...
Catalog * getBuiltinCatalog ()
 Get the catalog of base nodes (elementary and composed) More...
virtual void addCatalog (Catalog *catalog)
 Add a catalog of types and nodes to the runtime. More...
virtual TypeCode * getTypeCode (const std::string &name)
 Get a typecode by its name from runtime catalogs. More...
static void setRuntime (long flags=UsePython+UseCorba+UseXml+UseCpp+UseSalome, int argc=0, char *argv[]=NULL)
Public Attributes
enum YACS::ENGINE::RuntimeSALOME:: { ... }  FLAGS
- Public Attributes inherited from YACS::ENGINE::Runtime
std::map< std::string, CatalogLoader * > _catalogLoaderFactoryMap
 RuntimeSALOME ()
 RuntimeSALOME (long flags, int argc, char *argv[])
void initBuiltins ()
- Protected Member Functions inherited from YACS::ENGINE::Runtime
 Runtime ()
CORBA::ORB_var _orb
PyObject * _pyorb
PyObject * _bltins
DynamicAny::DynAnyFactory_var _dynFactory
omniORBpyAPI * _api
PyObject * _omnipy
long _flags
bool _usePython
bool _useCorba
bool _useCpp
bool _useXml
- Protected Attributes inherited from YACS::ENGINE::Runtime
std::set< std::string > _setOfImplementation
Catalog * _builtinCatalog
std::vector< Catalog * > _catalogs
static Runtime * getSingleton ()
ConnectionManager _connectionManager
Friends
RuntimeSALOME * getSALOMERuntime ()
- Static Public Attributes inherited from YACS::ENGINE::Runtime
static const char RUNTIME_ENGINE_INTERACTION_IMPL_NAME [] ="Neutral"
static YACS::ENGINE::TypeCode * _tc_double = 0
static YACS::ENGINE::TypeCode * _tc_int = 0
static YACS::ENGINE::TypeCode * _tc_bool = 0
static YACS::ENGINE::TypeCode * _tc_string = 0
static YACS::ENGINE::TypeCode * _tc_file = 0
static YACS::ENGINE::TypeCode * _tc_stringpair = 0
static YACS::ENGINE::TypeCode * _tc_propvec = 0
- Static Protected Attributes inherited from YACS::ENGINE::Runtime
static Runtime * _singleton = 0
Definition at line 58 of file RuntimeSALOME.hxx.
◆ anonymous enum
anonymous enum
IsPyExt
UsePython
UseCorba
UseXml
UseCpp
UseSalome
Definition at line 64 of file RuntimeSALOME.hxx.
◆ ~RuntimeSALOME()
RuntimeSALOME::~RuntimeSALOME ( )
Definition at line 244 of file RuntimeSALOME.cxx.
245{
246 DEBTRACE("RuntimeSALOME::~RuntimeSALOME");
247 // destroy catalog loader prototypes
248 std::map<std::string, CatalogLoader*>::const_iterator pt;
249 for(pt=_catalogLoaderFactoryMap.begin();pt!=_catalogLoaderFactoryMap.end();pt++)
250 {
251 delete (*pt).second;
252 }
254}
Definition: Runtime.hxx:144
References YACS::ENGINE::Runtime::_catalogLoaderFactoryMap, _connectionManager, DEBTRACE, and ConnectionManager::ShutdownWithExit().
◆ RuntimeSALOME() [1/2]
RuntimeSALOME::RuntimeSALOME ( )
Singleton creation, initialize converter map
Definition at line 165 of file RuntimeSALOME.cxx.
166{
167 YASSERT(0);
168}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
References YASSERT.
Referenced by setRuntime().
◆ RuntimeSALOME() [2/2]
RuntimeSALOME::RuntimeSALOME ( long  flags,
int  argc,
char *  argv[]
Definition at line 214 of file RuntimeSALOME.cxx.
215{
216 // If all flags (apart the IsPyExt flags) are unset, force them to true
217 if ((flags - flags & RuntimeSALOME::IsPyExt) == 0)
220
221 // Salome Nodes implies Corba Nodes
222 if (flags & RuntimeSALOME::UseSalome)
224
225 // Corba Nodes implies Python Nodes
226 if (flags & RuntimeSALOME::UseCorba)
228
233
234 /* Init libxml */
235 xmlInitParser();
236
241 init(flags, argc, argv);
242}
static const char IMPL_NAME[]
Definition: CORBANode.hxx:57
Definition: CppNode.hxx:61
Definition: PythonNode.hxx:123
virtual void init()
Definition: Runtime.hxx:72
Definition: Runtime.hxx:152
Definition: XMLNode.hxx:46
References YACS::ENGINE::Runtime::_setOfImplementation, _useCorba, _useCpp, _usePython, _useXml, YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, YACS::ENGINE::Runtime::init(), IsPyExt, UseCorba, UseCpp, UsePython, UseSalome, and UseXml.
◆ adapt() [1/6]
InputPort * RuntimeSALOME::adapt ( InPropertyPort *  source,
const std::string &  impl,
TypeCode *  type,
bool  init = false
source: InPropertyPort to be adapted
impl: new implementation (C++, python, CORBA, XML, Neutral)
type: data type provided by the InPropertyPort
init: indicates if the adapted InPropertyPort will be used for initialization (value true) or not (value false)
: adapted InputPort
Implements YACS::ENGINE::Runtime.
Definition at line 892 of file RuntimeSALOME.cxx.
895{
896 return adaptNeutral((InputPort *)source,impl,type,init);
897}
Base class for Input Ports.
Definition: InputPort.hxx:44
virtual InputPort * adaptNeutral(InputPort *source, const std::string &impl, TypeCode *type, bool init)
References adaptNeutral(), and YACS::ENGINE::Runtime::init().
◆ adapt() [2/6]
InputPort * RuntimeSALOME::adapt ( InputCorbaPort *  source,
TypeCode *  type,
bool  init
source: input port to adapt to implementation impl and type type
impl: output port implementation (C++, Python or Corba)
type: outport data type
init: if init is true the proxy port will be used in initialization of input port (needs value check)
an adaptator port which type depends on impl
Definition at line 1437 of file RuntimeSALOME.cxx.
1440{
1441 if(impl == CppNode::IMPL_NAME)
1442 {
1443 return adaptCorbaToCpp(source,type);
1444 }
1445 else if(impl == PythonNode::IMPL_NAME)
1446 {
1447 return adaptCorbaToPython(source,type);
1448 }
1449 else if(impl == CORBANode::IMPL_NAME)
1450 {
1451 if(init)
1452 return adaptCorbaToCorba(source,type);
1453 else
1454 return adaptCorbaToCorba(source,type);
1455 }
1456 else if(impl == XmlNode::IMPL_NAME )
1457 {
1458 return adaptCorbaToXml(source,type);
1459 }
1461 {
1462 return adaptCorbaToNeutral(source,type);
1463 }
1464 else
1465 {
1466 stringstream msg;
1467 msg << "Cannot connect InputCorbaPort : unknown implementation " ;
1468 msg << __FILE__ << ":" <<__LINE__;
1469 throw ConversionException(msg.str());
1470 }
1471}
virtual InputPort * adaptCorbaToXml(InputCorbaPort *source, TypeCode *type)
virtual InputPort * adaptCorbaToCpp(InputCorbaPort *source, TypeCode *type)
virtual InputPort * adaptCorbaToPython(InputCorbaPort *source, TypeCode *type)
virtual InputPort * adaptCorbaToNeutral(InputCorbaPort *source, TypeCode *type)
virtual InputPort * adaptCorbaToCorba(InputCorbaPort *source, TypeCode *type)
static const char RUNTIME_ENGINE_INTERACTION_IMPL_NAME[]
Definition: Runtime.hxx:135
References adaptCorbaToCorba(), adaptCorbaToCpp(), adaptCorbaToNeutral(), adaptCorbaToPython(), adaptCorbaToXml(), YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, YACS::ENGINE::Runtime::init(), and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
◆ adapt() [3/6]
InputPort * RuntimeSALOME::adapt ( InputCppPort *  source,
TypeCode *  type,
bool  init
type: output port supported type
the adaptated port
Definition at line 1868 of file RuntimeSALOME.cxx.
1871{
1872 DEBTRACE("RuntimeSALOME::adapt(InputCppPort* source)");
1873 if(impl == CORBANode::IMPL_NAME)
1874 {
1875 return adaptCppToCorba(source,type);
1876 }
1877 else if(impl == PythonNode::IMPL_NAME)
1878 {
1879 return adaptCppToPython(source,type);
1880 }
1881 else if(impl == XmlNode::IMPL_NAME)
1882 {
1883 return adaptCppToXml(source,type);
1884 }
1885 else if(impl == CppNode::IMPL_NAME)
1886 {
1887 return adaptCppToCpp(source, type);
1888 }
1890 {
1891 return adaptCppToNeutral(source, type);
1892 }
1893 else
1894 {
1895 stringstream msg;
1896 msg << "Cannot connect InputCppPort to " << impl << " implementation";
1897 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
1898 throw ConversionException(msg.str());
1899 }
1900}
virtual InputPort * adaptCppToCpp(InputCppPort *source, TypeCode *type)
virtual InputPort * adaptCppToCorba(InputCppPort *source, TypeCode *type)
virtual InputPort * adaptCppToPython(InputCppPort *source, TypeCode *type)
virtual InputPort * adaptCppToNeutral(InputCppPort *source, TypeCode *type)
virtual InputPort * adaptCppToXml(InputCppPort *source, TypeCode *type)
References adaptCppToCorba(), adaptCppToCpp(), adaptCppToNeutral(), adaptCppToPython(), adaptCppToXml(), DEBTRACE, YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
◆ adapt() [4/6]
InputPort * RuntimeSALOME::adapt ( InputPort *  source,
TypeCode *  type,
bool  init = false
source: InputPort to be adapted
type: data type provided by the InputPort
init: indicates if the adapted InputPort will be used for initialization (value true) or not (value false)
: adapted InputPort
Definition at line 849 of file RuntimeSALOME.cxx.
852{
853 string imp_source=source->getNode()->getImplementation();
854 if(imp_source == PythonNode::IMPL_NAME)
855 {
856 return adapt((InputPyPort*)source,impl,type,init);
857 }
858 else if(imp_source == CppNode::IMPL_NAME)
859 {
860 return adapt((InputCppPort*)source,impl,type,init);
861 }
862 else if(imp_source == CORBANode::IMPL_NAME)
863 {
864 return adapt((InputCorbaPort*)source,impl,type,init);
865 }
866 else if(imp_source == XmlNode::IMPL_NAME)
867 {
868 return adapt((InputXmlPort*)source,impl,type,init);
869 }
871 {
872 return adaptNeutral(source,impl,type,init);
873 }
874 else
875 {
876 stringstream msg;
877 msg << "Cannot adapt " << imp_source << " InputPort to " << impl;
878 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
879 throw ConversionException(msg.str());
880 }
881}
Class for CORBA Input Ports.
Definition: CORBAPorts.hxx:45
Class for C++ Ports.
Definition: CppPorts.hxx:40
Class for Python Ports.
Definition: PythonPorts.hxx:74
Class for XML Input Ports.
Definition: XMLPorts.hxx:38
std::string getImplementation() const
Definition: Node.cxx:350
Node * getNode() const
Definition: Port.hxx:46
virtual InputPort * adapt(InputPort *source, const std::string &impl, TypeCode *type, bool init=false)
Main adapter function : adapt an InputPort to be able to connect it to an OutputPort with a possible ...
