YACS::ENGINE::ProxyPort Class Reference
Base class for Proxy Input Ports. More...
#include <InputPort.hxx>
Inheritance diagram for YACS::ENGINE::ProxyPort:
Collaboration diagram for YACS::ENGINE::ProxyPort:
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 99 of file InputPort.hxx.
◆ ProxyPort()
ProxyPort::ProxyPort ( InputPort *  p)
Definition at line 179 of file InputPort.cxx.
179 :InputPort("Convertor", p->getNode(), p->edGetType()),DataPort("Convertor", p->getNode(), p->edGetType()),
180 Port( p->getNode())
181{
182 _port = p;
183}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
References _port, and p.
◆ ~ProxyPort()
ProxyPort::~ProxyPort ( )
Definition at line 185 of file InputPort.cxx.
186{
187 //For the moment, there is no case in YACS we have a proxy port in a proxy port
188 //So don't test that. _port may be already deleted. The test is not sure.
189 /*
190 if(_port->isIntermediate())
191 delete _port;
192 */
193}
◆ clone()
InputPort * ProxyPort::clone ( Node *  newHelder) const
: Should never been called because Node clone process does not duplicate data attributes relative to links. This part is done afterwards on relink process.
Implements YACS::ENGINE::InputPort.
Definition at line 204 of file InputPort.cxx.
205{
206 throw Exception("ProxyPort::clone : internal error - should never happened");
207}
◆ edGetNumberOfLinks()
int ProxyPort::edGetNumberOfLinks ( ) const
Returns number of physical backlinks NOT number of user backlinks.
Reimplemented from YACS::ENGINE::InPort.
Definition at line 224 of file InputPort.cxx.
225{
226 return _port->edGetNumberOfLinks();
227}
virtual int edGetNumberOfLinks() const
Definition: InPort.cxx:45
References _port, and YACS::ENGINE::InPort::edGetNumberOfLinks().
◆ edNotifyDereferencedBy()
void ProxyPort::edNotifyDereferencedBy ( OutPort *  fromPort)
Definition at line 214 of file InputPort.cxx.
215{
216 _port->edNotifyDereferencedBy(fromPort);
217}
virtual void edNotifyDereferencedBy(OutPort *fromPort)
Definition: InPort.cxx:102
References _port, and YACS::ENGINE::InPort::edNotifyDereferencedBy().
◆ edNotifyReferencedBy()
void ProxyPort::edNotifyReferencedBy ( OutPort *  fromPort,
bool  isLoopProof = true
overridevirtual
[in]isLoopProof- Tells if the data coming from fromPort will be send again in case of this is initialized. This value is important if this is an InPort of a Node contained directly or not inside a Loop, ForEachLoop, OptimizerLoop. In this case, to optimize memory consumption (see squeezeMemory method), we need to know if data coming from fromPort will be generated again in case. If true (the default) it means that for that link is a link loop proof so no need to take care. If false, the link is not loop proof so event in the context of agressive memory management the data can't be safely released.
Definition at line 209 of file InputPort.cxx.
210{
211 _port->edNotifyReferencedBy(fromPort,isLoopProof);
212}
virtual void edNotifyReferencedBy(OutPort *fromPort, bool isLoopProof=true)
Definition: InPort.cxx:93
References _port, and YACS::ENGINE::InPort::edNotifyReferencedBy().
◆ edRemoveAllLinksLinkedWithMe()
void ProxyPort::edRemoveAllLinksLinkedWithMe ( )
Definition at line 195 of file InputPort.cxx.
196{
198}
void edRemoveAllLinksLinkedWithMe()
Definition: InPort.cxx:50
References _port, and YACS::ENGINE::InPort::edRemoveAllLinksLinkedWithMe().
◆ edSetOutPort()
std::set< OutPort * > ProxyPort::edSetOutPort ( ) const
Returns physical backlinks NOT user backlinks.
Definition at line 219 of file InputPort.cxx.
