YACS::ENGINE::CorbaPySequence Class Reference
Class for conversion from CORBA Output port to Python Input port. More...
#include <CORBAPythonConv.hxx>
Inheritance diagram for YACS::ENGINE::CorbaPySequence:
Collaboration diagram for YACS::ENGINE::CorbaPySequence:
 CorbaPySequence (InputPyPort *p)
 Class to convert a CORBA::Any sequence to a PyObject Sequence. More...
void put (CORBA::Any *data)
 Convert a CORBA::Any sequence to PyObject Sequence. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
DynamicAny::DynAnyFactory_ptr _dynfactory
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 105 of file CORBAPythonConv.hxx.
◆ CorbaPySequence()
CorbaPySequence::CorbaPySequence ( InputPyPort *  p)
p: input Python port to adapt to Corba output port
Definition at line 150 of file CORBAPythonConv.cxx.
151 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
152{
154}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
DynamicAny::DynAnyFactory_ptr getDynFactory() const
Proc * p
Definition: driver.cxx:216
References _dynfactory, YACS::ENGINE::RuntimeSALOME::getDynFactory(), and YACS::ENGINE::getSALOMERuntime().
◆ put() [1/2]
void CorbaPySequence::put ( const void *  data)
Definition at line 156 of file CORBAPythonConv.cxx.
157{
158 put((CORBA::Any *)data);
159}
References put().
Referenced by put().
◆ put() [2/2]
void CorbaPySequence::put ( CORBA::Any *  data)
data: CORBA::Any object
Definition at line 165 of file CORBAPythonConv.cxx.
166{
168 PyObject* ob=convertCorbaPyObject(edGetType(),data);
169 DEBTRACE("ob refcnt: " << ob->ob_refcnt );
170 _port->put(ob);
171 Py_DECREF(ob);
172}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
PyObject * convertCorbaPyObject(const TypeCode *t, CORBA::Any *data)
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertCorbaPyObject(), DEBTRACE, YACS::ENGINE::DataPort::edGetType(), and YACS::ENGINE::InputPort::put().
◆ _dynfactory
DynamicAny::DynAnyFactory_ptr YACS::ENGINE::CorbaPySequence::_dynfactory
Definition at line 112 of file CORBAPythonConv.hxx.
Referenced by CorbaPySequence().