References adapt(), adaptNeutral(), YACS::ENGINE::Node::getImplementation(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, YACS::ENGINE::Runtime::init(), and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
Referenced by adapt().
◆ adapt() [5/6]
InputPort * RuntimeSALOME::adapt ( InputPyPort *  source,
TypeCode *  type,
bool  init
type: output port type
adaptated input port
Definition at line 1703 of file RuntimeSALOME.cxx.
1706{
1707 if(impl == CppNode::IMPL_NAME)
1708 {
1709 return adaptPythonToCpp(source,type);
1710 }
1711 else if(impl == PythonNode::IMPL_NAME)
1712 {
1713 return adaptPythonToPython(source,type,init);
1714 }
1715 else if(impl == CORBANode::IMPL_NAME)
1716 {
1717 return adaptPythonToCorba(source,type);
1718 }
1720 {
1721 return adaptPythonToNeutral(source,type);
1722 }
1723 else if(impl == XmlNode::IMPL_NAME)
1724 {
1725 return adaptPythonToXml(source,type);
1726 }
1727 else
1728 {
1729 stringstream msg;
1730 msg << "Cannot connect InputPyPort : unknown implementation " << impl;
1731 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1732 throw ConversionException(msg.str());
1733 }
1734}
virtual InputPort * adaptPythonToPython(InputPyPort *source, TypeCode *type, bool init)
virtual InputPort * adaptPythonToCorba(InputPyPort *source, TypeCode *type)
virtual InputPort * adaptPythonToXml(InputPyPort *source, TypeCode *type)
virtual InputPort * adaptPythonToNeutral(InputPyPort *source, TypeCode *type)
virtual InputPort * adaptPythonToCpp(InputPyPort *source, TypeCode *type)
References adaptPythonToCorba(), adaptPythonToCpp(), adaptPythonToNeutral(), adaptPythonToPython(), adaptPythonToXml(), YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, YACS::ENGINE::Runtime::init(), and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
◆ adapt() [6/6]
InputPort * RuntimeSALOME::adapt ( InputXmlPort *  source,
TypeCode *  type,
bool  init
the adaptated port
Definition at line 1175 of file RuntimeSALOME.cxx.
1178{
1179 if(impl == CORBANode::IMPL_NAME)
1180 {
1181 return adaptXmlToCorba(source,type);
1182 }
1183 else if(impl == PythonNode::IMPL_NAME)
1184 {
1185 return adaptXmlToPython(source,type);
1186 }
1187 else if(impl == CppNode::IMPL_NAME)
1188 {
1189 return adaptXmlToCpp(source,type);
1190 }
1191 else if(impl == XmlNode::IMPL_NAME )
1192 {
1193 return adaptXmlToXml(source,type,init);
1194 }
1196 {
1197 return adaptXmlToNeutral(source,type);
1198 }
1199 else
1200 {
1201 stringstream msg;
1202 msg << "Cannot connect InputXmlPort to " << impl << " implementation";
1203 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
1204 throw ConversionException(msg.str());
1205 }
1206}
virtual InputPort * adaptXmlToXml(InputXmlPort *inport, TypeCode *type, bool init)
virtual InputPort * adaptXmlToPython(InputXmlPort *inport, TypeCode *type)
virtual InputPort * adaptXmlToCorba(InputXmlPort *source, TypeCode *type)
virtual InputPort * adaptXmlToCpp(InputXmlPort *inport, TypeCode *type)
virtual InputPort * adaptXmlToNeutral(InputXmlPort *inport, TypeCode *type)
References adaptXmlToCorba(), adaptXmlToCpp(), adaptXmlToNeutral(), adaptXmlToPython(), adaptXmlToXml(), YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, YACS::ENGINE::Runtime::init(), and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
◆ adaptCorbaToCorba()
InputPort * RuntimeSALOME::adaptCorbaToCorba ( InputCorbaPort *  inport,
TypeCode *  type
inport: input port to adapt to CORBA outport data type
an adaptator port of type InputCORBAPort
Definition at line 1215 of file RuntimeSALOME.cxx.
1217{
1218 if(type->isA(inport->edGetType()))
1219 {
1220 //types are compatible : no conversion
1221 //outport data type is more specific than inport required type
1222 //so the inport can be used safely
1223 return new ProxyPort(inport);
1224 }
1225 else if(isAdaptableCorbaCorba(type,inport->edGetType()))
1226 {
1227 //ouport data can be converted to inport data type
1228 return new CorbaCorba(inport);
1229 }
1230 //outport data can not be converted
1231 stringstream msg;
1232 msg << "Cannot connect Corba output port with type: " << type->id() ;
1233 msg << " to CORBA input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1234#ifdef _DEVDEBUG_
1235 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1236#endif
1237 throw ConversionException(msg.str());
1238}
Class for conversion from CORBA Output port to CORBA Input port.
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string getName() const
Definition: DataPort.hxx:55
Base class for Proxy Input Ports.
Definition: InputPort.hxx:100
virtual const char * id() const
Definition: TypeCode.cxx:82
virtual int isA(const char *repositoryId) const
Definition: TypeCode.cxx:99
int isAdaptableCorbaCorba(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::TypeCode::isA(), and YACS::ENGINE::isAdaptableCorbaCorba().
◆ adaptCorbaToCpp()
InputPort * RuntimeSALOME::adaptCorbaToCpp ( InputCorbaPort *  inport,
TypeCode *  type
inport: input port to adapt to C++ type type
an adaptator port of type InputCPPPort
Definition at line 1352 of file RuntimeSALOME.cxx.
1354{
1355 DEBTRACE("RuntimeSALOME::adaptCorbaToCpp(InputCorbaPort* inport" );
1356 if(isAdaptableCorbaCpp(type,inport->edGetType()))
1357 {
1358 //output type is convertible to input type
1359 return new CppCorba(inport);
1360 }
1361 //output type is not convertible
1362 stringstream msg;
1363 msg << "Cannot connect Cpp output port with type: " << type->id() ;
1364 msg << " to Corba input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1365#ifdef _DEVDEBUG_
1366 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1367#endif
1368 throw ConversionException(msg.str());
1369}
int isAdaptableCorbaCpp(const TypeCode *t1, const TypeCode *t2)
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptableCorbaCpp().
◆ adaptCorbaToNeutral()
InputPort * RuntimeSALOME::adaptCorbaToNeutral ( InputCorbaPort *  inport,
TypeCode *  type
inport: InputPort to adapt to Neutral type type
an adaptator port of type Neutralxxxx
Definition at line 1378 of file RuntimeSALOME.cxx.
1380{
1381 if(inport->edGetType()->kind() == Double)
1382 {
1383 if(isAdaptableCorbaNeutral(type,inport->edGetType()))return new NeutralCorbaDouble(inport);
1384 }
1385 else if(inport->edGetType()->kind() == Int)
1386 {
1387 if(isAdaptableCorbaNeutral(type,inport->edGetType()))return new NeutralCorbaInt(inport);
1388 }
1389 else if(inport->edGetType()->kind() == String)
1390 {
1391 if(isAdaptableCorbaNeutral(type,inport->edGetType())) return new NeutralCorbaString(inport);
1392 }
1393 else if(inport->edGetType()->kind() == Bool)
1394 {
1395 if(isAdaptableCorbaNeutral(type,inport->edGetType()))return new NeutralCorbaBool(inport);
1396 }
1397 else if(inport->edGetType()->kind() == Objref)
1398 {
1399 if(isAdaptableCorbaNeutral(type,inport->edGetType())) return new NeutralCorbaObjref(inport);
1400 }
1401 else if(inport->edGetType()->kind() == Sequence)
1402 {
1403 if(isAdaptableCorbaNeutral(type,inport->edGetType()))
1404 return new NeutralCorbaSequence(inport);
1405 else
1406 {
1407 stringstream msg;
1408 msg << "Cannot convert this sequence type " ;
1409 msg << __FILE__ << ":" <<__LINE__;
1410 throw ConversionException(msg.str());
1411 }
1412 }
1413 else if(inport->edGetType()->kind() == Struct)
1414 {
1415 if(isAdaptableCorbaNeutral(type,inport->edGetType())) return new NeutralCorbaStruct(inport);
1416 }
1417
1418 // Adaptation not possible
1419 stringstream msg;
1420 msg << "Cannot connect Neutral output port with type: " << type->id() ;
1421 msg << " to Corba input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1422#ifdef _DEVDEBUG_
1423 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1424#endif
1425 throw ConversionException(msg.str());
1426}
DynType kind() const
Definition: TypeCode.cxx:47
int isAdaptableCorbaNeutral(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::Int, YACS::ENGINE::isAdaptableCorbaNeutral(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
◆ adaptCorbaToPython()
InputPort * RuntimeSALOME::adaptCorbaToPython ( InputCorbaPort *  inport,
TypeCode *  type
inport: input port to adapt to Python type type
an adaptator port of type InputPyPort
Definition at line 1247 of file RuntimeSALOME.cxx.
1249{
1250 if(inport->edGetType()->kind() == Double)
1251 {
1252 if(isAdaptableCorbaPyObject(type,inport->edGetType()))return new PyCorbaDouble(inport);
1253 }
1254 else if(inport->edGetType()->kind() == Int)
1255 {
1256 if(isAdaptableCorbaPyObject(type,inport->edGetType()))return new PyCorbaInt(inport);
1257 }
1258 else if(inport->edGetType()->kind() == String)
1259 {
1260 if(isAdaptableCorbaPyObject(type,inport->edGetType()))return new PyCorbaString(inport);
1261 }
1262 else if(inport->edGetType()->kind() == Bool)
1263 {
1264 if(isAdaptableCorbaPyObject(type,inport->edGetType()))return new PyCorbaBool(inport);
1265 }
1266 else if(inport->edGetType()->kind() == Objref )
1267 {
1268 if(isAdaptableCorbaPyObject(type,inport->edGetType()))
1269 {
1270 return new PyCorbaObjref(inport);
1271 }
1272 else
1273 {
1274 stringstream msg;
1275 msg << "Cannot connect Python output port with type: " << type->id() ;
1276 msg << " to CORBA input port " << inport->getName() << " with incompatible objref type: " << inport->edGetType()->id();
1277 msg << " (" << __FILE__ << ":" <<__LINE__ << ")";
1278 throw ConversionException(msg.str());
1279 }
1280 }
1281 else if(inport->edGetType()->kind() == Sequence)
1282 {
1283 if(isAdaptableCorbaPyObject(type,inport->edGetType()))
1284 {
1285 return new PyCorbaSequence(inport);
1286 }
1287 else
1288 {
1289 stringstream msg;
1290 msg << "Cannot convert this sequence type " ;
1291 msg << __FILE__ << ":" <<__LINE__;
1292 throw ConversionException(msg.str());
1293 }
1294 }
1295 else if(inport->edGetType()->kind() == YACS::ENGINE::Struct)
1296 {
1297 if(isAdaptableCorbaPyObject(type,inport->edGetType()))
1298 {
1299 return new PyCorbaStruct(inport);
1300 }
1301 else
1302 {
1303 stringstream msg;
1304 msg << "Cannot convert this struct type " << type->id() << " to " << inport->edGetType()->id();
1305 msg << __FILE__ << ":" <<__LINE__;
1306 throw ConversionException(msg.str());
1307 }
1308 }
1309 // Adaptation not possible
1310 stringstream msg;
1311 msg << "Cannot connect Python output port with type: " << type->id() ;
1312 msg << " to CORBA input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1313#ifdef _DEVDEBUG_
1314 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1315#endif
1316 throw ConversionException(msg.str());
1317}
int isAdaptableCorbaPyObject(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::Int, YACS::ENGINE::isAdaptableCorbaPyObject(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
◆ adaptCorbaToXml()
InputPort * RuntimeSALOME::adaptCorbaToXml ( InputCorbaPort *  inport,
TypeCode *  type
inport: input port to adapt to Xml type type
type: type supported by output port
an adaptator port of type InputXmlPort
Definition at line 1326 of file RuntimeSALOME.cxx.
