YACS::ENGINE::NeutralInit Class Reference
Class for initialization of a Neutral port with YACS::ENGINE::Any* object. More...
#include <NeutralInitConv.hxx>
Inheritance diagram for YACS::ENGINE::NeutralInit:
Collaboration diagram for YACS::ENGINE::NeutralInit:
 NeutralInit (InputPort *p)
 Initialize Neutral proxy port with received Any object after type check. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 36 of file NeutralInitConv.hxx.
◆ NeutralInit()
NeutralInit::NeutralInit ( InputPort *  p)
Definition at line 34 of file NeutralInitConv.cxx.
35 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
36{
37}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void NeutralInit::put ( const void *  data)
Definition at line 39 of file NeutralInitConv.cxx.
40{
41 DEBTRACE(" NeutralInit::put(const void *data)");
42 put((YACS::ENGINE::Any *)data);
43}
Definition: Any.hxx:79
References DEBTRACE, and put().
Referenced by put().
◆ put() [2/2]
void NeutralInit::put ( YACS::ENGINE::Any *  data)
data: YACS::ENGINE::Any object
Definition at line 50 of file NeutralInitConv.cxx.
51{
52 DEBTRACE("NeutralInit::put " << data);
53 if(!edGetType()->isAdaptable(data->getType()))
54 throw ConversionException("Value type is not compatible with port type");
55 _port->put((const void *)data);
56}
const TypeCode * getType() const
Definition: Any.hxx:85
TypeCode * edGetType() const
Definition: DataPort.hxx:53
int isAdaptable(const TypeCode *t1, const TypeCode *t2)
References YACS::ENGINE::ProxyPort::_port, DEBTRACE, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::Any::getType(), YACS::ENGINE::isAdaptable(), and YACS::ENGINE::InputPort::put().
