YACS::ENGINE::PyNeutral Class Reference
#include <PythonNeutralConv.hxx>
Inheritance diagram for YACS::ENGINE::PyNeutral:
Collaboration diagram for YACS::ENGINE::PyNeutral:
 PyNeutral (InputPort *p)
void put (PyObject *data)
 Convert received Python (PyObject *) value to Neutral (Any *) value and send it to proxy port. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 32 of file PythonNeutralConv.hxx.
◆ PyNeutral()
PyNeutral::PyNeutral ( InputPort *  p)
Definition at line 34 of file PythonNeutralConv.cxx.
35 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
36{
37}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void PyNeutral::put ( const void *  data)
Definition at line 39 of file PythonNeutralConv.cxx.
40{
41 DEBTRACE( " PyNeutral::put(const void *data)" );
42 put((PyObject *)data);
43}
References DEBTRACE, and put().
Referenced by put().
◆ put() [2/2]
void PyNeutral::put ( PyObject *  data)
data: Python value
Definition at line 50 of file PythonNeutralConv.cxx.
51{
52 DEBTRACE( "PyNeutral::put " );
54 //Do not need to take the Python GIL as put is called from Python node
57 DEBTRACE( "before put refcnt: " << ob->getRefCnt() );
58 _port->put(ob);
59 //_port has called incRef
60 ob->decrRef();
61 DEBTRACE( "after put refcnt: " << ob->getRefCnt() );
62}
Definition: Any.hxx:79
TypeCode * edGetType() const
Definition: DataPort.hxx:53
unsigned int getRefCnt() const
Definition: RefCounter.hxx:32
YACS::ENGINE::Any * convertPyObjectNeutral(const TypeCode *t, PyObject *data)
References YACS::ENGINE::ProxyPort::_port, YACS::ENGINE::convertPyObjectNeutral(), DEBTRACE, YACS::ENGINE::RefCounter::decrRef(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::RefCounter::getRefCnt(), and YACS::ENGINE::InputPort::put().