1328{
1329 // BEWARE : using the generic check
1330 if(inport->edGetType()->isAdaptable(type))
1331 {
1332 //output type is convertible to input type
1333 return new XmlCorba(inport);
1334 }
1335 //output type is not convertible
1336 stringstream msg;
1337 msg << "Cannot connect Xml output port with type: " << type->id() ;
1338 msg << " to Corba input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1339#ifdef _DEVDEBUG_
1340 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1341#endif
1342 throw ConversionException(msg.str());
1343}
virtual int isAdaptable(const TypeCode *tc) const
Check if this TypeCode is adaptable to a given TypeCode (tc)
Definition: TypeCode.cxx:116
References YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::TypeCode::isAdaptable().
◆ adaptCppToCorba()
InputPort * RuntimeSALOME::adaptCppToCorba ( InputCppPort *  inport,
TypeCode *  type
inport: input port to adapt to CORBA type type
an adaptator port of type InputCorbaPort
Definition at line 1744 of file RuntimeSALOME.cxx.
1746{
1747 DEBTRACE("RuntimeSALOME::adaptCppToCorba(InputCppPort* inport)");
1748 if(isAdaptableCppCorba(type,inport->edGetType()))
1749 {
1750 //output type is convertible to input type
1751 return new CorbaCpp(inport);
1752 }
1753 //output type is not convertible
1754 stringstream msg;
1755 msg << "Cannot connect Corba output port with type: " << type->id() ;
1756 msg << " to Cpp input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1757#ifdef _DEVDEBUG_
1758 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1759#endif
1760 throw ConversionException(msg.str());
1761}
int isAdaptableCppCorba(const TypeCode *t1, const TypeCode *t2)
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptableCppCorba().
◆ adaptCppToCpp()
InputPort * RuntimeSALOME::adaptCppToCpp ( InputCppPort *  inport,
TypeCode *  type
an adaptated input port of type InputPyPort
Definition at line 1794 of file RuntimeSALOME.cxx.
1796{
1797 DEBTRACE("RuntimeSALOME::adaptCppToCpp(InputPort* inport" );
1798 DEBTRACE(type->kind() << " " << inport->edGetType()->kind() );
1799 if(type->isAdaptable(inport->edGetType()))
1800 {
1801 //the output data is convertible to inport type
1802 return new CppCpp(inport);
1803 }
1804 //non convertible type
1805 stringstream msg;
1806 msg << "Cannot connect Cpp output port with type: " << type->id() ;
1807 msg << " to Cpp input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1808#ifdef _DEVDEBUG_
1809 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1810#endif
1811 throw ConversionException(msg.str());
1812}
Class for conversion from C++ Output port to C++ Input port.
Definition: CppCppConv.hxx:37
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::TypeCode::isAdaptable(), and YACS::ENGINE::TypeCode::kind().
◆ adaptCppToNeutral()
InputPort * RuntimeSALOME::adaptCppToNeutral ( InputCppPort *  inport,
TypeCode *  type
Definition at line 1820 of file RuntimeSALOME.cxx.
1822{
1823 DEBTRACE("RuntimeSALOME::adaptCppToNeutral(InputPort* inport" );
1824 DEBTRACE(type->kind() << " " << inport->edGetType()->kind() );
1825 if(type->isAdaptable(inport->edGetType()))
1826 {
1827 //the output data is convertible to inport type
1828 return new NeutralCpp(inport);
1829 }
1830 //non convertible type
1831 stringstream msg;
1832 msg << "Cannot connect Neutral output port with type: " << type->id() ;
1833 msg << " to Cpp input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1834#ifdef _DEVDEBUG_
1835 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1836#endif
1837 throw ConversionException(msg.str());
1838}
Class for conversion from Neutral Output port to Xml Input port.
◆ adaptCppToPython()
InputPort * RuntimeSALOME::adaptCppToPython ( InputCppPort *  inport,
TypeCode *  type
Definition at line 1769 of file RuntimeSALOME.cxx.
1771{
1772 DEBTRACE("RuntimeSALOME::adaptCppToPython(InputCppPort* inport)");
1773 if(isAdaptableCppPyObject(type,inport->edGetType()))
1774 {
1775 //output type is convertible to input type
1776 return new PyCpp(inport);
1777 }
1778 //output type is not convertible
1779 stringstream msg;
1780 msg << "Cannot connect Python output port with type: " << type->id() ;
1781 msg << " to Cpp input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1782#ifdef _DEVDEBUG_
1783 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1784#endif
1785 throw ConversionException(msg.str());
1786}
int isAdaptableCppPyObject(const TypeCode *t1, const TypeCode *t2)
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptableCppPyObject().
◆ adaptCppToXml()
InputPort * RuntimeSALOME::adaptCppToXml ( InputCppPort *  source,
TypeCode *  type
Definition at line 1840 of file RuntimeSALOME.cxx.
1842{
1843 DEBTRACE("RuntimeSALOME::adaptCppToXml(InputCppPort* inport" );
1844 if(isAdaptableCppXml(type,inport->edGetType()))
1845 {
1846 //convertible type
1847 return new XmlCpp(inport);
1848 }
1849 //non convertible type
1850 stringstream msg;
1851 msg << "Cannot connect Xml output port with type: " << type->id() ;
1852 msg << " to Cpp input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1853#ifdef _DEVDEBUG_
1854 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1855#endif
1856 throw ConversionException(msg.str());
1857}
int isAdaptableCppXml(const TypeCode *t1, const TypeCode *t2)
Definition: XMLCppConv.cxx:105
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptableCppXml().
◆ adaptNeutral()
InputPort * RuntimeSALOME::adaptNeutral ( InputPort *  source,
TypeCode *  type,
bool  init
source: Neutral input port to adapt to implementation impl and type type
impl: output port implementation (C++, Python, Corba, Xml or Neutral)
the adaptated port
Definition at line 1012 of file RuntimeSALOME.cxx.
1015{
1016 if(impl == CppNode::IMPL_NAME)
1017 {
1018 return adaptNeutralToCpp(source,type);
1019 }
1020 else if(impl == PythonNode::IMPL_NAME)
1021 {
1022 return adaptNeutralToPython(source,type);
1023 }
1024 else if(impl == CORBANode::IMPL_NAME)
1025 {
1026 return adaptNeutralToCorba(source,type);
1027 }
1028 else if(impl == XmlNode::IMPL_NAME )
1029 {
1030 return adaptNeutralToXml(source,type);
1031 }
1033 {
1034 if(init)
1035 return new NeutralInit(source);
1036 else
1037 return new ProxyPort(source);
1038 }
1039 stringstream msg;
1040 msg << "Cannot connect InputPort : unknown implementation " << impl;
1041 msg << " (" <<__FILE__ << ":" <<__LINE__ << ")";
1042 throw ConversionException(msg.str());
1043}
Class for initialization of a Neutral port with YACS::ENGINE::Any* object.
virtual InputPort * adaptNeutralToXml(InputPort *inport, TypeCode *type)
virtual InputPort * adaptNeutralToCorba(InputPort *inport, TypeCode *type)
virtual InputPort * adaptNeutralToPython(InputPort *inport, TypeCode *type)
virtual InputPort * adaptNeutralToCpp(InputPort *inport, TypeCode *type)
References adaptNeutralToCorba(), adaptNeutralToCpp(), adaptNeutralToPython(), adaptNeutralToXml(), YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, YACS::ENGINE::XmlNode::IMPL_NAME, YACS::ENGINE::Runtime::init(), and YACS::ENGINE::Runtime::RUNTIME_ENGINE_INTERACTION_IMPL_NAME.
◆ adaptNeutralToCorba()
InputPort * RuntimeSALOME::adaptNeutralToCorba ( InputPort *  inport,
TypeCode *  type
inport: Neutral input port to adapt to Corba type type
an adaptated input port of type InputCorbaPort
Definition at line 905 of file RuntimeSALOME.cxx.
907{
908 // BEWARE : using the generic check
909 if(inport->edGetType()->isAdaptable(type))
910 {
911 //the output data is convertible to inport type
912 return new CorbaNeutral(inport);
913 }
914 //non convertible type
915 stringstream msg;
916 msg << "Cannot connect Corba output port with type: " << type->id() ;
917 msg << " to Neutral input port " << inport->getName() << " with type: " << inport->edGetType()->id();
918#ifdef _DEVDEBUG_
919 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
920#endif
921 throw ConversionException(msg.str());
922}
Referenced by adaptNeutral().
◆ adaptNeutralToCpp()
InputPort * RuntimeSALOME::adaptNeutralToCpp ( InputPort *  inport,
TypeCode *  type
an input port of type InputCppPort
Definition at line 985 of file RuntimeSALOME.cxx.
987{
988 DEBTRACE("RuntimeSALOME::adaptNeutralToCpp(InputPort* inport" );
989 if(isAdaptableNeutralCpp(type,inport->edGetType()))
990 {
991 //convertible type
992 return new CppNeutral(inport);
993 }
994 //non convertible type
995 stringstream msg;
996 msg << "Cannot connect Cpp output port with type: " << type->id() ;
997 msg << " to Neutral input port " << inport->getName() << " with type: " << inport->edGetType()->id();
998#ifdef _DEVDEBUG_
999 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1000#endif
1001 throw ConversionException(msg.str());
1002}
int isAdaptableNeutralCpp(const TypeCode *t1, const TypeCode *t2)
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptableNeutralCpp().
◆ adaptNeutralToPython()
InputPort * RuntimeSALOME::adaptNeutralToPython ( InputPort *  inport,
TypeCode *  type
Definition at line 930 of file RuntimeSALOME.cxx.
932{
933 // BEWARE : using the generic check
934 if(inport->edGetType()->isAdaptable(type))
935 {
936 //convertible type
937 return new PyNeutral(inport);
938 }
939 //last chance : an py output that is seq[objref] can be connected to a neutral input objref (P13268)
940 else if(type->kind()==Sequence && type->contentType()->kind()==Objref && inport->edGetType()->kind()==Objref)
941 {
942 return new PyNeutral(inport);
943 }
944 //non convertible type
945 stringstream msg;
946 msg << "Cannot connect Python output port with type: " << type->id() ;
947 msg << " to Neutral input port " << inport->getName() << " with type: " << inport->edGetType()->id();
948#ifdef _DEVDEBUG_
949 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
950#endif
951 throw ConversionException(msg.str());
952}
virtual const TypeCode * contentType() const
Definition: TypeCode.cxx:174
References YACS::ENGINE::TypeCode::contentType(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::TypeCode::isAdaptable(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, and YACS::ENGINE::Sequence.
◆ adaptNeutralToXml()
InputPort * RuntimeSALOME::adaptNeutralToXml ( InputPort *  inport,
TypeCode *  type
an input port of type InputXmlPort
Definition at line 960 of file RuntimeSALOME.cxx.
