YACS::ENGINE::XmlCorba Class Reference
#include <XMLCORBAConv.hxx>
Inheritance diagram for YACS::ENGINE::XmlCorba:
Collaboration diagram for YACS::ENGINE::XmlCorba:
 XmlCorba (InputCorbaPort *p)
void put (const char *data)
 Convert a XML (char *) to CORBA::Any and push it in the proxy port. More...
 ProxyPort (InputPort *p)
 ~ProxyPort ()
void * get () const
void releaseData () override
bool isIntermediate () const
void exRestoreInit ()
void exSaveInit ()
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
InputPort * _port
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 33 of file XMLCORBAConv.hxx.
◆ XmlCorba()
XmlCorba::XmlCorba ( InputCorbaPort *  p)
Definition at line 36 of file XMLCORBAConv.cxx.
37 : ProxyPort(p), DataPort(p->getName(), p->getNode(), p->edGetType()), Port(p->getNode())
38{
39}
std::string getName() const
Definition: DataPort.cxx:41
friend class ProxyPort
Definition: InPort.hxx:50
Port(Node *node)
Definition: Port.cxx:34
Proc * p
Definition: driver.cxx:216
◆ put() [1/2]
void XmlCorba::put ( const char *  data)
data: Xml::char *
Definition at line 51 of file XMLCORBAConv.cxx.
52{
53 DEBTRACE(data);
54 xmlDocPtr doc;
55 xmlNodePtr cur;
56 CORBA::Any *a=NULL;
57
58 doc = xmlParseMemory(data, strlen(data));
59 if (doc == NULL )
60 {
61 stringstream msg;
62 msg << "Problem in conversion: XML Document not parsed successfully ";
63 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
64 throw ConversionException(msg.str());
65 }
66 cur = xmlDocGetRootElement(doc);
67 if (cur == NULL)
68 {
69 xmlFreeDoc(doc);
70 stringstream msg;
71 msg << "Problem in conversion: empty XML Document";
72 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
73 throw ConversionException(msg.str());
74 }
75 while (cur != NULL)
76 {
77 if ((!xmlStrcmp(cur->name, (const xmlChar *)"value")))
78 {
79 try
80 {
82 }
84 {
85 throw;
86 }
87 catch(...)
88 {
89 stringstream msg;
90 msg << "Problem in conversion: kind= " << edGetType()->kind() ;
91 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
92 throw ConversionException(msg.str());
93 }
94 break;
95 }
96 cur = cur->next;
97 }
98 xmlFreeDoc(doc);
99 if(a==NULL)
100 {
101 stringstream msg;
102 msg << "Problem in conversion: incorrect XML value";
103 msg << " (" << __FILE__ << ":" << __LINE__ << ")";
104 throw ConversionException(msg.str());
105 }
106
107 //xmlCleanupParser();
108 _port->put(a);
109 _port->setStringRef(data);
110 //delete Any that has been allocated by convertXmlCorba
111 delete a;
112}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
virtual void setStringRef(std::string strRef)
Definition: InputPort.cxx:169
DynType kind() const
Definition: TypeCode.cxx:47
static char doc[]
Definition: driver.cxx:63
CORBA::Any * convertXmlCorba(const TypeCode *t, xmlDocPtr doc, xmlNodePtr cur)
References YACS::ENGINE::ProxyPort::_port, gui.CONNECTOR::a, YACS::ENGINE::convertXmlCorba(), DEBTRACE, doc, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::TypeCode::kind(), YACS::ENGINE::InputPort::put(), and YACS::ENGINE::InputPort::setStringRef().
◆ put() [2/2]
void XmlCorba::put ( const void *  data)
Definition at line 41 of file XMLCORBAConv.cxx.
42{
43 DEBTRACE((const char *)data);
44 put((const char *)data);
45}
References DEBTRACE, and put().
Referenced by put().