220{
221 return _port->edSetOutPort();
222}
virtual std::set< OutPort * > edSetOutPort() const
Definition: InPort.cxx:65
References _port, and YACS::ENGINE::InPort::edSetOutPort().
◆ exRestoreInit()
void ProxyPort::exRestoreInit ( )
Definition at line 229 of file InputPort.cxx.
230{
232}
virtual void exRestoreInit()=0
References _port, and YACS::ENGINE::InputPort::exRestoreInit().
◆ exSaveInit()
void ProxyPort::exSaveInit ( )
Definition at line 234 of file InputPort.cxx.
235{
236 _port->exSaveInit();
237}
virtual void exSaveInit()=0
References _port, and YACS::ENGINE::InputPort::exSaveInit().
◆ get()
void * ProxyPort::get ( ) const
Definition at line 248 of file InputPort.cxx.
249{
250 return _port->get();
251}
virtual void * get() const =0
References _port, and YACS::ENGINE::InputPort::get().
◆ getAllRepresentants()
void ProxyPort::getAllRepresentants ( std::set< InPort * > &  repr) const
Definition at line 263 of file InputPort.cxx.
264{
265 DEBTRACE("ProxyPort::getAllRepresentants");
267}
virtual void getAllRepresentants(std::set< InPort * > &repr) const
Definition: InPort.cxx:110
References _port, DEBTRACE, and YACS::ENGINE::InPort::getAllRepresentants().
◆ getPublicRepresentant()
InputPort * ProxyPort::getPublicRepresentant ( )
returns the final physical port behind 'this'.
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 242 of file InputPort.cxx.
244{
246}
virtual InputPort * getPublicRepresentant()
Definition: InputPort.hxx:57
References YACS::ENGINE::InputPort::getPublicRepresentant().
◆ isIntermediate()
bool YACS::ENGINE::ProxyPort::isIntermediate ( ) const
Definition at line 119 of file InputPort.hxx.
119{ return true; }
◆ put()
void ProxyPort::put ( const void *  data)
Reimplemented in YACS::ENGINE::CorbaCorba, YACS::ENGINE::CorbaCpp, YACS::ENGINE::CorbaNeutral, YACS::ENGINE::CorbaPyDouble, YACS::ENGINE::CorbaPyInt, YACS::ENGINE::CorbaPyString, YACS::ENGINE::CorbaPyBool, YACS::ENGINE::CorbaPyObjref, YACS::ENGINE::CorbaPySequence, YACS::ENGINE::CorbaPyStruct, YACS::ENGINE::CorbaXml, YACS::ENGINE::CppCorba, YACS::ENGINE::CppCpp, YACS::ENGINE::CppNeutral, YACS::ENGINE::CppPy, YACS::ENGINE::CppXml, YACS::ENGINE::NeutralCorbaInt, YACS::ENGINE::NeutralCorbaDouble, YACS::ENGINE::NeutralCorbaBool, YACS::ENGINE::NeutralCorbaSequence, YACS::ENGINE::NeutralCorbaString, YACS::ENGINE::NeutralCorbaObjref, YACS::ENGINE::NeutralCorbaStruct, YACS::ENGINE::NeutralCpp, YACS::ENGINE::NeutralInit, YACS::ENGINE::NeutralPyDouble, YACS::ENGINE::NeutralPyInt, YACS::ENGINE::NeutralPyString, YACS::ENGINE::NeutralPyBool, YACS::ENGINE::NeutralPyObjref, YACS::ENGINE::NeutralPySequence, YACS::ENGINE::NeutralPyStruct, YACS::ENGINE::NeutralXml, YACS::ENGINE::PyCorbaInt, YACS::ENGINE::PyCorbaDouble, YACS::ENGINE::PyCorbaString, YACS::ENGINE::PyCorbaBool, YACS::ENGINE::PyCorbaObjref, YACS::ENGINE::PyCorbaSequence, YACS::ENGINE::PyCorbaStruct, YACS::ENGINE::PyCpp, YACS::ENGINE::PyInit, YACS::ENGINE::PyNeutral, YACS::ENGINE::PyXml, YACS::ENGINE::XmlCorba, YACS::ENGINE::XmlCpp, YACS::ENGINE::XmlNeutral, and YACS::ENGINE::XmlPython.