962{
963 // BEWARE : using the generic check
964 if(inport->edGetType()->isAdaptable(type))
965 {
966 //convertible type
967 return new XmlNeutral(inport);
968 }
969 //non convertible type
970 stringstream msg;
971 msg << "Cannot connect Xml output port with type: " << type->id() ;
972 msg << " to Neutral input port " << inport->getName() << " with type: " << inport->edGetType()->id();
973#ifdef _DEVDEBUG_
974 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
975#endif
976 throw ConversionException(msg.str());
977}
◆ adaptPythonToCorba()
InputPort * RuntimeSALOME::adaptPythonToCorba ( InputPyPort *  inport,
TypeCode *  type
Always convert the data
inport: InputPort to adapt to Corba type type
an adaptator port of Corba type (InputCorbaPort)
Definition at line 1597 of file RuntimeSALOME.cxx.
1599{
1600 if(inport->edGetType()->kind() == Double)
1601 {
1602 if(isAdaptablePyObjectCorba(type,inport->edGetType()))return new CorbaPyDouble(inport);
1603 }
1604 else if(inport->edGetType()->kind() == Int)
1605 {
1606 if(isAdaptablePyObjectCorba(type,inport->edGetType()))return new CorbaPyInt(inport);
1607 }
1608 else if(inport->edGetType()->kind() == String)
1609 {
1610 if(isAdaptablePyObjectCorba(type,inport->edGetType()))return new CorbaPyString(inport);
1611 }
1612 else if(inport->edGetType()->kind() == Bool)
1613 {
1614 if(isAdaptablePyObjectCorba(type,inport->edGetType()))return new CorbaPyBool(inport);
1615 }
1616 else if(inport->edGetType()->kind() == Objref)
1617 {
1618 if(isAdaptablePyObjectCorba(type,inport->edGetType()))
1619 {
1620 return new CorbaPyObjref(inport);
1621 }
1622 else
1623 {
1624 stringstream msg;
1625 msg << "Cannot connect InputCorbaPort : incompatible objref types " << type->id() << " " << inport->edGetType()->id();
1626 msg << " " << __FILE__ << ":" <<__LINE__;
1627 throw ConversionException(msg.str());
1628 }
1629 }
1630 else if(inport->edGetType()->kind() == Sequence)
1631 {
1632 if(isAdaptablePyObjectCorba(type,inport->edGetType()))
1633 {
1634 return new CorbaPySequence(inport);
1635 }
1636 else
1637 {
1638 stringstream msg;
1639 msg << "Cannot convert this sequence type " ;
1640 msg << __FILE__ << ":" <<__LINE__;
1641 throw ConversionException(msg.str());
1642 }
1643 }
1644 else if(inport->edGetType()->kind() == YACS::ENGINE::Struct)
1645 {
1646 if(isAdaptablePyObjectCorba(type,inport->edGetType()))
1647 {
1648 return new CorbaPyStruct(inport);
1649 }
1650 else
1651 {
1652 stringstream msg;
1653 msg << "Cannot convert this struct type " << type->id() << " to " << inport->edGetType()->id();
1654 msg << " " << __FILE__ << ":" <<__LINE__;
1655 throw ConversionException(msg.str());
1656 }
1657 }
1658 // Adaptation not possible
1659 stringstream msg;
1660 msg << "Cannot connect Corba output port with type: " << type->id() ;
1661 msg << " to Python input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1662#ifdef _DEVDEBUG_
1663 msg << " ("__FILE__ << ":" << __LINE__ << ")";
1664#endif
1665 throw ConversionException(msg.str());
1666}
Class for conversion from CORBA Output port to Python Input port.
Class for conversion of struct objects from CORBA Output port to Python Input port.
int isAdaptablePyObjectCorba(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::Int, YACS::ENGINE::isAdaptablePyObjectCorba(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
◆ adaptPythonToCpp()
InputPort * RuntimeSALOME::adaptPythonToCpp ( InputPyPort *  inport,
TypeCode *  type
inport: InputPort to adapt to C++ type type
an adaptator port of C++ type (InputCppPort)
Definition at line 1513 of file RuntimeSALOME.cxx.
1515{
1516 DEBTRACE("RuntimeSALOME::adaptPythonToCpp(InputPyPort* inport" );
1517 if(isAdaptablePyObjectCpp(type,inport->edGetType()))
1518 {
1519 //output type is convertible to input type
1520 return new CppPy(inport);
1521 }
1522 //output type is not convertible
1523 stringstream msg;
1524 msg << "Cannot connect Cpp output port with type: " << type->id() ;
1525 msg << " to Python input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1526#ifdef _DEVDEBUG_
1527 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1528#endif
1529 throw ConversionException(msg.str());
1530}
int isAdaptablePyObjectCpp(const TypeCode *t1, const TypeCode *t2)
References DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptablePyObjectCpp().
◆ adaptPythonToNeutral()
InputPort * RuntimeSALOME::adaptPythonToNeutral ( InputPyPort *  inport,
TypeCode *  type
an adaptator port of Neutral type (Neutralxxxx)
Definition at line 1539 of file RuntimeSALOME.cxx.
1541{
1542 if(inport->edGetType()->kind() == Double)
1543 {
1544 if(isAdaptablePyObjectNeutral(type,inport->edGetType()))return new NeutralPyDouble(inport);
1545 }
1546 else if(inport->edGetType()->kind() == Int)
1547 {
1548 if(isAdaptablePyObjectNeutral(type,inport->edGetType()))return new NeutralPyInt(inport);
1549 }
1550 else if(inport->edGetType()->kind() == String)
1551 {
1552 if(isAdaptablePyObjectNeutral(type,inport->edGetType()))return new NeutralPyString(inport);
1553 }
1554 else if(inport->edGetType()->kind() == Bool)
1555 {
1556 if(isAdaptablePyObjectNeutral(type,inport->edGetType()))return new NeutralPyBool(inport);
1557 }
1558 else if(inport->edGetType()->kind() == Objref)
1559 {
1560 if(isAdaptablePyObjectNeutral(type,inport->edGetType()))return new NeutralPyObjref(inport);
1561 }
1562 else if(inport->edGetType()->kind() == Sequence)
1563 {
1564 if(isAdaptablePyObjectNeutral(type,inport->edGetType()))
1565 return new NeutralPySequence(inport);
1566 else
1567 {
1568 stringstream msg;
1569 msg << "Cannot convert this sequence type " ;
1570 msg << __FILE__ << ":" <<__LINE__;
1571 throw ConversionException(msg.str());
1572 }
1573 }
1574 else if(inport->edGetType()->kind() == Struct)
1575 {
1576 if(isAdaptablePyObjectNeutral(type,inport->edGetType())) return new NeutralPyStruct(inport);
1577 }
1578
1579 // Adaptation not possible
1580 stringstream msg;
1581 msg << "Cannot connect Neutral output port with type: " << type->id() ;
1582 msg << " to Python input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1583#ifdef _DEVDEBUG_
1584 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1585#endif
1586 throw ConversionException(msg.str());
1587}
int isAdaptablePyObjectNeutral(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::Bool, YACS::ENGINE::Double, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::Int, YACS::ENGINE::isAdaptablePyObjectNeutral(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, YACS::ENGINE::Sequence, YACS::ENGINE::String, and YACS::ENGINE::Struct.
◆ adaptPythonToPython()
InputPort * RuntimeSALOME::adaptPythonToPython ( InputPyPort *  inport,
TypeCode *  type,
bool  init
No need to make conversion or cast. Only check, it's possible.
inport: InputPort to adapt to Python type type
Definition at line 1483 of file RuntimeSALOME.cxx.
1485{
1486 if(init)
1487 return new PyInit(inport);
1488
1489 if(isAdaptablePyObjectPyObject(type,inport->edGetType()))
1490 {
1491 //output data is convertible to input type
1492 //With python, no need to convert. Conversion will be done automatically
1493 //by the interpreter
1494 return new ProxyPort(inport);
1495 }
1496 //output data is not convertible to input type
1497 stringstream msg;
1498 msg << "Cannot connect Python output port with type: " << type->id() ;
1499 msg << " to Python input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1500#ifdef _DEVDEBUG_
1501 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1502#endif
1503 throw ConversionException(msg.str());
1504}
int isAdaptablePyObjectPyObject(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::Runtime::init(), and YACS::ENGINE::isAdaptablePyObjectPyObject().
◆ adaptPythonToXml()
InputPort * RuntimeSALOME::adaptPythonToXml ( InputPyPort *  inport,
TypeCode *  type
Definition at line 1675 of file RuntimeSALOME.cxx.
1677{
1678 // BEWARE : using the generic check
1679 if(inport->edGetType()->isAdaptable(type))
1680 {
1681 //convertible type
1682 return new XmlPython(inport);
1683 }
1684 //non convertible type
1685 stringstream msg;
1686 msg << "Cannot connect Xml output port with type: " << type->id() ;
1687 msg << " to Python input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1688#ifdef _DEVDEBUG_
1689 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1690#endif
1691 throw ConversionException(msg.str());
1692}
◆ adaptXmlToCorba()
InputPort * RuntimeSALOME::adaptXmlToCorba ( InputXmlPort *  inport,
TypeCode *  type
Definition at line 1052 of file RuntimeSALOME.cxx.
1054{
1055 if(isAdaptableXmlCorba(type,inport->edGetType()))
1056 {
1057 //output type is convertible to input type
1058 return new CorbaXml(inport);
1059 }
1060 //output type is not convertible
1061 stringstream msg;
1062 msg << "Cannot connect Corba output port with type: " << type->id() ;
1063 msg << " to Xml input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1064#ifdef _DEVDEBUG_
1065 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1066#endif
1067 throw ConversionException(msg.str());
1068}
int isAdaptableXmlCorba(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), and YACS::ENGINE::isAdaptableXmlCorba().
◆ adaptXmlToCpp()
InputPort * RuntimeSALOME::adaptXmlToCpp ( InputXmlPort *  inport,
TypeCode *  type
Definition at line 1100 of file RuntimeSALOME.cxx.
1102{
1103 DEBTRACE("RuntimeSALOME::adaptXmlToCpp(InputPort* inport" );
1104 DEBTRACE(type->kind() << " " << inport->edGetType()->kind() );
1105 if(type->isAdaptable(inport->edGetType()))
1106 {
1107 //the output data is convertible to inport type
1108 return new CppXml(inport);
1109 }
1110 //non convertible type
1111 stringstream msg;
1112 msg << "Cannot connect Cpp output port with type: " << type->id() ;
1113 msg << " to Xml input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1114#ifdef _DEVDEBUG_
1115 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1116#endif
1117 throw ConversionException(msg.str());
1118}
◆ adaptXmlToNeutral()
InputPort * RuntimeSALOME::adaptXmlToNeutral ( InputXmlPort *  inport,
TypeCode *  type
inport: input port to adapt to Neutral type type
an adaptated input port of type Neutralxxxx
Definition at line 1126 of file RuntimeSALOME.cxx.
1128{
1129 if(inport->edGetType()->isAdaptable(type))
1130 {
1131 //the output data is convertible to inport type
1132 return new NeutralXml(inport);
1133 }
1134 //non convertible type
1135 stringstream msg;
1136 msg << "Cannot connect Xml InputPort to OutputNeutralPort : " ;
1137 msg << "(" <<__FILE__ << ":" <<__LINE__<< ")";
1138 throw ConversionException(msg.str());
1139}
Class for conversion from Neutral Output port to XML Input port.
References YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::TypeCode::isAdaptable().
◆ adaptXmlToPython()
InputPort * RuntimeSALOME::adaptXmlToPython ( InputXmlPort *  inport,
TypeCode *  type
Definition at line 1076 of file RuntimeSALOME.cxx.
1078{
1079 if(inport->edGetType()->isAdaptable(type))
1080 {
1081 //the output data is convertible to inport type
1082 return new PyXml(inport);
1083 }
1084 //non convertible type
1085 stringstream msg;
1086 msg << "Cannot connect Python output port with type: " << type->id() ;
1087 msg << " to Xml input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1088#ifdef _DEVDEBUG_
1089 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1090#endif
1091 throw ConversionException(msg.str());
1092}
◆ adaptXmlToXml()
InputPort * RuntimeSALOME::adaptXmlToXml ( InputXmlPort *  inport,
TypeCode *  type,
bool  init
an adaptated input port of type Xmlxxxx
Definition at line 1148 of file RuntimeSALOME.cxx.
1150{
1151 if(init)
1152 return new ProxyPort(inport);
1153
1154 if(inport->edGetType()->isAdaptable(type))
1155 return new ProxyPort(inport);
1156
1157 stringstream msg;
1158 msg << "Cannot connect Xml output port with type: " << type->id() ;
1159 msg << " to Xml input port " << inport->getName() << " with type: " << inport->edGetType()->id();
1160#ifdef _DEVDEBUG_
1161 msg << " ("<<__FILE__ << ":" << __LINE__<<")";
1162#endif
1163 throw ConversionException(msg.str());
1164}
References YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::TypeCode::id(), YACS::ENGINE::Runtime::init(), and YACS::ENGINE::TypeCode::isAdaptable().
◆ convertNeutral()
void * RuntimeSALOME::convertNeutral ( TypeCode *  type,
Any *  data
This method is used to convert Neutral objects to script languages. For example Python language. The runtime has one external script language. The object is returned as a void * because engine knows nothing about external script language.
typethe type of the converted object if the conversion is possible
datathe object to convert
Reimplemented from YACS::ENGINE::Runtime.
Definition at line 1969 of file RuntimeSALOME.cxx.
1970{
1971 if(data)
1972 return (void *)convertNeutralPyObject(type,data);
1973 else
1974 {
1975 Py_INCREF(Py_None);
1976 return (void *)Py_None;
1977 }
1978}
PyObject * convertNeutralPyObject(const TypeCode *t, YACS::ENGINE::Any *data)
References YACS::ENGINE::convertNeutralPyObject().
◆ convertNeutralAsString()
std::string RuntimeSALOME::convertNeutralAsString ( TypeCode *  type,
Any *  data
engine package does not provide a conversion to string. It has to be implemented in the runtime package.
typethe type of the object to convert
the string representation of the object
Definition at line 1980 of file RuntimeSALOME.cxx.
1981{
1982 PyObject* ob;
1983 if(data)
1984 {
1985 // The call to PyGILState_Ensure was moved here because there was also
1986 // a crash when calling convertNeutralPyObject with a sequence of pyobj.
1987 // see also the comment below.
1988 PyGILState_STATE gstate = PyGILState_Ensure();
1989 ob=convertNeutralPyObject(type,data);
1990 std::string s=convertPyObjectToString(ob);
1991
1992 // Note (Renaud Barate, 8 jan 2013): With Python 2.7, this call to Py_DECREF causes a crash
1993 // (SIGSEGV) when ob is a sequence and the call is not protected with the global interpreter
1994 // lock. I thus added the call to PyGILState_Ensure / PyGILState_Release. It worked fine in
1995 // Python 2.6 without this call. If anyone finds the real reason of this bug and another fix,
1996 // feel free to change this code.
1997 //PyGILState_STATE gstate = PyGILState_Ensure();
1998 Py_DECREF(ob);
1999 PyGILState_Release(gstate);
2000 return s;
2001 }
2002 else
2003 {
2004 return "None";
2005 }
2006}
virtual std::string convertPyObjectToString(PyObject *ob)
References YACS::ENGINE::convertNeutralPyObject(), and convertPyObjectToString().
◆ convertPyObjectToString()
std::string RuntimeSALOME::convertPyObjectToString ( PyObject *  ob)
Definition at line 2008 of file RuntimeSALOME.cxx.
2009{
2011}
References YACS::ENGINE::convertPyObjectToString().
Referenced by convertNeutralAsString().
◆ convertStringToPyObject()
PyObject * RuntimeSALOME::convertStringToPyObject ( const std::string &  s)
Definition at line 2013 of file RuntimeSALOME.cxx.
2014{
2015 PyObject *mainmod;
2016 PyObject *globals;
2017 PyObject* ob;
2018 PyGILState_STATE gstate = PyGILState_Ensure();
2019 mainmod = PyImport_AddModule("__main__");
2020 globals = PyModule_GetDict(mainmod);
2021 PyObject* d = PyDict_New();
2022 //PyDict_SetItemString(d, "__builtins__", PyEval_GetBuiltins());
2023 ob= PyRun_String( s.c_str(), Py_eval_input, globals, d);
2024 Py_DECREF(d);
2025 if(ob==NULL)
2026 {
2027 //exception
2028 std::string error;
2029 PyObject* new_stderr = newPyStdOut(error);
2030 PySys_SetObject((char *)"stderr", new_stderr);
2031 PyErr_Print();
2032 PySys_SetObject((char *)"stderr", PySys_GetObject((char *)"__stderr__"));
2033 Py_DECREF(new_stderr);
2034 PyGILState_Release(gstate);
2035 throw Exception(error);
2036 }
2037 PyGILState_Release(gstate);
2038 return ob;
2039}
PyObject * newPyStdOut(std::string &out)
Definition: PyStdout.cxx:129
References YACS::ENGINE::newPyStdOut().
Referenced by YACS::HMI::CommandSetInPortValue::localExecute(), YACS::HMI::CommandSetOutPortValue::localExecute(), YACS::HMI::CommandSetInPortValue::localReverse(), and YACS::HMI::CommandSetOutPortValue::localReverse().
◆ createBloc()
Bloc * RuntimeSALOME::createBloc ( const std::string &  name)
Definition at line 599 of file RuntimeSALOME.cxx.
600{
601 return new Bloc(name);
602}
Definition: Bloc.hxx:36
Referenced by initBuiltins().
◆ createComponentInstance()
ComponentInstance * RuntimeSALOME::createComponentInstance ( const std::string &  name,
const std::string &  kind = ""
Definition at line 722 of file RuntimeSALOME.cxx.
724{
725 ComponentInstance* compo;
726 if(kind == "" || kind == SalomeComponent::KIND)
727 return new SalomeComponent(name);
728 else if(kind == CORBAComponent::KIND)
729 return new CORBAComponent(name);
730 else if(kind == SalomePythonComponent::KIND)
731 return new SalomePythonComponent(name);
732 else if (kind == CppComponent::KIND)
733 return new CppComponent(name);
734 else if (kind == SalomeHPComponent::KIND)
735 return new SalomeHPComponent(name);
736 std::string msg="Component Instance kind ("+kind+") unknown";
737 throw Exception(msg);
738}
Class for CORBA component instance.
static const char KIND[]
Class for Salome component instance.
References YACS::ENGINE::CORBAComponent::KIND, YACS::ENGINE::CppComponent::KIND, YACS::ENGINE::SalomeComponent::KIND, YACS::ENGINE::SalomeHPComponent::KIND, and YACS::ENGINE::SalomePythonComponent::KIND.
◆ createCompoNode()
ServiceNode * RuntimeSALOME::createCompoNode ( const std::string &  kind,
Definition at line 697 of file RuntimeSALOME.cxx.
698{
699 ServiceNode* node;
700 if(kind == "" || kind == SalomeNode::KIND )
701 {
702 node=new SalomeNode(name);
703 return node;
704 }
705 else if (kind == CppNode::KIND)
706 {
707 node = new CppNode(name);
708 return node;
709 }
710 std::string msg="CompoNode kind ("+kind+") unknown";
711 throw Exception(msg);
712}
Class for C++ Nodes (in process component)
Definition: CppNode.hxx:47
Definition: CppNode.hxx:62
Class for Salome component Service Node.
Definition: CORBANode.hxx:68
Definition: CORBANode.hxx:78
References YACS::ENGINE::SalomeNode::KIND, and YACS::ENGINE::CppNode::KIND.
◆ createContainer()
Container * RuntimeSALOME::createContainer ( const std::string &  kind = "")
Definition at line 740 of file RuntimeSALOME.cxx.
741{
742 if(kind == "" || kind == SalomeContainer::KIND)
743 return new SalomeContainer;
745 return new SalomeHPContainer;
746 else if (kind == CppContainer::KIND)
747 return new CppContainer;
748 std::string msg="Container kind ("+kind+") unknown";
749 throw Exception(msg);
750}
References YACS::ENGINE::CppContainer::KIND, YACS::ENGINE::SalomeContainer::KIND, and YACS::ENGINE::SalomeHPContainer::KIND.
◆ createForLoop()
ForLoop * RuntimeSALOME::createForLoop ( const std::string &  name)
Definition at line 609 of file RuntimeSALOME.cxx.
610{
611 return new ForLoop(name);
612}
Class for for loop node.
Definition: ForLoop.hxx:33
◆ createFuncNode()
InlineFuncNode * RuntimeSALOME::createFuncNode ( const std::string &  kind,
Definition at line 654 of file RuntimeSALOME.cxx.
655{
656 InlineFuncNode* node;
657 if(kind == "" || kind == SalomeNode::KIND || kind == PythonNode::KIND)
658 {
659 node = new PyFuncNode(name);
660 return node;
661 }
663 return new DistributedPythonNode(name);
664 std::string msg="FuncNode kind ("+kind+") unknown";
665 throw Exception(msg);
666}
Definition: InlineNode.hxx:93
Definition: PythonNode.hxx:122
References YACS::ENGINE::SalomeNode::KIND, YACS::ENGINE::DistributedPythonNode::KIND, and YACS::ENGINE::PythonNode::KIND.
◆ createInDataNode()
DataNode * RuntimeSALOME::createInDataNode ( const std::string &  kind,
Definition at line 623 of file RuntimeSALOME.cxx.
624{
625 DataNode* node;
626 if(kind == "" )
627 {
628 node = new PresetNode(name);
629 return node;
630 }
631 else if(kind == "study" )
632 {
633 return new StudyInNode(name);
634 }
635 std::string msg="DataNode kind ("+kind+") unknown";
636 throw Exception(msg);
637}
Definition: DataNode.hxx:38
Class for data in node.
Definition: PresetNode.hxx:31
◆ createInputDataStreamPort()
InputDataStreamPort * RuntimeSALOME::createInputDataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 812 of file RuntimeSALOME.cxx.
814{
815 DEBTRACE("createInputDataStreamPort: " << name << " " << type->shortName());
816 if(type->kind() == Objref && std::string(type->shortName(),7) == "CALCIUM")
817 {
818 return new InputCalStreamPort(name,node,type);
819 }
820 else
821 {
822 return new InputDataStreamPort(name,node,type);
823 }
824}
Class for Input Calcium DataStream Ports.
virtual const char * shortName() const
Definition: TypeCode.cxx:77
References DEBTRACE, YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::Objref, and YACS::ENGINE::TypeCode::shortName().
◆ createInputPort()
InputPort * RuntimeSALOME::createInputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 752 of file RuntimeSALOME.cxx.