Definition at line 258 of file InputPort.cxx.
259{
260 _port->put(data);
261}
References _port, and YACS::ENGINE::InputPort::put().
◆ releaseData()
void ProxyPort::releaseData ( )
overridevirtual
Definition at line 253 of file InputPort.cxx.
254{
256}
virtual void releaseData()=0
References _port, and YACS::ENGINE::InputPort::releaseData().
◆ typeName()
virtual std::string YACS::ENGINE::ProxyPort::typeName ( )
Definition at line 123 of file InputPort.hxx.
123{return "YACS__ENGINE__ProxyPort";}
◆ _port
InputPort* YACS::ENGINE::ProxyPort::_port
Definition at line 125 of file InputPort.hxx.
Referenced by edGetNumberOfLinks(), edNotifyDereferencedBy(), edNotifyReferencedBy(), edRemoveAllLinksLinkedWithMe(), edSetOutPort(), exRestoreInit(), exSaveInit(), get(), getAllRepresentants(), ProxyPort(), YACS::ENGINE::CppPy::put(), YACS::ENGINE::CppCorba::put(), YACS::ENGINE::CppCpp::put(), YACS::ENGINE::CppNeutral::put(), YACS::ENGINE::XmlCorba::put(), YACS::ENGINE::XmlCpp::put(), YACS::ENGINE::XmlNeutral::put(), YACS::ENGINE::XmlPython::put(), put(), YACS::ENGINE::CorbaCorba::put(), YACS::ENGINE::CorbaCpp::put(), YACS::ENGINE::CorbaNeutral::put(), YACS::ENGINE::CorbaPyDouble::put(), YACS::ENGINE::CorbaPyInt::put(), YACS::ENGINE::CorbaPyString::put(), YACS::ENGINE::CorbaPyBool::put(), YACS::ENGINE::CorbaPyObjref::put(), YACS::ENGINE::CorbaPySequence::put(), YACS::ENGINE::CorbaPyStruct::put(), YACS::ENGINE::CorbaXml::put(), YACS::ENGINE::PyCorbaInt::put(), YACS::ENGINE::PyCorbaDouble::put(), YACS::ENGINE::PyCorbaString::put(), YACS::ENGINE::PyCorbaBool::put(), YACS::ENGINE::PyCorbaObjref::put(), YACS::ENGINE::PyCorbaSequence::put(), YACS::ENGINE::PyCorbaStruct::put(), YACS::ENGINE::PyCpp::put(), YACS::ENGINE::PyInit::put(), YACS::ENGINE::PyNeutral::put(), YACS::ENGINE::PyXml::put(), YACS::ENGINE::CppXml::put(), YACS::ENGINE::NeutralCorbaInt::put(), YACS::ENGINE::NeutralCorbaDouble::put(), YACS::ENGINE::NeutralCorbaBool::put(), YACS::ENGINE::NeutralCorbaSequence::put(), YACS::ENGINE::NeutralCorbaString::put(), YACS::ENGINE::NeutralCorbaObjref::put(), YACS::ENGINE::NeutralCorbaStruct::put(), YACS::ENGINE::NeutralCpp::put(), YACS::ENGINE::NeutralInit::put(), YACS::ENGINE::NeutralPyDouble::put(), YACS::ENGINE::NeutralPyInt::put(), YACS::ENGINE::NeutralPyString::put(), YACS::ENGINE::NeutralPyBool::put(), YACS::ENGINE::NeutralPyObjref::put(), YACS::ENGINE::NeutralPySequence::put(), YACS::ENGINE::NeutralPyStruct::put(), YACS::ENGINE::NeutralXml::put(), and releaseData().