756{
757 if(impl == CppNode::IMPL_NAME)
758 {
759 return new InputCppPort(name, node, type);
760 }
761 else if(impl == PythonNode::IMPL_NAME)
762 {
763 return new InputPyPort(name, node, type);
764 }
765 else if(impl == CORBANode::IMPL_NAME)
766 {
767 return new InputCorbaPort(name, node, type);
768 }
769 else if(impl == XmlNode::IMPL_NAME)
770 {
771 return new InputXmlPort(name, node, type);
772 }
773 else
774 {
775 stringstream msg;
776 msg << "Cannot create " << impl << " InputPort" ;
777 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
778 throw Exception(msg.str());
779 }
780}
References YACS::ENGINE::CORBANode::IMPL_NAME, YACS::ENGINE::CppNode::IMPL_NAME, YACS::ENGINE::PythonNode::IMPL_NAME, and YACS::ENGINE::XmlNode::IMPL_NAME.
◆ createInterfaceTc()
TypeCode * RuntimeSALOME::createInterfaceTc ( const std::string &  id,
std::list< TypeCodeObjref * >  ltc
Definition at line 575 of file RuntimeSALOME.cxx.
577{
578 std::string myName;
579 if(id == "") myName = "IDL:" + name + ":1.0";
580 else myName = id;
581 return TypeCode::interfaceTc(myName.c_str(),name.c_str(),ltc);
582}
static TypeCode * interfaceTc(const char *id, const char *name)
static factory of object reference type given an id and a name
Definition: TypeCode.cxx:229
References YACS::ENGINE::TypeCode::interfaceTc().
◆ createOptimizerLoop()
OptimizerLoop * RuntimeSALOME::createOptimizerLoop ( const std::string &  name,
const std::string &  algLib,
const std::string &  factoryName,
bool  algInitOnFile,
const std::string &  kind = "",
Proc *  procForTypes = NULL
Definition at line 614 of file RuntimeSALOME.cxx.
616{
617 OptimizerLoop * ol = (kind == "base") ? new OptimizerLoop(name,algLib,factoryName,algInitOnFile, true, procForTypes) :
618 new SalomeOptimizerLoop(name,algLib,factoryName,algInitOnFile, true, procForTypes);
620 return ol;
621}
InputPort * edGetNbOfBranchesPort()
Definition: DynParaLoop.hxx:83
void edInit(T value)
Definition: InputPort.hxx:129
References YACS::ENGINE::DynParaLoop::edGetNbOfBranchesPort(), and YACS::ENGINE::InputPort::edInit().
◆ createOutDataNode()
DataNode * RuntimeSALOME::createOutDataNode ( const std::string &  kind,
Definition at line 639 of file RuntimeSALOME.cxx.
640{
641 if(kind == "" )
642 {
643 return new OutNode(name);
644 }
645 else if(kind == "study" )
646 {
647 return new StudyOutNode(name);
648 }
649
650 std::string msg="OutDataNode kind ("+kind+") unknown";
651 throw Exception(msg);
652}
Class for data out node.
Definition: OutNode.hxx:30
◆ createOutputDataStreamPort()
OutputDataStreamPort * RuntimeSALOME::createOutputDataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 826 of file RuntimeSALOME.cxx.
828{
829 DEBTRACE("createOutputDataStreamPort: " << name << " " << type->shortName());
830 if(type->kind() == Objref && std::string(type->shortName(),7) == "CALCIUM")
831 {
832 return new OutputCalStreamPort(name,node,type);
833 }
834 else
835 {
836 return new OutputDataStreamPort(name,node,type);
837 }
838}
Class for Output Calcium DataStream Ports.
◆ createOutputPort()
OutputPort * RuntimeSALOME::createOutputPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 782 of file RuntimeSALOME.cxx.
786{
787 if(impl == CppNode::IMPL_NAME)
788 {
789 return new OutputCppPort(name, node, type);
790 }
791 else if(impl == PythonNode::IMPL_NAME)
792 {
793 return new OutputPyPort(name, node, type);
794 }
795 else if(impl == CORBANode::IMPL_NAME)
796 {
797 return new OutputCorbaPort(name, node, type);
798 }
799 else if(impl == XmlNode::IMPL_NAME)
800 {
801 return new OutputXmlPort(name, node, type);
802 }
803 else
804 {
806 msg << "Cannot create " << impl << " OutputPort" ;
807 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
808 throw Exception(msg.str());
809 }
810}
Class for XML Output Ports.
Definition: XMLPorts.hxx:68
◆ createProc()
Proc * RuntimeSALOME::createProc ( const std::string &  name)
Definition at line 570 of file RuntimeSALOME.cxx.
571{
572 return new SalomeProc(name);
573}
Referenced by YACS::HMI::Invocator::Invocator(), and YACS::HMI::GenericGui::onNewSchema().
◆ createRefNode()
ServiceNode * RuntimeSALOME::createRefNode ( const std::string &  kind,
Definition at line 680 of file RuntimeSALOME.cxx.
681{
682 ServiceNode* node;
683 if(kind == "" || kind == SalomeNode::KIND || kind == CORBANode::KIND)
684 {
685 node = new CORBANode(name);
686 return node;
687 }
688 else if(kind == XmlNode::KIND)
689 {
690 node = new XmlNode(name);
691 return node;
692 }
693 std::string msg="RefNode kind ("+kind+") unknown";
694 throw Exception(msg);
695}
Class for CORBA Service Node.
Definition: CORBANode.hxx:45
Definition: CORBANode.hxx:54
Definition: XMLNode.hxx:47
References YACS::ENGINE::CORBANode::KIND, YACS::ENGINE::SalomeNode::KIND, and YACS::ENGINE::XmlNode::KIND.
◆ createScriptNode()
InlineNode * RuntimeSALOME::createScriptNode ( const std::string &  kind,
Definition at line 668 of file RuntimeSALOME.cxx.
669{
670 InlineNode* node;
671 if(kind == "" || kind == SalomeNode::KIND || kind == PythonNode::KIND)
672 {
673 node = new PythonNode(name);
674 return node;
675 }
676 std::string msg="ScriptNode kind ("+kind+") unknown";
677 throw Exception(msg);
678}
Definition: InlineNode.hxx:44
References YACS::ENGINE::SalomeNode::KIND, and YACS::ENGINE::PythonNode::KIND.
◆ createSequenceTc()
TypeCode * RuntimeSALOME::createSequenceTc ( const std::string &  id,
TypeCode *  content
Definition at line 584 of file RuntimeSALOME.cxx.
587{
588 return TypeCode::sequenceTc(id.c_str(),name.c_str(),content);
589};
static TypeCode * sequenceTc(const char *id, const char *name, TypeCode *content)
static factory of sequence type given an id, a name and a content type
Definition: TypeCode.cxx:254
References YACS::ENGINE::TypeCode::sequenceTc().
◆ createSInlineNode()
ServiceInlineNode * RuntimeSALOME::createSInlineNode ( const std::string &  kind,
Definition at line 714 of file RuntimeSALOME.cxx.
715{
716 if(kind == "" || kind == SalomeNode::KIND )
717 return new SalomePythonNode(name);
718 std::string msg="CompoNode kind ("+kind+") unknown";
719 throw Exception(msg);
720}
References YACS::ENGINE::SalomeNode::KIND.
◆ createStructTc()
TypeCodeStruct * RuntimeSALOME::createStructTc ( const std::string &  id,
Definition at line 591 of file RuntimeSALOME.cxx.
592{
593 std::string myName;
594 if(id == "") myName = "IDL:" + name + ":1.0";
595 else myName = id;
596 return (TypeCodeStruct *)TypeCode::structTc(myName.c_str(),name.c_str());
597}
Class for struct type.
Definition: TypeCode.hxx:228
static TypeCode * structTc(const char *id, const char *name)
static factory of struct type given an id and a name
Definition: TypeCode.cxx:269
References YACS::ENGINE::TypeCode::structTc().
◆ createWhileLoop()
WhileLoop * RuntimeSALOME::createWhileLoop ( const std::string &  name)
Definition at line 604 of file RuntimeSALOME.cxx.
605{
606 return new WhileLoop(name);
607}
Class for a while loop.
Definition: WhileLoop.hxx:39
◆ fini()
void RuntimeSALOME::fini ( bool  isFinalizingPython = true)
Definition at line 423 of file RuntimeSALOME.cxx.
424{
425 if (_usePython)
426 {
427 PyGILState_STATE gstate = PyGILState_Ensure();
428#ifdef REFCNT
429 DEBTRACE("_orb refCount: " << ((omniOrbORB*)_orb.in())->pd_refCount);
430#endif
431 PyObject *mainmod, *globals;
432 mainmod = PyImport_AddModule("__main__");
433 globals = PyModule_GetDict(mainmod);
434 if (_useCorba)
435 {
436 PyObject* res;
437 res=PyRun_String("orb.destroy()\n"
438 "\n",
439 Py_file_input,globals,globals );
440 if(res == NULL)
441 PyErr_Print();
442 else
443 Py_DECREF(res);
444 }
445 std::map<std::string,Node*>& nodeMap=_builtinCatalog->_nodeMap;
446 delete nodeMap["PyFunction"];
447 delete nodeMap["PyScript"];
448 delete nodeMap["SalomePythonNode"];
449 nodeMap.erase("PyFunction");
450 nodeMap.erase("PyScript");
451 nodeMap.erase("SalomePythonNode");
452
453 if( isFinalizingPython )
454 Py_Finalize();
455#ifdef REFCNT
456 DEBTRACE("_orb refCount: " << ((omniOrbORB*)_orb.in())->pd_refCount);
457#endif
458 }
459 else
460 {
461 if (_useCorba)
462 {
463#ifdef REFCNT
464 DEBTRACE("_orb refCount: " << ((omniOrbORB*)_orb.in())->pd_refCount);
465#endif
466 _orb->destroy();
467 }
468 }
469}
std::map< std::string, Node * > _nodeMap
Definition: Catalog.hxx:51
Catalog * _builtinCatalog
Definition: Runtime.hxx:153
References YACS::ENGINE::Runtime::_builtinCatalog, YACS::ENGINE::Catalog::_nodeMap, _orb, _useCorba, _usePython, and DEBTRACE.
◆ get_omnipy()
PyObject * RuntimeSALOME::get_omnipy ( )
Definition at line 1959 of file RuntimeSALOME.cxx.
1960{
1961 return _omnipy;
1962}
References _omnipy.
◆ getApi()
omniORBpyAPI * RuntimeSALOME::getApi ( )
Definition at line 1964 of file RuntimeSALOME.cxx.
1965{
1966 return _api;
1967}
References _api.
Referenced by YACS::ENGINE::convertFromYacsObjref< PYTHONImpl, PyObject * >::convert().
◆ getBuiltins()
PyObject * RuntimeSALOME::getBuiltins ( ) const
Definition at line 1949 of file RuntimeSALOME.cxx.
1950{
1951 return _bltins;
1952}
References _bltins.
Referenced by launchSubProcess().
◆ getCatalogOfComputeNodes()
std::vector< std::pair< std::string, int > > RuntimeSALOME::getCatalogOfComputeNodes ( ) const
Definition at line 503 of file RuntimeSALOME.cxx.
504{
505 CORBA::ORB_ptr orb(getOrb());
506 SALOME_NamingService_Wrapper namingService;
507 try
508 {
509 namingService.init_orb(orb);
510 }
511 catch(SALOME_Exception& e)
512 {
513 throw Exception("RuntimeSALOME::getCatalogOfComputeNodes : Unable to contact the SALOME Naming Service");
514 }
515 CORBA::Object_var obj(namingService.Resolve(SALOME_ResourcesManager::_ResourcesManagerNameInNS));
516 if(CORBA::is_nil(obj))
517 throw Exception("RuntimeSALOME::getCatalogOfComputeNodes : Unable to access to the resource manager !");
518 Engines::ResourcesManager_var resManager(Engines::ResourcesManager::_narrow(obj));
519 if(CORBA::is_nil(resManager))
520 throw Exception("RuntimeSALOME::getCatalogOfComputeNodes : Internal error ! The entry attached to the res manager in NS does not have right type !");
521 std::vector< std::pair<std::string,int> > ret;
522 Engines::ResourceParameters params;
523 params.name = "";
524 params.hostname = "";
525 params.OS = "";
526 params.nb_proc = 0;
527 params.mem_mb = 0;
528 params.cpu_clock = 0;
529 params.nb_node = 0;
530 params.nb_proc_per_node = 0;
531 params.policy = "";
532 params.can_launch_batch_jobs = false;
533 params.can_run_containers = true;
534 params.componentList.length(0);
535 try
536 {
537 Engines::ResourceList_var resourceList;
538 resourceList = resManager->GetFittingResources(params);
539 ret.reserve(resourceList->length());
540 for(int i = 0; i<resourceList->length(); i++)
541 {
542 const char* resource_name = resourceList[i];
543 std::string std_resource_name = resource_name;
544 Engines::ResourceDefinition_var resource_definition
545 = resManager->GetResourceDefinition(resource_name);
546 int nb_cores = resource_definition->nb_node *
547 resource_definition->nb_proc_per_node;
548 ret.push_back(std::pair<std::string,int>(resource_name, nb_cores));
549 }
550 }
551 catch(SALOME::SALOME_Exception& e)
552 {
553 std::string message;
554 message=e.details.text.in();
555 throw Exception(message);
556 }
557
558 return ret;
559}
void init_orb(CORBA::ORB_ptr orb=0) override
CORBA::Object_ptr Resolve(const char *Path) override
CORBA::ORB_ptr getOrb() const
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
References getOrb(), yacsorb.CORBAEngineTest::i, SALOME_NamingService_Wrapper::init_orb(), orb, and SALOME_NamingService_Wrapper::Resolve().
◆ getConnectionManager()
ConnectionManager & YACS::ENGINE::RuntimeSALOME::getConnectionManager ( )
Definition at line 246 of file RuntimeSALOME.hxx.
246{return _connectionManager;}
◆ getDynFactory()
◆ getFromNS()
CORBA::Object_var RuntimeSALOME::getFromNS ( const char *  entry) const
Retrieve from custom NS the entry. Custom NS is supposed to be hosted in current process. This method try to emulate CORBA ns convention : "corbaname:rir:#test.my_context/Echo.Object" is converted into "Echo"
See Engines::EmbeddedNamingService
Definition at line 1920 of file RuntimeSALOME.cxx.
1921{
1922 CORBA::Object_var ret;
1923 std::string entryCpp(entry);
1924 if(entryCpp.substr(0,4) == "IOR:")
1925 {
1926 ret = _orb->string_to_object( entry );
1927 }
1928 else
1929 {
1930 auto pos = entryCpp.find_last_of('/');
1931 std::string entry1( entryCpp.substr(pos+1,std::string::npos) );
1932 pos = entry1.find_last_of('.');
1933 std::string entry2( entry1.substr(0,pos) );
1934 Engines::EmbeddedNamingService_var ns = GetEmbeddedNamingService();
1935 std::unique_ptr<Engines::IORType> iorRet( ns->Resolve( entry2.c_str() ) );
1936 auto len = iorRet->length();
1937 std::unique_ptr<char[]> iorTrans(new char[len+1]); iorTrans[len] = '\0';
1938 for(auto i = 0 ; i < len ; ++i) iorTrans[i] = (*iorRet)[i];
1939 ret = _orb->string_to_object(iorTrans.get());
1940 }
1941 return ret;
1942}
References _orb, and yacsorb.CORBAEngineTest::i.
Referenced by YACS::ENGINE::convertFromYacsObjref< PYTHONImpl, PyObject * >::convert(), YACS::ENGINE::convertFromYacsObjref< CORBAImpl, CORBA::Any * >::convert(), and YACS::ENGINE::CORBAComponent::load().
◆ getNS()
std::unique_ptr< SALOME_NamingService_Container_Abstract > RuntimeSALOME::getNS ( )
Definition at line 138 of file RuntimeSALOME.cxx.
139{
140 std::unique_ptr<SALOME_NamingService_Container_Abstract> ret(new SALOME_NamingService_Wrapper);
141 return ret;
142}
◆ getOrb()
◆ getPyOrb()
PyObject * RuntimeSALOME::getPyOrb ( ) const
Definition at line 1944 of file RuntimeSALOME.cxx.
1945{
1946 return _pyorb;
1947}
References _pyorb.
Referenced by YACS::ENGINE::PyCorbaObjref::PyCorbaObjref().
◆ getSingleton()
static Runtime * YACS::ENGINE::RuntimeSALOME::getSingleton ( )
inlinestaticprivate
Definition at line 60 of file RuntimeSALOME.hxx.
60{ return Runtime::_singleton; }
static Runtime * _singleton
Definition: Runtime.hxx:150
References YACS::ENGINE::Runtime::_singleton.
Referenced by YACS::ENGINE::getSALOMERuntime().
◆ getVersion()
std::string RuntimeSALOME::getVersion ( ) const
Definition at line 561 of file RuntimeSALOME.cxx.
562{
563#ifdef YACS_DEVELOPMENT
564 return CORBA::string_dup(YACS_VERSION_STR"dev");
565#else
566 return CORBA::string_dup(YACS_VERSION_STR);
567#endif
568}
◆ init()
void RuntimeSALOME::init ( long  flags,
int  argc,
char *  argv[]
CORBA and Python initialization.
flagscontains several bits bit0 (ispyext) true when method is called from Python (Python initialization must not be done!) bit1 (UsePython) true if python nodes are needed bit1 (UseCorba) true if CORBA nodes are needed bit1 (UseXml) true if python nodes are needed bit1 (UseCpp) true if C++ nodes are needed bit1 (UseSalome) true if Salome nodes are needed
argcnumber of command line arguments (used to initialize the Python interpreter)
argvcommand line arguments (used to initialize the Python interpreter)
Definition at line 280 of file RuntimeSALOME.cxx.
281{
282 bool ispyext = flags & RuntimeSALOME::IsPyExt;
283 if (_useCorba)
284 {
285 PortableServer::POA_var root_poa;
286 PortableServer::POAManager_var pman;
287 CORBA::Object_var obj;
288 int nbargs = 0; char **args = 0;
289 _orb = CORBA::ORB_init (nbargs, args);
290 obj = _orb->resolve_initial_references("RootPOA");
291 root_poa = PortableServer::POA::_narrow(obj);
292 pman = root_poa->the_POAManager();
293 pman->activate();
294
295#ifdef REFCNT
296 DEBTRACE("_orb refCount: " << ((omniOrbORB*)_orb.in())->pd_refCount);
297#endif
298 obj = _orb->resolve_initial_references("DynAnyFactory");
299 _dynFactory = DynamicAny::DynAnyFactory::_narrow(obj);
300 }
301
302 if (_usePython)
303 {
304 DEBTRACE("RuntimeSALOME::init, is python extension = " << ispyext);
305
306 // Initialize Python interpreter in embedded mode
307 if (!Py_IsInitialized())
308 {
309#if PY_VERSION_HEX < 0x02040000 // python version earlier than 2.4.0
310 Py_Initialize();
311#else
312 Py_InitializeEx(0); // do not install signal handlers
313#endif
314 if (argc > 0 && argv != NULL)
315 {
316 wchar_t **changed_argv = new wchar_t*[argc];
317 for (int i = 0; i < argc; i++)
318 {
319 changed_argv[i] = Py_DecodeLocale(argv[i], NULL);
320 }
321 PySys_SetArgv(argc, changed_argv);
322 }
323 else
324 {
325 int pyArgc = 1;
326 char* pyArgv[1];
327 char defaultName[] = "SALOME_YACS_RUNTIME";
328 wchar_t **changed_pyArgv = new wchar_t*[pyArgc];
329 pyArgv[0] = defaultName;
330 for (int i = 0; i < pyArgc; i++)
331 {
332 changed_pyArgv[i] = Py_DecodeLocale(pyArgv[i], NULL);
333 }
334 PySys_SetArgv(pyArgc, changed_pyArgv);
335 }
336#if PY_VERSION_HEX < 0x03070000
337 PyEval_InitThreads(); /* Create (and acquire) the interpreter lock (for threads)*/
338#endif
339 PyEval_SaveThread(); /* Release the thread state */
340 //here we do not have the Global Interpreter Lock
341 }
342
343 PyObject *mainmod,*pyapi,*res ;
344 PyObject *globals;
345 PyGILState_STATE gstate;
346 gstate = PyGILState_Ensure(); // acquire the Global Interpreter Lock
347
348 mainmod = PyImport_AddModule("__main__");
349 globals = PyModule_GetDict(mainmod);
350 /* globals is a borrowed reference */
351
352 if (PyDict_GetItemString(globals, "__builtins__") == NULL)
353 {
354 PyObject *bimod = PyImport_ImportModule("builtins");
355 if (bimod == NULL || PyDict_SetItemString(globals, "__builtins__", bimod) != 0)
356 Py_FatalError("can't add __builtins__ to __main__");
357 Py_DECREF(bimod);
358 }
359
360 _bltins = PyEval_GetBuiltins(); /* borrowed ref */
361
362 if (_useCorba)
363 {
364
365 //init section
366 _omnipy = PyImport_ImportModule((char*)"_omnipy");
367 if (!_omnipy)
368 {
369 PyErr_Print();
370 PyErr_SetString(PyExc_ImportError, (char*)"Cannot import _omnipy");
371 goto out;
372 }
373 pyapi = PyObject_GetAttrString(_omnipy, (char*)"API");
374 if (!pyapi)
375 {
376 goto out;
377 }
378 _api = (omniORBpyAPI*)PyCapsule_GetPointer(pyapi,"_omnipy.API");
379 Py_DECREF(pyapi);
380
381 res=PyRun_String("\n"
382 "from math import *\n"
383 "import sys\n"
384 "sys.path.insert(0,'.')\n"
385 "from omniORB import CORBA\n"
386 "from omniORB import any\n"
387 "orb = CORBA.ORB_init([], CORBA.ORB_ID)\n"
388 "#print(sys.getrefcount(orb))\n"
389 "try:\n"
390 " import SALOME\n"
391 "except:\n"
392 " pass\n"
393 "\n",
394 Py_file_input,globals,globals );
395 if(res == NULL)
396 {
397 PyErr_Print();
398 goto out;
399 }
400 Py_DECREF(res);
401
402 _pyorb = PyDict_GetItemString(globals,"orb");
403 /* PyDict_GetItemString returns a borrowed reference. There is no need to decref _pyorb */
404
405 PyObject *pyany;
406 pyany = PyDict_GetItemString(globals,"any");
407 /* PyDict_GetItemString returns a borrowed reference. There is no need to decref pyany */
408
409#ifdef REFCNT
410 DEBTRACE("_orb refCount: " << ((omniOrbORB*)_orb.in())->pd_refCount);
411#endif
412 }
413 out:
414 PyGILState_Release(gstate); // Release the Global Interpreter Lock
415 }
416 if (_useCorba)
417 {
418 // initialize the catalogLoaderFactory map with the session one
420 }
421}
static wchar_t * Py_DecodeLocale(const char *arg, size_t *size)
References _api, _bltins, YACS::ENGINE::Runtime::_catalogLoaderFactoryMap, _dynFactory, _omnipy, _orb, _pyorb, _useCorba, _usePython, driver_internal::args, DEBTRACE, yacsorb.CORBAEngineTest::i, IsPyExt, and Py_DecodeLocale().
◆ initBuiltins()
void RuntimeSALOME::initBuiltins ( )
Definition at line 170 of file RuntimeSALOME.cxx.
171{
172 //Fill the builtin catalog with nodes specific to the runtime
173 std::map<std::string,TypeCode*>& typeMap=_builtinCatalog->_typeMap;
174 std::map<std::string,Node*>& nodeMap=_builtinCatalog->_nodeMap;
175 std::map<std::string,ComposedNode*>& composednodeMap=_builtinCatalog->_composednodeMap;
176 std::map<std::string,ComponentDefinition*>& componentMap=_builtinCatalog->_componentMap;
177 nodeMap["PyFunction"]=new PyFuncNode("PyFunction");
178 nodeMap["PyScript"]=new PythonNode("PyScript");
179 nodeMap["CORBANode"]=new CORBANode("CORBANode");
180 nodeMap["XmlNode"]=new XmlNode("XmlNode");
181 nodeMap["SalomeNode"]=new SalomeNode("SalomeNode");
182 nodeMap["CppNode"]=new CppNode("CppNode");
183 nodeMap["SalomePythonNode"]=new SalomePythonNode("SalomePythonNode");
184 nodeMap["PresetNode"]=new PresetNode("PresetNode");
185 nodeMap["OutNode"]=new OutNode("OutNode");
186 nodeMap["StudyInNode"]=new StudyInNode("StudyInNode");
187 nodeMap["StudyOutNode"]=new StudyOutNode("StudyOutNode");
188 composednodeMap["OptimizerLoop"]=createOptimizerLoop("OptimizerLoop","","",true);
189 typeMap["dblevec"]= createSequenceTc("dblevec","dblevec",_tc_double);
190 typeMap["intvec"]= createSequenceTc("intvec","intvec",_tc_int);
191 typeMap["stringvec"]= createSequenceTc("stringvec","stringvec",_tc_string);
192 typeMap["boolvec"]= createSequenceTc("boolvec","boolvec",_tc_bool);
193 typeMap["seqdblevec"]= createSequenceTc("seqdblevec","seqdblevec",typeMap["dblevec"]);
194 typeMap["seqintvec"]= createSequenceTc("seqintvec","seqintvec",typeMap["intvec"]);
195 typeMap["seqstringvec"]= createSequenceTc("seqstringvec","seqstringvec",typeMap["stringvec"]);
196 typeMap["seqboolvec"]= createSequenceTc("seqboolvec","seqboolvec",typeMap["boolvec"]);
197 std::list<TypeCodeObjref *> ltc;
198 typeMap["pyobj"]= createInterfaceTc("python:obj:1.0","pyobj",ltc);
199 typeMap["seqpyobj"]= createSequenceTc("seqpyobj","seqpyobj",typeMap["pyobj"]);
200 composednodeMap["Bloc"]=createBloc("Bloc");
201 composednodeMap["Switch"]=createSwitch("Switch");
202 composednodeMap["WhileLoop"]=createWhileLoop("WhileLoop");
203 composednodeMap["ForLoop"]=createForLoop("ForLoop");
204 composednodeMap["ForEachLoop_double"]=createForEachLoop("ForEachLoop_double",Runtime::_tc_double);
205 composednodeMap["ForEachLoop_string"]=createForEachLoop("ForEachLoop_string",Runtime::_tc_string);
206 composednodeMap["ForEachLoop_int"]=createForEachLoop("ForEachLoop_int",Runtime::_tc_int);
207 composednodeMap["ForEachLoop_bool"]=createForEachLoop("ForEachLoop_bool",Runtime::_tc_bool);
208 composednodeMap["ForEachLoop_pyobj"]=createForEachLoop("ForEachLoop_pyobj",typeMap["pyobj"]);;
209 ENGINE::TypeCodeStruct *t = createStructTc("","Engines/dataref");
210 t->addMember("ref",_tc_string);
211 typeMap["dataref"]= t;
212}
std::map< std::string, ComposedNode * > _composednodeMap
Definition: Catalog.hxx:52
std::map< std::string, ComponentDefinition * > _componentMap
Definition: Catalog.hxx:50
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
virtual WhileLoop * createWhileLoop(const std::string &name)
virtual TypeCodeStruct * createStructTc(const std::string &id, const std::string &name)
virtual TypeCode * createSequenceTc(const std::string &id, const std::string &name, TypeCode *content)
virtual TypeCode * createInterfaceTc(const std::string &id, const std::string &name, std::list< TypeCodeObjref * > ltc)
virtual Bloc * createBloc(const std::string &name)
virtual ForLoop * createForLoop(const std::string &name)
virtual OptimizerLoop * createOptimizerLoop(const std::string &name, const std::string &algLib, const std::string &factoryName, bool algInitOnFile, const std::string &kind="", Proc *procForTypes=NULL)
static YACS::ENGINE::TypeCode * _tc_double
Definition: Runtime.hxx:136
virtual Switch * createSwitch(const std::string &name)
Definition: Runtime.cxx:236
static YACS::ENGINE::TypeCode * _tc_bool
Definition: Runtime.hxx:138
virtual ForEachLoop * createForEachLoop(const std::string &name, TypeCode *type)
Definition: Runtime.cxx:251
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
static YACS::ENGINE::TypeCode * _tc_string
Definition: Runtime.hxx:139
References YACS::ENGINE::Runtime::_builtinCatalog, YACS::ENGINE::Catalog::_componentMap, YACS::ENGINE::Catalog::_composednodeMap, YACS::ENGINE::Catalog::_nodeMap, YACS::ENGINE::Runtime::_tc_bool, YACS::ENGINE::Runtime::_tc_double, YACS::ENGINE::Runtime::_tc_int, YACS::ENGINE::Runtime::_tc_string, YACS::ENGINE::Catalog::_typeMap, createBloc(), YACS::ENGINE::Runtime::createForEachLoop(), createForLoop(), createInterfaceTc(), createOptimizerLoop(), createSequenceTc(), createStructTc(), YACS::ENGINE::Runtime::createSwitch(), createWhileLoop(), and gui.Appli::t.
◆ launchSubProcess()
PyObject * RuntimeSALOME::launchSubProcess ( const std::vector< std::string > &  cmds)
Definition at line 471 of file RuntimeSALOME.cxx.
472{
473 std::ostringstream oss; oss << "from subprocess import Popen" << std::endl;
474 oss << "p = Popen([";
475 for(auto i = 0 ; i < cmds.size() ; ++i)
476 {
477 oss << " " << "\"" << cmds[i] << "\"";
478 if(i < cmds.size()-1)
479 oss << ", ";
480 else
481 oss << " ";
482 }
483 oss << "])";
484 AutoGIL agil;
485 AutoPyRef context = PyDict_New();
486 PyDict_SetItemString( context, "__builtins__", getBuiltins() );
487 std::string errorDetails;
488 try
489 {
490 PythonNode::ExecuteLocalInternal(oss.str().c_str(),context,errorDetails);
491 }
492 catch(const YACS::Exception& e)
493 {
494 std::cerr << e.what() << std::endl << errorDetails << std::endl;
495 throw e;
496 }
497 PyObject *ret = PyDict_GetItemString(context,"p");
498 Py_XINCREF(ret);
499 Py_XINCREF(ret);
500 return ret;
501}
static void ExecuteLocalInternal(const std::string &codeStr, PyObject *context, std::string &errorDetails)
Definition: PythonNode.cxx:733
PyObject * getBuiltins() const
const char * what(void) const noexcept
Definition: Exception.cxx:50
References YACS::ENGINE::PythonNode::ExecuteLocalInternal(), getBuiltins(), yacsorb.CORBAEngineTest::i, and YACS::Exception::what().
◆ loadModulCatalog()
void RuntimeSALOME::loadModulCatalog ( )
Definition at line 256 of file RuntimeSALOME.cxx.
257{
258 AutoGIL agil;
259 const char * SCRIPT = "from salome_kernel import list_of_catalogs_regarding_environement\n"
260"import KernelModuleCatalog\n"
261"KernelModuleCatalog.myModuleCatalog( list_of_catalogs_regarding_environement() )\n";
262 PyRun_SimpleString(SCRIPT);
263}
Referenced by main(), and shutdownServers().
◆ setRuntime()
void RuntimeSALOME::setRuntime ( long  flags = UsePython+UseCorba+UseXml+UseCpp+UseSalome,
int  argc = 0,
char *  argv[] = NULL
Definition at line 144 of file RuntimeSALOME.cxx.
145{
147 {
148 RuntimeSALOME* r=new RuntimeSALOME(flags, argc, argv);
150 r->initBuiltins();
151 }
152 DEBTRACE("RuntimeSALOME::setRuntime() done !");
153}
References YACS::ENGINE::Runtime::_singleton, DEBTRACE, testCppPluginInvokation::r, and RuntimeSALOME().
Referenced by YACS::HMI::GenericGui::GenericGui(), and main().
◆ getSALOMERuntime
RuntimeSALOME * getSALOMERuntime ( )
friend
◆ _api
omniORBpyAPI* YACS::ENGINE::RuntimeSALOME::_api
Definition at line 256 of file RuntimeSALOME.hxx.
Referenced by getApi(), and init().
◆ _bltins
PyObject* YACS::ENGINE::RuntimeSALOME::_bltins
Definition at line 254 of file RuntimeSALOME.hxx.
Referenced by getBuiltins(), and init().
◆ _connectionManager
ConnectionManager YACS::ENGINE::RuntimeSALOME::_connectionManager
Definition at line 262 of file RuntimeSALOME.hxx.
Referenced by ~RuntimeSALOME().
◆ _dynFactory
DynamicAny::DynAnyFactory_var YACS::ENGINE::RuntimeSALOME::_dynFactory
Definition at line 255 of file RuntimeSALOME.hxx.
Referenced by getDynFactory(), and init().
◆ _flags
long YACS::ENGINE::RuntimeSALOME::_flags
Definition at line 258 of file RuntimeSALOME.hxx.
◆ _omnipy
PyObject* YACS::ENGINE::RuntimeSALOME::_omnipy
Definition at line 257 of file RuntimeSALOME.hxx.
Referenced by get_omnipy(), and init().
◆ _orb
CORBA::ORB_var YACS::ENGINE::RuntimeSALOME::_orb
Definition at line 252 of file RuntimeSALOME.hxx.
Referenced by fini(), getFromNS(), getOrb(), and init().
◆ _pyorb
PyObject* YACS::ENGINE::RuntimeSALOME::_pyorb
Definition at line 253 of file RuntimeSALOME.hxx.
Referenced by getPyOrb(), and init().
◆ _useCorba
bool YACS::ENGINE::RuntimeSALOME::_useCorba
Definition at line 259 of file RuntimeSALOME.hxx.
Referenced by fini(), init(), and RuntimeSALOME().
◆ _useCpp
bool YACS::ENGINE::RuntimeSALOME::_useCpp
Referenced by RuntimeSALOME().
◆ _usePython
bool YACS::ENGINE::RuntimeSALOME::_usePython
◆ _useXml
bool YACS::ENGINE::RuntimeSALOME::_useXml
enum { ... } YACS::ENGINE::RuntimeSALOME::FLAGS
